T4241 Power calculation
1,338件の閲覧回数
Har_ika30
Hi all,
I am using T4241 processor in my design. It has 12 cores, but i will be using only 4 cores.
In datasheet, VID core power mentioned based on 12 cores usage, but i need VID power for only 4 cores usage. I will be putting other cores in power down mode.
Can anyone suggest how to calculate the power for T4241 with 4 cores enabled?
Thankyou
Harika B N V L
1,324件の閲覧回数
yipingwang
There is T4081 part, this has 4 cores. I guess if you require only 4 cores then this is the part number you should be choosing.
https://www.nxp.com/products/processors-and-microcontrollers/power-architecture/qoriq-communication-...
has the link for T4160.pdf
Refer "Table 9. T4081 Power dissipation for rev 2 silicon with Altivec power-gated off1" for power numbers.
