How to use Linux Kernel version 4.20 in T1040RDB
19,562 次查看
Suraj_Prakash
      I am currently working on T1040RDB reference board and i am using SDK 2.0.
The latest linux version supported in the sdk is 4.1.35. I wanted MPLS features in the linux kernel but it is supported in linux version 4.20 and above.
Please suggest how to use linux 4.20 or above on my board.
16 回复数
19,558 次查看
yipingwang
Please download the latest Yocto 3.1 release from NXP following the instruction in the following link. Please create a build project for t1042d4rdb to build Linux Kernel. Linux Kernel version in this release is 5.4.3.
https://source.codeaurora.org/external/qoriq/qoriq-components/yocto-sdk/tree/readme?h=dunfell
$: mkdir ~/bin
$: curl http://commondatastorage.googleapis.com/git-repo-downloads/repo  > ~/bin/repo
$: chmod a+x ~/bin/repo
$: PATH=${PATH}:~/bin
$: mkdir yocto-sdk
$: cd yocto-sdk
$: repo init -u https://source.codeaurora.org/external/qoriq/qoriq-components/yocto-sdk -b dunfell
$: repo sync --force-sync
19,551 次查看
Suraj_Prakash
SDK 3.1 does not provide support for T1040RDB (64 bit).
Please suggest how to add receipes in SDK 3.1 for T1040RDB??????
19,547 次查看
yipingwang
In folder sources/meta-freescale/conf/machine/, please add configuration file t1040d4rdb-64b.conf according to t1042d4rdb-64b.conf.
19,524 次查看
Suraj_Prakash
      I have done according to your suggestion but I m facing the following errors. please suggest.
I have attached conf files of T1040d4rdb-64 and T1042d4rdb-64.
suchita@linux:~/yocto-sdk/build_t1040d4rdb-64b$ bitbake fsl-image-networking-full
Loading cache: 100% |##########################################################################################################| Time: 0:00:00
Loaded 6737 entries from dependency cache.
NOTE: Resolving any missing task queue dependencies
ERROR: Nothing PROVIDES 'hypervisor'. Close matches:
hyperstart
ERROR: Required build target 'fsl-image-networking-full' has no buildable providers.
Missing or unbuildable dependency chain was: ['fsl-image-networking-full', 'hypervisor']
Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
19,520 次查看
yipingwang
Please use the following in t1040d4rdb-64b.conf
EXTRA_IMAGEDEPENDS += "fm-ucode rcw qe-ucode"
19,516 次查看
Suraj_Prakash
     i am getting the following errors, please suggest.
Parsing recipes: 100% |########################################################################################################| Time: 0:01:06
Parsing of 2765 .bb files complete (0 cached, 2765 parsed). 6737 targets, 658 skipped, 0 masked, 0 errors.
Build Configuration:
BB_VERSION = "1.46.0"
BUILD_SYS = "x86_64-linux"
NATIVELSBSTRING = "universal"
TARGET_SYS = "powerpc64-fsl-linux"
MACHINE = "t1040d4rdb-64b"
DISTRO = "fsl-qoriq"
DISTRO_VERSION = "3.1.1"
TUNE_FEATURES = "m64 fpu-hard e5500 bigendian"
TARGET_FPU = "hard"
meta
meta-poky
meta-yocto-bsp = "HEAD:c253fd28ad26b4996666b0794dfee1d59c14e3ca"
meta-oe
meta-multimedia
meta-python
meta-networking
meta-gnome
meta-filesystems
meta-webserver
meta-perl = "HEAD:cc155826b0b4f202a8fa4ac103b7c38368d32734"
meta-virtualization = "HEAD:5c2de3daedd3f65171b9debf938683ce6e7746ea"
meta-cloud-services = "HEAD:ba99cce99d248b383871db562d694be5b3d52c77"
meta-security = "HEAD:d83f7cb0c90666fedd127d5173e6c8b972755c32"
meta-selinux = "HEAD:f677a09992413f32e6b2c4c607ae44fb42de72c2"
meta-freescale = "HEAD:682c00566aa3cf0deeff0cfd349494f078f38a04"
meta-freescale-distro = "HEAD:fbd12ff7e5f80a0e1fd71fa217d52a3c96659d16"
meta-qoriq = "HEAD:760e52a9a4c05729689595d4a884ebf97cba81ad"
Initialising tasks: 100% |#####################################################################################################| Time: 0:00:03
WARNING: netbase-1_6.1-r0 do_fetch: Failed to fetch URL http://ftp.debian.org/debian/pool/main/n/netbase/netbase_6.1.tar.xz, attempting MIRRORS if available
WARNING: iptables-1.8.4-r0 do_fetch: Failed to fetch URL http://netfilter.org/projects/iptables/files/iptables-1.8.4.tar.bz2, attempting MIRRORS if available
WARNING: libmnl-1.0.4-r0 do_fetch: Failed to fetch URL https://netfilter.org/projects/libmnl/files/libmnl-1.0.4.tar.bz2;name=tar, attempting MIRRORS if available
WARNING: fmlib-git-r1 do_fetch: Failed to fetch URL git://source.codeaurora.org/external/qoriq/qoriq-components/fmlib;nobranch=1, attempting MIRRORS if available
ERROR: linux-qoriq-5.4.3+gitAUTOINC+134788b164-r0 do_merge_delta_config: oe_runmake failed
ERROR: linux-qoriq-5.4.3+gitAUTOINC+134788b164-r0 do_merge_delta_config: Execution of '/home/suchita/yocto-sdk/build_t1040d4rdb-64b/tmp/work/t1040d4rdb_64b-fsl-linux/linux-qoriq/5.4.3+gitAUTOINC+134788b164-r0/temp/run.do_merge_delta_config.2218664' failed with exit code 1:
make: Entering directory '/home/suchita/yocto-sdk/build_t1040d4rdb-64b/tmp/work-shared/t1040d4rdb-64b/kernel-source'
make[1]: Entering directory '/home/suchita/yocto-sdk/build_t1040d4rdb-64b/tmp/work/t1040d4rdb_64b-fsl-linux/linux-qoriq/5.4.3+gitAUTOINC+134788b164-r0/build'
GEN Makefile
HOSTCC scripts/basic/fixdep
HOSTCC scripts/kconfig/conf.o
HOSTCC scripts/kconfig/confdata.o
HOSTCC scripts/kconfig/expr.o
LEX scripts/kconfig/lexer.lex.c
YACC scripts/kconfig/parser.tab.[ch]
HOSTCC scripts/kconfig/lexer.lex.o
HOSTCC scripts/kconfig/parser.tab.o
HOSTCC scripts/kconfig/preprocess.o
HOSTCC scripts/kconfig/symbol.o
HOSTLD scripts/kconfig/conf
*** Can't find default configuration "arch/powerpc/configs//home/suchita/yocto-sdk/build_t1040d4rdb-64b/tmp/work/t1040d4rdb_64b-fsl-linux/linux-qoriq/5.4.3+gitAUTOINC+134788b164-r0/git/arch/powerpc/configs/corenet64_fmanv3l_smp_defconfig"!
make[2]: *** [/home/suchita/yocto-sdk/build_t1040d4rdb-64b/tmp/work-shared/t1040d4rdb-64b/kernel-source/scripts/kconfig/Makefile:90: /home/suchita/yocto-sdk/build_t1040d4rdb-64b/tmp/work/t1040d4rdb_64b-fsl-linux/linux-qoriq/5.4.3+gitAUTOINC+134788b164-r0/git/arch/powerpc/configs/corenet64_fmanv3l_smp_defconfig] Error 1
make[1]: *** [/home/suchita/yocto-sdk/build_t1040d4rdb-64b/tmp/work-shared/t1040d4rdb-64b/kernel-source/Makefile:567: /home/suchita/yocto-sdk/build_t1040d4rdb-64b/tmp/work/t1040d4rdb_64b-fsl-linux/linux-qoriq/5.4.3+gitAUTOINC+134788b164-r0/git/arch/powerpc/configs/corenet64_fmanv3l_smp_defconfig] Error 2
make[1]: Leaving directory '/home/suchita/yocto-sdk/build_t1040d4rdb-64b/tmp/work/t1040d4rdb_64b-fsl-linux/linux-qoriq/5.4.3+gitAUTOINC+134788b164-r0/build'
make: *** [Makefile:179: sub-make] Error 2
make: Leaving directory '/home/suchita/yocto-sdk/build_t1040d4rdb-64b/tmp/work-shared/t1040d4rdb-64b/kernel-source'
WARNING: exit code 1 from a shell command.
ERROR: Logfile of failure stored in: /home/suchita/yocto-sdk/build_t1040d4rdb-64b/tmp/work/t1040d4rdb_64b-fsl-linux/linux-qoriq/5.4.3+gitAUTOINC+134788b164-r0/temp/log.do_merge_delta_config.2218664
Log data follows:
| DEBUG: Executing python function extend_recipe_sysroot
| NOTE: Direct dependencies are ['/home/suchita/yocto-sdk/sources/poky/meta/recipes-devtools/gcc/gcc-cross_9.3.bb:do_populate_sysroot', 'virtual:native:/home/suchita/yocto-sdk/sources/poky/meta/recipes-devtools/bison/bison_3.5.3.bb:do_populate_sysroot', '/home/suchita/yocto-sdk/sources/poky/meta/recipes-devtools/quilt/quilt-native_0.66.bb:do_populate_sysroot', 'virtual:native:/home/suchita/yocto-sdk/sources/poky/meta/recipes-devtools/patch/patch_2.7.6.bb:do_populate_sysroot']
| NOTE: Installed into sysroot: []
| NOTE: Skipping as already exists in sysroot: ['gcc-cross-powerpc64', 'bison-native', 'quilt-native', 'patch-native', 'attr-native', 'autoconf-native', 'gnu-config-native', 'automake-native', 'libtool-native', 'xz-native', 'texinfo-dummy-native', 'libmpc-native', 'gmp-native', 'linux-libc-headers', 'mpfr-native', 'binutils-cross-powerpc64', 'zlib-native', 'flex-native', 'gettext-minimal-native', 'm4-native']
| DEBUG: Python function extend_recipe_sysroot finished
| DEBUG: Executing shell function do_merge_delta_config
| NOTE: make HOSTCC=gcc -isystem/home/suchita/yocto-sdk/build_t1040d4rdb-64b/tmp/work/t1040d4rdb_64b-fsl-linux/linux-qoriq/5.4.3+gitAUTOINC+134788b164-r0/recipe-sysroot-native/usr/include -O2 -pipe -L/home/suchita/yocto-sdk/build_t1040d4rdb-64b/tmp/work/t1040d4rdb_64b-fsl-linux/linux-qoriq/5.4.3+gitAUTOINC+134788b164-r0/recipe-sysroot-native/usr/lib -L/home/suchita/yocto-sdk/build_t1040d4rdb-64b/tmp/work/t1040d4rdb_64b-fsl-linux/linux-qoriq/5.4.3+gitAUTOINC+134788b164-r0/recipe-sysroot-native/lib -Wl,--enable-new-dtags -Wl,-rpath-link,/home/suchita/yocto-sdk/build_t1040d4rdb-64b/tmp/work/t1040d4rdb_64b-fsl-linux/linux-qoriq/5.4.3+gitAUTOINC+134788b164-r0/recipe-sysroot-native/usr/lib -Wl,-rpath-link,/home/suchita/yocto-sdk/build_t1040d4rdb-64b/tmp/work/t1040d4rdb_64b-fsl-linux/linux-qoriq/5.4.3+gitAUTOINC+134788b164-r0/recipe-sysroot-native/lib -Wl,-rpath,/home/suchita/yocto-sdk/build_t1040d4rdb-64b/tmp/work/t1040d4rdb_64b-fsl-linux/linux-qoriq/5.4.3+gitAUTOINC+134788b164-r0/recipe-sysroot-native/usr/lib -Wl,-rpath,/home/suchita/yocto-sdk/build_t1040d4rdb-64b/tmp/work/t1040d4rdb_64b-fsl-linux/linux-qoriq/5.4.3+gitAUTOINC+134788b164-r0/recipe-sysroot-native/lib -Wl,-O1 -Wl,--allow-shlib-undefined -Wl,--dynamic-linker=/home/suchita/yocto-sdk/build_t1040d4rdb-64b/tmp/sysroots-uninative/x86_64-linux/lib/ld-linux-x86-64.so.2 HOSTCPP=gcc -E -C /home/suchita/yocto-sdk/build_t1040d4rdb-64b/tmp/work/t1040d4rdb_64b-fsl-linux/linux-qoriq/5.4.3+gitAUTOINC+134788b164-r0/git O=/home/suchita/yocto-sdk/build_t1040d4rdb-64b/tmp/work/t1040d4rdb_64b-fsl-linux/linux-qoriq/5.4.3+gitAUTOINC+134788b164-r0/build /home/suchita/yocto-sdk/build_t1040d4rdb-64b/tmp/work/t1040d4rdb_64b-fsl-linux/linux-qoriq/5.4.3+gitAUTOINC+134788b164-r0/git/arch/powerpc/configs/corenet64_fmanv3l_smp_defconfig
| GEN Makefile
| ERROR: oe_runmake failed
| ERROR: Execution of '/home/suchita/yocto-sdk/build_t1040d4rdb-64b/tmp/work/t1040d4rdb_64b-fsl-linux/linux-qoriq/5.4.3+gitAUTOINC+134788b164-r0/temp/run.do_merge_delta_config.2218664' failed with exit code 1:
| GEN Makefile
ERROR: Task (/home/suchita/yocto-sdk/sources/meta-freescale/recipes-kernel/linux/linux-qoriq_5.4.bb:do_merge_delta_config) failed with exit code '1'
NOTE: Tasks Summary: Attempted 1997 tasks of which 534 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There were 6 WARNING messages shown.
19,509 次查看
yipingwang
Please modify the following in t1040d4rdb-64b.conf
KERNEL_DEFCONFIG ?= "${S}/arch/powerpc/configs/corenet64_fmanv3l_smp_defconfig"
KBUILD_DEFCONFIG ?= "corenet64_fmanv3l_smp_defconfig
to
KERNEL_DEFCONFIG ?= "corenet64_smp_defconfig"
标记 (1)
19,486 次查看
Suraj_Prakash
          I am getting the following errors, Please suggest
Parsing recipes: 100% |################################################################################################################| Time: 0:01:06
TARGET_FPU = "hard"
meta
meta-poky
meta-oe
meta-multimedia
meta-python
meta-networking
meta-gnome
meta-filesystems
meta-webserver
Initialising tasks: 100% |#############################################################################################################| Time: 0:00:03
Sstate summary: Wanted 2740 Found 0 Missed 2740 Current 641 (0% match, 18% complete)
NOTE: Executing Tasks
WARNING: u-boot-qoriq-2019.10+fslgit-r0 do_fetch: Failed to fetch URL git://source.codeaurora.org/external/qoriq/qoriq-components/u-boot;nobranch=1, attempting MIRRORS if available
WARNING: bjam-native-1.72.0-r0 do_fetch: Failed to fetch URL https://dl.bintray.com/boostorg/release/1.72.0/source/boost_1_72_0.tar.bz2, attempting MIRRORS if available
WARNING: boot-format-native-git-r6 do_fetch: Failed to fetch URL git://source.codeaurora.org/external/qoriq/qoriq-yocto-sdk/boot-format;nobranch=1, attempting MIRRORS if available
WARNING: qe-ucode-git-r0 do_fetch: Failed to fetch URL git://github.com/NXP/qoriq-qe-ucode.git;nobranch=1, attempting MIRRORS if available
WARNING: rcw-git-r0 do_fetch: Failed to fetch URL git://source.codeaurora.org/external/qoriq/qoriq-components/rcw;nobranch=1, attempting MIRRORS if available
WARNING: fm-ucode-git-r1 do_fetch: Failed to fetch URL git://github.com/NXP/qoriq-fm-ucode.git;nobranch=1, attempting MIRRORS if available
WARNING: man-pages-5.05-r0 do_fetch: Failed to fetch URL https://cdn.kernel.org/pub/linux/docs/man-pages/man-pages-5.05.tar.gz, attempting MIRRORS if available
WARNING: stress-ng-0.11.01-r0 do_fetch: Failed to fetch URL https://kernel.ubuntu.com/~cking/tarballs/stress-ng/stress-ng-0.11.01.tar.xz, attempting MIRRORS if available
WARNING: linuxptp-2.0-r0 do_fetch: Failed to fetch URL http://sourceforge.net/projects/linuxptp/files/v2.0/linuxptp-2.0.tgz, attempting MIRRORS if available
WARNING: libnfnetlink-1.0.1-r0 do_fetch: Failed to fetch URL http://www.netfilter.org/projects/libnfnetlink/files/libnfnetlink-1.0.1.tar.bz2;name=tar, attempting MIRRORS if available
WARNING: qemu-qoriq-4.1.0-r0 do_fetch: Failed to fetch URL gitsm://source.codeaurora.org/external/qoriq/qoriq-components/qemu;nobranch=1, attempting MIRRORS if available
ERROR: qemu-qoriq-4.1.0-r0 do_fetch: Fetcher failure: Fetch command export PSEUDO_DISABLED=1; unset _PYTHON_SYSCONFIGDATA_NAME; export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1000/bus"; export ftp_proxy="ftp://pnc:[email protected]:8080/"; export https_proxy="https://pnc:[email protected]:8080/"; export http_proxy="http://pnc:[email protected]:8080/"; export PATH="/home/suchita/yocto-sdk/build_t1040d4rdb-64b/tmp/sysroots-uninative/x86_64-linux/usr/bin:/home/suchita/yocto-sdk/sources/poky/scripts:/home/suchita/yocto-sdk/build_t1040d4rdb-64b/tmp/work/ppc64e5500-fsl-linux/qemu-qoriq/4.1.0-r0/recipe-sysroot-native/usr/bin/powerpc64-fsl-linux:/home/suchita/yocto-sdk/build_t1040d4rdb-64b/tmp/work/ppc64e5500-fsl-linux/qemu-qoriq/4.1.0-r0/recipe-sysroot/usr/bin/crossscripts:/home/suchita/yocto-sdk/build_t1040d4rdb-64b/tmp/work/ppc64e5500-fsl-linux/qemu-qoriq/4.1.0-r0/recipe-sysroot-native/usr/sbin:/home/suchita/yocto-sdk/build_t1040d4rdb-64b/tmp/work/ppc64e5500-fsl-linux/qemu-qoriq/4.1.0-r0/recipe-sysroot-native/usr/bin:/home/suchita/yocto-sdk/build_t1040d4rdb-64b/tmp/work/ppc64e5500-fsl-linux/qemu-qoriq/4.1.0-r0/recipe-sysroot-native/sbin:/home/suchita/yocto-sdk/build_t1040d4rdb-64b/tmp/work/ppc64e5500-fsl-linux/qemu-qoriq/4.1.0-r0/recipe-sysroot-native/bin:/home/suchita/yocto-sdk/sources/poky/bitbake/bin:/home/suchita/yocto-sdk/build_t1040d4rdb-64b/tmp/hosttools"; export HOME="/home/suchita"; LANG=C git -c core.fsyncobjectfiles=0 clone --bare --mirror git://source.codeaurora.org/external/qoriq/qoriq-components/qemu /home/suchita/yocto-sdk/downloads/git2/source.codeaurora.org.external.qoriq.qoriq-components.qemu --progress failed with exit code 128, output:
Cloning into bare repository '/home/suchita/yocto-sdk/downloads/git2/source.codeaurora.org.external.qoriq.qoriq-components.qemu'...
fatal: unable to connect to source.codeaurora.org:
source.codeaurora.org[0: 149.129.177.114]: errno=Connection timed out
ERROR: qemu-qoriq-4.1.0-r0 do_fetch: Fetcher failure for URL: 'gitsm://source.codeaurora.org/external/qoriq/qoriq-components/qemu;nobranch=1'. Unable to fetch URL from any source.
ERROR: Logfile of failure stored in: /home/suchita/yocto-sdk/build_t1040d4rdb-64b/tmp/work/ppc64e5500-fsl-linux/qemu-qoriq/4.1.0-r0/temp/log.do_fetch.3457431
ERROR: Task (/home/suchita/yocto-sdk/sources/meta-freescale/recipes-devtools/qemu/qemu-qoriq_4.1.0.bb:do_fetch) failed with exit code '1'
NOTE: Tasks Summary: Attempted 5096 tasks of which 2435 didn't need to be rerun and 1 failed.
Summary: There were 11 WARNING messages shown.
19,479 次查看
yipingwang
It seems that the Website accessing is not stable, please run the following command to fetch the qemu source code again.
$ bitbake qemu-qoriq -c patch -f
19,473 次查看
Suraj_Prakash
    I m still getting the below errors.
suchita@linux:~/yocto-sdk/build_t1040d4rdb-64b$ bitbake qemu-qoriq -c patch -f
Loading cache: 100% |##################################################################################################################| Time: 0:00:01
TARGET_FPU = "hard"
meta
meta-poky
meta-oe
meta-multimedia
meta-python
meta-networking
meta-gnome
meta-filesystems
meta-webserver
NOTE: Tainting hash to force rebuild of task /home/suchita/yocto-sdk/sources/meta-freescale/recipes-devtools/qemu/qemu-qoriq_4.1.0.bb, do_patch0:00:00
WARNING: /home/suchita/yocto-sdk/sources/meta-freescale/recipes-devtools/qemu/qemu-qoriq_4.1.0.bb:do_patch is tainted from a forced run| ETA: 0:00:00
Initialising tasks: 100% |#############################################################################################################| Time: 0:00:01
Sstate summary: Wanted 0 Found 0 Missed 0 Current 20 (0% match, 100% complete)
ERROR: qemu-qoriq-4.1.0-r0 do_fetch: Fetcher failure: Fetch command export PSEUDO_DISABLED=1; unset _PYTHON_SYSCONFIGDATA_NAME; export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1000/bus"; export ftp_proxy="suchita:@[email protected]:8080"; export https_proxy="suchita:@[email protected]:8080"; export http_proxy="suchita:[email protected]:8080"; export PATH="/home/suchita/yocto-sdk/build_t1040d4rdb-64b/tmp/sysroots-uninative/x86_64-linux/usr/bin:/home/suchita/yocto-sdk/sources/poky/scripts:/home/suchita/yocto-sdk/build_t1040d4rdb-64b/tmp/work/ppc64e5500-fsl-linux/qemu-qoriq/4.1.0-r0/recipe-sysroot-native/usr/bin/powerpc64-fsl-linux:/home/suchita/yocto-sdk/build_t1040d4rdb-64b/tmp/work/ppc64e5500-fsl-linux/qemu-qoriq/4.1.0-r0/recipe-sysroot/usr/bin/crossscripts:/home/suchita/yocto-sdk/build_t1040d4rdb-64b/tmp/work/ppc64e5500-fsl-linux/qemu-qoriq/4.1.0-r0/recipe-sysroot-native/usr/sbin:/home/suchita/yocto-sdk/build_t1040d4rdb-64b/tmp/work/ppc64e5500-fsl-linux/qemu-qoriq/4.1.0-r0/recipe-sysroot-native/usr/bin:/home/suchita/yocto-sdk/build_t1040d4rdb-64b/tmp/work/ppc64e5500-fsl-linux/qemu-qoriq/4.1.0-r0/recipe-sysroot-native/sbin:/home/suchita/yocto-sdk/build_t1040d4rdb-64b/tmp/work/ppc64e5500-fsl-linux/qemu-qoriq/4.1.0-r0/recipe-sysroot-native/bin:/home/suchita/yocto-sdk/sources/poky/bitbake/bin:/home/suchita/yocto-sdk/build_t1040d4rdb-64b/tmp/hosttools"; export HOME="/home/suchita"; LANG=C git -c core.fsyncobjectfiles=0 clone --bare --mirror git://source.codeaurora.org/external/qoriq/qoriq-components/qemu /home/suchita/yocto-sdk/downloads/git2/source.codeaurora.org.external.qoriq.qoriq-components.qemu --progress failed with exit code 128, output:
ERROR: Logfile of failure stored in: /home/suchita/yocto-sdk/build_t1040d4rdb-64b/tmp/work/ppc64e5500-fsl-linux/qemu-qoriq/4.1.0-r0/temp/log.do_fetch.52735
NOTE: Tasks Summary: Attempted 91 tasks of which 90 didn't need to be rerun and 1 failed.
Summary: There were 2 WARNING messages shown.
19,450 次查看
Suraj_Prakash
      Please let me know how to compile linux only in SDK and also also how to open menuconfig window.
19,431 次查看
yipingwang
1. $ bitbake virtual/kernel -c cleansstate
2. $ bitbake virtual/kernel -c configure
3. Go to folder build_t1040d4rdb/tmp/work/t1040d4rdb-fsl-linux/linux-qoriq/5.4.3+gitAUTOINC+134788b164-r0/build/, run the following command.
$make ARCH=powerpc menuconfig
4. $ bitbake virtual/kernel -c compile -f
5. $ bitbake virtual/kernel
6. Go to step3 to configure Linux Kernel again.
19,469 次查看
yipingwang
Please check whether is is possible to execute the following command on your host PC.
git clone git://source.codeaurora.org/external/qoriq/qoriq-components/qemu
If not, please check the proxy settings  on your host PC.
It seems that all packages from "source.codeaurora.org/external/qoriq/qoriq-components" are not accessible on your host PC.
19,457 次查看
Suraj_Prakash
      I was getting some booting errors and also the mapping of eth* interfaces to fm1-gb* interfaces is also not happening when I tried using the Linux compiled in SDK 3.1 but the Linux which I used earlier from SDK 2.0 (patch SDK-V2.0-1701)  gave no such errors.
Please suggest how to overcome the issue.
Please find attached the bootlogs with Linux from SDK 2.0 and SDK 3.1
19,556 次查看
Suraj_Prakash
Also I would like to know is there any latest freescale firmware supports mpls in hardware or not ???
19,546 次查看
yipingwang
I don't have this information, please create a new thread to let the hardware team to answer you.
