T1042d4rdb-64b building process.
Mewan
I have downloaded the source and ppce5500 yocto cache from https://nxp.flexnetoperations.com/control/frse/download?agree=Accept&element=7726177, I installed the source iso first and then the yocto cache, ran the host_prepare.sh, and sourced(fsl_env_setup) with machine t1042d4rdb-64b. I ran the command
$ bitbake fsl-toolchain
Got the error
"the '--set-upstream' option is no longer supported. Please use '--track' or '--set-upstream-to' instead." I update the source/poky/bitbake/lib/bb/fetch2/git.py file to use --set-upstream-to command and reran
$bitbake fsl-toolchain
And now i am getting the error below
"ERROR: Function failed: Fetcher failure: Fetch command failed with exit code 128, output:
fatal: branch 'origin/master' does not exist".
Is there a way to resolve this? I checked the $$ git remote -v
fsl-public git://git.freescale.com/yocto/meta-freescale (fetch)
fsl-public git://git.freescale.com/yocto/meta-freescale (push)
and when i tried openning on chrome, it showed that the site does not exist.
T1042
Oswalag
Oswalag
The git://git.freescale.com repository was replaced by https://github.com/nxp-qoriq
Some recipes may still refer to the old repository so please replace them on the recipes where you are experiencing issues.
Regards.
Mewan
The link  you have provided contains the meta-qoriq repo. I am trying to build the fsl-toolchain or fsl/ls-image-main, on running bitbake-layers show-recipes, it shows that these(fsl-toolchain & fsl-image-main) reference meta-freescale.
I am not able to find this from the link you provided. But i have found https://github.com/Freescale/meta-freescale and this depends on openembeddedcore. I understand that i have to replace the url src of my project (meta-freescale) to the ones still being maintained above, but what branch do I have to use? I am not finding any list of supported devices which lists t1022 or t1042.
Oswalag
You can review as an option dunfell branch, please take a look in the links below:
https://github.com/nxp-qoriq/yocto-sdk/tree/dunfell
https://github.com/Freescale/meta-freescale/tree/dunfell?tab=readme-ov-file
Mewan
I fetched the yocto sdk dunfell branch and updated the manifest file to use the freescale git source instead of the codeaurora source. Then I updated the src_url in the layers as well and removed nativesdk-cst and I finally had a successful build.
Thanks for the assistance.
%3CLINGO-SUB%20id%3D%22lingo-sub-2011032%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ET1042d4rdb-64b%20building%20process.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2011032%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20have%20downloaded%20the%20source%20and%20ppce5500%20yocto%20cache%20from%20%3CA%20href%3D%22https%3A%2F%2Fnxp.flexnetoperations.com%2Fcontrol%2Ffrse%2Fdownload%3Fagree%3DAccept%26amp%3Belement%3D7726177%2C%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fnxp.flexnetoperations.com%2Fcontrol%2Ffrse%2Fdownload%3Fagree%3DAccept%26amp%3Belement%3D7726177%2C%3C%2FA%3E%20I%20installed%20the%20source%20iso%20first%20and%20then%20the%20yocto%20cache%2C%20ran%20the%20host_prepare.sh%2C%20and%20sourced(fsl_env_setup)%20with%20machine%20t1042d4rdb-64b.%20I%20ran%20the%20command%3CBR%20%2F%3E%24%20bitbake%20fsl-toolchain%3CBR%20%2F%3EGot%20the%20error%3CBR%20%2F%3E%22the%20'--set-upstream'%20option%20is%20no%20longer%20supported.%20Please%20use%20'--track'%20or%20'--set-upstream-to'%20instead.%22%20I%20update%20the%20source%2Fpoky%2Fbitbake%2Flib%2Fbb%2Ffetch2%2Fgit.py%20file%20to%20use%20--set-upstream-to%20command%20and%20reran%3CBR%20%2F%3E%24bitbake%20fsl-toolchain%3CBR%20%2F%3EAnd%20now%20i%20am%20getting%20the%20error%20below%3CBR%20%2F%3E%22ERROR%3A%20Function%20failed%3A%20Fetcher%20failure%3A%20Fetch%20command%20failed%20with%20exit%20code%20128%2C%20output%3A%3CBR%20%2F%3Efatal%3A%20branch%20'origin%2Fmaster'%20does%20not%20exist%22.%3CBR%20%2F%3E%3CBR%20%2F%3EIs%20there%20a%20way%20to%20resolve%20this%3F%20I%20checked%20the%20%24%24%20git%20remote%20-v%3CBR%20%2F%3Efsl-public%20git%3A%2F%2Fgit.freescale.com%2Fyocto%2Fmeta-freescale%20(fetch)%3CBR%20%2F%3Efsl-public%20git%3A%2F%2Fgit.freescale.com%2Fyocto%2Fmeta-freescale%20(push)%3CBR%20%2F%3Eand%20when%20i%20tried%20openning%20on%20chrome%2C%20it%20showed%20that%20the%20site%20does%20not%20exist.%3CBR%20%2F%3E%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fc-pwmxy87654%2FT1042%2Fpd-p%2FT1042%22%20class%3D%22lia-product-mention%22%20data-product%3D%221765-1%22%20target%3D%22_blank%22%3ET1042%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2014872%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20T1042d4rdb-64b%20building%20process.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2014872%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3CBR%20%2F%3EI%20fetched%20the%20yocto%20sdk%20dunfell%20branch%20and%20updated%20the%20manifest%20file%20to%20use%20the%20freescale%20git%20source%20instead%20of%20the%20codeaurora%20source.%20Then%20I%20updated%20the%20src_url%20in%20the%20layers%20as%20well%20and%20removed%20nativesdk-cst%20and%20I%20finally%20had%20a%20successful%20build.%3CBR%20%2F%3E%3CBR%20%2F%3EThanks%20for%20the%20assistance.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2013142%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20T1042d4rdb-64b%20building%20process.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2013142%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EYou%20can%20review%20as%20an%20option%20dunfell%20branch%2C%20please%20take%20a%20look%20in%20the%20links%20below%3A%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-qoriq%2Fyocto-sdk%2Ftree%2Fdunfell%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-qoriq%2Fyocto-sdk%2Ftree%2Fdunfell%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FFreescale%2Fmeta-freescale%2Ftree%2Fdunfell%3Ftab%3Dreadme-ov-file%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FFreescale%2Fmeta-freescale%2Ftree%2Fdunfell%3Ftab%3Dreadme-ov-file%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2012594%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20T1042d4rdb-64b%20building%20process.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2012594%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EThe%20link%26nbsp%3B%20you%20have%20provided%20contains%20the%20meta-qoriq%20repo.%20I%20am%20trying%20to%20build%20the%20fsl-toolchain%20or%20fsl%2Fls-image-main%2C%20on%20running%20bitbake-layers%20show-recipes%2C%20it%20shows%20that%20these(fsl-toolchain%20%26amp%3B%20fsl-image-main)%20reference%20meta-freescale.%3CBR%20%2F%3EI%20am%20not%20able%20to%20find%20this%20from%20the%20link%20you%20provided.%20But%20i%20have%20found%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FFreescale%2Fmeta-freescale%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FFreescale%2Fmeta-freescale%3C%2FA%3E%20and%20this%20depends%20on%20openembeddedcore.%20I%20understand%20that%20i%20have%20to%20replace%20the%20url%20src%20of%20my%20project%20(meta-freescale)%20to%20the%20ones%20still%20being%20maintained%20above%2C%20but%20what%20branch%20do%20I%20have%20to%20use%3F%20I%20am%20not%20finding%20any%20list%20of%20supported%20devices%20which%20lists%20t1022%20or%20t1042.%3CBR%20%2F%3E%3CBR%20%2F%3ERegards%3C%2FP%3E%3C%2FLINGO-BODY%3E
