QCVS DDR Tool Target connection setup
2,688 次查看
xiaopengma
From QCVS DDR Tool User Guide,When clicking Target Connections button,Hardware Configuration Manager shows.
But in my QCVS DDR project,when I click Target Connections button,QQ图片20160803142322.jpg
I can not find Hardware Configuration Manager.
My QCVS version is 4.5 and CW version is 10.5.1.
I want to change the probe type to USBTAP,I don't know how to do it.
Thank you.
2,523 次查看
addiyi
USPTAP is obsolete and the support was removed from QCVS. You should use a CWTAP for DDR validation.
Adrian
2,523 次查看
addiyi
The screen shot from QCVS DDR Tool User Guide is old. The Hardware COnfiguration Manager was renamed to Target connection.
Adrian
2,523 次查看
xiaopengma
Can I use USBTAP to run DDR validation?
2,524 次查看
addiyi
Adrian
