NCJ38 operation method
2,737 次查看
nioer
hello, NXP,
we use MCU to operate the NCJ38 device, now we need to use software to test the SPI hardware which between MCU and NCJ38 is ok .
My question is that how to test the SPI, could we read some device ID of NCJ38 and check the hardware. In the datasheet of NCJ38 , we could not find related information about the device ID that the SPI could check. Could you give us some advice on how to test the NCJ38 device?
Thank you .
1 回复
2,732 次查看
Kan_Li
Hi @nioer ,
Info about NCJ38 is under NDA protection, and so we are not allowed to discuss it in a public community, is it possible to create a private ticket according to the following video?
https://www.nxp.com/video/tutorial-for-nxp-support-case-portal:NCP-VIDEO
Thanks for your patience!
Kan
