License problem
License problem
10,531 次查看
Simulator
I am installed CodeWarrior.
I am get the registry and authorisation code. and ETHERNET card
I get the license:
But, then I press to IDE icon I get
the next message:
THe license was not found, auth code was not found
No such future exist:
Win32_CWIDE_limited
Flexlm error -5,357
Please help me to open codeWarrior
标记 (1)
4,734 次查看
CrasyCat
Specialist III
Hello
I would recommend you to send an email to our licensing department describing the problem and attaching the license file and information about the product you have installed.
Also if you can deliver tools information tat would be perfect.
To collect these information:
- Start a window explorer
- Browse for your installation PROG sub-directory
- Start linker.exe
- Select Help -> About
-     Click on the “Extended Information” button.
-      When text changes to “Added Information” all necessary data are available.
-       Copy whole content of the dialog box to a text file that you can send over to licensing.
CrasyCat
7 回复数
4,734 次查看
CrasyCat
Specialist III
Hello
Which processor are you targeting (HC08, HC12, Coldfire, ...)?
Which version of CodeWarrior are you using?
CrasyCat
4,734 次查看
Simulator
I  installed  CodeWarrior 8
Development Studio MPC5XX Edition
and on disk is CW_EPPC 5XX_8.1
Thank you
4,734 次查看
CrasyCat
Specialist III
Hello
 For some reason you probably discard your original license.dat file.
 Can you please add the following line at the beginning of your license file (in
 your CodeWarrior installation directory):
FEATURE Win32_CWIDE_Limited metrowks 5.5 permanent uncounted \
       2589EF7E8174 HOSTID=ANY
This should allow you to at least open the IDE
CrasyCat
4,734 次查看
Simulator
CrasyCat.
Thank you ,for help
But after registration
I get the
next file,that is not working.
That can I do with this license file?
We buy 10 licenses ,and no one of them worked.
FEATURE
        HI014150 HIWARE 2.0 permanent uncounted B8CD4F1481D0 \
       HOSTID=000d61604ee6 NOTICE=AAJC8-2E813-F313D-C686E
FEATURE HI040155 HIWARE 2.0 permanent uncounted 0555E7EE7A8D \
FEATURE HI040160 HIWARE 2.0 permanent uncounted FD4907CF10F9 \
FEATURE HI040170 HIWARE 2.0 permanent uncounted F1D434B402FD \
FEATURE HI044010 HIWARE 2.0 permanent uncounted 2172228AFC82 \
FEATURE HI044011 HIWARE 2.0 permanent uncounted 8327078208D6 \
FEATURE HI044012 HIWARE 2.0 permanent uncounted D41A006E9CE2 \
FEATURE HI044013 HIWARE 2.0 permanent uncounted 889925DE0836 \
FEATURE HI044014 HIWARE 2.0 permanent uncounted BBAA560A2CDA \
FEATURE HI044015 HIWARE 2.0 permanent uncounted CF6DCB62180E \
FEATURE HI044016 HIWARE 2.0 permanent uncounted 8B8FD48EFC8A \
FEATURE HI044017 HIWARE 2.0 permanent uncounted 1980D96E28EE \
FEATURE HI044018 HIWARE 2.0 permanent uncounted 4172AA7AAC32 \
FEATURE HI044019 HIWARE 2.0 permanent uncounted 3C254F9238C6 \
FEATURE HI044020 HIWARE 2.0 permanent uncounted 8872C71F064E \
FEATURE HI044021 HIWARE 2.0 permanent uncounted A89B2093FEEA \
FEATURE HI404000 HIWARE 2.0 permanent uncounted B88F89911236 \
FEATURE HI404010 HIWARE 2.0 permanent uncounted 7C4DDA26B4B6 \
FEATURE HI404020 HIWARE 2.0 permanent uncounted 3BE52F3B8EC2 \
FEATURE HI404030 HIWARE 2.0 permanent uncounted 8053A89020CA \
FEATURE HI404050 HIWARE 2.0 permanent uncounted B28906EA94A6 \
FEATURE HI404060 HIWARE 2.0 permanent uncounted 84EEEB6F5ED2 \
FEATURE HI404100 HIWARE 2.0 permanent uncounted C5F3A5C568F5 \
FEATURE HI404105 HIWARE 2.0 permanent uncounted 70711A1590D1 \
FEATURE HI404220 HIWARE 2.0 permanent uncounted 49926F4386A8 \
FEATURE HI415240 HIWARE 2.0 permanent uncounted B7B2FACD68CA \
FEATURE HI415245 HIWARE 2.0 permanent uncounted 577AE7D9E086 \
FEATURE HI491000 HIWARE 2.0 permanent uncounted 0A78B651AC18 \
4,735 次查看
CrasyCat
Specialist III
Hello
- Start linker.exe
CrasyCat
4,734 次查看
alex_spotw
HI:
Did you copy the new licence file into the CodeWarrior folder (C:\Program Files\Metrowerks\CW xxxx )
This works for us.
Alex
4,735 次查看
peg
Senior Contributor IV
Gee now Codewarrior is prophesying!!!
Sorry I am sure you meant feature :smileyvery-happy:
Peg
