Freedom Board --- Warning about on-board Crystal / PLL
WARNING
If you stumble across the "getting started page" FREEDOM BOARD / CORTEX M0+ GETTING STARTED Please take note:
While working with a large number of Freedom boards in a course,  it was observed that the Init Clock Routines would *sometimes* not work.    *Some* of the crystals on the freedom boards do NOT like "HIGH_GAIN" mode.
change the line
  pll_init(8000000, HIGH_GAIN, CRYSTAL, 4, 24, MCGOUT);
to
  pll_init(8000000, LOW_POWER, CRYSTAL, 4, 24, MCGOUT);
Comments
That's because the resistor R25 is not already populated in the majority of the boards, those who have it not exhibit this problem.
In all cases R25 was removed.
I also tried populating R25 in 2 boards and could still get the same result (1M).   Usually a *series* resistor is put in the EXTAL path to limit drive level.
My first freedom board had R25 populated, but the others 2 not. I tried
high gain in all of them and only worked in the first. I will try to
populate the others 2 and try high gain mode I will tell you the results...
2013/3/28 Eli Hughes <admin@community.freescale.com>
image: Freescale Community<https://community.freescale.com/index.jspa> Freedom Board --- Warning about on-board Crystal / PLL new comment by Eli
Hughes <https://community.freescale.com/people/eli_hughes> View all
comments on this document<https://community.freescale.com/docs/DOC-94311#comment-3682>
%3CLINGO-SUB%20id%3D%22lingo-sub-1102784%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFreedom%20Board%20---%20%20Warning%20about%20on-board%20Crystal%20%2F%20PLL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1102784%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CH2%20id%3D%22toc-hId--1416399823%22%20id%3D%22toc-hId--499225293%22%3E%3CSPAN%20style%3D%22color%3A%20%23ff6600%3B%22%3E%3CSTRONG%3EWARNING%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FH2%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EIf%20you%20stumble%20across%20the%20%22getting%20started%20page%22%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-93960%22%20target%3D%22_blank%22%3EFREEDOM%20BOARD%20%2F%20CORTEX%20M0%2B%20GETTING%20STARTED%20%20%3C%2FA%3EPlease%20take%20note%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3EWhile%20working%20with%20a%20large%20number%20of%20Freedom%20boards%20in%20a%20course%2C%26nbsp%3B%20it%20was%20observed%20that%20the%20Init%20Clock%20Routines%20would%20*sometimes*%20not%20work.%26nbsp%3B%26nbsp%3B%26nbsp%3B%20*Some*%20of%20the%20crystals%20on%20the%20freedom%20boards%20do%20NOT%20like%20%22HIGH_GAIN%22%20mode.%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Echange%20the%20line%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CEM%3E%3CSTRONG%3E%26nbsp%3B%20pll_init(8000000%2C%20HIGH_GAIN%2C%20CRYSTAL%2C%204%2C%2024%2C%20MCGOUT)%3B%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Eto%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CEM%3E%3CSTRONG%3E%26nbsp%3B%20pll_init(8000000%2C%20LOW_POWER%2C%20CRYSTAL%2C%204%2C%2024%2C%20MCGOUT)%3B%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1102784%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EFreescale%20Cup%20Content%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EStudent%20Project%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1102787%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freedom%20Board%20---%20%20Warning%20about%20on-board%20Crystal%20%2F%20PLL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1102787%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EMy%20first%20freedom%20board%20had%20R25%20populated%2C%20but%20the%20others%202%20not.%20I%20tried%3C%2FP%3E%3CP%3Ehigh%20gain%20in%20all%20of%20them%20and%20only%20worked%20in%20the%20first.%20I%20will%20try%20to%3C%2FP%3E%3CP%3Epopulate%20the%20others%202%20and%20try%20high%20gain%20mode%20I%20will%20tell%20you%20the%20results...%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E2013%2F3%2F28%20Eli%20Hughes%20%3CADMIN%3E%3C%2FADMIN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%20level%3D%221%22%3E%3CP%3E**%3C%2FP%3E%3CP%3E%20%20%20%20%20%3CA%20href%3D%22image%3A%20Freescale%20Community%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Eimage%3A%20Freescale%20Community%3C%2FA%3E%26lt%3B%26gt%3B%20%20Freedom%20Board%20---%20Warning%20about%20on-board%20Crystal%20%2F%20PLL%20new%20comment%20by%20Eli%3C%2FP%3E%3CP%3EHughes%20%26lt%3B%26gt%3B%20View%20all%3C%2FP%3E%3CP%3Ecomments%20on%20this%20document%26lt%3B%26gt%3B%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1102786%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freedom%20Board%20---%20%20Warning%20about%20on-board%20Crystal%20%2F%20PLL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1102786%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EIn%20all%20cases%20R25%20was%20removed.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20also%20tried%20populating%20R25%20in%202%20boards%20and%20could%20still%20get%20the%20same%20result%20(1M).%26nbsp%3B%26nbsp%3B%20Usually%20a%20*series*%20resistor%20is%20put%20in%20the%20EXTAL%20path%20to%20limit%20drive%20level.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1102785%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freedom%20Board%20---%20%20Warning%20about%20on-board%20Crystal%20%2F%20PLL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1102785%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThat's%20because%20the%20resistor%20R25%20is%20not%20already%20populated%20in%20the%20majority%20of%20the%20boards%2C%20those%20who%20have%20it%20not%20exhibit%20this%20problem.%3C%2FP%3E%3C%2FLINGO-BODY%3E
No ratings
Version history
Last update:
‎03-18-2013 07:07 PM
Updated by:
