FlexLM server Licensing
2,222 次查看
stankogradev
- Do I have to delete the enviremental variable which points to the license server in order to release the license copy for use by other colleagues or the normal closing of the application is sufficient for the release of the license number ?
标记 (3)
1,693 次查看
trytohelp
just an additional info.
By default the feature(s) is(are) pre-reserved some times (5mn) for the same client/user.
The feature(s) can not be use immediately by another customer during this time, even if the CodeWarrior was closed on First client.
After 5mn the feature(s) will be available for other clients.
the rule is defined in Flexlm manual as lingering time.
For CodeWarrior the default value is 5mn.
The user can not reduce this time but can increase it.
regards
Pascal
1,693 次查看
ZhangJennie
yes, the normal closing of the application is sufficient for the release of the license number.
