Perpetual license problem
Tgomes
A few months ago bought a perpetual license, but the CodeWarrior (10.1) does not recognize the file "license.dat". This file has been changed several times, but the problem persists. Anyone ever had or currently has a similar problem?
Tgomes
The problem was solved. A new license file was generated with the help of technical support from Freescale, and this time the file worked perfectly.
Regards.
c0170
Senior Contributor III
Hi Tgomes,
you posted your problem to the wrong section. People should be able to help you in Codewarrior section.
MartinK
Tgomes
MartinK,
You're right, I will move the problem. Thank's..
admin
Specialist II
Hi Tgomes,
If you still have a licensing problem, please email [email protected] for help.
Thanks!
Lee
Tgomes
Lee,
I filled out a service request a few days ago, but I'll also send an email, as you suggested, thanks for the help.
Tgomes.
Tgomes
Regards.
