Build error in code warrior project
kanu__
hi ,
when i am trying to  build my project , am getting the following error.
any idea ?
process_begin: CreateProcess(NULL, echo "Regenerating dependency file: code/common/residu.d", ...) failed.
make (e=2): The system cannot find the file specified.
But the same project is successfully building in all other machines other than my machine.
Can you give ma rough idea about this kind of error ?
/renjith_g
kanu__
hi all ,
me solved the above problem by the following way.
* The problem was due to the registry corruption(for path) in my machine for  my own user.
* Deleted that user and created a new one .
* Tried building it in the new user account and it was found successfull.
/Kanu__
kanu__
hi ,
can anyone solve my new problem ?
https://community.freescale.com/thread/51806
/Kanu__
Irene
NXP Pro Support
NXP Pro Support
Which version of CodeWarrior tools are you using? Which processor are you using?  What operating system are you running on this machine?
Irene
kanu__
Please see the inline reply,
>> Code warrior version 10.0
>>My host machine is Genuine Intel(R) CPU 2140 @1.60 GHz
>> I am having Microsoft Windows Xp professional version 2002 with service pack 2
/Kanu__
CrasyCat
Specialist III
Hello
Can you please try to do a Clean Project and than a Build Project?
I assume the CodeWarrior generated make files are pointing to some directory paths that do not exist on your system.
CrasyCat
kanu__
yes , i have done like that.
Now am suspecting my registry settings (especially the path settings , regedt32.exe) , because i've tried all other code warrior settings.
Also , i havn't got the expansion of the elb file format  yet.
/Kanu__
Irene
NXP Pro Support
NXP Pro Support
You did get a response for they elb format.  It is just the extension that is given to binary files that are produced by the Librarian.
Irene
NXP Pro Support
NXP Pro Support
Is this a wizard project?  Is this a project that was imported from a previous version of CodeWarrior?
kanu__
hi all ,
/Kanu__
