t4240 discrete ddr Parameter Settings
muaxi8
t4240 customer board.
How to configure the DDR parameter of the discrete type in ddr.c
Attached is my configuration method, function call
zhangyi11
你电话多少,我现在也在搞ddr,工具还没下下来,想找你要一个,我得电话是18602507364
yipingwang
You could refer to the section "#ifndef CONFIG_SYS_DDR_RAW_TIMING" in board/freescale/p1010rdb/ddr.c to initialize DDR controller with fixed SDRAM registers setting.
Please refer to "/* DDR3 Controller Settings */" section in include/configs/P1010RDB.h to define registers values.
