Programming
Programming
9,036 次查看
aidanobrien
Hi, I am trying to debug my program and download it onto my board for Freescale Cup Car. However when I attempt this i get an error message (shown in the screenshot). My board is attached to the battery and connected to the computer correctly as my computer is recognising the board. Anyone know how i can fix this ? thanks
标签 (2)
7,852 次查看
hectorsanchez
Hi Aidan,
I suggest you to read this thread on Erich Styger blog:
“An error occurred…”: Applied Debugging Rules | MCU on Eclipse
Keep me informed if you could fix the problem.
Hector Sanchez
7 回复数
7,852 次查看
lucasmahieu
Hollo i have exactly the same problem ! The same error occurs.
I have try all parameter of frequency but nothing worked ...
I also tried to follow the link you have send, but it is not for the same problem i think ...
Can you help me please ?
thank a lot
7,852 次查看
aidanobrien
Thank you
7,852 次查看
aidanobrien
Stupid question really but I'm stuck again. I have the board programmed with the demo code and I have tested each demo state (servo etc). How would I get the car following the track now its programmed ? Unsure which is the start button for the car or am I missing something? Any more help would be grateful, thanks.
7,852 次查看
FlavioStiffan
No question is stupid...I recommend you use The Freescale Cup Knowledge Center as we have several examples of code and online tutorials about how to use the Freedom board in conjunction with the motor control shield for the Freescale Cup
7,852 次查看
aidanobrien
Thank you , Iv got it working
7,853 次查看
hectorsanchez
Hi Aidan,
Hector Sanchez
7,851 次查看
FlavioStiffan
hectorsanchez do you have any clue about this one? Can you point Aidan to some help?  Thanks
