QEMU - Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000004
25,234件の閲覧回数
hosytan
I build T4240rdb-64b with QorIQ-SDK-V2.0-20160527-yocto on Ubuntu Linux 16. LTS 64bit.
This is my output:
~/QorIQ-SDK-V2.0-20160527-yocto$ source ./fsl-setup-env -m t4240rdb-64b
Configuring for t4240rdb-64b ...
~/QorIQ-SDK-V2.0-20160527-yocto/build_t4240rdb-64b was created before.
Back to build project ~/QorIQ-SDK-V2.0-20160527-yocto/build_t4240rdb-64b.
Nothing is changed.
~/QorIQ-SDK-V2.0-20160527-yocto/build_t4240rdb-64b$ bitbake fsl-image-minimal
WARNING: Host distribution "Ubuntu-16.04" has not been validated with this version of the build system; you may possibly experience unexpected failures. It is recommended that you use a tested distribution.
Loading cache: 100% |##########################################################################################################| ETA: 00:00:00
Loaded 6050 entries from dependency cache.
NOTE: Resolving any missing task queue dependencies
Build Configuration:
BB_VERSION = "1.28.0"
BUILD_SYS = "x86_64-linux"
NATIVELSBSTRING = "Ubuntu-16.04"
TARGET_SYS = "powerpc64-fsl-linux"
MACHINE = "t4240rdb-64b"
DISTRO = "fsl-qoriq"
DISTRO_VERSION = "2.0"
TUNE_FEATURES = "m64 fpu-hard e6500 altivec"
TARGET_FPU = "hard"
meta
meta-yocto
meta-yocto-bsp = "HEAD:9a211a4a2c1bfcb292dc97d8dcac149bca9e3f1b"
meta-oe
meta-multimedia
meta-gnome
meta-networking
meta-perl
meta-python
meta-ruby
meta-filesystems
meta-webserver
meta-xfce = "HEAD:dc5634968b270dde250690609f0015f881db81f2"
meta-freescale = "HEAD:7facbdb726e2dda0515e084c2066a4b8dd99c6d2"
meta-freescale-internal = "HEAD:4829293f807e35a1111e79763294fc8b98b97810"
meta-freescale-extra = "HEAD:bee911b027e0480b034674d0ddee3fcb06d2e985"
meta-virtualization = "HEAD:042425c1d98bdd7e44a62789bd03b375045266f5"
meta-java = "HEAD:8b776ac68f9af4596be3824152bcf0bc6b67fa1d"
meta-openstack
meta-openstack-aio-deploy
meta-openstack-compute-deploy
meta-openstack-compute-test-config
meta-openstack-controller-deploy
meta-openstack-controller-test-config
meta-openstack-qemu
meta-openstack-swift-deploy
meta-cloud-services = "HEAD:d8bc0d92d0f741e2ea1e6d3d9bc6b7a091d03cfb"
meta-security = "HEAD:f9367e71f923fc7d2fb600208e2b97535ea41777"
NOTE: Preparing RunQueue
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
NOTE: Tasks Summary: Attempted 1499 tasks of which 1499 didn't need to be rerun and all succeeded.
Summary: There was 1 WARNING message shown.
When I run QEMU with this command:
sudo ~/QorIQ-SDK-V2.0-20160527-yocto/build_t4240rdb-64b/tmp/sysroots/x86_64-linux/usr/bin/qemu-system-ppc64 \
-cpu e5500 -nographic -m 1028 -M ppce500 \
-kernel ~/QorIQ-SDK-V2.0-20160527-yocto/build_t4240rdb-64b/tmp/deploy/images/t4240rdb-64b/uImage \
-initrd ~/QorIQ-SDK-V2.0-20160527-yocto/build_t4240rdb-64b/tmp/deploy/images/t4240rdb-64b/fsl-image-minimal-t4240rdb-64b.ext2.gz \
-append "root=/dev/ram rw console=ttyS0,115200 \
ip=26.26.26.2::26.26.26.1:255.255.255.0 mem=1028M" -serial tcp::4444,server,telnet -net nic,model=e1000 \
-net tap,ifname=tap0,script=no,downscript=no
I cannot boot the system, this is output when it boot:
~/QorIQ-SDK-V2.0-20160527-yocto/build_t4240rdb-64b$ telnet 26.26.26.1 4444
Trying 26.26.26.1...
Connected to 26.26.26.1.
Escape character is '^]'.
Using QEMU e500 machine description
MMU: Supported page sizes
4 KB as direct
4096 KB as direct
16384 KB as direct
65536 KB as direct
262144 KB as direct
1048576 KB as direct
MMU: Book3E HW tablewalk not supported
Found initrd at 0xc000000004000000:0xc000000004423e3b
bootconsole [udbg0] enabled
CPU maps initialized for 1 thread per core
Starting Linux PPC64 #1 SMP Sun Jan 8 12:42:09 ICT 2017
ppc64_pft_size = 0x0
phys_mem_size = 0x40000000
dcache_line_size = 0x40
icache_line_size = 0x40
cpu_features = 0x00180400181802c0
possible = 0x00180480581802c8
always = 0x00180400581802c0
cpu_user_features = 0xcc008000 0x08000000
mmu_features = 0x000a0010
firmware_features = 0x0000000000000000
<- setup_system()
Linux version 4.1.8-rt8+gbd51baf (hstan@server-06) (gcc version 4.9.2 (GCC) ) #1 SMP Sun Jan 8 12:42:09 ICT 2017
qemu_e500_setup_arch()
Zone ranges:
DMA [mem 0x0000000000000000-0x000000003fffffff]
DMA32 empty
Normal empty
Movable zone start for each node
Early memory node ranges
node 0: [mem 0x0000000000000000-0x000000003fffffff]
Initmem setup node 0 [mem 0x0000000000000000-0x000000003fffffff]
MMU: Allocated 2112 bytes of context maps for 255 contexts
PERCPU: Embedded 17 pages/cpu @c00000003f000000 s28824 r0 d40808 u1048576
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 258560
Kernel command line: root=/dev/ram rw console=ttyS0,115200 ip=26.26.26.2::26.26.26.1:255.255.255.0 mem=1028M
PID hash table entries: 4096 (order: 3, 32768 bytes)
Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
Inode-cache hash table entries: 65536 (order: 7, 524288 bytes)
Sorting __ex_table...
Memory: 949036K/1048576K available (7856K kernel code, 1132K rwdata, 3008K rodata, 364K init, 764K bss, 99540K reserved, 0K cma-reserved)
Hierarchical RCU implementation.
RCU debugfs-based tracing is enabled.
CONFIG_RCU_FANOUT set to non-default value of 32
Additional per-CPU info printed with stalls.
RCU restricting CPUs from NR_CPUS=24 to nr_cpu_ids=1.
RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
NR_IRQS:512 nr_irqs:512 16
mpic: Setting up MPIC " OpenPIC " version 1.2 at fe0040000, max 1 CPUs
mpic: ISU size: 256, shift: 8, mask: ff
mpic: Initializing for 256 sources
clocksource timebase: mask: 0xffffffffffffffff max_cycles: 0x5c4093a7d1, max_idle_ns: 440795210635 ns
clocksource: timebase mult[2800000] shift[24] registered
Console: colour dummy device 80x25
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 2048 (order: 2, 16384 bytes)
Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes)
e500 family performance monitor hardware support registered
Brought up 1 CPUs
devtmpfs: initialized
clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
xor: measuring software checksum speed
8regs : 1289.000 MB/sec
8regs_prefetch: 1079.000 MB/sec
32regs : 1745.000 MB/sec
32regs_prefetch: 1572.000 MB/sec
xor: using function: 32regs (1745.000 MB/sec)
NET: Registered protocol family 16
Found FSL PCI host bridge at 0x0000000fe0008000. Firmware bus number: 0->255
PCI host bridge /pci@fe0008000 (primary) ranges:
MEM 0x0000000c00000000..0x0000000c1fffffff -> 0x00000000e0000000
IO 0x0000000fe1000000..0x0000000fe100ffff -> 0x0000000000000000
/pci@fe0008000: PCICSRBAR @ 0xdff00000
setup_pci_atmu: end of DRAM 40000000
EDAC PCI0: Giving out device to module MPC85xx_edac controller mpc85xx_pci_err: DEV fe0008000.pci (INTERRUPT)
MPC85xx_edac acquired irq 24 for PCI Err
MPC85xx_edac PCI err registered
fsl-pamu: fsl_pamu_init: could not find a PAMU node
PCI: Probing PCI hardware
fsl-pci fe0008000.pci: PCI host bridge to bus 0000:00
pci_bus 0000:00: root bus resource [io 0x10000-0x1ffff] (bus address [0x0000-0xffff])
pci_bus 0000:00: root bus resource [mem 0xc00000000-0xc1fffffff] (bus address [0xe0000000-0xffffffff])
pci_bus 0000:00: root bus resource [bus 00-ff]
pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
pci 0000:00:00.0: PCI bridge to [bus 01-ff]
PCI: Cannot allocate resource region 0 of device 0000:00:00.0, will remap
pci 0000:00:00.0: BAR 0: assigned [mem 0xc00000000-0xc000fffff]
pci 0000:00:00.0: BAR 8: assigned [mem 0xc00100000-0xc001fffff]
pci 0000:00:01.0: BAR 6: assigned [mem 0xc00200000-0xc0023ffff pref]
pci 0000:00:01.0: BAR 0: assigned [mem 0xc00240000-0xc0025ffff]
pci 0000:00:01.0: BAR 1: assigned [io 0x11000-0x1103f]
pci 0000:00:00.0: PCI bridge to [bus 01]
pci 0000:00:00.0: bridge window [io 0x10000-0x10fff]
pci 0000:00:00.0: bridge window [mem 0xc00100000-0xc001fffff]
raid6: int64x1 gen() 721 MB/s
raid6: int64x1 xor() 495 MB/s
raid6: int64x2 gen() 1018 MB/s
raid6: int64x2 xor() 370 MB/s
raid6: int64x4 gen() 1334 MB/s
raid6: int64x4 xor() 890 MB/s
raid6: int64x8 gen() 650 MB/s
raid6: int64x8 xor() 440 MB/s
raid6: using algorithm int64x4 gen() 1334 MB/s
raid6: .... xor() 890 MB/s, rmw enabled
raid6: using intx1 recovery algorithm
vgaarb: loaded
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
PTP clock support registered
EDAC MC: Ver: 3.0.0
No BMan portals available!
QMan: Allocated lookup table at 8000000000002000, entry count 65537
No QMan portals available!
No USDPAA memory, no 'fsl,usdpaa-mem' in device-tree
Switched to clocksource timebase
NET: Registered protocol family 2
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 5, 131072 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
Trying to unpack rootfs image as initramfs...
rootfs image is not initramfs (no cpio magic); looks like an initrd
Freeing initrd memory: 4236K (c000000004000000 - c000000004423000)
futex hash table entries: 256 (order: 2, 16384 bytes)
audit: initializing netlink subsys (disabled)
audit: type=2000 audit(0.952:1): initialized
HugeTLB registered 4 MB page size, pre-allocated 0 pages
HugeTLB registered 16 MB page size, pre-allocated 0 pages
HugeTLB registered 64 MB page size, pre-allocated 0 pages
HugeTLB registered 256 MB page size, pre-allocated 0 pages
HugeTLB registered 1 GB page size, pre-allocated 0 pages
NFS: Registering the id_resolver key type
Key type id_resolver registered
Key type id_legacy registered
ntfs: driver 2.1.32 [Flags: R/O].
jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
async_tx: api initialized (async)
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
console [ttyS0] disabled
serial8250.0: ttyS0 at MMIO 0xfe0004500 (irq = 42, base_baud = 115200) is a 16550A
console [ttyS0] enabled
bootconsole [udbg0] disabled
ePAPR hypervisor byte channel driver
brd: module loaded
loop: module loaded
st: Version 20101219, fixed bufsize 32768, s/g segs 256
libphy: Fixed MDIO Bus: probed
Freescale FM module, FMD API version 21.1.0
Freescale FM Ports module
fsl_mac: fsl_mac: FSL FMan MAC API based driver
fsl_dpa: FSL DPAA Ethernet driver
fsl_advanced: FSL DPAA Advanced drivers:
fsl_proxy: FSL DPAA Proxy initialization driver
fsl_dpa_shared: FSL DPAA Shared Ethernet driver
fsl_dpa_macless: FSL DPAA MACless Ethernet driver
fsl_oh: FSL FMan Offline Parsing port driver
e1000e: Intel(R) PRO/1000 Network Driver - 2.3.2-k
e1000e: Copyright(c) 1999 - 2014 Intel Corporation.
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci-pci: EHCI PCI platform driver
usbcore: registered new interface driver usb-storage
i2c /dev entries driver
md: raid6 personality registered for level 6
md: raid5 personality registered for level 5
md: raid4 personality registered for level 4
Freescale(R) MPC85xx EDAC driver, (C) 2006 Montavista Software
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
No fsl,qman node
Freescale USDPAA process driver
fsl-usdpaa: no region found
Freescale USDPAA process IRQ driver
dce_sys_init done!
No fsl,dce node
Freescale pme2 db driver
PME2: fsl_pme2_db_init: not on ctrl-plane
Freescale pme2 scan driver
fsl-pme2-scan: device pme_scan registered
Freescale hypervisor management driver
fsl-hv: no hypervisor found
ipip: IPv4 over IPv4 tunneling driver
Initializing XFRM netlink socket
NET: Registered protocol family 10
sit: IPv6 over IPv4 tunneling driver
NET: Registered protocol family 17
NET: Registered protocol family 15
8021q: 802.1Q VLAN Support v1.8
Key type dns_resolver registered
fsl_generic: FSL DPAA Generic Ethernet driver
hctosys: unable to open rtc device (rtc0)
md: Skipping autodetection of RAID arrays. (raid=autodetect will force)
RAMDISK: gzip image found at block 0
VFS: Mounted root (ext2 filesystem) on device 1:0.
devtmpfs: mounted
Freeing unused kernel memory: 364K (c000000000aa3000 - c000000000afe000)
init[1]: unhandled signal 4 at 00003fff90c3c0fc nip 00003fff90c3c0fc lr 00003fff90c1dd94 code 30001
CPU: 0 PID: 1 Comm: init Not tainted 4.1.8-rt8+gbd51baf #1
Call Trace:
[c0000000390538d0] [c0000000007a34fc] .dump_stack+0x8c/0xb8 (unreliable)
[c000000039053950] [c0000000007a0e34] .panic+0xf0/0x270
[c0000000390539f0] [c00000000003b520] .do_exit+0xa00/0xa04
[c000000039053ae0] [c00000000003c5a4] .do_group_exit+0x54/0xec
[c000000039053b70] [c000000000048640] .get_signal+0x2f8/0x674
[c000000039053c70] [c0000000000092bc] .do_signal+0x44/0x218
[c000000039053db0] [c00000000000959c] .do_notify_resume+0x64/0x78
[c000000039053e30] [c000000000000c4c] .ret_from_except_lite+0x78/0x7c
Rebooting in 180 seconds..
Please help me.
Thanks in advanced.
ラベル(3)
タグ(2)
20 返答(返信)
18,686件の閲覧回数
hosytan
Thanhs Yiping Wang,
Now I can boot my T4240RDB device but I have other problems with QEMU/KVM.
I follow the Chapter 11 Virtualization of QorIQ SDK v2.0-1703 Documentation:
1. Setup br0 interface:
$ brctl addbr br0
$ ifconfig br0 192.168.1.139
$ ifconfig fm1-mac1 up
$ brctl addif br0 mac1-gb1
2. Add a files: /home/root/qemu-ifup
#!/bin/sh
# TAP interface will be passed in $1
bridge=br0
guest_device=$1
ifconfig $guest_device up
brctl addif $bridge $guest_device
3. Add a files: /home/root/qemu-ifdown
#!/bin/sh
bridge=br0
guest_device=$1
ifconfig $guest_device down
4. Run QEMU/KVM
qemu-system-ppc -enable-kvm -nographic -m 256 -M ppce500 -kernel uImage -initrd rootfs.ext2.gz -append "root=/dev/ram rw console=ttyS0,115200" -serial tcp::4444,server -netdev
tap,id=tap0,script=/root/qemu-ifup,downscript=/home/root/qemu-ifdown,vhost=on -device virtionet-pci,netdev=tap0
When I boot the Guest, I cannot see any ethernet interface.
Please show my what I should do to resolv the problem?
18,695件の閲覧回数
hosytan
I tried to run on QorIQ T4240 QEMU/KVM guest on Ubuntu host for some months but always failed.
If anyone already set up for T4240RDB QEMU ỏ KVM guest running on Linux hosts please help me.
This problem is giving me a headache for months!
18,695件の閲覧回数
yipingwang
Hello Ho Sy Tan,
There is a known issue to setup qemu on a x86 system, please refer to Bug #1570119 “xenial ppc64le cloud image crashes on nested virt” : Bugs : qemu package : Ubuntu, I have also verfied qemu 2.8 with these patches applied, but this problem remains.
So if you have a real board, I suggest you use  KVM/QEMU solution on the target board.
Yiping
18,695件の閲覧回数
hosytan
II. Deploy U-Boot, Linux Kernel, and Root Filesystem to a Reference Design Board (RDB)
In my case, I want to deploy the build to T4240RDB board with SD card.
I follow the guide of QorIQ SDK v2.0-1701 Documentation.
1. Switch Settings:
SW1 [1:8] = 0010 0000
SW2 [1:8] = 0011 1001
SW3 [1:8] = 1110 0001
2. Setting U-Boot Environment:
# setenv bootfile uImage
# setenv fdtfile uImage.dtb
# setenv bootcmd 'setenv bootargs root=/dev/mmcblk0p2 rw rootdelay=5 console=$consoledev,$baudrate;mmcinfo;ext2load mmc 0:2 $loadaddr /boot/$bootfile;ext2load mmc 0:2 $fdtaddr /boot/$fdtfile;bootm $loadaddr - $fdtaddr'
# save
3. Deploy Filesystem to the SD Card
Once the U-Boot network parameters have been set, follow the steps below to deploy the filesystem to the SD card:
Connect the card reader with SD card to the Linux Host PC.
Create the partitions by "fdisk /dev/sdb", one MS-DOS partition(sdb1 and this partition usually for u-boot) and one ext2 partition(sdb2) in the SD card.
#fdisk /dev/sdb
Use the mkfs.ext2 command to create the filesystems.
# mkfs.vfat /dev/sdb1
# mkfs.ext2 /dev/sdb2
Create temp directory in host PC and mount the ext2 partition to the temp.
# mkdir /temp
# mount /dev/sdb2 /temp
# cd /temp
Mount the target board type .iso (eg. QorIQ-SDK-<Version>-PPCE6500-<release date>-yocto.iso) to get the tarball (eg. QorIQ_SDK_<Version>_E6500_<release date>_ROOTFS_Image.tar.gz) on host PC.
# mount -o loop QorIQ-SDK-<Version>-PPCE6500-<release date>-yocto.iso /work
Copy the file system to harddisk by extracing the QorIQ_SDK_<Version>_E6500_<release date>_ROOTFS_Image.tar.gz. Remove the tarball after extracting rootfs.
# cp QorIQ_SDK_<Version>_E6500_<release date>_ROOTFS_Image.tar.gz
# sudo tar -zxvf QorIQ_SDK_<Version>_E6500_<release date>_ROOTFS_Image.tar.gz
# rm QorIQ_SDK_<Version>_E6500_<release date>_ROOTFS_Image.tar.gz
Make sure the kernel image and dtb file are in /temp/boot directory, then umount the /temp.
# cp uImage and uImage.dtb to /temp/boot folder
# umount /temp
Plug in the SD card to the target board and power on.
When I power on to boot the board, I can boot it but I have the same error: Kernel panic above!
18,694件の閲覧回数
hosytan
Hi Wang,
I try QEMU with -enable-kvm, but I think it is not support to run KVM on my host hardware (HP Proliant GEN9 server).
$ /home/hstan/Build/nxp/QorIQ-SDK-V2.0-20160527-yocto/build_t4240rdb-64b/tmp/sysroots/x86_64-linux/usr/bin/qemu-system-ppc64 -enable-kvm -nographic -m 1024 -M ppce500 -kernel uImage -initrd fsl-image-minimal-t4240rdb-64b.ext2.gz -append "root=/dev/ram rw console=ttyS0,115200" -serial tcp::4444, server
/home/hstan/Build/nxp/QorIQ-SDK-V2.0-20160527-yocto/build_t4240rdb-64b/tmp/sysroots/x86_64-linux/usr/bin/qemu-system-ppc64: /home/hstan/Build/nxp/QorIQ-SDK-V2.0-20160527-yocto/build_t4240rdb-64b/tmp/sysroots/x86_64-linux/usr/bin/../lib/libncursesw.so.5: no version information available (required by /usr/lib/x86_64-linux-gnu/libcaca.so.0)
/home/hstan/Build/nxp/QorIQ-SDK-V2.0-20160527-yocto/build_t4240rdb-64b/tmp/sysroots/x86_64-linux/usr/bin/qemu-system-ppc64: /home/hstan/Build/nxp/QorIQ-SDK-V2.0-20160527-yocto/build_t4240rdb-64b/tmp/sysroots/x86_64-linux/usr/bin/../lib/libtinfo.so.5: no version information available (required by /usr/lib/x86_64-linux-gnu/libcaca.so.0)
"kvm" accelerator not found.
No accelerator found!
I think "kvm" accelerator is enabled on my server. Let's check it:
$ kvm-ok
INFO: /dev/kvm exists
KVM acceleration can be used
18,695件の閲覧回数
hosytan
I can build fsl-image-core with some rebuild:
$ bitbake -c clean usdpaa-apps
$ bitbake usdpaa-apps
$ bitbake fsl-image-core
But when I try run QEMU guest with above command, I have same error.
$ sudo ./t4240rdb-64b-core.sh
The boot log:
4 KB as direct
4096 KB as direct
16384 KB as direct
65536 KB as direct
262144 KB as direct
Found initrd at 0xc000000004000000:0xc000000005f379b6
Starting Linux PPC64 #1 SMP Sun Mar 5 11:47:42 ICT 2017
<- setup_system()
Linux version 4.1.30-rt34+g4004071 (hstan@server-06) (gcc version 4.9.2 (GCC) ) #1 SMP Sun Mar 5 11:47:42 ICT 2017
Zone ranges:
DMA32 empty
Normal empty
PERCPU: Embedded 17 pages/cpu @c00000003f000000 s29336 r0 d40296 u1048576
Kernel command line: root=/dev/ram rw console=ttyS0,115200 ip=26.26.26.2::26.26.26.1:255.255.255.0 mem=1024M ramdisk_size=512000
Memory: 921084K/1048576K available (8004K kernel code, 1148K rwdata, 3064K rodata, 364K init, 765K bss, 127492K reserved, 0K cma-reserved)
Brought up 1 CPUs
8regs : 1286.000 MB/sec
8regs_prefetch: 1449.000 MB/sec
32regs : 1737.000 MB/sec
32regs_prefetch: 1386.000 MB/sec
xor: using function: 32regs (1737.000 MB/sec)
raid6: int64x1 gen() 761 MB/s
raid6: int64x1 xor() 520 MB/s
raid6: int64x2 gen() 1046 MB/s
raid6: int64x2 xor() 740 MB/s
raid6: int64x4 gen() 1351 MB/s
raid6: int64x4 xor() 887 MB/s
raid6: int64x8 gen() 669 MB/s
raid6: int64x8 xor() 488 MB/s
raid6: using algorithm int64x4 gen() 1351 MB/s
raid6: .... xor() 887 MB/s, rmw enabled
vgaarb: loaded
EDAC MC: Ver: 3.0.0
Freeing initrd memory: 31964K (c000000004000000 - c000000005f37000)
audit: type=2000 audit(0.992:1): initialized
brd: module loaded
loop: module loaded
No fsl,qman node
dce_sys_init done!
No fsl,dce node
devtmpfs: mounted
Freeing unused kernel memory: 364K (c000000000ad7000 - c000000000b32000)
init[1]: unhandled signal 4 at 00003fffa8ab30fc nip 00003fffa8ab30fc lr 00003fffa8a94d94 code 30001
CPU: 0 PID: 1 Comm: init Not tainted 4.1.30-rt34+g4004071 #1
Call Trace:
[c0000000390538c0] [c0000000007c80e0] .dump_stack+0xac/0xec (unreliable)
[c000000039053950] [c0000000007c59dc] .panic+0xf0/0x280
[c0000000390539f0] [c0000000000536ec] .do_exit+0xa0c/0xa10
[c000000039053ae0] [c00000000005478c] .do_group_exit+0x54/0xec
[c000000039053b70] [c00000000006086c] .get_signal+0x2f8/0x674
Rebooting in 180 seconds..Connection closed by foreign host.
18,695件の閲覧回数
hosytan
Now, I folow thing that Wang do:
1. Customize Linux Kernel
hstan@server-06:~/Build/nxp/QorIQ-SDK-V2.0-20160527-yocto/build_t4240rdb-64b$ bitbake -c cleansstate virtual/kernel
Loading cache: 100% |########################################################################################################################################################| ETA: 00:00:00
Loaded 6065 entries from dependency cache.
TARGET_FPU = "hard"
meta
meta-yocto
meta-oe
meta-multimedia
meta-gnome
meta-networking
meta-perl
meta-python
meta-ruby
meta-filesystems
meta-webserver
meta-openstack
meta-openstack-qemu
meta-nxp-npi-1609.old = "master:68e60ceae569d4f1ae898eb1ca2ddada1d0f3bc5"
meta-nxp-npi-1701 = "jethro-sdk-v2.0-ga-1701:11975eebce9096a3567d00ba2067a2dbd2ed4d5c"
meta-nxp-npi-ga.1611 = "jethro-sdk-v2.0-ga-16.11:81df2dc9f9723ff59417e57af1700735770ddff2"
NOTE: Tasks Summary: Attempted 2 tasks of which 0 didn't need to be rerun and all succeeded.
... I cut some lines
hstan@server-06:~/Build/nxp/QorIQ-SDK-V2.0-20160527-yocto/build_t4240rdb-64b$ bitbake -c patch virtual/kernel
NOTE: Tasks Summary: Attempted 10 tasks of which 7 didn't need to be rerun and all succeeded.
$ bitbake -c menuconfig virtual/kernel
Virtualization
   [*] Detailed exit timing
 [*] KVM support for PowerPC E500MC/E5500/E6500 processors
 [*] KVM in-kernel MPIC emulation
 <*> Host kernel accelerator for virtio net
hstan@server-06:~/Build/nxp/QorIQ-SDK-V2.0-20160527-yocto/build_t4240rdb-64b$ bitbake -c compile -f virtual/kernel
NOTE: Tainting hash to force rebuild of task /home/hstan/Build/nxp/QorIQ-SDK-V2.0-20160527-yocto/sources/meta-freescale/recipes-kernel/linux/linux-qoriq_4.1.bb, do_compile
WARNING: /home/hstan/Build/nxp/QorIQ-SDK-V2.0-20160527-yocto/sources/meta-freescale/recipes-kernel/linux/linux-qoriq_4.1.bb.do_compile is tainted from a forced run
NOTE: Tasks Summary: Attempted 285 tasks of which 284 didn't need to be rerun and all succeeded.
Summary: There were 2 WARNING messages shown.
hstan@server-06:~/Build/nxp/QorIQ-SDK-V2.0-20160527-yocto/build_t4240rdb-64b$ bitbake virtual/kernel
NOTE: Checking sstate mirror object availability (for 8 objects)
NOTE: Tasks Summary: Attempted 423 tasks of which 408 didn't need to be rerun and all succeeded.
2. Build fsl-image-core again with new kernel
hstan@server-06:~/Build/nxp/QorIQ-SDK-V2.0-20160527-yocto/build_t4240rdb-64b$ bitbake fsl-image-core
NOTE: Checking sstate mirror object availability (for 45 objects)
ERROR: oe_runmake failed
ERROR: Function failed: do_configure (log file is located at /home/hstan/Build/nxp/QorIQ-SDK-V2.0-20160527-yocto/build_t4240rdb-64b/tmp/work/t4240rdb_64b-fsl-linux/usdpaa-apps/git-r0/temp/log.do_configure.31402)
ERROR: Logfile of failure stored in: /home/hstan/Build/nxp/QorIQ-SDK-V2.0-20160527-yocto/build_t4240rdb-64b/tmp/work/t4240rdb_64b-fsl-linux/usdpaa-apps/git-r0/temp/log.do_configure.31402
Log data follows:
ERROR: Task 1397 (/home/hstan/Build/nxp/QorIQ-SDK-V2.0-20160527-yocto/sources/meta-freescale/recipes-dpaa/usdpaa-apps/usdpaa-apps_git.bb, do_configure) failed with exit code '1'
NOTE: Tasks Summary: Attempted 3133 tasks of which 3067 didn't need to be rerun and 1 failed.
Waiting for 0 running tasks to finish:
Summary: 1 task failed:
Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
It is not success, there are some erors...
Any idea, Wang?
18,695件の閲覧回数
hosytan
Now, I tried boot fsl-image-core by run t4240rdb-64b-core.sh like this:
$ nano t4240rdb-64b-core.sh
/home/hstan/Build/nxp/QorIQ-SDK-V2.0-20160527-yocto/build_t4240rdb-64b/tmp/sysroots/x86_64-linux/usr/bin/qemu-system-ppc64 \
-cpu e5500 -nographic -m 1024 -M ppce500 \
-kernel /home/hstan/Build/nxp/QorIQ-SDK-V2.0-20160527-yocto/build_t4240rdb-64b/tmp/deploy/images/t4240rdb-64b/uImage \
--initrd /home/hstan/Build/nxp/QorIQ-SDK-V2.0-20160527-yocto/build_t4240rdb-64b/tmp/deploy/images/t4240rdb-64b/fsl-image-core-t4240rdb-64b.ext2.gz \
--append "root=/dev/ram rw console=ttyS0,115200 \
ip=26.26.26.2::26.26.26.1:255.255.255.0 mem=1024M ramdisk_size=512000" -serial tcp::4444,server,telnet -net nic,model=e1000 \
Run QEMU guest again:
[sudo] password for hstan:
QEMU 2.4.0 monitor - type 'help' for more information
(qemu) QEMU waiting for connection on: disconnected:telnet::4444,server
Telnet to it again:
Boot message:
4 KB as direct
4096 KB as direct
16384 KB as direct
65536 KB as direct
262144 KB as direct
Found initrd at 0xc000000004000000:0xc000000005f378c4
Starting Linux PPC64 #1 SMP Sun Mar 5 10:13:16 ICT 2017
<- setup_system()
Linux version 4.1.30-rt34+g4004071 (hstan@server-06) (gcc version 4.9.2 (GCC) ) #1 SMP Sun Mar 5 10:13:16 ICT 2017
Zone ranges:
DMA32 empty
Normal empty
Memory: 921276K/1048576K available (7872K kernel code, 1144K rwdata, 3016K rodata, 360K init, 764K bss, 127300K reserved, 0K cma-reserved)
Brought up 1 CPUs
8regs : 1052.000 MB/sec
8regs_prefetch: 1081.000 MB/sec
32regs : 1256.000 MB/sec
32regs_prefetch: 873.000 MB/sec
xor: using function: 32regs (1256.000 MB/sec)
raid6: int64x1 gen() 543 MB/s
raid6: int64x1 xor() 382 MB/s
raid6: int64x2 gen() 767 MB/s
raid6: int64x2 xor() 696 MB/s
raid6: int64x4 gen() 1310 MB/s
raid6: int64x4 xor() 850 MB/s
raid6: int64x8 gen() 614 MB/s
raid6: int64x8 xor() 415 MB/s
raid6: using algorithm int64x4 gen() 1310 MB/s
raid6: .... xor() 850 MB/s, rmw enabled
vgaarb: loaded
EDAC MC: Ver: 3.0.0
audit: type=2000 audit(1.052:1): initialized
brd: module loaded
loop: module loaded
No fsl,qman node
dce_sys_init done!
No fsl,dce node
devtmpfs: mounted
Freeing unused kernel memory: 360K (c000000000aa9000 - c000000000b03000)
init[1]: unhandled signal 4 at 00003fffa92a90fc nip 00003fffa92a90fc lr 00003fffa928ad94 code 30001
Call Trace:
[c0000000390538c0] [c0000000007a77d8] .dump_stack+0xac/0xec (unreliable)
[c000000039053950] [c0000000007a50d4] .panic+0xf0/0x280
[c0000000390539f0] [c00000000003b608] .do_exit+0xa0c/0xa10
[c000000039053ae0] [c00000000003c6a8] .do_group_exit+0x54/0xec
[c000000039053b70] [c000000000048788] .get_signal+0x2f8/0x674
Nothing better, something went wrong with this?
18,695件の閲覧回数
hosytan
From other Ubuntu host terminal, I telnet to QEMU guest like this:
This is my boot logs:
4 KB as direct
4096 KB as direct
16384 KB as direct
65536 KB as direct
262144 KB as direct
Found initrd at 0xc000000004000000:0xc000000004423eee
<- setup_system()
Zone ranges:
DMA32 empty
Normal empty
Memory: 949004K/1048576K available (7872K kernel code, 1144K rwdata, 3016K rodata, 360K init, 764K bss, 99572K reserved, 0K cma-reserved)
Brought up 1 CPUs
8regs : 1681.000 MB/sec
8regs_prefetch: 1419.000 MB/sec
32regs : 1713.000 MB/sec
32regs_prefetch: 1331.000 MB/sec
xor: using function: 32regs (1713.000 MB/sec)
raid6: int64x1 gen() 738 MB/s
raid6: int64x1 xor() 497 MB/s
raid6: int64x2 gen() 1021 MB/s
raid6: int64x2 xor() 706 MB/s
raid6: int64x4 gen() 1322 MB/s
raid6: int64x4 xor() 694 MB/s
raid6: int64x8 gen() 502 MB/s
raid6: int64x8 xor() 393 MB/s
raid6: using algorithm int64x4 gen() 1322 MB/s
raid6: .... xor() 694 MB/s, rmw enabled
vgaarb: loaded
EDAC MC: Ver: 3.0.0
audit: type=2000 audit(0.968:1): initialized
brd: module loaded
loop: module loaded
No fsl,qman node
dce_sys_init done!
No fsl,dce node
devtmpfs: mounted
init[1]: unhandled signal 4 at 00003fff831690fc nip 00003fff831690fc lr 00003fff8314ad94 code 30001
Call Trace:
So sad, it cannot boot....
18,695件の閲覧回数
hosytan
f.2. Run QEMU.
Fistly, I bring up the brigde interface for my Ubuntu host:
$ sudo ./qemu-start.sh
Sun Mar 5 10:44:47 2017 TUN/TAP device tap0 opened
Sun Mar 5 10:44:47 2017 Persist state set to: ON
$ ifconfig
... I just cut some lines
br1 Link encap:Ethernet HWaddr 1c:98:ec:16:2f:11
inet addr:26.26.26.1 Bcast:26.26.26.255 Mask:255.255.255.0
inet6 addr: fe80::1e98:ecff:fe16:2f11/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:34 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:4335 (4.3 KB)
eno2 Link encap:Ethernet HWaddr 1c:98:ec:16:2f:11
inet6 addr: fe80::3321:f5ee:ad18:f04f/64 Scope:Link
UP BROADCAST RUNNING PROMISC MULTICAST MTU:1500 Metric:1
TX packets:91 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:10686 (10.6 KB)
Interrupt:17
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:253747 errors:0 dropped:0 overruns:0 frame:0
TX packets:253747 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:17563888 (17.5 MB) TX bytes:17563888 (17.5 MB)
tap0 Link encap:Ethernet HWaddr 8a:99:0d:a6:7d:3f
inet6 addr: fe80::8899:dff:fea6:7d3f/64 Scope:Link
UP BROADCAST PROMISC MULTICAST MTU:1500 Metric:1
TX packets:1 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:90 (90.0 B)
vnet0 Link encap:Ethernet HWaddr fe:54:00:34:eb:9b
RX packets:796 errors:0 dropped:0 overruns:0 frame:0
TX packets:33483 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:96210 (96.2 KB) TX bytes:2788417 (2.7 MB)
I think I setup brigded network fine for QEMU, don't I? Because I can ping to br1:
$ ping 26.26.26.1
PING 26.26.26.1 (26.26.26.1) 56(84) bytes of data.
64 bytes from 26.26.26.1: icmp_seq=1 ttl=64 time=0.042 ms
64 bytes from 26.26.26.1: icmp_seq=2 ttl=64 time=0.028 ms
64 bytes from 26.26.26.1: icmp_seq=3 ttl=64 time=0.029 ms
64 bytes from 26.26.26.1: icmp_seq=4 ttl=64 time=0.033 ms
64 bytes from 26.26.26.1: icmp_seq=5 ttl=64 time=0.033 ms
Now, I run QEMU guest:
$ sudo ./t4240rdb-64b.sh
18,695件の閲覧回数
hosytan
f. Run t4240rdb-64b QEMU guest on Ubuntu 16.04 host
f.1. Preparing for QEMU.
I want to run QEMU with its network interface brigded to my Ubuntu-16.04 host network interface (eno2, my server have 4 NIC: en1, eno2, eno3, eno4, I just use eno2 for QEMU).
Fistly, I add 2 shell files to start and stop the brigde interface like this:
$ nano qemu-start.sh
#!/bin/bash
# Set up Ethernet bridge on Linux
# Requires: bridge-utils
ifconfig eno2 26.26.26.1 netmask 255.255.255.0
# Define Bridge Interface
br="br1"
# Define list of TAP interfaces to be bridged,
# for example tap="tap0 tap1 tap2".
tap="tap0"
# Define physical ethernet interface to be bridged
# with TAP interface(s) above.
eth="eno2"
eth_ip="26.26.26.1"
eth_netmask="255.255.255.0"
eth_broadcast="26.26.26.255"
for t in $tap; do
openvpn --mktun --dev $t
done
brctl addbr $br
brctl addif $br $eth
for t in $tap; do
brctl addif $br $t
done
for t in $tap; do
ifconfig $t 0.0.0.0 promisc up
done
ifconfig $eth 0.0.0.0 promisc up
ifconfig $br $eth_ip netmask $eth_netmask broadcast $eth_broadcast
$ chmod 755 qemu-start.sh
$ nano qemu-stop.sh
#!/bin/bash
# Tear Down Ethernet bridge on Linux
br="br1"
# Define list of TAP interfaces to be bridged together
tap="tap0"
ifconfig $br down
brctl delbr $br
for t in $tap; do
openvpn --rmtun --dev $t
done
$ chmod 755 qemu-stop.sh
Secondly, I add QEMU command running t4240rdb-64b guest to t4240qds-64b.sh like this:
$ nano t4240rdb-64b.sh
--initrd /home/hstan/Build/nxp/QorIQ-SDK-V2.0-20160527-yocto/build_t4240rdb-64b/tmp/deploy/images/t4240rdb-64b/fsl-image-minimal-t4240rdb-64b.ext2.gz \
18,695件の閲覧回数
hosytan
e.1. Build fsl-image-core.
TARGET_FPU = "hard"
meta
meta-yocto
meta-oe
meta-multimedia
meta-gnome
meta-networking
meta-perl
meta-python
meta-ruby
meta-filesystems
meta-webserver
meta-openstack
meta-openstack-qemu
NOTE: Checking sstate mirror object availability (for 49 objects)
WARNING: sysklogd: useradd command did not succeed. Retrying...
ERROR: Function failed: do_configure (log file is located at /home/hstan/Build/nxp/QorIQ-SDK-V2.0-20160527-yocto/build_t4240rdb-64b/tmp/work/x86_64-linux/qemu-native/2.4.0-r1/temp/log.do_configure.25195)
ERROR: Logfile of failure stored in: /home/hstan/Build/nxp/QorIQ-SDK-V2.0-20160527-yocto/build_t4240rdb-64b/tmp/work/x86_64-linux/qemu-native/2.4.0-r1/temp/log.do_configure.25195
Log data follows:
| DEBUG: Executing python function sysroot_cleansstate
| DEBUG: Python function sysroot_cleansstate finished
| DEBUG: Executing shell function autotools_preconfigure
| DEBUG: Shell function autotools_preconfigure finished
| DEBUG: Executing python function autotools_copy_aclocals
| DEBUG: Python function autotools_copy_aclocals finished
| DEBUG: Executing shell function do_configure
| ERROR: User requested feature sdl
| configure was not able to find it.
| Install SDL devel
| WARNING: /home/hstan/Build/nxp/QorIQ-SDK-V2.0-20160527-yocto/build_t4240rdb-64b/tmp/work/x86_64-linux/qemu-native/2.4.0-r1/temp/run.do_configure.25195:1 exit 1 from
| /home/hstan/Build/nxp/QorIQ-SDK-V2.0-20160527-yocto/build_t4240rdb-64b/tmp/work/x86_64-linux/qemu-native/2.4.0-r1/qemu-2.4.0/configure --prefix=/home/hstan/Build/nxp/QorIQ-SDK-V2.0-20160527-yocto/build_t4240rdb-64b/tmp/sysroots/x86_64-linux/usr --sysconfdir=/home/hstan/Build/nxp/QorIQ-SDK-V2.0-20160527-yocto/build_t4240rdb-64b/tmp/sysroots/x86_64-linux/etc --libexecdir=/home/hstan/Build/nxp/QorIQ-SDK-V2.0-20160527-yocto/build_t4240rdb-64b/tmp/sysroots/x86_64-linux/usr/lib/qemu --localstatedir=/home/hstan/Build/nxp/QorIQ-SDK-V2.0-20160527-yocto/build_t4240rdb-64b/tmp/sysroots/x86_64-linux/var --disable-strip --target-list=mips64-softmmu,arm-linux-user,arm-softmmu,aarch64-linux-user,aarch64-softmmu,i386-linux-user,i386-softmmu,mips-linux-user,mips-softmmu,mipsel-linux-user,mipsel-softmmu,ppc-linux-user,ppc-softmmu,x86_64-linux-user,x86_64-softmmu,ppc64-linux-user,ppc64-softmmu --disable-werror --disable-bluez --disable-libiscsi --with-system-pixman --extra-cflags='-isystem/home/hstan/Build/nxp/QorIQ-SDK-V2.0-20160527-yocto/build_t4240rdb-64b/tmp/sysroots/x86_64-linux/usr/include -O2 -pipe' --audio-drv-list=oss,alsa --disable-linux-aio --disable-bzip2 --disable-curses --enable-fdt --disable-opengl --disable-gnutls --disable-gtk --disable-vte --disable-cap-ng --disable-curl --disable-libusb --disable-lzo --disable-smartcard-nss --disable-numa --enable-sdl --disable-libssh2 --enable-uuid --disable-virtfs --disable-vnc-jpeg --disable-vnc-png --disable-vnc-sasl --disable-vnc-tls --disable-xen --disable-xfsctl $KVMOPTS
ERROR: Task 2845 (virtual:native:/home/hstan/Build/nxp/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-devtools/qemu/qemu_2.4.0.bb, do_configure) failed with exit code '1'
NOTE: Tasks Summary: Attempted 3135 tasks of which 2934 didn't need to be rerun and 1 failed.
Summary: There was 1 ERROR message shown, returning a non-zero exit code.
Because the errors, I changed my conf/local.conf by adding a line BUILD_LDFLAGS_prepend_pn-qemu-native = "-Wl,-rpath-link,/lib/x86_64-linux-gnu " at the end of this file at following:
hstan@server-06:~/Build/nxp/QorIQ-SDK-V2.0-20160527-yocto/build_t4240rdb-64b$ nano conf/local.conf
MACHINE ??= 't4240rdb-64b'
DISTRO ?= 'fsl-qoriq'
PACKAGE_CLASSES ?= "package_rpm"
EXTRA_IMAGE_FEATURES = "debug-tweaks"
USER_CLASSES ?= "buildstats image-mklibs"
PATCHRESOLVE = "noop"
BB_DISKMON_DIRS = "\
STOPTASKS,${TMPDIR},1G,100K \
STOPTASKS,${DL_DIR},1G,100K \
STOPTASKS,${SSTATE_DIR},1G,100K \
STOPTASKS,/tmp,100M,100K \
ABORT,${TMPDIR},100M,1K \
ABORT,${DL_DIR},100M,1K \
ABORT,${SSTATE_DIR},100M,1K \
ABORT,/tmp,10M,1K"
PACKAGECONFIG_append_pn-qemu-native = " sdl"
PACKAGECONFIG_append_pn-nativesdk-qemu = " sdl"
ASSUME_PROVIDED += "libsdl-native"
CONF_VERSION = "1"
# Parallelism Options
BB_NUMBER_THREADS = "24"
PARALLEL_MAKE = "-j 24"
DL_DIR = "/home/hstan/Build/nxp/QorIQ-SDK-V2.0-20160527-yocto/downloads"
SSTATE_DIR = "/home/hstan/Build/nxp/QorIQ-SDK-V2.0-20160527-yocto/sstate-cache"
INHERIT += "own-mirrors"
SOURCE_MIRROR_URL ?= "http://git.freescale.com/source/"
SSTATE_MIRRORS = "file://.*/(.*)/(.*) file://${SSTATE_DIR}/native/\1/\2 \n"
# use xz to compress sstate
SSTATE_PKG_SUFFIX = "txz"
SSTATE_PKG_TARZIPPROG = "xz"
ACCEPT_FSL_EULA = "1"
Trying build again:
Parsing recipes: 100% |######################################################################################################################################################| Time: 00:00:32
Parsing of 2689 .bb files complete (0 cached, 2689 parsed). 6064 targets, 702 skipped, 0 masked, 0 errors.
TARGET_FPU = "hard"
meta
meta-yocto
meta-oe
meta-multimedia
meta-gnome
meta-networking
meta-perl
meta-python
meta-ruby
meta-filesystems
meta-webserver
meta-openstack
meta-openstack-qemu
NOTE: Checking sstate mirror object availability (for 32 objects)
NOTE: Tasks Summary: Attempted 3215 tasks of which 3154 didn't need to be rerun and all succeeded.
Again, I can see the results:
hstan@server-06:~/Build/nxp/QorIQ-SDK-V2.0-20160527-yocto/build_t4240rdb-64b$ ls -la tmp/deploy/images/t4240rdb-64b/
total 285064
drwxr-xr-x 5 hstan hstan 4096 Mar 5 10:29 .
drwxrwxr-x 3 hstan hstan 4096 Mar 5 10:11 ..
-rwxr-xr-x 2 hstan hstan 1184 Mar 5 10:11 byte_swap.tcl
-rw-r--r-- 2 hstan hstan 133738 Mar 5 10:11 cs4315-cs4340-PHY-ucode.txt
-rw-r--r-- 2 hstan hstan 32604 Mar 5 10:11 fsl_fman_ucode_t4240_r2.0_106_4_18.bin
-rw-r--r-- 2 hstan hstan 35252 Mar 5 10:11 fsl_fman_ucode_t4240_r2.0_108_4_5.bin
-rw-r--r-- 1 hstan hstan 32733380 Mar 5 10:29 fsl-image-core-t4240rdb-64b-20170305032527.rootfs.ext2.gz
-rw-r--r-- 1 hstan hstan 32733444 Mar 5 10:29 fsl-image-core-t4240rdb-64b-20170305032527.rootfs.ext2.gz.u-boot
-rw-r--r-- 1 hstan hstan 42795008 Mar 5 10:29 fsl-image-core-t4240rdb-64b-20170305032527.rootfs.jffs2
-rw-r--r-- 1 hstan hstan 6977 Mar 5 10:29 fsl-image-core-t4240rdb-64b-20170305032527.rootfs.manifest
-rw-r--r-- 1 hstan hstan 32482230 Mar 5 10:29 fsl-image-core-t4240rdb-64b-20170305032527.rootfs.tar.gz
-rw-r--r-- 1 hstan hstan 54165504 Mar 5 10:29 fsl-image-core-t4240rdb-64b-20170305032527.rootfs.ubi
-rw-r--r-- 1 hstan hstan 50749440 Mar 5 10:29 fsl-image-core-t4240rdb-64b-20170305032527.rootfs.ubifs
... Just cut some lines because they to long...
-rw-r--r-- 1 hstan hstan 4341486 Mar 5 10:16 fsl-image-minimal-t4240rdb-64b-20170305031119.rootfs.ext2.gz
-rw-r--r-- 1 hstan hstan 4341550 Mar 5 10:16 fsl-image-minimal-t4240rdb-64b-20170305031119.rootfs.ext2.gz.u-boot
-rw-r--r-- 1 hstan hstan 5636096 Mar 5 10:16 fsl-image-minimal-t4240rdb-64b-20170305031119.rootfs.jffs2
-rw-r--r-- 1 hstan hstan 1485 Mar 5 10:16 fsl-image-minimal-t4240rdb-64b-20170305031119.rootfs.manifest
-rw-r--r-- 1 hstan hstan 4322725 Mar 5 10:16 fsl-image-minimal-t4240rdb-64b-20170305031119.rootfs.tar.gz
-rw-r--r-- 1 hstan hstan 7979008 Mar 5 10:16 fsl-image-minimal-t4240rdb-64b-20170305031119.rootfs.ubi
-rw-r--r-- 1 hstan hstan 7449600 Mar 5 10:16 fsl-image-minimal-t4240rdb-64b-20170305031119.rootfs.ubifs
drwxr-xr-x 2 hstan hstan 4096 Mar 5 10:11 hv
drwxr-xr-x 3 hstan hstan 4096 Mar 5 10:11 hv-cfg
-rw-rw-r-- 2 hstan hstan 5797055 Mar 5 10:13 modules--4.1-r0-t4240rdb-64b-20170305031119.tgz
lrwxrwxrwx 1 hstan hstan 47 Mar 5 10:13 modules-t4240rdb-64b.tgz -> modules--4.1-r0-t4240rdb-64b-20170305031119.tgz
drwxr-xr-x 3 hstan hstan 4096 Mar 5 10:12 rcw
-rw-r--r-- 2 hstan hstan 294 Mar 5 10:28 README_-_DO_NOT_DELETE_FILES_IN_THIS_DIRECTORY.txt
-rw-r--r-- 1 hstan hstan 257 Mar 5 10:29 ubinize.cfg
lrwxrwxrwx 1 hstan hstan 32 Mar 5 10:11 u-boot.bin -> u-boot-nor-2016.09+fslgit-r0.bin
-rwxr-xr-x 2 hstan hstan 786432 Mar 5 10:11 u-boot-nor-2016.09+fslgit-r0.bin
lrwxrwxrwx 1 hstan hstan 32 Mar 5 10:11 u-boot-nor.bin -> u-boot-nor-2016.09+fslgit-r0.bin
lrwxrwxrwx 1 hstan hstan 32 Mar 5 10:11 u-boot-t4240rdb-64b.bin -> u-boot-nor-2016.09+fslgit-r0.bin
lrwxrwxrwx 1 hstan hstan 46 Mar 5 10:13 uImage -> uImage--4.1-r0-t4240rdb-64b-20170305031119.bin
-rw-r--r-- 2 hstan hstan 60756 Mar 5 10:13 uImage--4.1-r0-t4240rdb-20170305031119.dtb
-rw-r--r-- 2 hstan hstan 5105052 Mar 5 10:13 uImage--4.1-r0-t4240rdb-64b-20170305031119.bin
-rw-r--r-- 2 hstan hstan 64230 Mar 5 10:13 uImage--4.1-r0-t4240rdb-usdpaa-20170305031119.dtb
-rw-r--r-- 2 hstan hstan 63665 Mar 5 10:13 uImage--4.1-r0-t4240rdb-usdpaa-shared-interfaces-20170305031119.dtb
18,695件の閲覧回数
hosytan
e. Perform Builds.
e. Build fsl-image-minimal.
hstan@server-06:~/Build/nxp/QorIQ-SDK-V2.0-20160527-yocto/build_t4240rdb-64b$ bitbake fsl-image-minimal
Parsing recipes: 100% |######################################################################################################################################################| Time: 00:00:54
TARGET_FPU = "hard"
meta
meta-yocto
meta-oe
meta-multimedia
meta-gnome
meta-networking
meta-perl
meta-python
meta-ruby
meta-filesystems
meta-webserver
meta-openstack
meta-openstack-qemu
NOTE: Checking sstate mirror object availability (for 23 objects)
NOTE: Tasks Summary: Attempted 1500 tasks of which 1310 didn't need to be rerun and all succeeded.
OK, I can see the results:
total 45136
drwxr-xr-x 5 hstan hstan 4096 Mar 5 10:16 .
-rw-r--r-- 2 hstan hstan 294 Mar 5 10:15 README_-_DO_NOT_DELETE_FILES_IN_THIS_DIRECTORY.txt
-rw-r--r-- 1 hstan hstan 260 Mar 5 10:16 ubinize.cfg
lrwxrwxrwx 1 hstan hstan 46 Mar 5 10:13 uImage-t4240rdb-64b.bin -> uImage--4.1-r0-t4240rdb-64b-20170305031119.bin
lrwxrwxrwx 1 hstan hstan 42 Mar 5 10:13 uImage-t4240rdb.dtb -> uImage--4.1-r0-t4240rdb-20170305031119.dtb
lrwxrwxrwx 1 hstan hstan 49 Mar 5 10:13 uImage-t4240rdb-usdpaa.dtb -> uImage--4.1-r0-t4240rdb-usdpaa-20170305031119.dtb
lrwxrwxrwx 1 hstan hstan 67 Mar 5 10:13 uImage-t4240rdb-usdpaa-shared-interfaces.dtb -> uImage--4.1-r0-t4240rdb-usdpaa-shared-interfaces-20170305031119.dtb
18,695件の閲覧回数
hosytan
c. Follow the instructions in the "Set Up Host Environment" of "QorIQ SDK v2.0-1701 Documentation".
$ sudo apt-get install gawk wget git-core diffstat unzip texinfo gcc-multilib \
build-essential chrpath socat libsdl1.2-dev xterm
Everything worked fine!
$ sudo apt-get install lib32z1 lib32ncurses5 lib32bz2-1.0 ia32-libs lib32ncurses5-dev
I could install lib32ncurses5 lib32bz2-1.0 ib32ncurses5-dev but not lib32z1 and ia32-libs because Ubuntu 16.04 say that they don't need on version 16.04.
d. Set Up Poky.
hstan@server-06:~/Build/nxp/QorIQ-SDK-V2.0-20160527-yocto$ source ./fsl-setup-env -m t4240rdb-64b
Do you accept the EULA you just read? (y/n) y
EULA has been accepted.
Welcome to Freescale QorIQ SDK (Reference Distro)
The Yocto Project has extensive documentation about OE including a
reference manual which can be found at:
http://yoctoproject.org/documentation
For more information about OpenEmbedded see their website:
http://www.openembedded.org/
You can now run 'bitbake <target>'
Targets specific to Freescale targets:
fsl-image-core
fsl-image-full
fsl-image-kernelitb
fsl-image-mfgtool
fsl-image-minimal
fsl-image-virt
fsl-toolchain
To return to this build environment later please run:
. /home/hstan/Build/nxp/QorIQ-SDK-V2.0-20160527-yocto/build_t4240rdb-64b/SOURCE_THIS
This my local.conf file:
hstan@server-06:~/Build/nxp/QorIQ-SDK-V2.0-20160527-yocto/build_t4240rdb-64b$ cat conf/local.conf
ABORT,/tmp,10M,1K"
CONF_VERSION = "1"
18,695件の閲覧回数
hosytan
I. I tried to build and run the emulation QEMUT guest(4240RDB-64b built from QorIQ SDK 2.0) on Ubuntu-16.0.4 host (Hardware: HP Proliant DL380 GEN9).
1. Build Linux kernel and root filesystem,... guided in "QorIQ SDK v2.0-1701 Documentation":
a. Setup the Linux host with Ubuntu-16.0.4 x64 on HP Proliant DL380 GEN9 server.
I think no need to describe this step because it is too basic!
b. Install SDK 2.0 on Linux host above.
$ sudo mount -o loop QorIQ-Linux-SDK-v2.0-SOURCE.iso /mnt/cdrom
$ /mnt/cdrom/install
Everything was OK! My SDK installed in ~/Build/nxp/QorIQ-SDK-V2.0-20160527-yocto.
hstan@server-06:~/Build/nxp/QorIQ-SDK-V2.0-20160527-yocto$ ./sources/meta-freescale/scripts/host-prepare.sh
Verifying sudo permission to execute apt-get command.
Now we're going to install all the other development packages needed to build Yocto, please wait
Reading package lists... Done
Building dependency tree
Reading state information... Done
build-essential is already the newest version (12.1ubuntu2).
diffstat is already the newest version (1.61-1).
gawk is already the newest version (1:4.1.3+dfsg-0.1).
gcc-multilib is already the newest version (4:5.3.1-1ubuntu1).
git-core is already the newest version (1:2.7.4-0ubuntu1).
libsdl1.2-dev is already the newest version (1.2.15+dfsg1-3).
screen is already the newest version (4.3.1-2build1).
unzip is already the newest version (6.0-20ubuntu1).
xterm is already the newest version (322-1ubuntu1).
xz-utils is already the newest version (5.1.1alpha+20120614-2ubuntu2).
chrpath is already the newest version (0.16-1).
libstring-crc32-perl is already the newest version (1.5-1build2).
socat is already the newest version (1.7.3.1-1).
texinfo is already the newest version (6.1.0.dfsg.1-5).
tofrodos is already the newest version (1.7.13+ds-2ubuntu1).
vim-common is already the newest version (2:7.4.1689-3ubuntu1.2).
wget is already the newest version (1.17.1-1ubuntu1.1).
0 upgraded, 0 newly installed, 0 to remove and 339 not upgraded.
Done. You're ready to go with Yocto build now
18,695件の閲覧回数
hosytan
@Yiping Wang: Thanks for you your help.
I can provide more information about the things I've done as follows:
d. Set Up Poky.
e. Perform Builds:
e.1. Build fsl-image-minimal.
e.2. Build fsl-image-minimal.
f.2. Run QEMU.
II. I deploy the 4240RDB-64b built (Linux Kernel and Root Filesystem) to a real Reference Design Board (Device that I bought from NXP).
I'll detail them so you can see something to help me again!
18,695件の閲覧回数
yipingwang
Hello Ho Sy Tan,
First please build Kernel image with KVM enabled.
1.Enabling KVM
[*] Virtualization --->
    [*] KVM support for PowerPC E6500 processors
Please setup qemu with the following commands.
root@t4240rdb:~# qemu-system-ppc64 -enable-kvm -nographic -m 1024 -M ppce500 -kernel uImage -i inimal-t4240qds-64b.ext2.gz  -append "root=/dev/ram rw console=ttyS0,115200"  -serial tcp::4444, server
(qemu) QEMU waiting for connection on: disconnected:tcp::4444,server
Then telnet the qemu console:
b25805@star:~$ telnet 192.168.2.73 4444
Yiping
18,695件の閲覧回数
hosytan
Thanks Wang again, now I trying folow you help at some my following posts.
18,695件の閲覧回数
hosytan
Thanks Yiping Wang Employ&#233;
I think your solution is for qemu emulation, but in the real board the issue still happends...
I don't know why issued the error, but when I deploy the image to SD card and run on T4240RDB board, I have the same problems. It couldn't load the linux kernel with the same messages:
Call Trace:
Any idea for my issue?
Thanks in advanced.
18,695件の閲覧回数
yipingwang
Hello Ho Sy Tan,
I have verified my above procedure on the target board.
Would you please attach the whole log including Kernel booting up and your operations on the target board.
Yiping
