How to compile kernel module for T2080rdb
2,591件の閲覧回数
hongyuanzhao
driver$ make ARCH=powerpc CROSS_COMPILE=$CROSS_COMPILE CC="${CC}" LD="${LD}" AR="${AR}" OBJCOPY="${OBJCOPY}"
make -I . ARCH=powerpc CROSS_COMPILE=powerpc64-fsl-linux- -C /home/ast/QorIQ-SDK-V2.0-20160527-yocto/build_t2080rdb-64b/tmp/work/t2080rdb_64b-fsl-linux/linux-qoriq/4.1-r0/build/ M=/mnt/work/7900/ALTHEA7910/driver modules
make[1]: Entering directory `/home/ast/QorIQ-SDK-V2.0-20160527-yocto/build_t2080rdb-64b/tmp/work/t2080rdb_64b-fsl-linux/linux-qoriq/4.1-r0/build'
CC [M] /mnt/work/src/driver/test_drvr.o
powerpc64-fsl-linux-ld: unrecognized option '-Wl,-O1'
powerpc64-fsl-linux-ld: use the --help option for usa
4 返答(返信)
2,516件の閲覧回数
June_Lu
Have you follow the
 FAQ | QorIQ SDK v2.0-1703 Documentation | NXP Semiconductors
 "How do I use standalone toolchain to build kernel?".
2,548件の閲覧回数
June_Lu
Please refer to FAQ | QorIQ SDK v2.0-1703 Documentation | NXP Semiconductors
Find the "How do I use standalone toolchain to build kernel?".
2,537件の閲覧回数
hongyuanzhao
Compile your own defined kernel module and compile to generate ko
2,538件の閲覧回数
hongyuanzhao
hi June_Lu ,
Write your own kernel module;
