Hello, again!
The problem was solved only partially.
Now we can receive and transmit frames thru the 10GBASE-KR interface, but with 3-7% losses.
Linux 10GBASE-KR driver has more complex routines than only writing the SerDes register but we still dont know how to launch the driver properly.
Is it right that u-boot sources are need to be changed, or we have to change only device-tree file?
Is there some instructions - how to perform all the changes to customize software (u-boot, dts, kernel, etc.) in this aspect?
