[TapLink SDK iOS] Authentication with AES 128 not working
SamanaGG
Hello, I have read your guide UG10045 and I have successfully integrated the Taplink iOS SDK in a demo Project.
In section 6.1 you describe an authenticationFlow with EV2 Card.
I have to use EV3 Cards, so I replicated that flow using a DesEV3Instance
Here my code:
private func authenticateWithCustomOrZero(_ desfire: TL_DESFireEV3, completion: @escaping (Bool, Bool) -> Void) {
        desfire.authenticate(withCardKeyNo: 0, withAuthenticationType: .native, withAuthKeyType: .THREEDES, withCommandSetForAuth: .Native, withAuthkey: threeDESZero) { firstAuth3D in
            os_log("Internal Log  - %{public}@", log: OSLog(subsystem: Bundle.main.bundleIdentifier!, category: "DemoLog"), type: .error, "firstAuth3D: \(firstAuth3D)")
            desfire.changeKey(withCardKeyNo: 0, withAuthKeyType: .AES128, withFromKey: threeDESZero, withToKey: aesZero) { firstChangeAES in
                os_log("Internal Log  - %{public}@", log: OSLog(subsystem: Bundle.main.bundleIdentifier!, category: "DemoLog"), type: .error, "firstChangeAES: \(firstChangeAES)")
                desfire.authenticate(withCardKeyNo: 0, withAuthenticationType: .AES, withAuthKeyType: .AES128, withCommandSetForAuth: .Native, withAuthkey: aesZero) { firstAuthAES in
                    os_log("Internal Log  - %{public}@", log: OSLog(subsystem: Bundle.main.bundleIdentifier!, category: "DemoLog"), type: .error, "firstAuthAES: \(firstAuthAES)")
                    desfire.changeKey(withCardKeyNo: 0, withAuthKeyType: .THREEDES, withFromKey: aesZero, withToKey: threeDESZero) { lastChange3D in
                        os_log("Internal Log  - %{public}@", log: OSLog(subsystem: Bundle.main.bundleIdentifier!, category: "DemoLog"), type: .error, "lastChange3D: \(lastChange3D)")
                        desfire.authenticate(withCardKeyNo: 0, withAuthenticationType: .native, withAuthKeyType: .THREEDES, withCommandSetForAuth: .Native, withAuthkey: threeDESZero) { lastAuth3D in
                            os_log("Internal Log  - %{public}@", log: OSLog(subsystem: Bundle.main.bundleIdentifier!, category: "DemoLog"), type: .error, "lastAuth3D: \(lastAuth3D)")
The first authentication with 3DES, the change to aes key and then the authentication with Aes key works perfectly.
Then when I tried to change to old 3DES key I received a error and now the card is still "authenticated" with AES key
For completism, the keys are
private let aesZero = Data(repeating: 0x00, count: 16)
private let threeDESZero = Data(repeating: 0x00, count: 24)
I received this error from SDK logs (see the attachments).
Exception Caught: com.nxp.nfclib.exceptions.PICCException: Integrity Error SW2 = 30
Before doing others tests, I hope to know from you if my implementation is working as expected  and what that error means.
Thanks in advance
Labels (2)
Fabian_R
Hello sir,
Thank you for sharing your code. My apologies for the delay.
I believe the root cause is very likely to be due to the threeDESZero odd parity per byte. After authenticating with an AES key and, the changing to the 3DES
You could quickly test this instead of using a 0x00, try a non-zero key to ensure odd parity byte.
If this still fails, please try changing from 3DES -> AES -> 3DES in two separated sessions but, please try using non-zero keys.
I hope this helps
Fabian
%3CLINGO-SUB%20id%3D%22lingo-sub-2324491%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%5BTapLink%20SDK%20iOS%5D%20Authentication%20with%20AES%20128%20not%20working%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2324491%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%20I%20have%20read%20your%20guide%26nbsp%3BUG10045%20and%20I%20have%20successfully%20integrated%20the%20Taplink%20iOS%20SDK%20in%20a%20demo%20Project.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EIn%20section%206.1%20you%20describe%20an%20authenticationFlow%20with%20EV2%20Card.%3C%2FP%3E%3CP%3EI%20have%20to%20use%20EV3%20Cards%2C%20so%20I%20replicated%20that%20flow%20using%20a%20DesEV3Instance%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EHere%20my%20code%3A%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%3E%3CSPAN%3E%3CSTRONG%3Eprivate%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%3E%3CSTRONG%3Efunc%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%3EauthenticateWithCustomOrZero%3C%2FSPAN%3E(%3CSPAN%3E_%3C%2FSPAN%3E%20desfire%3A%20TL_DESFireEV3%2C%20%3CSPAN%3Ecompletion%3C%2FSPAN%3E%3A%20%3CSPAN%3E%3CSTRONG%3E%40escaping%3C%2FSTRONG%3E%3C%2FSPAN%3E%20(%3CSPAN%3EBool%3C%2FSPAN%3E%2C%20%3CSPAN%3EBool%3C%2FSPAN%3E)%20-%26gt%3B%20%3CSPAN%3EVoid%3C%2FSPAN%3E)%20%7B%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3Edesfire.authenticate(withCardKeyNo%3A%20%3CSPAN%3E0%3C%2FSPAN%3E%2C%20withAuthenticationType%3A%20.%3CSPAN%3Enative%3C%2FSPAN%3E%2C%20withAuthKeyType%3A%20.THREEDES%2C%20withCommandSetForAuth%3A%20.Native%2C%20withAuthkey%3A%20%3CSPAN%3EthreeDESZero%3C%2FSPAN%3E)%20%7B%20firstAuth3D%20%3CSPAN%3E%3CSTRONG%3Ein%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Eos_log%3C%2FSPAN%3E(%3CSPAN%3E%22Internal%20Log%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E-%20%25%7Bpublic%7D%40%22%3C%2FSPAN%3E%2C%20%3CSPAN%3Elog%3C%2FSPAN%3E%3A%20OSLog(subsystem%3A%20%3CSPAN%3EBundle%3C%2FSPAN%3E.%3CSPAN%3Emain%3C%2FSPAN%3E.%3CSPAN%3EbundleIdentifier%3C%2FSPAN%3E!%2C%20category%3A%20%3CSPAN%3E%22DemoLog%22%3C%2FSPAN%3E)%2C%20%3CSPAN%3Etype%3C%2FSPAN%3E%3A%20.%3CSPAN%3Eerror%3C%2FSPAN%3E%2C%20%3CSPAN%3E%22firstAuth3D%3A%20%3C%2FSPAN%3E%5C(firstAuth3D)%3CSPAN%3E%22%3C%2FSPAN%3E)%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3Edesfire.changeKey(withCardKeyNo%3A%20%3CSPAN%3E0%3C%2FSPAN%3E%2C%20withAuthKeyType%3A%20.AES128%2C%20withFromKey%3A%20%3CSPAN%3EthreeDESZero%3C%2FSPAN%3E%2C%20withToKey%3A%20%3CSPAN%3EaesZero%3C%2FSPAN%3E)%20%7B%20firstChangeAES%20%3CSPAN%3E%3CSTRONG%3Ein%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Eos_log%3C%2FSPAN%3E(%3CSPAN%3E%22Internal%20Log%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E-%20%25%7Bpublic%7D%40%22%3C%2FSPAN%3E%2C%20%3CSPAN%3Elog%3C%2FSPAN%3E%3A%20OSLog(subsystem%3A%20%3CSPAN%3EBundle%3C%2FSPAN%3E.%3CSPAN%3Emain%3C%2FSPAN%3E.%3CSPAN%3EbundleIdentifier%3C%2FSPAN%3E!%2C%20category%3A%20%3CSPAN%3E%22DemoLog%22%3C%2FSPAN%3E)%2C%20%3CSPAN%3Etype%3C%2FSPAN%3E%3A%20.%3CSPAN%3Eerror%3C%2FSPAN%3E%2C%20%3CSPAN%3E%22firstChangeAES%3A%20%3C%2FSPAN%3E%5C(firstChangeAES)%3CSPAN%3E%22%3C%2FSPAN%3E)%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3Edesfire.authenticate(withCardKeyNo%3A%20%3CSPAN%3E0%3C%2FSPAN%3E%2C%20withAuthenticationType%3A%20.AES%2C%20withAuthKeyType%3A%20.AES128%2C%20withCommandSetForAuth%3A%20.Native%2C%20withAuthkey%3A%20%3CSPAN%3EaesZero%3C%2FSPAN%3E)%20%7B%20firstAuthAES%20%3CSPAN%3E%3CSTRONG%3Ein%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Eos_log%3C%2FSPAN%3E(%3CSPAN%3E%22Internal%20Log%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E-%20%25%7Bpublic%7D%40%22%3C%2FSPAN%3E%2C%20%3CSPAN%3Elog%3C%2FSPAN%3E%3A%20OSLog(subsystem%3A%20%3CSPAN%3EBundle%3C%2FSPAN%3E.%3CSPAN%3Emain%3C%2FSPAN%3E.%3CSPAN%3EbundleIdentifier%3C%2FSPAN%3E!%2C%20category%3A%20%3CSPAN%3E%22DemoLog%22%3C%2FSPAN%3E)%2C%20%3CSPAN%3Etype%3C%2FSPAN%3E%3A%20.%3CSPAN%3Eerror%3C%2FSPAN%3E%2C%20%3CSPAN%3E%22firstAuthAES%3A%20%3C%2FSPAN%3E%5C(firstAuthAES)%3CSPAN%3E%22%3C%2FSPAN%3E)%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3Edesfire.changeKey(withCardKeyNo%3A%20%3CSPAN%3E0%3C%2FSPAN%3E%2C%20withAuthKeyType%3A%20.THREEDES%2C%20withFromKey%3A%20%3CSPAN%3EaesZero%3C%2FSPAN%3E%2C%20withToKey%3A%20%3CSPAN%3EthreeDESZero%3C%2FSPAN%3E)%20%7B%20lastChange3D%20%3CSPAN%3E%3CSTRONG%3Ein%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Eos_log%3C%2FSPAN%3E(%3CSPAN%3E%22Internal%20Log%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E-%20%25%7Bpublic%7D%40%22%3C%2FSPAN%3E%2C%20%3CSPAN%3Elog%3C%2FSPAN%3E%3A%20OSLog(subsystem%3A%20%3CSPAN%3EBundle%3C%2FSPAN%3E.%3CSPAN%3Emain%3C%2FSPAN%3E.%3CSPAN%3EbundleIdentifier%3C%2FSPAN%3E!%2C%20category%3A%20%3CSPAN%3E%22DemoLog%22%3C%2FSPAN%3E)%2C%20%3CSPAN%3Etype%3C%2FSPAN%3E%3A%20.%3CSPAN%3Eerror%3C%2FSPAN%3E%2C%20%3CSPAN%3E%22lastChange3D%3A%20%3C%2FSPAN%3E%5C(lastChange3D)%3CSPAN%3E%22%3C%2FSPAN%3E)%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3Edesfire.authenticate(withCardKeyNo%3A%20%3CSPAN%3E0%3C%2FSPAN%3E%2C%20withAuthenticationType%3A%20.%3CSPAN%3Enative%3C%2FSPAN%3E%2C%20withAuthKeyType%3A%20.THREEDES%2C%20withCommandSetForAuth%3A%20.Native%2C%20withAuthkey%3A%20%3CSPAN%3EthreeDESZero%3C%2FSPAN%3E)%20%7B%20lastAuth3D%20%3CSPAN%3E%3CSTRONG%3Ein%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Eos_log%3C%2FSPAN%3E(%3CSPAN%3E%22Internal%20Log%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E-%20%25%7Bpublic%7D%40%22%3C%2FSPAN%3E%2C%20%3CSPAN%3Elog%3C%2FSPAN%3E%3A%20OSLog(subsystem%3A%20%3CSPAN%3EBundle%3C%2FSPAN%3E.%3CSPAN%3Emain%3C%2FSPAN%3E.%3CSPAN%3EbundleIdentifier%3C%2FSPAN%3E!%2C%20category%3A%20%3CSPAN%3E%22DemoLog%22%3C%2FSPAN%3E)%2C%20%3CSPAN%3Etype%3C%2FSPAN%3E%3A%20.%3CSPAN%3Eerror%3C%2FSPAN%3E%2C%20%3CSPAN%3E%22lastAuth3D%3A%20%3C%2FSPAN%3E%5C(lastAuth3D)%3CSPAN%3E%22%3C%2FSPAN%3E)%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%7D%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%7D%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%7D%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%7D%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%7D%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3EThe%20first%20authentication%20with%203DES%2C%20the%20change%20to%20aes%20key%20and%20then%20the%20authentication%20with%20Aes%20key%20works%20perfectly.%3C%2FP%3E%3CP%3EThen%20when%20I%20tried%20to%20change%20to%20old%203DES%20key%20I%20received%20a%20error%20and%20now%20the%20card%20is%20still%20%22authenticated%22%20with%20AES%20key%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EFor%20completism%2C%20the%20keys%20are%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSTRONG%3Eprivate%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%3E%3CSTRONG%3Elet%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%3EaesZero%3C%2FSPAN%3E%3CSPAN%3E%20%3D%20%3C%2FSPAN%3EData%3CSPAN%3E(%3C%2FSPAN%3Erepeating%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E0x00%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3Ecount%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E16%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSTRONG%3Eprivate%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%3E%3CSTRONG%3Elet%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%3EthreeDESZero%3C%2FSPAN%3E%3CSPAN%3E%20%3D%20%3C%2FSPAN%3EData%3CSPAN%3E(%3C%2FSPAN%3Erepeating%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E0x00%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3Ecount%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E24%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EI%20received%20this%20error%20from%20SDK%20logs%20(see%20the%20attachments).%3C%2FP%3E%3CP%3E%3CSTRONG%3EException%20Caught%3A%20com.nxp.nfclib.exceptions.PICCException%3A%20Integrity%20Error%20SW2%20%3D%2030%3C%2FSTRONG%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EBefore%20doing%20others%20tests%2C%20I%20hope%20to%20know%20from%20you%20if%20my%20implementation%20is%20working%20as%20expected%20%26nbsp%3Band%20what%20that%20error%20means.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThanks%20in%20advance%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2324491%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ECode%20examples%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EExample%20code%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2336211%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5BTapLink%20SDK%20iOS%5D%20Authentication%20with%20AES%20128%20not%20working%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2336211%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3EHello%20sir%2C%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3EThank%20you%20for%20sharing%20your%20code.%20My%20apologies%20for%20the%20delay.%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3EI%20believe%20the%20root%20cause%20is%20very%20likely%20to%20be%20due%20to%20the%20threeDESZero%20odd%20parity%20per%20byte.%20After%20authenticating%20with%20an%20AES%20key%20and%2C%20the%20changing%20to%20the%203DES%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3EYou%20could%20quickly%20test%20this%20instead%20of%20using%20a%200x00%2C%20try%20a%20non-zero%20key%20to%20ensure%20odd%20parity%20byte.%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3EIf%20this%20still%20fails%2C%20please%20try%20changing%20from%203DES%20-%26gt%3B%20AES%20-%26gt%3B%203DES%20in%20two%20separated%20sessions%20but%2C%20please%20try%20using%20non-zero%20keys.%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3EI%20hope%20this%20helps%3C%2FP%3E%3C%2FLINGO-BODY%3E
