T4240 data rate ratios
3,187 次查看
davidcchung
Why can I not set all the DDR data rate ratios that the reference manual says are supported by the RCW “MEM_PLL_RAT” field bits 10-15?
标记 (4)
2,983 次查看
Saul_Salazar
There is a footnote in the T4240 reference manual that states “Not all ratios are supported due to frequency restrictions. Refer to the hardware specifications for the supported frequencies."
Hope it helps
2,983 次查看
addiyi
Do you try to use QCVS? Or what is your scenario?
Adrian
