License compatibility between classic and eclipse ide
1,810件の閲覧回数
CorderBollie
I wonder if it Is possible to use a perpetual floating license of 10.6 Codewarrior also for the classic Codewarrior 9.2 (mobileGT) ?
1,572件の閲覧回数
Carlos_Mendoza
Hi CorderBoliie,
If you want a license to work with both CodeWarrior 10.6 and CodeWarrior 9.2 you need to generate a new one, to do that please follow these steps:
- Access your Software products
- Go to Order History
- Select your Registration Code
- Go to Licenses
- Select the licenses you need, in this case you need to select CodeWarrior 10.6 and CodeWarrior 9.2
- Assign Server Information
- Click on Generate
The license generated will now work with both CodeWarrior versions.
Here is a video that shows how to access your Software products:
How to access your Software products|Freescale
Hope it helps!
Carlos Mendoza
Technical Support Engineer
1,573件の閲覧回数
Carlos_Mendoza
Hi CorderBoliie,
- Go to Licenses
- Click on Generate
Hope it helps!
Carlos Mendoza
