U4N: How to Improve Throttle Control in FH6
1,357 次查看
BladePulse9
If you’ve been tearing up the neon-lit neon streets of Tokyo and the mountain passes of Mt. Fuji in Forza Horizon 6, you’ve probably noticed that the driving physics feel a bit more grounded than past entries. Power delivery is aggressive.
If you are treating the right trigger or accelerator pedal like an on/off switch, you aren't driving—you are just converting rubber into smoke. Getting your cars around corners cleanly requires actual nuance. Here is a practical, data-driven breakdown on how to master throttle control in FH6, stop spinning your wheels, and shave seconds off your lap times.
1. Fix Your Deadzones First (The 0-100 Rule)
Out of the box, FH6 sets your controller trigger deadzones to a default 15 inside and 90 outside. This means the first 15% of your trigger pull does absolutely nothing, and once you hit 90%, the game registers 100% full throttle. In short, you are fighting with only 75% of the trigger's physical travel to modulate your power.
Go into Settings > Advanced Controls and apply these changes immediately:
  • Acceleration Axis Deadzone Inside: Lower this from 15 down to 0 or 2.
  • Acceleration Axis Deadzone Outside: Raise this from 90 up to 98 or 100.
Why the math matters: By dropping the inside deadzone to 0 and raising the outside to 100, you expand your input window from 75% to a full 100% of the trigger's mechanical range. If you are piloting a rear-wheel-drive monster out of a tight corner, having that extra physical space to breathe means you can hold a steady 45% throttle without accidentally spiking into spin territory.
2. Corner Exit Analysis: The 50-70-100 Progression
Let’s look at a concrete racing scenario. Say you are driving an S1-Class 2024 Ford Mustang Dark Horse around a 90-degree street corner.
If you smash the throttle to 100% the moment you hit the apex, your rear wheels will immediately break traction, the telemetry will show a 100% loss of friction, and your rear end will snap out, costing you roughly 1.5 to 2 seconds as the car bogs down or spins.
Instead, use a staged linear application:
Corner PhaseTarget Throttle InputCar Behavior
Apex (Clipping Point)30% — 50%Stabilizes the chassis; transfers weight smoothly to the rear tires without breaking traction.
Mid-Exit (Unwinding Wheel)60% — 75%Matches the straightening of the front wheels. More grip becomes available as steering lock decreases.
Straightaway100%Full power once the wheels are completely straight and the car is stabilized.
By stepping your throttle application through this 50-70-100 progression over the span of just 1.5 seconds, you keep the slip angle minimal and maximize forward bite.
3. Manage Launch Control and Wheelspin
Launching a car off the line in FH6 is a major test of your right index finger. If you are using manual transmission, holding the brake and accelerator simultaneously engages the in-game Launch Control. However, once you release the brake, you still have to actively manage the revs.
If your garage is loaded with top-tier builds, managing this manually becomes much easier. For players looking to quickly expand their collection with high-tier cars that can handle heavy power, checking third-party marketplaces like U4N can offer shortcuts, where items like a FH6 wheel spin for sale allow you to instantly bank credits and rare Horizon Edition vehicles to practice on.
Once you are on the grid, remember that wheelspin equals wasted energy. If you let a high-horsepower car bounce off the rev limiter at 8,000 RPM while stationary, your actual forward acceleration drops by up to 40% due to static friction loss. The sweet spot is to hold the throttle right around the car's peak torque curve—usually between 4,500 and 5,500 RPM for sports cars—and slowly roll into 100% throttle as the tires bite.
4. Visualizing Your Power via Telemetry
If you want to know exactly how much throttle you are giving, don't guess. Go into your control bindings and map the Telemetry function to a button (like down on the D-pad).
Switch to the friction and input page while free-roaming. Watch the throttle bar. If you find that your input jumps instantly from 10% to 100%, check your controller hardware. For instance, if you use an Xbox Elite controller, ensure your physical hair-trigger switches on the back are completely turned off. Hair-trigger locks turn an analog trigger into a digital button, making actual throttle modulation physically impossible.
Slowing down your inputs feels unnatural in an arcade-leaning racer, but FH6 rewards precise driving. Smoothly rolling on the gas will always beat smashing the trigger.
0 回复数
%3CLINGO-SUB%20id%3D%22lingo-sub-2372774%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EU4N%3A%20%E5%A6%82%E4%BD%95%E5%9C%A8%20FH6%20%E4%B8%AD%E6%94%B9%E8%BF%9B%E6%B2%B9%E9%97%A8%E6%8E%A7%E5%88%B6%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2372774%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E5%9C%A8%E4%B8%9C%E4%BA%AC%E9%9C%93%E8%99%B9%E7%81%AF%E9%97%AA%E7%83%81%E7%9A%84%E8%A1%97%E9%81%93%E5%92%8C%E5%AF%8C%E5%A3%AB%E5%B1%B1%E7%9A%84%E5%B1%B1%E8%B7%AF%E4%B8%8A%E8%82%86%E6%84%8F%E9%A9%B0%E9%AA%8B%EF%BC%8C%E9%82%A3%E4%B9%88%E6%82%A8%E4%B8%80%E5%AE%9A%E4%BC%9A%E5%8F%91%E7%8E%B0%E8%87%AA%E5%B7%B1%E5%B7%B2%E7%BB%8F%E5%9C%A8%E4%B8%9C%E4%BA%AC%E7%9A%84%E5%A4%A7%E8%A1%97%E5%B0%8F%E5%B7%B7%E5%92%8C%E5%AF%8C%E5%A3%AB%E5%B1%B1%E7%9A%84%E5%B1%B1%E8%B7%AF%E4%B8%8A%E8%82%86%E6%84%8F%E9%A9%B0%E9%AA%8B%E4%BA%86%E3%80%82%E5%9C%A8%E3%80%8A%E6%9E%81%E9%99%90%E7%AB%9E%E9%80%9F%E5%9C%B0%E5%B9%B3%E7%BA%BF%206%E3%80%8B%E4%B8%AD%E9%A9%BE%E9%A9%B6%E5%AF%8C%E5%A3%AB%E5%B1%B1%E6%97%B6%EF%BC%8C%E6%82%A8%E5%8F%AF%E8%83%BD%E4%BC%9A%E6%B3%A8%E6%84%8F%E5%88%B0%E9%A9%BE%E9%A9%B6%E7%89%A9%E7%90%86%E6%95%88%E6%9E%9C%E6%AF%94%E4%BB%A5%E5%BE%80%E7%9A%84%E4%BD%9C%E5%93%81%E6%9B%B4%E6%8E%A5%E5%9C%B0%E6%B0%94%E3%80%82%E5%8A%A8%E5%8A%9B%E8%BE%93%E5%87%BA%E5%BC%BA%E5%8A%B2%E6%9C%89%E5%8A%9B%E3%80%82%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E4%BD%A0%E6%8A%8A%E6%AD%A3%E7%A1%AE%E7%9A%84%E6%89%B3%E6%9C%BA%E6%88%96%E6%B2%B9%E9%97%A8%E8%B8%8F%E6%9D%BF%E5%BD%93%E4%BD%9C%E5%BC%80%2F%E5%85%B3%E5%BC%80%E5%85%B3%EF%BC%8C%E9%82%A3%E4%B9%88%E4%BD%A0%E4%B8%8D%E6%98%AF%E5%9C%A8%E5%BC%80%E8%BD%A6%EF%BC%8C%E4%BD%A0%E5%8F%AA%E6%98%AF%E5%9C%A8%E6%8A%8A%E6%A9%A1%E8%83%B6%E5%8F%98%E6%88%90%E7%83%9F%E9%9B%BE%E3%80%82%E8%A6%81%E8%AE%A9%E6%B1%BD%E8%BD%A6%E5%B9%B2%E5%87%80%E5%88%A9%E8%90%BD%E5%9C%B0%E8%BD%AC%E5%BC%AF%EF%BC%8C%E9%9C%80%E8%A6%81%E7%9C%9F%E6%AD%A3%E7%9A%84%E7%BB%86%E5%BE%AE%E5%B7%AE%E5%88%AB%E3%80%82%E4%BB%A5%E4%B8%8B%E6%98%AF%E5%A6%82%E4%BD%95%E5%9C%A8%20FH6%20%E4%B8%AD%E6%8E%8C%E6%8F%A1%E6%B2%B9%E9%97%A8%E6%8E%A7%E5%88%B6%E3%80%81%E5%81%9C%E6%AD%A2%E6%89%93%E6%BB%91%E5%B9%B6%E7%BC%A9%E7%9F%AD%E5%8D%95%E5%9C%88%E6%97%B6%E9%97%B4%E7%9A%84%E5%AE%9E%E7%94%A8%E6%95%B0%E6%8D%AE%E5%88%86%E6%9E%90%E3%80%82%3C%2FP%3E%3CH2%20id%3D%22toc-hId--465173224%22%20id%3D%22toc-hId--465143402%22%3E1.%E9%A6%96%E5%85%88%E4%BF%AE%E5%A4%8D%E6%AD%BB%E5%8C%BA%EF%BC%880-100%20%E8%A7%84%E5%88%99%EF%BC%89%3C%2FH2%3E%3CP%3EFH6%20%E5%BC%80%E7%AE%B1%E5%8D%B3%E7%94%A8%EF%BC%8C%E5%B0%86%E6%82%A8%E7%9A%84%E6%8E%A7%E5%88%B6%E5%99%A8%E8%A7%A6%E5%8F%91%E6%AD%BB%E5%8C%BA%E8%AE%BE%E7%BD%AE%E4%B8%BA%E9%BB%98%E8%AE%A4%2015%20%E4%B8%AA%E5%86%85%E9%83%A8%E3%80%8190%20%E4%B8%AA%E5%A4%96%E9%83%A8%E3%80%82%E8%BF%99%E6%84%8F%E5%91%B3%E7%9D%80%E4%BD%A0%E7%9A%84%E5%89%8D15%EF%BC%85%E6%89%A3%E5%8A%A8%E6%89%B3%E6%9C%BA%E7%BB%9D%E5%AF%B9%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%EF%BC%8C%E4%B8%80%E6%97%A6%E4%BD%A0%E8%BE%BE%E5%88%B090%EF%BC%85%EF%BC%8C%E6%B8%B8%E6%88%8F%E7%9A%84%E6%B2%B9%E9%97%A8%E5%B0%86%E8%BE%BE%E5%88%B0100%EF%BC%85%E3%80%82%E7%AE%80%E8%80%8C%E8%A8%80%E4%B9%8B%EF%BC%8C%E4%BD%A0%E5%9C%A8%E6%88%98%E6%96%97%E4%B8%AD%E4%BB%85%E4%BD%BF%E7%94%A8%E8%A7%A6%E5%8F%91%E5%99%A8%E7%89%A9%E7%90%86%E8%A1%8C%E7%A8%8B%E7%9A%8475%EF%BC%85%E6%9D%A5%E8%B0%83%E8%8A%82%E4%BD%A0%E7%9A%84%E5%8A%9B%E9%87%8F%E3%80%82%3C%2FP%3E%3CP%3E%E8%BF%9B%E5%85%A5%E8%AE%BE%E7%BD%AE%26gt%3B%20%E9%AB%98%E7%BA%A7%E6%8E%A7%E5%88%B6%EF%BC%8C%E7%AB%8B%E5%8D%B3%E5%BA%94%E7%94%A8%E8%BF%99%E4%BA%9B%E6%9B%B4%E6%94%B9%EF%BC%9A%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3E%E5%8A%A0%E9%80%9F%E8%BD%B4%E5%86%85%E6%AD%BB%E5%8C%BA%EF%BC%9A%E5%B0%86%E6%AD%A4%E5%80%BC%E4%BB%8E%2015%20%E9%99%8D%E8%87%B3%200%20%E6%88%96%202%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E5%8A%A0%E9%80%9F%E8%BD%B4%E5%A4%96%E9%83%A8%E6%AD%BB%E5%8C%BA%EF%BC%9A%E5%B0%86%E5%85%B6%E4%BB%8E%2090%20%E6%8F%90%E5%8D%87%E8%87%B3%2098%20%E6%88%96%20100%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E4%B8%BA%E4%BB%80%E4%B9%88%E6%95%B0%E5%AD%A6%E5%BE%88%E9%87%8D%E8%A6%81%EF%BC%9A%E9%80%9A%E8%BF%87%E5%B0%86%E5%86%85%E9%83%A8%E6%AD%BB%E5%8C%BA%E9%99%8D%E4%BD%8E%E5%88%B00%E5%B9%B6%E5%B0%86%E5%A4%96%E9%83%A8%E6%AD%BB%E5%8C%BA%E6%8F%90%E9%AB%98%E5%88%B0100%EF%BC%8C%E5%8F%AF%E4%BB%A5%E5%B0%86%E8%BE%93%E5%85%A5%E7%AA%97%E5%8F%A3%E4%BB%8E%E8%A7%A6%E5%8F%91%E5%99%A8%E6%9C%BA%E6%A2%B0%E8%8C%83%E5%9B%B4%E7%9A%8475%EF%BC%85%E6%89%A9%E5%A4%A7%E5%88%B0%E6%95%B4%E6%95%B4100%EF%BC%85%E3%80%82%E5%A6%82%E6%9E%9C%E4%BD%A0%E9%A9%BE%E9%A9%B6%E4%B8%80%E8%BE%86%E5%90%8E%E8%BD%AE%E9%A9%B1%E5%8A%A8%E7%9A%84%E6%80%AA%E5%85%BD%E9%A9%B6%E5%87%BA%E4%B8%80%E4%B8%AA%E7%8B%AD%E7%AA%84%E7%9A%84%E5%BC%AF%E9%81%93%EF%BC%8C%E6%9C%89%E9%A2%9D%E5%A4%96%E7%9A%84%E7%89%A9%E7%90%86%E7%A9%BA%E9%97%B4%E5%8F%AF%E4%BB%A5%E5%91%BC%E5%90%B8%EF%BC%8C%E8%BF%99%E6%84%8F%E5%91%B3%E7%9D%80%E4%BD%A0%E5%8F%AF%E4%BB%A5%E4%BF%9D%E6%8C%81%E7%A8%B3%E5%AE%9A%E7%9A%84%2045%25%20%E6%B2%B9%E9%97%A8%EF%BC%8C%E8%80%8C%E4%B8%8D%E4%BC%9A%E6%84%8F%E5%A4%96%E9%99%B7%E5%85%A5%E6%89%93%E6%BB%91%E7%9A%84%E5%A2%83%E5%9C%B0%E3%80%82%3C%2FP%3E%3CH2%20id%3D%22toc-hId-2022339609%22%20id%3D%22toc-hId-2022369431%22%3E2.%E8%A7%92%E5%87%BA%E5%8F%A3%E5%88%86%E6%9E%90%EF%BC%9A50-70-100%20%E7%BA%A7%E8%BF%9B%E9%98%B6%3C%2FH2%3E%3CP%3E%E8%AE%A9%E6%88%91%E4%BB%AC%E6%9D%A5%E7%9C%8B%E4%B8%80%E4%B8%AA%E5%85%B7%E4%BD%93%E7%9A%84%E6%AF%94%E8%B5%9B%E5%9C%BA%E6%99%AF%E3%80%82%E5%81%87%E8%AE%BE%E4%BD%A0%E6%AD%A3%E9%A9%BE%E9%A9%B6%E7%9D%80%E4%B8%80%E8%BE%86%20S1%20%E7%BA%A7%202024%20%E5%B9%B4%E6%AC%BE%E7%A6%8F%E7%89%B9%E9%87%8E%E9%A9%AC%E9%BB%91%E9%A9%AC%E5%9C%A8%2090%20%E5%BA%A6%E8%A1%97%E8%A7%92%E8%BD%AC%E5%BC%AF%E3%80%82%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E4%BD%A0%E5%9C%A8%E5%88%B0%E8%BE%BE%E9%A1%B6%E7%82%B9%E7%9A%84%E7%9E%AC%E9%97%B4%E5%B0%86%E6%B2%B9%E9%97%A8%E8%B8%A9%E5%88%B0%20100%25%20%EF%BC%8C%E4%BD%A0%E7%9A%84%E5%90%8E%E8%BD%AE%E4%BC%9A%E7%AB%8B%E5%8D%B3%E5%A4%B1%E5%8E%BB%E7%89%B5%E5%BC%95%E5%8A%9B%EF%BC%8C%E9%81%A5%E6%B5%8B%E6%95%B0%E6%8D%AE%E4%BC%9A%E6%98%BE%E7%A4%BA%20100%25%20%E7%9A%84%E6%91%A9%E6%93%A6%E5%8A%9B%E6%8D%9F%E5%A4%B1%EF%BC%8C%E4%BD%A0%E7%9A%84%E8%BD%A6%E5%B0%BE%E4%BC%9A%E7%8C%9B%E5%9C%B0%E7%94%A9%E5%87%BA%E5%8E%BB%EF%BC%8C%E5%BD%93%E6%B1%BD%E8%BD%A6%E9%99%B7%E5%85%A5%E5%9B%B0%E5%A2%83%E6%88%96%E6%89%93%E6%BB%91%E6%97%B6%EF%BC%8C%E4%BD%A0%E4%BC%9A%E6%8D%9F%E5%A4%B1%E5%A4%A7%E7%BA%A6%201.5%20%E5%88%B0%202%20%E7%A7%92%E9%92%9F%E3%80%82%3C%2FP%3E%3CP%3E%E5%8F%96%E8%80%8C%E4%BB%A3%E4%B9%8B%E7%9A%84%E6%98%AF%E5%88%86%E9%98%B6%E6%AE%B5%E7%BA%BF%E6%80%A7%E5%BA%94%E7%94%A8%EF%BC%9A%3C%2FP%3E%3CTABLE%3E%3CTBODY%3E%3CTR%3E%3CTD%3E%E8%BD%AC%E8%A7%92%E9%98%B6%E6%AE%B5%3C%2FTD%3E%3CTD%3E%E7%9B%AE%E6%A0%87%E8%8A%82%E6%B0%94%E9%97%A8%E8%BE%93%E5%85%A5%3C%2FTD%3E%3CTD%3E%E6%B1%BD%E8%BD%A6%E8%A1%8C%E4%B8%BA%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%3CSPAN%3E%E9%A1%B6%E7%82%B9%EF%BC%88%E5%89%AA%E5%88%87%E7%82%B9%EF%BC%89%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%3E%3CSPAN%3E30%25%20-%2050%25%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%3E%3CSPAN%3E%E7%A8%B3%E5%AE%9A%E5%BA%95%E7%9B%98%EF%BC%9B%E5%9C%A8%E4%B8%8D%E7%A0%B4%E5%9D%8F%E7%89%B5%E5%BC%95%E5%8A%9B%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8C%E5%B0%86%E9%87%8D%E9%87%8F%E5%B9%B3%E7%A8%B3%E5%9C%B0%E8%BD%AC%E7%A7%BB%E5%88%B0%E5%90%8E%E8%BD%AE%E8%83%8E%E4%B8%8A%E3%80%82%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%3CSPAN%3E%E4%B8%AD%E9%80%94%E5%87%BA%E5%8F%A3%EF%BC%88%E5%BC%80%E5%8D%B7%E8%BD%AE%EF%BC%89%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%3E%3CSPAN%3E60%25%20-%2075%25%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%3E%3CSPAN%3E%E4%B8%8E%E5%89%8D%E8%BD%AE%E6%A0%A1%E7%9B%B4%E7%9B%B8%E5%8C%B9%E9%85%8D%E3%80%82%E9%9A%8F%E7%9D%80%E8%BD%AC%E5%90%91%E9%94%81%E7%9A%84%E5%87%8F%E5%B0%91%EF%BC%8C%E6%8A%93%E5%9C%B0%E5%8A%9B%E4%B9%9F%E4%BC%9A%E5%A2%9E%E5%8A%A0%E3%80%82%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%3CSPAN%3E%E7%9B%B4%E8%BE%BE%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%3E%3CSPAN%3E100%25%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%3E%3CSPAN%3E%E4%B8%80%E6%97%A6%E8%BD%A6%E8%BD%AE%E5%AE%8C%E5%85%A8%E6%89%93%E7%9B%B4%EF%BC%8C%E6%B1%BD%E8%BD%A6%E7%A8%B3%E5%AE%9A%E4%B8%8B%E6%9D%A5%EF%BC%8C%E5%B0%B1%E4%BC%9A%E5%85%A8%E5%8A%9B%E4%BB%A5%E8%B5%B4%E3%80%82%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%E5%9C%A8%E7%9F%AD%E7%9F%AD%201.5%20%E7%A7%92%E7%9A%84%E6%97%B6%E9%97%B4%E5%86%85%EF%BC%8C%E5%B0%86%E6%B2%B9%E9%97%A8%E6%8E%A7%E5%88%B6%E5%9C%A8%2050-70-100%20%E7%BA%A7%E4%B9%8B%E9%97%B4%EF%BC%8C%E5%B0%B1%E8%83%BD%E5%B0%86%E6%BB%91%E7%A7%BB%E8%A7%92%E4%BF%9D%E6%8C%81%E5%9C%A8%E6%9C%80%E5%B0%8F%E8%8C%83%E5%9B%B4%E5%86%85%EF%BC%8C%E5%B9%B6%E6%9C%80%E5%A4%A7%E9%99%90%E5%BA%A6%E5%9C%B0%E6%8F%90%E9%AB%98%E5%89%8D%E8%A1%8C%E5%92%AC%E5%90%88%E5%8A%9B%E3%80%82%3C%2FP%3E%3CH2%20id%3D%22toc-hId-214885146%22%20id%3D%22toc-hId-214914968%22%3E3.%E7%AE%A1%E7%90%86%E5%90%AF%E5%8A%A8%E6%8E%A7%E5%88%B6%E5%92%8C%20Wheelspin%3C%2FH2%3E%3CP%3E%E5%9C%A8%20FH6%20%E4%B8%AD%E5%B0%86%E6%B1%BD%E8%BD%A6%E5%86%B2%E5%87%BA%E5%BA%95%E7%BA%BF%E6%98%AF%E5%AF%B9%E5%8F%B3%E6%89%8B%E9%A3%9F%E6%8C%87%E7%9A%84%E4%B8%80%E5%A4%A7%E8%80%83%E9%AA%8C%E3%80%82%E5%A6%82%E6%9E%9C%E4%BD%A0%E4%BD%BF%E7%94%A8%E6%89%8B%E5%8A%A8%E5%8F%98%E9%80%9F%E7%AE%B1%EF%BC%8C%E6%8C%89%E4%BD%8F%E5%88%B9%E8%BD%A6%E5%92%8C%E6%B2%B9%E9%97%A8%E4%BC%9A%E5%90%8C%E6%97%B6%E5%90%AF%E5%8A%A8%E6%B8%B8%E6%88%8F%E4%B8%AD%E7%9A%84%E5%90%AF%E5%8A%A8%E6%8E%A7%E5%88%B6%E3%80%82%E4%BD%86%E6%98%AF%EF%BC%8C%E4%B8%80%E6%97%A6%E4%BD%A0%E6%9D%BE%E5%BC%80%E5%88%B9%E8%BD%A6%EF%BC%8C%E4%BD%A0%E4%BB%8D%E7%84%B6%E5%BF%85%E9%A1%BB%E7%A7%AF%E6%9E%81%E7%AE%A1%E7%90%86%E8%BD%AC%E9%80%9F%E3%80%82%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E4%BD%A0%E7%9A%84%E8%BD%A6%E5%BA%93%E9%87%8C%E8%A3%85%E6%BB%A1%E4%BA%86%E9%A1%B6%E7%BA%A7%E7%89%88%E6%9C%AC%EF%BC%8C%E9%82%A3%E4%B9%88%E6%89%8B%E5%8A%A8%E7%AE%A1%E7%90%86%E4%BC%9A%E5%8F%98%E5%BE%97%E5%AE%B9%E6%98%93%E5%BE%97%E5%A4%9A%E3%80%82%E5%A6%82%E6%9E%9C%E7%8E%A9%E5%AE%B6%E5%B8%8C%E6%9C%9B%E5%BF%AB%E9%80%9F%E6%89%A9%E5%85%85%E8%87%AA%E5%B7%B1%E7%9A%84%E6%94%B6%E8%97%8F%EF%BC%8C%E8%8E%B7%E5%BE%97%E8%83%BD%E9%A9%BE%E9%A9%AD%E9%87%8D%E5%9E%8B%E5%8A%A8%E5%8A%9B%E7%9A%84%E9%AB%98%E7%BA%A7%E8%BD%A6%E8%BE%86%EF%BC%8C%E6%9F%A5%E7%9C%8B%20U4N%20%E7%AD%89%E7%AC%AC%E4%B8%89%E6%96%B9%E5%B8%82%E5%9C%BA%E5%8F%AF%E4%BB%A5%E6%8F%90%E4%BE%9B%E6%8D%B7%E5%BE%84%EF%BC%8C%E5%85%B6%E4%B8%AD%3CA%20href%3D%22https%3A%2F%2Fwww.u4n.com%2Fforza-horizon-6%2Fboosting%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%E5%87%BA%E5%94%AE%E7%9A%84%20FH6%20%E8%BD%A6%E8%BD%AE%E6%97%8B%E8%BD%AC%3C%2FA%3E%E7%AD%89%E7%89%A9%E5%93%81%E5%8F%AF%E8%AE%A9%E6%82%A8%E7%AB%8B%E5%8D%B3%E5%AD%98%E5%85%A5%E4%BF%A1%E7%94%A8%E7%82%B9%E5%92%8C%E7%A8%80%E6%9C%89%E7%9A%84%E5%9C%B0%E5%B9%B3%E7%BA%BF%E7%89%88%E8%BD%A6%E8%BE%86%E6%9D%A5%E8%BF%9B%E8%A1%8C%E7%BB%83%E4%B9%A0%E3%80%82%3C%2FP%3E%3CP%3E%E4%B8%80%E6%97%A6%E8%BF%9B%E5%85%A5%E7%94%B5%E7%BD%91%EF%BC%8C%E8%AF%B7%E8%AE%B0%E4%BD%8F%E8%BD%A6%E8%BD%AE%E6%89%93%E6%BB%91%E7%AD%89%E4%BA%8E%E6%B5%AA%E8%B4%B9%E8%83%BD%E9%87%8F%E3%80%82%E5%A6%82%E6%9E%9C%E8%AE%A9%E5%A4%A7%E9%A9%AC%E5%8A%9B%E6%B1%BD%E8%BD%A6%E5%9C%A8%E9%9D%99%E6%AD%A2%E7%8A%B6%E6%80%81%E4%B8%8B%E4%BB%A5%208%2C000%20RPM%20%E7%9A%84%E8%BD%AC%E9%80%9F%E8%B7%B3%E8%BF%87%E8%BD%AC%E9%80%9F%E9%99%90%E5%88%B6%E5%99%A8%EF%BC%8C%E7%94%B1%E4%BA%8E%E9%9D%99%E6%91%A9%E6%93%A6%E6%8D%9F%E5%A4%B1%EF%BC%8C%E5%AE%9E%E9%99%85%E5%89%8D%E8%BF%9B%E5%8A%A0%E9%80%9F%E5%BA%A6%E6%9C%80%E5%A4%9A%E4%BC%9A%E4%B8%8B%E9%99%8D%2040%25%20%E3%80%82%E6%9C%80%E4%BD%B3%E4%BD%8D%E7%BD%AE%E6%98%AF%E5%B0%86%E6%B2%B9%E9%97%A8%E4%BF%9D%E6%8C%81%E5%9C%A8%E6%B1%BD%E8%BD%A6%E5%B3%B0%E5%80%BC%E6%89%AD%E7%9F%A9%E6%9B%B2%E7%BA%BF%E9%99%84%E8%BF%91--%E8%B7%91%E8%BD%A6%E7%9A%84%E5%B3%B0%E5%80%BC%E6%89%AD%E7%9F%A9%E6%9B%B2%E7%BA%BF%E9%80%9A%E5%B8%B8%E5%9C%A8%204%2C500%20%E8%87%B3%205%2C500%20RPM%20%E4%B9%8B%E9%97%B4--%E7%84%B6%E5%90%8E%E5%9C%A8%E8%BD%AE%E8%83%8E%E5%92%AC%E5%90%88%E6%97%B6%E6%85%A2%E6%85%A2%E8%B8%A9%E4%B8%8B%20100%25%20%E6%B2%B9%E9%97%A8%E3%80%82%3C%2FP%3E%3CH2%20id%3D%22toc-hId--1592569317%22%20id%3D%22toc-hId--1592539495%22%3E4.%E9%80%9A%E8%BF%87%E9%81%A5%E6%B5%8B%E5%8F%AF%E8%A7%86%E5%8C%96%E6%82%A8%E7%9A%84%E5%8A%9F%E7%8E%87%3C%2FH2%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E6%83%B3%E7%9F%A5%E9%81%93%E6%82%A8%E7%9A%84%E6%B2%B9%E9%97%A8%E5%88%B0%E5%BA%95%E6%9C%89%E5%A4%9A%E5%A4%A7%EF%BC%8C%E8%AF%B7%E4%B8%8D%E8%A6%81%E7%8C%9C%E6%B5%8B%E3%80%82%E8%BF%9B%E5%85%A5%E6%8E%A7%E5%88%B6%E7%BB%91%E5%AE%9A%EF%BC%8C%E5%B0%86%E9%81%A5%E6%B5%8B%E5%8A%9F%E8%83%BD%E6%98%A0%E5%B0%84%E5%88%B0%E4%B8%80%E4%B8%AA%E6%8C%89%E9%92%AE%E4%B8%8A%EF%BC%88%E5%A6%82%20D%20%E9%94%AE%E7%9B%98%E4%B8%8A%E7%9A%84%E5%90%91%E4%B8%8B%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%E5%9C%A8%E8%87%AA%E7%94%B1%E6%BC%AB%E6%B8%B8%E6%97%B6%E5%88%87%E6%8D%A2%E5%88%B0%E6%91%A9%E6%93%A6%E5%92%8C%E8%BE%93%E5%85%A5%E9%A1%B5%E9%9D%A2%E3%80%82%E6%B3%A8%E6%84%8F%E6%B2%B9%E9%97%A8%E6%9D%86%E3%80%82%E5%A6%82%E6%9E%9C%E5%8F%91%E7%8E%B0%E8%BE%93%E5%85%A5%E7%9E%AC%E9%97%B4%E4%BB%8E%2010%25%20%E8%B7%B3%E8%BD%AC%E5%88%B0%20100%25%20%EF%BC%8C%E8%AF%B7%E6%A3%80%E6%9F%A5%E6%8E%A7%E5%88%B6%E5%99%A8%E7%A1%AC%E4%BB%B6%E3%80%82%E4%BE%8B%E5%A6%82%EF%BC%8C%E5%A6%82%E6%9E%9C%E4%BD%A0%E4%BD%BF%E7%94%A8%20Xbox%20Elite%20%E6%8E%A7%E5%88%B6%E5%99%A8%EF%BC%8C%E8%AF%B7%E7%A1%AE%E4%BF%9D%E8%83%8C%E9%9D%A2%E7%9A%84%E7%89%A9%E7%90%86%E8%A7%A6%E5%8F%91%E5%BC%80%E5%85%B3%E5%AE%8C%E5%85%A8%E5%85%B3%E9%97%AD%E3%80%82%E8%A7%A6%E5%8F%91%E9%94%81%E5%B0%86%E6%A8%A1%E6%8B%9F%E8%A7%A6%E5%8F%91%E4%BF%A1%E5%8F%B7%E5%8F%98%E6%88%90%E6%95%B0%E5%AD%97%E6%8C%89%E9%92%AE%EF%BC%8C%E8%BF%99%E4%BD%BF%E5%BE%97%E5%AE%9E%E9%99%85%E7%9A%84%E6%B2%B9%E9%97%A8%E8%B0%83%E5%88%B6%E5%AE%9E%E9%99%85%E4%B8%8A%E6%98%AF%E4%B8%8D%E5%8F%AF%E8%83%BD%E7%9A%84%E3%80%82%3C%2FP%3E%3CP%3E%E5%9C%A8%E4%B8%80%E6%AC%BE%E8%A1%97%E6%9C%BA%E9%A3%8E%E6%A0%BC%E7%9A%84%E8%B5%9B%E8%BD%A6%E6%B8%B8%E6%88%8F%E4%B8%AD%EF%BC%8C%E6%94%BE%E6%85%A2%E8%BE%93%E5%85%A5%E9%80%9F%E5%BA%A6%E4%BC%9A%E8%AE%A9%E4%BA%BA%E6%84%9F%E8%A7%89%E4%B8%8D%E8%87%AA%E7%84%B6%EF%BC%8C%E4%BD%86%E3%80%8AFH6%E3%80%8B%E5%A5%96%E5%8A%B1%E7%9A%84%E6%98%AF%E7%B2%BE%E5%87%86%E7%9A%84%E9%A9%BE%E9%A9%B6%E3%80%82%E5%B9%B3%E7%A8%B3%E5%9C%B0%E5%9C%A8%E6%B1%BD%E6%B2%B9%E4%B8%8A%E6%BB%9A%E5%8A%A8%E6%80%BB%E6%98%AF%E6%AF%94%E7%A0%B8%E7%A2%8E%E6%89%B3%E6%9C%BA%E6%9B%B4%E8%83%9C%E4%B8%80%E7%AD%B9%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
