If you stumble across the "getting started page" FREEDOM BOARD / CORTEX M0+ GETTING STARTED Please take note:
While working with a large number of Freedom boards in a course, it was observed that the Init Clock Routines would *sometimes* not work. *Some* of the crystals on the freedom boards do NOT like "HIGH_GAIN" mode.
change the line
pll_init(8000000, HIGH_GAIN, CRYSTAL, 4, 24, MCGOUT);
to
pll_init(8000000, LOW_POWER, CRYSTAL, 4, 24, MCGOUT);
That's because the resistor R25 is not already populated in the majority of the boards, those who have it not exhibit this problem.
In all cases R25 was removed.
I also tried populating R25 in 2 boards and could still get the same result (1M). Usually a *series* resistor is put in the EXTAL path to limit drive level.
My first freedom board had R25 populated, but the others 2 not. I tried
high gain in all of them and only worked in the first. I will try to
populate the others 2 and try high gain mode I will tell you the results...
2013/3/28 Eli Hughes <[email protected]>
image: Freescale Community<https://community.freescale.com/index.jspa> Freedom Board --- Warning about on-board Crystal / PLL new comment by Eli
Hughes <https://community.freescale.com/people/eli_hughes> View all
comments on this document<https://community.freescale.com/docs/DOC-94311#comment-3682>
