T1024 ehernet interface doesn't up
kriptonus
Hi everyone!
I've tried to compile an image for the t1024 based board. For the building I've used a Buildroot tools and fresh kernel 6.1.44. But ethernet interfaces doesn't up although
 ip a
show me a list of interfaces
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop qlen 1000
    link/ether 00:00:00:00:01:00 brd ff:ff:ff:ff:ff:ff
3: eth1: <BROADCAST,MULTICAST> mtu 1500 qdisc noop qlen 1000
    link/ether 00:00:00:00:01:01 brd ff:ff:ff:ff:ff:ff
4: eth2: <BROADCAST,MULTICAST> mtu 1500 qdisc noop qlen 1000
    link/ether 00:00:00:00:01:02 brd ff:ff:ff:ff:ff:ff
5: eth3: <BROADCAST,MULTICAST> mtu 1500 qdisc noop qlen 1000
    link/ether 00:00:00:00:01:03 brd ff:ff:ff:ff:ff:ff
6: tunl0@NONE: <NOARP> mtu 1480 qdisc noop qlen 1000
    link/ipip 0.0.0.0 brd 0.0.0.0
7: sit0@NONE: <NOARP> mtu 1480 qdisc noop qlen 1000
    link/sit 0.0.0.0 brd 0.0.0.0
trying
ip link set dev eth0 up
give me an error
fsl_dpaa_mac ffe4e0000.ethernet eth0: init_phy() failed
During a boot log I can watch this:
mdio_bus 0x0000000ffe4fc000: MDIO device at address 2 is missing.
mdio_bus 0x0000000ffe4fc000: MDIO device at address 6 is missing.
mdio_bus 0x0000000ffe4fd000: MDIO device at address 1 is missing.
mdio_bus 0x0000000ffe4fd000: MDIO device at address 2 is missing.
platform ffe488000.port: Adding to iommu group 15
platform ffe489000.port: Adding to iommu group 16
platform ffe48a000.port: Adding to iommu group 17
platform ffe48b000.port: Adding to iommu group 18
fsl_dpaa_mac ffe4e0000.ethernet: FMan MEMAC
fsl_dpaa_mac ffe4e0000.ethernet: FMan MAC address: 00:00:00:00:01:00
fsl_dpaa_mac ffe4e2000.ethernet: FMan MEMAC
fsl_dpaa_mac ffe4e2000.ethernet: FMan MAC address: 00:00:00:00:01:01
fsl_dpaa_mac ffe4e4000.ethernet: FMan MEMAC
fsl_dpaa_mac ffe4e4000.ethernet: FMan MAC address: 00:00:00:00:01:02
fsl_dpaa_mac ffe4e6000.ethernet: FMan MEMAC
fsl_dpaa_mac ffe4e6000.ethernet: FMan MAC address: 00:00:00:00:01:03
fsl_dpaa_mac ffe4e0000.ethernet eth0: Probed interface eth0
fsl_dpaa_mac ffe4e2000.ethernet eth1: Probed interface eth1
fsl_dpaa_mac ffe4e4000.ethernet eth2: Probed interface eth2
fsl_dpaa_mac ffe4e6000.ethernet eth3: Probed interface eth3
Is it true that the MDIO is not configured correctly?  I use a device tree from kernel source, Uboot has been kept from previous image (kernel version 3.12.27). I've loaded a new rootfs, dtb and uImage into ram and ran from there.
ethtool show me the next:
 ethtool eth0
Settings for eth0:
        Supported ports: [ ]
        Supported link modes:   Not reported
        Supported pause frame use: No
        Supports auto-negotiation: No
        Supported FEC modes: Not reported
        Advertised link modes:  Not reported
        Advertised pause frame use: No
        Advertised auto-negotiation: No
        Advertised FEC modes: Not reported
        Speed: Unknown!
        Duplex: Half
        Port: Twisted Pair
        PHYAD: 0
        Transceiver: internal
        Auto-negotiation: off
        MDI-X: Unknown
        Current message level: 0x00002037 (8247)
                               drv probe link ifdown ifup hw
        Link detected: no
Is there some tricks to use ethernet on T1024?
I tried to compile new image from QorIQ SDK 2.0, but it has a very old tools and stopped with a lot of errors.
Tags (3)
yipingwang
Please modify the dts file arch/powerpc/boot/dts/fsl/t1024rdb.dts according to your custom board. Please modify "reg" values to your real PHY addresses at mdio@fc000  and mdio@fd000.
fman@400000 {
enet0: ethernet@e0000 {
phy-handle = <&xg_aqr105_phy3>;
phy-connection-type = "xgmii";
sleep = <&rcpm 0x80000000>;
enet1: ethernet@e2000 {
sleep = <&rcpm 0x40000000>;
enet2: ethernet@e4000 {
phy-handle = <&rgmii_phy2>;
phy-connection-type = "rgmii";
sleep = <&rcpm 0x20000000>;
enet3: ethernet@e6000 {
phy-handle = <&rgmii_phy1>;
sleep = <&rcpm 0x10000000>;
mdio0: mdio@fc000 {
rgmii_phy1: ethernet-phy@2 {
reg = <0x2>;
rgmii_phy2: ethernet-phy@6 {
reg = <0x6>;
xmdio0: mdio@fd000 {
xg_aqr105_phy3: ethernet-phy@1 {
compatible = "ethernet-phy-ieee802.3-c45";
reg = <0x1>;
sg_2500_aqr105_phy4: ethernet-phy@2 {
reg = <0x2>;
yipingwang
fman@400000 {
mdio0: mdio@fc000 {
reg = <0x2>;
reg = <0x6>;
reg = <0x1>;
reg = <0x2>;
kriptonus
Thanks a lot. I've solved the issue.
%3CLINGO-SUB%20id%3D%22lingo-sub-1980999%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ET1024%20ehernet%20interface%20doesn't%20up%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1980999%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20everyone!%3C%2FP%3E%3CP%3EI've%20tried%20to%20compile%20an%20image%20for%20the%20t1024%20based%20board.%20For%20the%20building%20I've%20used%20a%20Buildroot%20tools%20and%20fresh%20kernel%206.1.44.%20But%20ethernet%20interfaces%20doesn't%20up%20although%3C%2FP%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3E%20ip%20a%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3Eshow%20me%20a%20list%20of%20interfaces%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3E1%3A%20lo%3A%20%3CLOOPBACK%3E%20mtu%2065536%20qdisc%20noqueue%20qlen%201000%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20link%2Floopback%2000%3A00%3A00%3A00%3A00%3A00%20brd%2000%3A00%3A00%3A00%3A00%3A00%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20inet%20127.0.0.1%2F8%20scope%20host%20lo%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20valid_lft%20forever%20preferred_lft%20forever%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20inet6%20%3A%3A1%2F128%20scope%20host%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20valid_lft%20forever%20preferred_lft%20forever%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A2%3A%20eth0%3A%20%3CBROADCAST%3E%20mtu%201500%20qdisc%20noop%20qlen%201000%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20link%2Fether%2000%3A00%3A00%3A00%3A01%3A00%20brd%20ff%3Aff%3Aff%3Aff%3Aff%3Aff%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A3%3A%20eth1%3A%20%3CBROADCAST%3E%20mtu%201500%20qdisc%20noop%20qlen%201000%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20link%2Fether%2000%3A00%3A00%3A00%3A01%3A01%20brd%20ff%3Aff%3Aff%3Aff%3Aff%3Aff%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A4%3A%20eth2%3A%20%3CBROADCAST%3E%20mtu%201500%20qdisc%20noop%20qlen%201000%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20link%2Fether%2000%3A00%3A00%3A00%3A01%3A02%20brd%20ff%3Aff%3Aff%3Aff%3Aff%3Aff%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A5%3A%20eth3%3A%20%3CBROADCAST%3E%20mtu%201500%20qdisc%20noop%20qlen%201000%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20link%2Fether%2000%3A00%3A00%3A00%3A01%3A03%20brd%20ff%3Aff%3Aff%3Aff%3Aff%3Aff%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A6%3A%20tunl0%40NONE%3A%20%3CNOARP%3E%20mtu%201480%20qdisc%20noop%20qlen%201000%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20link%2Fipip%200.0.0.0%20brd%200.0.0.0%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A7%3A%20sit0%40NONE%3A%20%3CNOARP%3E%20mtu%201480%20qdisc%20noop%20qlen%201000%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20link%2Fsit%200.0.0.0%20brd%200.0.0.0%3C%2FNOARP%3E%3C%2FNOARP%3E%3C%2FBROADCAST%3E%3C%2FBROADCAST%3E%3C%2FBROADCAST%3E%3C%2FBROADCAST%3E%3C%2FLOOPBACK%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3Etrying%3C%2FP%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3Eip%20link%20set%20dev%20eth0%20up%20%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3Egive%20me%20an%20error%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3Efsl_dpaa_mac%20ffe4e0000.ethernet%20eth0%3A%20init_phy()%20failed%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3EDuring%20a%20boot%20log%20I%20can%20watch%20this%3A%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3Emdio_bus%200x0000000ffe4fc000%3A%20MDIO%20device%20at%20address%202%20is%20missing.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0Amdio_bus%200x0000000ffe4fc000%3A%20MDIO%20device%20at%20address%206%20is%20missing.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0Amdio_bus%200x0000000ffe4fd000%3A%20MDIO%20device%20at%20address%201%20is%20missing.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0Amdio_bus%200x0000000ffe4fd000%3A%20MDIO%20device%20at%20address%202%20is%20missing.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0Aplatform%20ffe488000.port%3A%20Adding%20to%20iommu%20group%2015%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0Aplatform%20ffe489000.port%3A%20Adding%20to%20iommu%20group%2016%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0Aplatform%20ffe48a000.port%3A%20Adding%20to%20iommu%20group%2017%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0Aplatform%20ffe48b000.port%3A%20Adding%20to%20iommu%20group%2018%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0Afsl_dpaa_mac%20ffe4e0000.ethernet%3A%20FMan%20MEMAC%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0Afsl_dpaa_mac%20ffe4e0000.ethernet%3A%20FMan%20MAC%20address%3A%2000%3A00%3A00%3A00%3A01%3A00%20%20%20%20%20%20%20%20%20%20%20%20%0Afsl_dpaa_mac%20ffe4e2000.ethernet%3A%20FMan%20MEMAC%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0Afsl_dpaa_mac%20ffe4e2000.ethernet%3A%20FMan%20MAC%20address%3A%2000%3A00%3A00%3A00%3A01%3A01%20%20%20%20%20%20%20%20%20%20%20%20%0Afsl_dpaa_mac%20ffe4e4000.ethernet%3A%20FMan%20MEMAC%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0Afsl_dpaa_mac%20ffe4e4000.ethernet%3A%20FMan%20MAC%20address%3A%2000%3A00%3A00%3A00%3A01%3A02%20%20%20%20%20%20%20%20%20%20%20%20%0Afsl_dpaa_mac%20ffe4e6000.ethernet%3A%20FMan%20MEMAC%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0Afsl_dpaa_mac%20ffe4e6000.ethernet%3A%20FMan%20MAC%20address%3A%2000%3A00%3A00%3A00%3A01%3A03%20%20%20%20%20%20%20%20%20%20%20%20%0Afsl_dpaa_mac%20ffe4e0000.ethernet%20eth0%3A%20Probed%20interface%20eth0%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0Afsl_dpaa_mac%20ffe4e2000.ethernet%20eth1%3A%20Probed%20interface%20eth1%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0Afsl_dpaa_mac%20ffe4e4000.ethernet%20eth2%3A%20Probed%20interface%20eth2%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0Afsl_dpaa_mac%20ffe4e6000.ethernet%20eth3%3A%20Probed%20interface%20eth3%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3EIs%20it%20true%20that%20the%20MDIO%20is%20not%20configured%20correctly%3F%26nbsp%3B%20I%20use%20a%20device%20tree%20from%20kernel%20source%2C%20Uboot%20has%20been%20kept%20from%20previous%20image%20(kernel%20version%203.12.27).%20I've%20loaded%20a%20new%20rootfs%2C%20dtb%20and%20uImage%20into%20ram%20and%20ran%20from%20there.%3C%2FP%3E%3CP%3Eethtool%20show%20me%20the%20next%3A%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3E%20ethtool%20eth0%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0ASettings%20for%20eth0%3A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20Supported%20ports%3A%20%5B%20%5D%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20Supported%20link%20modes%3A%20%20%20Not%20reported%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20Supported%20pause%20frame%20use%3A%20No%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20Supports%20auto-negotiation%3A%20No%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20Supported%20FEC%20modes%3A%20Not%20reported%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20Advertised%20link%20modes%3A%20%20Not%20reported%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20Advertised%20pause%20frame%20use%3A%20No%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20Advertised%20auto-negotiation%3A%20No%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20Advertised%20FEC%20modes%3A%20Not%20reported%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20Speed%3A%20Unknown!%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20Duplex%3A%20Half%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20Port%3A%20Twisted%20Pair%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20PHYAD%3A%200%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20Transceiver%3A%20internal%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20Auto-negotiation%3A%20off%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20MDI-X%3A%20Unknown%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20Current%20message%20level%3A%200x00002037%20(8247)%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20drv%20probe%20link%20ifdown%20ifup%20hw%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20Link%20detected%3A%20no%20%20%20%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3EIs%20there%20some%20tricks%20to%20use%20ethernet%20on%20T1024%3F%3C%2FP%3E%3CP%3EI%20tried%20to%20compile%20new%20image%20from%20QorIQ%20SDK%202.0%2C%20but%20it%20has%20a%20very%20old%20tools%20and%20stopped%20with%20a%20lot%20of%20errors.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1980999%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EQorIQ%20T1%20Devices%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1984672%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20T1024%20ehernet%20interface%20doesn't%20up%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1984672%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EThanks%20a%20lot.%20I've%20solved%20the%20issue.%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1983672%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20T1024%20ehernet%20interface%20doesn't%20up%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1983672%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EPlease%20modify%20the%20dts%20file%20arch%2Fpowerpc%2Fboot%2Fdts%2Ffsl%2Ft1024rdb.dts%20according%20to%20your%20custom%20board.%20Please%20modify%20%22reg%22%20values%20to%20your%20real%20PHY%20addresses%20at%26nbsp%3B%3CA%20href%3D%22mailto%3Amdio%40fc000%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Emdio%40fc000%26nbsp%3B%3C%2FA%3E%26nbsp%3Band%26nbsp%3Bmdio%40fd000.%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3Efman%40400000%20%7B%3CBR%20%2F%3Eenet0%3A%20ethernet%40e0000%20%7B%3CBR%20%2F%3Ephy-handle%20%3D%20%26lt%3B%26amp%3Bxg_aqr105_phy3%26gt%3B%3B%3CBR%20%2F%3Ephy-connection-type%20%3D%20%22xgmii%22%3B%3CBR%20%2F%3Esleep%20%3D%20%26lt%3B%26amp%3Brcpm%200x80000000%26gt%3B%3B%3CBR%20%2F%3E%7D%3B%3C%2FP%3E%0A%3CP%3Eenet1%3A%20ethernet%40e2000%20%7B%3CBR%20%2F%3Esleep%20%3D%20%26lt%3B%26amp%3Brcpm%200x40000000%26gt%3B%3B%3CBR%20%2F%3E%7D%3B%3C%2FP%3E%0A%3CP%3Eenet2%3A%20ethernet%40e4000%20%7B%3CBR%20%2F%3Ephy-handle%20%3D%20%26lt%3B%26amp%3Brgmii_phy2%26gt%3B%3B%3CBR%20%2F%3Ephy-connection-type%20%3D%20%22rgmii%22%3B%3CBR%20%2F%3Esleep%20%3D%20%26lt%3B%26amp%3Brcpm%200x20000000%26gt%3B%3B%3CBR%20%2F%3E%7D%3B%3C%2FP%3E%0A%3CP%3Eenet3%3A%20ethernet%40e6000%20%7B%3CBR%20%2F%3Ephy-handle%20%3D%20%26lt%3B%26amp%3Brgmii_phy1%26gt%3B%3B%3CBR%20%2F%3Ephy-connection-type%20%3D%20%22rgmii%22%3B%3CBR%20%2F%3Esleep%20%3D%20%26lt%3B%26amp%3Brcpm%200x10000000%26gt%3B%3B%3CBR%20%2F%3E%7D%3B%3C%2FP%3E%0A%3CP%3Emdio0%3A%20mdio%40fc000%20%7B%3CBR%20%2F%3Ergmii_phy1%3A%20ethernet-phy%402%20%7B%3CBR%20%2F%3Ereg%20%3D%20%26lt%3B0x2%26gt%3B%3B%3CBR%20%2F%3E%7D%3B%3CBR%20%2F%3Ergmii_phy2%3A%20ethernet-phy%406%20%7B%3CBR%20%2F%3Ereg%20%3D%20%26lt%3B0x6%26gt%3B%3B%3CBR%20%2F%3E%7D%3B%3CBR%20%2F%3E%7D%3B%3C%2FP%3E%0A%3CP%3Exmdio0%3A%20mdio%40fd000%20%7B%3CBR%20%2F%3Exg_aqr105_phy3%3A%20ethernet-phy%401%20%7B%3CBR%20%2F%3Ecompatible%20%3D%20%22ethernet-phy-ieee802.3-c45%22%3B%3CBR%20%2F%3Ereg%20%3D%20%26lt%3B0x1%26gt%3B%3B%3CBR%20%2F%3E%7D%3B%3CBR%20%2F%3Esg_2500_aqr105_phy4%3A%20ethernet-phy%402%20%7B%3CBR%20%2F%3Ecompatible%20%3D%20%22ethernet-phy-ieee802.3-c45%22%3B%3CBR%20%2F%3Ereg%20%3D%20%26lt%3B0x2%26gt%3B%3B%3CBR%20%2F%3E%7D%3B%3CBR%20%2F%3E%7D%3B%3CBR%20%2F%3E%7D%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E
