ARC Raiders Canister Farm Guide
5,244 次查看
BladePulse9
If you're aiming to gather resources efficiently in ARC Raiders, the Canister is one of the most versatile and valuable items in the game. This article explains everything you need to know about farming Canisters, including where to find them, how to use them, and their role in crafting and recycling.
What Are Canisters?
Canisters are an Uncommon item in ARC Raiders that are primarily used in crafting and recycling. They are lightweight, stacking up to 15 per inventory slot, and each Canister can be recycled into valuable crafting materials, notably plastic. While the Canister itself isn't rare, it’s often found in important crafting recipes, making it an essential part of your farming routine.
How to Farm Canisters
1. Scavenging for Canisters
The best way to find Canisters in ARC Raiders is through scavenging. These can be found in various locations on the map, particularly in commercial zones where players often explore. When scavenging, look for the common Canister containers which are relatively abundant in certain areas. Focus on zones that are rich in industrial or mechanical items, as these have a higher chance of containing Canisters.
2. Recycling Other Items
You can also recycle other materials and components to yield Canisters. This method may not be as efficient as scavenging, but it’s an alternative if you're focusing on gathering different resources and can afford to spare a few other items for recycling. Items like Bicycle Pumps, Flame Sprays, and Mini Centrifuges can all be broken down into Canisters.
3. Buying Canisters
If you find yourself short on Canisters and in need of them quickly, you can buy Canisters from NPC vendors like Celeste, or even from other players if you're trading items. However, this can be expensive, especially if you need them in bulk, so it's generally better to focus on farming them yourself.
Using Canisters in Crafting
Canisters are integral in several crafting recipes in ARC Raiders. They are used to create a variety of items, from grenades to health-related supplies, making them a key component for progressing in the game.
Common Recipes Involving Canisters:
  • Heavy Fuze Grenade: Requires 1 Explosive Compound and 2 Canisters. Crafted at Explosives Station 3.
  • Smoke Grenade: Requires 1 Canister and 14 Chemicals. Crafted at Workbench or Utility Station 1.
  • Vita Spray: Crafted with 1 Antiseptic and 1 Canister. Crafted at Medical Lab 3.
  • Flame Spray: Requires 1 Canister and 1 Fireball Burner.
These recipes make Canisters a high-demand item for crafting useful tools and weapons. Always keep a good supply of Canisters for these critical recipes.
Recycling Canisters
One of the most valuable uses of Canisters is their ability to be recycled. Recycling Canisters yields Plastic Parts, which are essential for various crafting recipes. You can recycle Canisters at Recycling Stations to turn them into plastic, which can then be used in the creation of other items.
  • Recycling: 1 Canister → 3 Plastic Parts
  • Salvaging: You can also salvage Canisters for 1 Plastic Part.
This makes Canisters valuable even after you’ve used them for crafting, as their recycling value helps keep your inventory full of useful materials for future crafting.
Can You Sell Blueprints for Canisters?
While you can't exactly "sell" Canisters directly, blueprints related to crafting items involving Canisters can be traded or sold. You might want to check out the Blueprints for Bettina, Smoke Grenades, or Vita Sprays, all of which require Canisters as a crafting ingredient. If you have extra blueprints related to these items, you can sell blueprints ARC Raiders in the marketplace to earn coins or other items.
Practical Tips for Efficient Farming
  1. Prioritize Commercial Zones: These are the areas with a high concentration of Canisters. Make sure to spend your time in these zones.
  2. Recycle Wisely: Don’t just focus on crafting with Canisters—recycle them too. You’ll save up valuable materials like Plastic Parts, which are needed for many crafting recipes.
  3. Keep a Stockpile: Since Canisters are used in so many important recipes, it’s wise to keep a stockpile. Don’t wait until you’re low on them to start farming.
  4. Trade Canisters: If you find yourself overloaded with Canisters, consider trading them with other players for items you need more urgently.
Farming Canisters in ARC Raiders is a straightforward but rewarding task. Whether you’re scavenging for them in the wild or recycling old items, Canisters play an important role in crafting and survival. Keep your stockpiles full, focus on recycling when necessary, and be sure to make use of them in your crafting recipes to stay ahead in the game. Happy farming!
Helpful Tip: Get Fast ARC Raiders Boosting at U4N
0 回复数
%3CLINGO-SUB%20id%3D%22lingo-sub-2298636%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EARC%20Raiders%20%E7%BD%90%E8%A3%85%E5%86%9C%E5%9C%BA%E6%8C%87%E5%8D%97%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2298636%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E6%83%B3%E5%9C%A8%E3%80%8AARC%20Raiders%E3%80%8B%E4%B8%AD%E6%9C%89%E6%95%88%E5%9C%B0%E6%94%B6%E9%9B%86%E8%B5%84%E6%BA%90%EF%BC%8C%E9%82%A3%E4%B9%88%E7%BD%90%E5%AD%90%E5%B0%B1%E6%98%AF%E6%B8%B8%E6%88%8F%E4%B8%AD%E7%94%A8%E9%80%94%E6%9C%80%E5%B9%BF%E3%80%81%E6%9C%80%E6%9C%89%E4%BB%B7%E5%80%BC%E7%9A%84%E7%89%A9%E5%93%81%E4%B9%8B%E4%B8%80%E3%80%82%E8%BF%99%E7%AF%87%E6%96%87%E7%AB%A0%E4%BB%8B%E7%BB%8D%E4%BA%86%E5%85%B3%E4%BA%8E%E5%86%9C%E7%94%A8%E7%BD%90%E7%9A%84%E6%89%80%E6%9C%89%E7%9F%A5%E8%AF%86%EF%BC%8C%E5%8C%85%E6%8B%AC%E5%9C%A8%E5%93%AA%E9%87%8C%E5%8F%AF%E4%BB%A5%E6%89%BE%E5%88%B0%E5%AE%83%E4%BB%AC%E3%80%81%E5%A6%82%E4%BD%95%E4%BD%BF%E7%94%A8%E5%AE%83%E4%BB%AC%E4%BB%A5%E5%8F%8A%E5%AE%83%E4%BB%AC%E5%9C%A8%E5%88%B6%E4%BD%9C%E5%92%8C%E5%9B%9E%E6%94%B6%E4%B8%AD%E7%9A%84%E4%BD%9C%E7%94%A8%E3%80%82%3C%2FP%3E%3CH3%20id%3D%22toc-hId-2006238267%22%20id%3D%22toc-hId-2006269980%22%3E%E4%BB%80%E4%B9%88%E6%98%AF%E7%BD%90%E5%AD%90%EF%BC%9F%3C%2FH3%3E%3CP%3E%E7%BD%90%E5%AD%90%E6%98%AF%20ARC%20Raiders%20%E4%B8%AD%E7%9A%84%E4%B8%80%E7%A7%8D%E4%B8%8D%E5%B8%B8%E8%A7%81%E7%89%A9%E5%93%81%EF%BC%8C%E4%B8%BB%E8%A6%81%E7%94%A8%E4%BA%8E%E5%88%B6%E4%BD%9C%E5%92%8C%E5%9B%9E%E6%94%B6%E3%80%82%E5%AE%83%E4%BB%AC%E9%87%8D%E9%87%8F%E8%BD%BB%EF%BC%8C%E6%AF%8F%E4%B8%AA%E5%AD%98%E8%B4%A7%E6%A0%8F%E6%9C%80%E5%A4%9A%E5%8F%AF%E5%A0%86%E5%8F%A0%2015%20%E4%B8%AA%EF%BC%8C%E6%AF%8F%E4%B8%AA%E7%BD%90%E5%AD%90%E5%8F%AF%E4%BB%A5%E5%9B%9E%E6%94%B6%E6%88%90%E6%9C%89%E4%BB%B7%E5%80%BC%E7%9A%84%E5%88%B6%E4%BD%9C%E6%9D%90%E6%96%99%EF%BC%8C%E5%B0%A4%E5%85%B6%E6%98%AF%E5%A1%91%E6%96%99%E3%80%82%E8%99%BD%E7%84%B6%E7%BD%90%E5%AD%90%E6%9C%AC%E8%BA%AB%E5%B9%B6%E4%B8%8D%E7%BD%95%E8%A7%81%EF%BC%8C%E4%BD%86%E5%AE%83%E7%BB%8F%E5%B8%B8%E5%87%BA%E7%8E%B0%E5%9C%A8%E9%87%8D%E8%A6%81%E7%9A%84%E6%89%8B%E5%B7%A5%E5%88%B6%E4%BD%9C%E9%85%8D%E6%96%B9%E4%B8%AD%EF%BC%8C%E4%BD%BF%E5%85%B6%E6%88%90%E4%B8%BA%E6%82%A8%E6%97%A5%E5%B8%B8%E8%80%95%E4%BD%9C%E7%9A%84%E9%87%8D%E8%A6%81%E7%BB%84%E6%88%90%E9%83%A8%E5%88%86%E3%80%82%3C%2FP%3E%3CH3%20id%3D%22toc-hId-198783804%22%20id%3D%22toc-hId-198815517%22%3E%E5%A6%82%E4%BD%95%E7%A7%8D%E6%A4%8D%E7%BD%90%E5%A4%B4%3C%2FH3%3E%3CH4%20id%3D%22toc-hId-889345278%22%20id%3D%22toc-hId-889376991%22%3E1.%E6%B8%85%E9%99%A4%E7%BD%90%E5%AD%90%3C%2FH4%3E%3CP%3E%E5%9C%A8%E3%80%8AARC%20%E7%AA%81%E8%A2%AD%E8%80%85%E3%80%8B%E4%B8%AD%E6%89%BE%E5%88%B0%E7%BD%90%E5%AD%90%E7%9A%84%E6%9C%80%E4%BD%B3%E6%96%B9%E6%B3%95%E6%98%AF%E9%80%9A%E8%BF%87%E6%90%9C%E5%88%AE%E3%80%82%E5%9C%A8%E5%9C%B0%E5%9B%BE%E4%B8%8A%E7%9A%84%E4%B8%8D%E5%90%8C%E5%9C%B0%E7%82%B9%E9%83%BD%E8%83%BD%E6%89%BE%E5%88%B0%E8%BF%99%E4%BA%9B%E4%B8%9C%E8%A5%BF%EF%BC%8C%E5%B0%A4%E5%85%B6%E6%98%AF%E5%9C%A8%E7%8E%A9%E5%AE%B6%E7%BB%8F%E5%B8%B8%E6%8E%A2%E7%B4%A2%E7%9A%84%E5%95%86%E4%B8%9A%E5%8C%BA%E3%80%82%E5%9C%A8%E6%8B%BE%E8%8D%92%E6%97%B6%EF%BC%8C%E8%A6%81%E5%AF%BB%E6%89%BE%E5%B8%B8%E8%A7%81%E7%9A%84%E7%BD%90%E5%BC%8F%E5%AE%B9%E5%99%A8%EF%BC%8C%E8%BF%99%E4%BA%9B%E5%AE%B9%E5%99%A8%E5%9C%A8%E6%9F%90%E4%BA%9B%E5%9C%B0%E5%8C%BA%E7%9B%B8%E5%AF%B9%E8%BE%83%E5%A4%9A%E3%80%82%E9%87%8D%E7%82%B9%E5%85%B3%E6%B3%A8%E5%B7%A5%E4%B8%9A%E6%88%96%E6%9C%BA%E6%A2%B0%E7%89%A9%E5%93%81%E4%B8%B0%E5%AF%8C%E7%9A%84%E5%8C%BA%E5%9F%9F%EF%BC%8C%E5%9B%A0%E4%B8%BA%E8%BF%99%E4%BA%9B%E5%8C%BA%E5%9F%9F%E5%87%BA%E7%8E%B0%E7%BD%90%E5%AD%90%E7%9A%84%E5%87%A0%E7%8E%87%E8%BE%83%E9%AB%98%E3%80%82%3C%2FP%3E%3CH4%20id%3D%22toc-hId--918109185%22%20id%3D%22toc-hId--918077472%22%3E2.%E5%9B%9E%E6%94%B6%E5%85%B6%E4%BB%96%E7%89%A9%E5%93%81%3C%2FH4%3E%3CP%3E%E6%82%A8%E8%BF%98%E5%8F%AF%E4%BB%A5%E5%9B%9E%E6%94%B6%E5%85%B6%E4%BB%96%E6%9D%90%E6%96%99%E5%92%8C%E5%85%83%E5%99%A8%E4%BB%B6%E6%9D%A5%E7%94%9F%E4%BA%A7%E7%BD%90%E5%AD%90%E3%80%82%E8%BF%99%E7%A7%8D%E6%96%B9%E6%B3%95%E7%9A%84%E6%95%88%E7%8E%87%E5%8F%AF%E8%83%BD%E6%AF%94%E4%B8%8D%E4%B8%8A%E6%8D%A1%E7%A0%B4%E7%83%82%EF%BC%8C%E4%BD%86%E5%A6%82%E6%9E%9C%E4%BD%A0%E4%B8%93%E6%B3%A8%E4%BA%8E%E6%94%B6%E9%9B%86%E4%B8%8D%E5%90%8C%E7%9A%84%E8%B5%84%E6%BA%90%EF%BC%8C%E5%B9%B6%E8%83%BD%E8%88%8D%E5%BE%97%E5%9B%9E%E6%94%B6%E4%B8%80%E4%BA%9B%E5%85%B6%E4%BB%96%E7%89%A9%E5%93%81%EF%BC%8C%E8%BF%99%E4%B9%9F%E4%B8%8D%E5%A4%B1%E4%B8%BA%E4%B8%80%E7%A7%8D%E9%80%89%E6%8B%A9%E3%80%82%E8%87%AA%E8%A1%8C%E8%BD%A6%E6%B3%B5%E3%80%81%E7%81%AB%E7%84%B0%E5%96%B7%E9%9B%BE%E5%99%A8%E5%92%8C%E8%BF%B7%E4%BD%A0%E7%A6%BB%E5%BF%83%E6%9C%BA%E7%AD%89%E7%89%A9%E5%93%81%E9%83%BD%E5%8F%AF%E4%BB%A5%E5%88%86%E8%A7%A3%E6%88%90%E7%BD%90%E5%AD%90%E3%80%82%3C%2FP%3E%3CH4%20id%3D%22toc-hId-1569403648%22%20id%3D%22toc-hId-1569435361%22%3E3.%E8%B4%AD%E4%B9%B0%E7%BD%90%E5%AD%90%3C%2FH4%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E5%8F%91%E7%8E%B0%E8%87%AA%E5%B7%B1%E7%9A%84%E7%BD%90%E5%AD%90%E4%B8%8D%E5%A4%9F%E7%94%A8%EF%BC%8C%E9%9C%80%E8%A6%81%E5%B0%BD%E5%BF%AB%E8%B4%AD%E4%B9%B0%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BB%8E%E5%A1%9E%E8%8E%B1%E6%96%AF%E7%89%B9%E7%AD%89%20NPC%20%E5%95%86%E8%B4%A9%E9%82%A3%E9%87%8C%E8%B4%AD%E4%B9%B0%E7%BD%90%E5%AD%90%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%82%A8%E5%9C%A8%E8%BF%9B%E8%A1%8C%E7%89%A9%E5%93%81%E4%BA%A4%E6%98%93%EF%BC%8C%E4%B9%9F%E5%8F%AF%E4%BB%A5%E4%BB%8E%E5%85%B6%E4%BB%96%E7%8E%A9%E5%AE%B6%E9%82%A3%E9%87%8C%E8%B4%AD%E4%B9%B0%E7%BD%90%E5%AD%90%E3%80%82%E4%B8%8D%E8%BF%87%EF%BC%8C%E8%BF%99%E5%8F%AF%E8%83%BD%E4%BC%9A%E5%BE%88%E6%98%82%E8%B4%B5%EF%BC%8C%E5%B0%A4%E5%85%B6%E6%98%AF%E5%BD%93%E4%BD%A0%E9%9C%80%E8%A6%81%E5%A4%A7%E9%87%8F%E8%B4%AD%E4%B9%B0%E6%97%B6%EF%BC%8C%E6%89%80%E4%BB%A5%E4%B8%80%E8%88%AC%E6%9D%A5%E8%AF%B4%EF%BC%8C%E6%9C%80%E5%A5%BD%E8%BF%98%E6%98%AF%E9%9B%86%E4%B8%AD%E7%B2%BE%E5%8A%9B%E8%87%AA%E5%B7%B1%E7%A7%8D%E6%A4%8D%E3%80%82%3C%2FP%3E%3CH3%20id%3D%22toc-hId-1558900544%22%20id%3D%22toc-hId-1558932257%22%3E%E5%9C%A8%E5%88%B6%E4%BD%9C%E8%BF%87%E7%A8%8B%E4%B8%AD%E4%BD%BF%E7%94%A8%E7%BD%90%E5%AD%90%3C%2FH3%3E%3CP%3E%E5%9C%A8%20ARC%20Raiders%20%E7%9A%84%E5%A4%9A%E4%B8%AA%E5%88%B6%E4%BD%9C%E9%85%8D%E6%96%B9%E4%B8%AD%EF%BC%8C%E7%BD%90%E5%AD%90%E6%98%AF%E4%B8%8D%E5%8F%AF%E6%88%96%E7%BC%BA%E7%9A%84%E3%80%82%E5%AE%83%E4%BB%AC%E8%A2%AB%E7%94%A8%E6%9D%A5%E5%88%B6%E4%BD%9C%E5%90%84%E7%A7%8D%E7%89%A9%E5%93%81%EF%BC%8C%E4%BB%8E%E6%89%8B%E6%A6%B4%E5%BC%B9%E5%88%B0%E4%B8%8E%E7%94%9F%E5%91%BD%E7%9B%B8%E5%85%B3%E7%9A%84%E7%89%A9%E5%93%81%EF%BC%8C%E4%BD%BF%E5%AE%83%E4%BB%AC%E6%88%90%E4%B8%BA%E6%B8%B8%E6%88%8F%E8%BF%9B%E5%B1%95%E7%9A%84%E5%85%B3%E9%94%AE%E5%85%83%E5%99%A8%E4%BB%B6%E3%80%82%3C%2FP%3E%3CH4%20id%3D%22toc-hId--2045505278%22%20id%3D%22toc-hId--2045473565%22%3E%E6%B6%89%E5%8F%8A%E7%BD%90%E5%AD%90%E7%9A%84%E5%B8%B8%E8%A7%81%E9%85%8D%E6%96%B9%EF%BC%9A%3C%2FH4%3E%3CUL%3E%3CLI%3E%3CP%3E%E9%87%8D%E5%9E%8B%E5%BC%95%E4%BF%A1%E6%89%8B%E6%A6%B4%E5%BC%B9%E9%9C%80%E8%A6%81%201%20%E4%B8%AA%E7%88%86%E7%82%B8%E5%8C%96%E5%90%88%E7%89%A9%E5%92%8C%202%20%E4%B8%AA%E7%BD%90%E5%AD%90%E3%80%82%E5%9C%A8%203%20%E5%8F%B7%E7%82%B8%E8%8D%AF%E7%AB%99%E5%88%B6%E4%BD%9C%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E7%83%9F%E9%9B%BE%E5%BC%B9%E9%9C%80%E8%A6%81%201%20%E4%B8%AA%E7%BD%90%E5%AD%90%E5%92%8C%2014%20%E7%A7%8D%E5%8C%96%E5%AD%A6%E5%93%81%E3%80%82%E5%9C%A8%E5%B7%A5%E4%BD%9C%E5%8F%B0%E6%88%96%E5%85%AC%E7%94%A8%E8%AE%BE%E6%96%BD%E7%AB%99%E5%88%B6%E4%BD%9C%201.%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3EVita%20%E5%96%B7%E9%9B%BE%E5%89%82%EF%BC%9A%E5%8C%85%E5%90%AB%201%20%E4%B8%AA%E6%B6%88%E6%AF%92%E5%89%82%E5%92%8C%201%20%E4%B8%AA%E7%BD%90%E5%AD%90%E3%80%82%E5%9C%A8%E5%8C%BB%E5%AD%A6%E5%AE%9E%E9%AA%8C%E5%AE%A4%203%20%E5%88%B6%E4%BD%9C%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E7%81%AB%E7%84%B0%E5%96%B7%E5%B0%84%E9%9C%80%E8%A6%81%201%20%E4%B8%AA%E7%BD%90%E5%AD%90%E5%92%8C%201%20%E4%B8%AA%E7%81%AB%E7%90%83%E7%87%83%E7%83%A7%E5%99%A8%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E8%BF%99%E4%BA%9B%E9%85%8D%E6%96%B9%E4%BD%BF%E7%BD%90%E5%AD%90%E6%88%90%E4%B8%BA%E5%88%B6%E4%BD%9C%E6%9C%89%E7%94%A8%E5%B7%A5%E5%85%B7%E5%92%8C%E6%AD%A6%E5%99%A8%E7%9A%84%E9%AB%98%E9%9C%80%E6%B1%82%E7%89%A9%E5%93%81%E3%80%82%E4%B8%80%E5%AE%9A%E8%A6%81%E4%B8%BA%E8%BF%99%E4%BA%9B%E5%85%B3%E9%94%AE%E9%85%8D%E6%96%B9%E5%82%A8%E5%A4%87%E5%85%85%E8%B6%B3%E7%9A%84%E7%BD%90%E5%AD%90%E3%80%82%3C%2FP%3E%3CH3%20id%3D%22toc-hId--2056008382%22%20id%3D%22toc-hId--2055976669%22%3E%E5%9B%9E%E6%94%B6%E7%BD%90%3C%2FH3%3E%3CP%3E%E6%98%93%E6%8B%89%E7%BD%90%E6%9C%80%E6%9C%89%E4%BB%B7%E5%80%BC%E7%9A%84%E7%94%A8%E9%80%94%E4%B9%8B%E4%B8%80%E5%B0%B1%E6%98%AF%E5%8F%AF%E4%BB%A5%E5%9B%9E%E6%94%B6%E5%88%A9%E7%94%A8%E3%80%82%E5%9B%9E%E6%94%B6%E7%BD%90%E5%AD%90%E4%BC%9A%E4%BA%A7%E7%94%9F%E5%A1%91%E6%96%99%E9%9B%B6%E4%BB%B6%EF%BC%8C%E8%BF%99%E4%BA%9B%E9%9B%B6%E4%BB%B6%E5%AF%B9%E4%BA%8E%E5%90%84%E7%A7%8D%E5%88%B6%E4%BD%9C%E9%85%8D%E6%96%B9%E8%87%B3%E5%85%B3%E9%87%8D%E8%A6%81%E3%80%82%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%9C%A8%E5%9B%9E%E6%94%B6%E7%AB%99%E5%9B%9E%E6%94%B6%E6%98%93%E6%8B%89%E7%BD%90%EF%BC%8C%E5%B0%86%E5%85%B6%E8%BD%AC%E5%8C%96%E4%B8%BA%E5%A1%91%E6%96%99%EF%BC%8C%E7%84%B6%E5%90%8E%E7%94%A8%E4%BA%8E%E5%88%B6%E9%80%A0%E5%85%B6%E4%BB%96%E7%89%A9%E5%93%81%E3%80%82%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3E%E5%9B%9E%E6%94%B6%EF%BC%9A1%20%E4%B8%AA%E7%BD%90%E5%AD%90%20%E2%86%92%203%20%E4%B8%AA%E5%A1%91%E6%96%99%E9%9B%B6%E4%BB%B6%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E6%89%93%E6%8D%9E%EF%BC%9A%E6%82%A8%E8%BF%98%E5%8F%AF%E4%BB%A5%E7%94%A8%E6%89%93%E6%8D%9E%E7%BD%90%E6%8D%A2%E5%8F%96%201%20%E4%B8%AA%E5%A1%91%E6%96%99%E9%9B%B6%E4%BB%B6%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E5%8D%B3%E4%BD%BF%E4%BD%A0%E5%B7%B2%E7%BB%8F%E4%BD%BF%E7%94%A8%E8%BF%87%E7%BD%90%E5%AD%90%E8%BF%9B%E8%A1%8C%E5%88%B6%E4%BD%9C%EF%BC%8C%E8%BF%99%E4%B9%9F%E4%BD%BF%E5%AE%83%E4%BB%AC%E5%8F%98%E5%BE%97%E6%9C%89%E4%BB%B7%E5%80%BC%EF%BC%8C%E5%9B%A0%E4%B8%BA%E5%AE%83%E4%BB%AC%E7%9A%84%E5%9B%9E%E6%94%B6%E4%BB%B7%E5%80%BC%E6%9C%89%E5%8A%A9%E4%BA%8E%E4%BD%A0%E7%9A%84%E5%AD%98%E8%B4%A7%E4%B8%AD%E5%85%85%E6%96%A5%E6%9C%89%E7%94%A8%E7%9A%84%E6%9D%90%E6%96%99%EF%BC%8C%E4%BB%A5%E5%A4%87%E5%B0%86%E6%9D%A5%E5%88%B6%E4%BD%9C%E3%80%82%3C%2FP%3E%3CH3%20id%3D%22toc-hId-431504451%22%20id%3D%22toc-hId-431536164%22%3E%E4%BD%A0%E8%83%BD%E5%87%BA%E5%94%AE%E7%BD%90%E5%AD%90%E7%9A%84%E8%93%9D%E5%9B%BE%E5%90%97%EF%BC%9F%3C%2FH3%3E%3CP%3E%E8%99%BD%E7%84%B6%E6%82%A8%E4%B8%8D%E8%83%BD%E7%9B%B4%E6%8E%A5%22%22%20%E7%BD%90%EF%BC%8C%E4%BD%86%E4%B8%8E%E6%B6%89%E5%8F%8A%E7%BD%90%E7%9A%84%E5%88%B6%E4%BD%9C%E7%89%A9%E5%93%81%E7%9B%B8%E5%85%B3%E7%9A%84%E8%93%9D%E5%9B%BE%E5%8F%AF%E4%BB%A5%E4%BA%A4%E6%98%93%E6%88%96%E5%87%BA%E5%94%AE%E3%80%82%E6%82%A8%E5%8F%AF%E8%83%BD%E9%9C%80%E8%A6%81%E6%9F%A5%E7%9C%8B%E8%B4%9D%E8%92%82%E5%A8%9C%E3%80%81%E7%83%9F%E9%9B%BE%E5%BC%B9%E6%88%96%E7%BB%B4%E5%A1%94%E5%96%B7%E9%9B%BE%E5%89%82%E7%9A%84%E8%93%9D%E5%9B%BE%EF%BC%8C%E6%89%80%E6%9C%89%E8%BF%99%E4%BA%9B%E9%83%BD%E9%9C%80%E8%A6%81%E7%BD%90%E5%AD%90%E4%BD%9C%E4%B8%BA%E5%88%B6%E4%BD%9C%E5%8E%9F%E6%96%99%E3%80%82%E5%A6%82%E6%9E%9C%E6%82%A8%E6%9C%89%E4%B8%8E%E8%BF%99%E4%BA%9B%E7%89%A9%E5%93%81%E7%9B%B8%E5%85%B3%E7%9A%84%E9%A2%9D%E5%A4%96%E8%93%9D%E5%9B%BE%EF%BC%8C%E5%8F%AF%E4%BB%A5%E5%9C%A8%E5%B8%82%E5%9C%BA%E4%B8%8A%3CA%20href%3D%22https%3A%2F%2Fwww.u4n.com%2Farc-raiders%2Fitems%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E5%87%BA%E5%94%AE%E8%93%9D%E5%9B%BE%20ARC%20Raiders%3C%2FA%3E%EF%BC%8C%E4%BB%A5%E8%B5%9A%E5%8F%96%E9%87%91%E5%B8%81%E6%88%96%E5%85%B6%E4%BB%96%E7%89%A9%E5%93%81%E3%80%82%3C%2FP%3E%3CH3%20id%3D%22toc-hId--1375950012%22%20id%3D%22toc-hId--1375918299%22%3E%E9%AB%98%E6%95%88%E5%86%9C%E4%B8%9A%E5%AE%9E%E7%94%A8%E6%8A%80%E5%B7%A7%3C%2FH3%3E%3COL%3E%3CLI%3E%3CP%3E%E4%BC%98%E5%85%88%E8%80%83%E8%99%91%E5%95%86%E4%B8%9A%E5%8C%BA%EF%BC%9A%E8%BF%99%E4%BA%9B%E5%8C%BA%E5%9F%9F%E6%98%AF%E6%98%93%E6%8B%89%E7%BD%90%E9%AB%98%E5%BA%A6%E9%9B%86%E4%B8%AD%E7%9A%84%E5%8C%BA%E5%9F%9F%E3%80%82%E7%A1%AE%E4%BF%9D%E5%9C%A8%E8%BF%99%E4%BA%9B%E5%8C%BA%E5%9F%9F%E5%BA%A6%E8%BF%87%E6%82%A8%E7%9A%84%E7%BE%8E%E5%A5%BD%E6%97%B6%E5%85%89%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E6%98%8E%E6%99%BA%E5%9B%9E%E6%94%B6%EF%BC%9A%E4%B8%8D%E8%A6%81%E5%8F%AA%E4%B8%93%E6%B3%A8%E4%BA%8E%E4%BD%BF%E7%94%A8%E6%98%93%E6%8B%89%E7%BD%90%E5%88%B6%E4%BD%9C%E5%B7%A5%E8%89%BA%E5%93%81%EF%BC%8C%E4%B9%9F%E8%A6%81%E5%9B%9E%E6%94%B6%E5%88%A9%E7%94%A8%E5%AE%83%E4%BB%AC%E3%80%82%E6%82%A8%E5%B0%86%E8%8A%82%E7%9C%81%E5%AE%9D%E8%B4%B5%E7%9A%84%E6%9D%90%E6%96%99%EF%BC%8C%E4%BE%8B%E5%A6%82%E5%A1%91%E6%96%99%E9%9B%B6%E4%BB%B6%EF%BC%8C%E8%BF%99%E4%BA%9B%E6%9D%90%E6%96%99%E6%98%AF%E8%AE%B8%E5%A4%9A%E5%88%B6%E4%BD%9C%E9%85%8D%E6%96%B9%E6%89%80%E5%BF%85%E9%9C%80%E7%9A%84%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E4%BF%9D%E7%95%99%E5%82%A8%E5%A4%87%EF%BC%9A%E7%94%B1%E4%BA%8E%E7%BD%90%E5%AD%90%E8%A2%AB%E7%94%A8%E4%BA%8E%E8%AE%B8%E5%A4%9A%E9%87%8D%E8%A6%81%E7%9A%84%E9%85%8D%E6%96%B9%EF%BC%8C%E5%9B%A0%E6%AD%A4%E6%98%8E%E6%99%BA%E7%9A%84%E5%81%9A%E6%B3%95%E6%98%AF%E4%BF%9D%E7%95%99%E5%BA%93%E5%AD%98%E3%80%82%E4%B8%8D%E8%A6%81%E7%AD%89%E5%88%B0%E8%B5%84%E6%BA%90%E4%B8%8D%E8%B6%B3%E6%97%B6%E6%89%8D%E5%BC%80%E5%A7%8B%E8%80%95%E7%A7%8D%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E4%BA%A4%E6%98%93%E7%BD%90%E5%AD%90%E5%A6%82%E6%9E%9C%E6%82%A8%E5%8F%91%E7%8E%B0%E8%87%AA%E5%B7%B1%E7%9A%84%E7%BD%90%E5%AD%90%E8%BF%87%E5%A4%9A%EF%BC%8C%E5%8F%AF%E4%BB%A5%E8%80%83%E8%99%91%E4%B8%8E%E5%85%B6%E4%BB%96%E7%8E%A9%E5%AE%B6%E4%BA%A4%E6%98%93%EF%BC%8C%E6%8D%A2%E5%8F%96%E6%82%A8%E6%9B%B4%E6%80%A5%E9%9C%80%E7%9A%84%E7%89%A9%E5%93%81%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%E5%9C%A8%E3%80%8AARC%20Raiders%E3%80%8B%E4%B8%AD%E5%85%BB%E6%AE%96%E7%BD%90%E5%AD%90%E6%98%AF%E4%B8%80%E9%A1%B9%E7%AE%80%E5%8D%95%E8%80%8C%E5%8F%88%E6%9C%89%E7%9B%8A%E7%9A%84%E4%BB%BB%E5%8A%A1%E3%80%82%E6%97%A0%E8%AE%BA%E6%98%AF%E5%9C%A8%E9%87%8E%E5%A4%96%E6%8B%BE%E8%8D%92%E8%BF%98%E6%98%AF%E5%9B%9E%E6%94%B6%E6%97%A7%E7%89%A9%E5%93%81%EF%BC%8C%E7%BD%90%E5%AD%90%E9%83%BD%E5%9C%A8%E5%88%B6%E4%BD%9C%E5%92%8C%E7%94%9F%E5%AD%98%E4%B8%AD%E5%8F%91%E6%8C%A5%E7%9D%80%E9%87%8D%E8%A6%81%E4%BD%9C%E7%94%A8%E3%80%82%E4%BF%9D%E6%8C%81%E5%BA%93%E5%AD%98%E5%85%85%E8%B6%B3%EF%BC%8C%E5%9C%A8%E5%BF%85%E8%A6%81%E6%97%B6%E9%9B%86%E4%B8%AD%E7%B2%BE%E5%8A%9B%E5%9B%9E%E6%94%B6%E5%88%A9%E7%94%A8%EF%BC%8C%E5%B9%B6%E7%A1%AE%E4%BF%9D%E5%9C%A8%E5%88%B6%E4%BD%9C%E9%85%8D%E6%96%B9%E4%B8%AD%E4%BD%BF%E7%94%A8%E5%AE%83%E4%BB%AC%EF%BC%8C%E4%BB%A5%E4%BF%9D%E6%8C%81%E6%B8%B8%E6%88%8F%E7%9A%84%E9%A2%86%E5%85%88%E5%9C%B0%E4%BD%8D%E3%80%82%E5%BF%AB%E4%B9%90%E8%80%95%E4%BD%9C%3C%2FP%3E%3CP%3E%E6%9C%89%E7%94%A8%E7%9A%84%E6%8F%90%E7%A4%BA%EF%BC%9A%3CA%20href%3D%22https%3A%2F%2Fwww.u4n.com%2Farc-raiders%2Fboosting%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E5%9C%A8%20U4N%20%E8%8E%B7%E5%BE%97%E5%BF%AB%E9%80%9F%20ARC%20Raiders%20%E6%8F%90%E5%8D%87%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
