NXP Gazebo Launch Issue
3,290 次查看
GogaGriffin
Hi, I've been unable to get the NXP Gazebo simulation software to launch on my laptop using Ubuntu. I've followed the instructions up to the point where it requires you to use the command "ros2 launch sim_ignition_bringup sim_ignition.launch.py" to launch the software, which fails with this error:
[ERROR] [launch]: Caught exception in launch (see debug for traceback): Caught exception when trying to load file of format [py]: unsupported format string passed to NoneType.__format__
Does anyone have any recommendations on how to fix this?
2,843 次查看
GuyHorne
Same issue as well
2,903 次查看
usman686
Hi, I am facing a similar issue. Let me know if you found any solution.
Thanks!
