T1024RDB ASLEEP Led is On Always
1,157件の閲覧回数
mehmet2793
Hi Guys,
İ have issue with t1024rdb board, when i powered up the board, ASLEEP led is always on and  no message in console. Then i tried to connect with peedi jtag adapter i failed with "BYPASS check failed" message as you can see. I checked dip switches but all of them is set default state. How can i detect the problem, do you have any clue ?
Thanks.
タグ(1)
1,140件の閲覧回数
Hector_Villarruel
Hello @mehmet2793
Could you please inform us which SDK version are you using?
We will be aware for your kind reply.
BR,
Hector
