[TAPLink SDK IOS] Error: ApplicationId [appId] must be 3 bytes long
3,612件の閲覧回数
SamanaGG
Hello, I have read your guide UG10045 and I have successfully integrated the Taplink iOS SDK in a demo Project.
In section 5.2 you describe the selection and change of applications.
I am interested because I want to use EV3 Card features.
So I tried to do a creation and selection of a specific application, with appId = [0x11, 022, 0x33]
As reference, I do the same operations on a Android App using the TApLink SDK Android; in Android enviroment everything goes smoothly.
I report my code
       //var desfire = TLLibraryManager.shared().getDESFireEV3Instance()
        desfire.selectApplicationPICCP1 { selectedPICCOK in
            let text = "Selected PICC: \(selectedPICCOK)"
            os_log("Internal Log  - %{public}@", log: OSLog(subsystem: Bundle.main.bundleIdentifier!, category: "DemoLog"), type: .error, text)
            let settings = CreateAppSettingsModel()
            settings.appKeySettingChangable = true
            settings.masterKeyInterchangable = true
            settings.authRequiredForFileManagement = false
            settings.authRequiredForFileConfiguration = false
            settings.keyType = .AES128
            desfire.createApplication(withAppID: self.appId, withNumberOfBytes: 16, withAppSettings: settings) { createdOK in
                let text = "CREATED Application: \(createdOK)"
                desfire.selectApplication(withAppID: self.appId, withNumberOfBytes: 16) { selectedOK in
                    let text = "SELECTED Application: \(createdOK)"
I initialize the appId in this way:
private let appId: Int32 = 0x112233
That seems to generate strange errors; I received this from library:
com.nxp.nfclib.exceptions.UsageException: Application ID [appId] must be 3 bytes
but the appId is indeed 3 bytes!
I attach complete logs.
I hope you can help me to resolve this.
ラベル(2)
5 返答(返信)
3,590件の閲覧回数
Fabian_R
Hello sir,
I would like to try a couple of things.
1.- After creating the application using iOS, please test if the application can be correctly selected on Android.
2.- It would also be quite helpful to check if the application ID in desfire.selectApplication(), but the endianness as LSB instead of MSB.
If both of these recommendations aren't working, please be sure you are using the latest TapLinx version for iOS and share your setup as well.
One more thing, are you able to select the PICC as application 0x000000 in iOS?
Fabian
3,521件の閲覧回数
SamanaGG
Question: Can the problem be SDK requiring appId to be a Int32 type?
If i have a Int32 value, when I convert it to a bytes array, I obtain a 4-bytes array.
Can you check if on SDK iOS 3.0.0 this thing is considered inside 'createApplication' method?
P.s: when I try to select a application different from 0x000000, I see from SDK logs:
Command sent to card : 5A112233
so, for what I can see, it seems that 'selectApplication' is instead working as expected.
Thank you in advance
1,258件の閲覧回数
Fabian_R
Hello, Sorry for the delay answering.
Could you please try the following:
let piccAid = Data([0x00, 0x00, 0x00])
Then, you need to pass the Data to the actual Select command.
Fabian
3,560件の閲覧回数
SamanaGG
After reading your reply, I also tried appId = 0x332211, but nothing
The appId I used in createApplication and selectedApplication is the same.
I confirm I have the latest latest TapLinx version for iOS, 3.0.0
I confirm I am able to select the PICC as application 0x000000 in iOS, using selectApplication method
I see this interesting post: https://community.nxp.com/t5/TapLinx-SDK-TagWriter-and/iOS-SDK-Creating-an-application-fails-because...
Can that help you?
After reading that post, I then tried to set 'numberOfBytes" to value  "3" instead of "16" and I made this discovery:
'numberOfBytes" set to value  "16" --> Library return
"com.nxp.nfclib.exceptions.UsageException: Application ID [appId] must be 3 bytes"
'numberOfBytes" set to value different to "16" --> Library return "com.nxp.nfclib.exceptions.PICCException: Parameter Error SW2 = -98"
Does It make any sense to you?
P.s.: I see there is a method "getApplicationIDs"
 * Returns the application identifiers of all active applications on a PICC.
 * @param completion returns true or false
- (void)getApplicationIDsOnCompletion:(completionBlockWithResult)completion;
I think that it will great if in future releases if this method does what it is described to do instead of returning a boolean
I also tried to call this method before the createApplication method; nothing changes.
3,552件の閲覧回数
SamanaGG
P.s.: Referring to LSB endianess:
I tried different ways to convert a 3-bytes array into Int32, without success
Do you know if there is a method "createApplication"\"selectedApplication" that accept directly a Uint8 array, instead of Int32 type?
Or maybe, can you give me an example of conversion that I have to use to make this cast work with mentioned methods?
%3CLINGO-SUB%20id%3D%22lingo-sub-2324496%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%5BTAPLink%20SDK%20IOS%5D%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20ID%20%5BappId%5D%20%E3%81%AF%203%20%E3%83%90%E3%82%A4%E3%83%88%E3%81%AE%E9%95%B7%E3%81%95%E3%81%A7%E3%81%82%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2324496%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82%E3%82%AC%E3%82%A4%E3%83%89%20UG10045%20%E3%82%92%E8%AA%AD%E3%81%BF%E3%80%81Taplink%20iOS%20SDK%20%E3%82%92%E3%83%87%E3%83%A2%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AB%E6%AD%A3%E5%B8%B8%E3%81%AB%E7%B5%B1%E5%90%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%205.2%20%E3%81%A7%E3%81%AF%E3%80%81%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E9%81%B8%E6%8A%9E%E3%81%A8%E5%A4%89%E6%9B%B4%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EEV3%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AE%E6%A9%9F%E8%83%BD%E3%82%92%E4%BD%BF%E3%81%84%E3%81%9F%E3%81%84%E3%81%AE%E3%81%A7%E8%88%88%E5%91%B3%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%9D%E3%81%93%E3%81%A7%E3%80%81appId%20%3D%20%5B0x11%2C%20022%2C%200x33%5D%20%E3%81%AE%E7%89%B9%E5%AE%9A%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E4%BD%9C%E6%88%90%E3%81%A8%E9%81%B8%E6%8A%9E%E3%82%92%E8%A9%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E5%8F%82%E8%80%83%E3%81%BE%E3%81%A7%E3%81%AB%E3%80%81TApLink%20SDK%20Android%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20Android%20%E3%82%A2%E3%83%97%E3%83%AA%E3%81%A7%E5%90%8C%E3%81%98%E6%93%8D%E4%BD%9C%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82Android%20%E7%92%B0%E5%A2%83%E3%81%A7%E3%81%AF%E3%81%99%E3%81%B9%E3%81%A6%E3%81%8C%E3%82%B9%E3%83%A0%E3%83%BC%E3%82%BA%E3%81%AB%E9%80%B2%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E7%A7%81%E3%81%AF%E8%87%AA%E5%88%86%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E5%A0%B1%E5%91%8A%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CPRE%20translate%3D%22no%22%3E%3CSPAN%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%2F%2Fvar%20desfire%20%3D%20TLLibraryManager.shared().getDESFireEV3Instance()%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Edesfire%3C%2FSPAN%3E.selectApplicationPICCP1%20%7B%20selectedPICCOK%20%3CSPAN%3E%3CSTRONG%3Ein%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%3CSTRONG%3Elet%3C%2FSTRONG%3E%3C%2FSPAN%3E%20text%20%3D%20%3CSPAN%3E%22Selected%20PICC%3A%20%3C%2FSPAN%3E%5C(selectedPICCOK)%3CSPAN%3E%22%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Eos_log%3C%2FSPAN%3E(%3CSPAN%3E%22Internal%20Log%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E-%20%25%7Bpublic%7D%40%22%3C%2FSPAN%3E%2C%20%3CSPAN%3Elog%3C%2FSPAN%3E%3A%20OSLog(subsystem%3A%20%3CSPAN%3EBundle%3C%2FSPAN%3E.%3CSPAN%3Emain%3C%2FSPAN%3E.%3CSPAN%3EbundleIdentifier%3C%2FSPAN%3E!%2C%20category%3A%20%3CSPAN%3E%22DemoLog%22%3C%2FSPAN%3E)%2C%20%3CSPAN%3Etype%3C%2FSPAN%3E%3A%20.%3CSPAN%3Eerror%3C%2FSPAN%3E%2C%20text)%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%3CSTRONG%3Elet%3C%2FSTRONG%3E%3C%2FSPAN%3E%20settings%20%3D%20CreateAppSettingsModel()%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3Esettings.appKeySettingChangable%20%3D%20%3CSPAN%3E%3CSTRONG%3Etrue%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3Esettings.masterKeyInterchangable%20%3D%20%3CSPAN%3E%3CSTRONG%3Etrue%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3Esettings.authRequiredForFileManagement%20%3D%20%3CSPAN%3E%3CSTRONG%3Efalse%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3Esettings.authRequiredForFileConfiguration%20%3D%20%3CSPAN%3E%3CSTRONG%3Efalse%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3Esettings.keyType%20%3D%20.AES128%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Edesfire%3C%2FSPAN%3E.createApplication(withAppID%3A%20%3CSPAN%3E%3CSTRONG%3Eself%3C%2FSTRONG%3E%3C%2FSPAN%3E.%3CSPAN%3EappId%3C%2FSPAN%3E%2C%20withNumberOfBytes%3A%20%3CSPAN%3E16%3C%2FSPAN%3E%2C%20withAppSettings%3A%20settings)%20%7B%20createdOK%20%3CSPAN%3E%3CSTRONG%3Ein%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%3CSTRONG%3Elet%3C%2FSTRONG%3E%3C%2FSPAN%3E%20text%20%3D%20%3CSPAN%3E%22CREATED%20Application%3A%20%3C%2FSPAN%3E%5C(createdOK)%3CSPAN%3E%22%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Eos_log%3C%2FSPAN%3E(%3CSPAN%3E%22Internal%20Log%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E-%20%25%7Bpublic%7D%40%22%3C%2FSPAN%3E%2C%20%3CSPAN%3Elog%3C%2FSPAN%3E%3A%20OSLog(subsystem%3A%20%3CSPAN%3EBundle%3C%2FSPAN%3E.%3CSPAN%3Emain%3C%2FSPAN%3E.%3CSPAN%3EbundleIdentifier%3C%2FSPAN%3E!%2C%20category%3A%20%3CSPAN%3E%22DemoLog%22%3C%2FSPAN%3E)%2C%20%3CSPAN%3Etype%3C%2FSPAN%3E%3A%20.%3CSPAN%3Eerror%3C%2FSPAN%3E%2C%20text)%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Edesfire%3C%2FSPAN%3E.selectApplication(withAppID%3A%20%3CSPAN%3E%3CSTRONG%3Eself%3C%2FSTRONG%3E%3C%2FSPAN%3E.%3CSPAN%3EappId%3C%2FSPAN%3E%2C%20withNumberOfBytes%3A%20%3CSPAN%3E16%3C%2FSPAN%3E)%20%7B%20selectedOK%20%3CSPAN%3E%3CSTRONG%3Ein%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%3CSTRONG%3Elet%3C%2FSTRONG%3E%3C%2FSPAN%3E%20text%20%3D%20%3CSPAN%3E%22SELECTED%20Application%3A%20%3C%2FSPAN%3E%5C(createdOK)%3CSPAN%3E%22%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Eos_log%3C%2FSPAN%3E(%3CSPAN%3E%22Internal%20Log%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E-%20%25%7Bpublic%7D%40%22%3C%2FSPAN%3E%2C%20%3CSPAN%3Elog%3C%2FSPAN%3E%3A%20OSLog(subsystem%3A%20%3CSPAN%3EBundle%3C%2FSPAN%3E.%3CSPAN%3Emain%3C%2FSPAN%3E.%3CSPAN%3EbundleIdentifier%3C%2FSPAN%3E!%2C%20category%3A%20%3CSPAN%3E%22DemoLog%22%3C%2FSPAN%3E)%2C%20%3CSPAN%3Etype%3C%2FSPAN%3E%3A%20.%3CSPAN%3Eerror%3C%2FSPAN%3E%2C%20text)%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E7%A7%81%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%ABappId%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E3%83%97%E3%83%A9%E3%82%A4%E3%83%99%E3%83%BC%E3%83%88%3C%2FSTRONG%3E%3CSTRONG%3Elet%3C%2FSTRONG%3E%20%3CSPAN%3EappId%3C%2FSPAN%3E%20%3CSPAN%3E%3A%3C%2FSPAN%3E%20%3CSPAN%3EInt32%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E0x112233%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E5%A5%87%E5%A6%99%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%8B%E3%82%89%E6%AC%A1%E3%81%AE%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E5%8F%97%E3%81%91%E5%8F%96%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Ecom.nxp.nfclib.exceptions.UsageException%3A%20%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3ID%20%5BappId%5D%20%E3%81%AF3%E3%83%90%E3%82%A4%E3%83%88%E3%81%A7%E3%81%82%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81appId%20%E3%81%AF%E5%AE%9F%E9%9A%9B%E3%81%AB%E3%81%AF%203%20%E3%83%90%E3%82%A4%E3%83%88%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%AE%8C%E5%85%A8%E3%81%AA%E3%83%AD%E3%82%B0%E3%82%92%E6%B7%BB%E4%BB%98%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AB%E3%81%94%E5%8D%94%E5%8A%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2324496%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E3%82%B3%E3%83%BC%E3%83%89%E3%83%BB%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%20%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3E%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%83%BB%E3%82%B3%E3%83%BC%E3%83%89%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2324549%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5BTAPLink%20SDK%20IOS%5D%20Error%3A%20ApplicationId%20%5BappId%5D%20must%20be%203%20bytes%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2324549%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3CBR%20%2F%3E%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%9F%E3%81%84%E3%81%93%E3%81%A8%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E1.-iOS%E3%81%A7%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%9C%E6%88%90%E5%BE%8C%E3%80%81Android%E3%81%A7%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E9%81%B8%E6%8A%9E%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%8B%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E2.-%20desfire.selectApplication()%20%E3%81%A7%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3ID%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82%E9%9D%9E%E5%B8%B8%E3%81%AB%E5%BD%B9%E7%AB%8B%E3%81%A1%E3%81%BE%E3%81%99%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E3%82%A8%E3%83%B3%E3%83%87%E3%82%A3%E3%82%A2%E3%83%B3%E3%81%A7%E3%81%AF%20MSB%20%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%20LSB%20%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%93%E3%82%8C%E3%82%89%E4%B8%A1%E6%96%B9%E3%81%AE%E6%8E%A8%E5%A5%A8%E4%BA%8B%E9%A0%85%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81iOS%20%E7%94%A8%E3%81%AE%E6%9C%80%E6%96%B0%E3%81%AE%20TapLinx%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%80%81%E8%A8%AD%E5%AE%9A%E3%82%82%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%E3%82%82%E3%81%86%201%20%E3%81%A4%E3%80%81iOS%20%E3%81%A7%20PICC%20%E3%82%92%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%200x000000%20%E3%81%A8%E3%81%97%E3%81%A6%E9%81%B8%E6%8A%9E%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2324866%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5BTAPLink%20SDK%20IOS%5D%20Error%3A%20ApplicationId%20%5BappId%5D%20must%20be%203%20bytes%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2324866%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EPs%3A%20LSB%20%E3%82%A8%E3%83%B3%E3%83%87%E3%82%A3%E3%82%A2%E3%83%B3%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%3A%3C%2FP%3E%3CP%3E3%E3%83%90%E3%82%A4%E3%83%88%E9%85%8D%E5%88%97%E3%82%92Int32%E3%81%AB%E5%A4%89%E6%8F%9B%E3%81%99%E3%82%8B%E3%81%95%E3%81%BE%E3%81%96%E3%81%BE%E3%81%AA%E6%96%B9%E6%B3%95%E3%82%92%E8%A9%A6%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EInt32%20%E5%9E%8B%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81Uint8%20%E9%85%8D%E5%88%97%E3%82%92%E7%9B%B4%E6%8E%A5%E5%8F%97%E3%81%91%E5%85%A5%E3%82%8C%E3%82%8B%E6%96%B9%E6%B3%95%20%22createApplication%22%5C%22selectedApplication%22%20%E3%81%8C%E3%81%82%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%81%94%E5%AD%98%E7%9F%A5%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8B%E3%81%84%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%88%E3%82%92%E5%89%8D%E8%BF%B0%E3%81%AE%E6%96%B9%E6%B3%95%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%95%E3%81%9B%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E5%A4%89%E6%8F%9B%E3%81%AE%E4%BE%8B%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2324841%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5BTAPLink%20SDK%20IOS%5D%20Error%3A%20ApplicationId%20%5BappId%5D%20must%20be%203%20bytes%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2324841%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E8%BF%94%E4%BF%A1%E3%82%92%E8%AA%AD%E3%82%93%E3%81%A0%E5%BE%8C%E3%80%81%E7%A7%81%E3%82%82appId%20%3D%200x332211%E3%82%92%E8%A9%A6%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E4%BD%95%E3%82%82%E8%B5%B7%E3%81%93%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EcreateApplication%20%E3%81%A8%20selectedApplication%20%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%20appId%20%E3%81%AF%E5%90%8C%E3%81%98%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3EiOS%E7%94%A8%E3%81%AE%E6%9C%80%E6%96%B0%E3%81%AETapLinx%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B33.0.0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EiOS%E3%81%A7selectApplication%E3%83%A1%E3%82%BD%E3%83%83%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6PICC%E3%82%92%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B30x000000%E3%81%A8%E3%81%97%E3%81%A6%E9%81%B8%E6%8A%9E%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E8%88%88%E5%91%B3%E6%B7%B1%E3%81%84%E6%8A%95%E7%A8%BF%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%BE%E3%81%97%E3%81%9F%3A%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FTapLinx-SDK-TagWriter-and%2FiOS-SDK-Creating-an-application-fails-because-of-appId-not-being%2Fm-p%2F2089418%22%20target%3D%22_self%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FTapLinx-SDK-TagWriter-and%2FiOS-SDK-Creating-an-application-fails-because-of-appId-not-being%2Fmp%2F2089418%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%81%AF%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A1%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%9D%E3%81%AE%E6%8A%95%E7%A8%BF%E3%82%92%E8%AA%AD%E3%82%93%E3%81%A0%E5%BE%8C%E3%80%81%E7%A7%81%E3%81%AF%E3%80%8CnumberOfBytes%E3%80%8D%E3%81%AE%E5%80%A4%E3%82%92%E3%80%8C16%E3%80%8D%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%8C3%E3%80%8D%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E6%AC%A1%E3%81%AE%E3%81%93%E3%81%A8%E3%82%92%E7%99%BA%E8%A6%8B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E'numberOfBytes%22%20%E3%81%AE%E5%80%A4%E3%81%8C%20%2216%22%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20--%26gt%3B%20%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%8C%E8%BF%94%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E3%80%8Ccom.nxp.nfclib.exceptions.UsageException%3A%20%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3ID%20%5BappId%5D%20%E3%81%AF3%E3%83%90%E3%82%A4%E3%83%88%E3%81%A7%E3%81%82%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3C%2FSTRONG%3E%E3%80%8D%3C%2FP%3E%3CP%3E'numberOfBytes%22%20%E3%81%8C%20%2216%22%20%E3%81%A8%E3%81%AF%E7%95%B0%E3%81%AA%E3%82%8B%E5%80%A4%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20--%26gt%3B%20%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%AF%20%22%20%3CSTRONG%3Ecom.nxp.nfclib.exceptions.PICCException%3A%20%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%20%E3%82%A8%E3%83%A9%E3%83%BC%20SW2%20%3D%20-98%3C%2FSTRONG%3E%20%22%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AB%E3%81%A8%E3%81%A3%E3%81%A6%E6%84%8F%E5%91%B3%E3%81%8C%E5%88%86%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3EPs%3A%20%E3%80%8CgetApplicationIDs%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86%E6%96%B9%E6%B3%95%E3%81%8C%E3%81%82%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%3C%2FP%3E%3CPRE%20translate%3D%22no%22%3E**%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E*%3C%2FSPAN%3E%20Returns%20the%20application%20identifiers%20of%20all%20active%20applications%20on%20a%20PICC.%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E*%3C%2FSPAN%3E%20%3CSPAN%3E%3CSTRONG%3E%40param%20%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%3Ecompletion%3C%2FSPAN%3E%20returns%20true%20or%20false%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E*%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E*%2F%3CBR%20%2F%3E%3CBR%20%2F%3E-%20(%3CSPAN%3E%3CSTRONG%3Evoid%3C%2FSTRONG%3E%3C%2FSPAN%3E)getApplicationIDsOnCompletion%3A(completionBlockWithResult)completion%3B%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E5%B0%86%E6%9D%A5%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%A7%E3%81%93%E3%81%AE%E3%83%A1%E3%82%BD%E3%83%83%E3%83%89%E3%81%8C%E3%83%96%E3%83%BC%E3%83%AB%E5%80%A4%E3%82%92%E8%BF%94%E3%81%99%E3%81%AE%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81%E8%AA%AC%E6%98%8E%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%AE%E5%8B%95%E4%BD%9C%E3%82%92%E3%81%97%E3%81%A6%E3%81%8F%E3%82%8C%E3%82%8B%E3%81%A8%E7%B4%A0%E6%99%B4%E3%82%89%E3%81%97%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81createApplication%20%E6%96%B9%E6%B3%95%E3%81%AE%E5%89%8D%E3%81%AB%E3%81%93%E3%81%AE%E6%96%B9%E6%B3%95%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E4%BD%95%E3%82%82%E5%A4%89%E3%82%8F%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2325521%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5BTAPLink%20SDK%20IOS%5D%20Error%3A%20ApplicationId%20%5BappId%5D%20must%20be%203%20bytes%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2325521%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%B3%AA%E5%95%8F%3A%20SDK%20%E3%81%8C%20appId%20%E3%82%92%20Int32%20%E5%9E%8B%E3%81%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E8%A6%81%E6%B1%82%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EInt32%20%E5%80%A4%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E3%81%9D%E3%82%8C%E3%82%92%E3%83%90%E3%82%A4%E3%83%88%E9%85%8D%E5%88%97%E3%81%AB%E5%A4%89%E6%8F%9B%E3%81%99%E3%82%8B%E3%81%A8%E3%80%814%20%E3%83%90%E3%82%A4%E3%83%88%E3%81%AE%E9%85%8D%E5%88%97%E3%81%8C%E5%BE%97%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ESDK%20iOS%203.0.0%E3%81%A7%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E3%81%93%E3%82%8C%E3%81%AF%20'createApplication'%20%E6%96%B9%E6%B3%95%E5%86%85%E3%81%A7%E8%80%83%E6%85%AE%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EPs%3A%200x000000%20%E4%BB%A5%E5%A4%96%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81SDK%20%E3%83%AD%E3%82%B0%E3%81%AB%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AB%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%9F%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%205A112233%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3ESO%E3%80%81%E7%A7%81%E3%81%8C%E8%A6%8B%E3%82%8B%E9%99%90%E3%82%8A%E3%81%A7%E3%81%AF%E3%80%81%E3%80%8CselectApplication%E3%80%8D%E3%81%AF%E6%9C%9F%E5%BE%85%E3%81%A9%E3%81%8A%E3%82%8A%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2335422%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5BTAPLink%20SDK%20IOS%5D%20Error%3A%20ApplicationId%20%5BappId%5D%20must%20be%203%20bytes%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2335422%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82%E8%BF%94%E4%BF%A1%E3%81%8C%E9%81%85%E3%81%8F%E3%81%AA%E3%82%8A%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%81%93%E3%81%A8%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3Elet%20piccAid%20%3D%20Data(%5B0x00%2C%200x00%2C%200x00%5D)%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E6%AC%A1%E3%81%AB%E3%80%81%E3%81%9D%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E5%AE%9F%E9%9A%9B%E3%81%AESelect%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AB%E6%B8%A1%E3%81%99%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
