Freedom Board --- Warning about on-board Crystal / PLL
WARNING
If you stumble across the "getting started page" FREEDOM BOARD / CORTEX M0+ GETTING STARTED Please take note:
While working with a large number of Freedom boards in a course,  it was observed that the Init Clock Routines would *sometimes* not work.    *Some* of the crystals on the freedom boards do NOT like "HIGH_GAIN" mode.
change the line
  pll_init(8000000, HIGH_GAIN, CRYSTAL, 4, 24, MCGOUT);
to
  pll_init(8000000, LOW_POWER, CRYSTAL, 4, 24, MCGOUT);
ラベル(2)
コメント
That's because the resistor R25 is not already populated in the majority of the boards, those who have it not exhibit this problem.
In all cases R25 was removed.
I also tried populating R25 in 2 boards and could still get the same result (1M).   Usually a *series* resistor is put in the EXTAL path to limit drive level.
My first freedom board had R25 populated, but the others 2 not. I tried
high gain in all of them and only worked in the first. I will try to
populate the others 2 and try high gain mode I will tell you the results...
2013/3/28 Eli Hughes <[email protected]>
image: Freescale Community<https://community.freescale.com/index.jspa> Freedom Board --- Warning about on-board Crystal / PLL new comment by Eli
Hughes <https://community.freescale.com/people/eli_hughes> View all
comments on this document<https://community.freescale.com/docs/DOC-94311#comment-3682>
%3CLINGO-SUB%20id%3D%22lingo-sub-1102784%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0%E3%83%9C%E3%83%BC%E3%83%89%20---%20Crystal%20%2F%20PLL%E6%90%AD%E8%BC%89%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E8%AD%A6%E5%91%8A%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1102784%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CH2%20id%3D%22toc-hId--1416399823%22%20id%3D%22toc-hId--499224553%22%3E%3CSPAN%20style%3D%22color%3A%20%23ff6600%3B%22%3E%3CSTRONG%3E%E8%AD%A6%E5%91%8A%EF%BC%88WARNING%EF%BC%89%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FH2%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%80%8C%E3%81%AF%E3%81%98%E3%82%81%E3%81%AB%E3%80%8D%E3%83%9A%E3%83%BC%E3%82%B8%E3%81%AB%E5%87%BA%E3%81%8F%E3%82%8F%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-93960%22%20target%3D%22_blank%22%3EFREEDOM%20BOARD%20%2F%20CORTEX%20M0%20%2B%E3%81%AF%E3%81%98%E3%82%81%E3%81%AB%20%20%3C%2FA%3E%E6%B3%A8%E6%84%8F%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3E%E3%82%B3%E3%83%BC%E3%82%B9%E3%81%A7%E5%A4%9A%E6%95%B0%E3%81%AE%20Freedom%20%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%80%81Init%20Clock%20Routines%20%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%8C%E8%A6%B3%E5%AF%9F%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E3%82%AF%E3%83%AA%E3%82%B9%E3%82%BF%E3%83%AB%E3%81%AE*%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B*%E3%81%AF%E3%80%81%E3%80%8CHIGH_GAIN%E3%80%8D%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E5%A5%BD%E3%81%BF%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E8%A1%8C%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CEM%3E%3CSTRONG%3Epll_init(8000000%E3%80%81HIGH_GAIN%E3%80%81%E3%82%AF%E3%83%AA%E3%82%B9%E3%82%BF%E3%83%AB%E3%80%814%E3%80%8124%E3%80%81%E3%83%9E%E3%82%AF%E3%82%AC%E3%82%A6%E3%83%88)%3B%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%EF%BD%9E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CEM%3E%3CSTRONG%3Epll_init(8000000%E3%80%81LOW_POWER%E3%80%81%E3%82%AF%E3%83%AA%E3%82%B9%E3%82%BF%E3%83%AB%E3%80%814%E3%80%8124%E3%80%81%E3%83%9E%E3%82%AF%E3%82%AC%E3%82%A6%E3%83%88)%3B%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1102784%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%83%BB%E3%82%AB%E3%83%83%E3%83%97%E3%81%AE%E5%86%85%E5%AE%B9%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3E%E5%AD%A6%E7%94%9F%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1102786%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0%E3%83%9C%E3%83%BC%E3%83%89%20---%20%E3%82%AA%E3%83%B3%E3%83%9C%E3%83%BC%E3%83%89%E3%82%AF%E3%83%AA%E3%82%B9%E3%82%BF%E3%83%AB%2F%20PLL%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E8%AD%A6%E5%91%8A%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1102786%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AB%E3%81%8A%E3%81%84%E3%81%A6%E3%80%81R25%E3%81%AF%E5%89%8A%E9%99%A4%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81R25%E3%82%922%E3%81%A4%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E5%AE%9F%E8%A3%85%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A7%E3%82%82%E5%90%8C%E3%81%98%E7%B5%90%E6%9E%9C(1M)%E3%81%8C%E5%BE%97%E3%82%89%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E9%80%9A%E5%B8%B8%E3%80%81*%E7%9B%B4%E5%88%97*%E6%8A%B5%E6%8A%97%E3%81%AF%E3%80%81%E3%83%89%E3%83%A9%E3%82%A4%E3%83%96%E3%83%AC%E3%83%99%E3%83%AB%E3%82%92%E5%88%B6%E9%99%90%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%ABEXTAL%E3%83%91%E3%82%B9%E3%81%AB%E9%85%8D%E7%BD%AE%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1102785%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%83%80%E3%83%A0%E3%83%9C%E3%83%BC%E3%83%89%20---%20%E3%82%AA%E3%83%B3%E3%83%9C%E3%83%BC%E3%83%89%E3%82%AF%E3%83%AA%E3%82%B9%E3%82%BF%E3%83%AB%2F%20PLL%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E8%AD%A6%E5%91%8A%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1102785%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E6%8A%B5%E6%8A%97R25%E3%81%8C%E5%A4%A7%E9%83%A8%E5%88%86%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%81%BE%E3%81%A0%E5%AE%9F%E8%A3%85%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E3%81%9D%E3%82%8C%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E4%BA%BA%E3%81%AF%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎03-18-2013 07:07 PM
更新者:
