mma8451 Motion Detection and RaspberryPi 2b+
4,777 次查看
luigi5hd
Goodmornig,
This is my main code:
xOffset = -0.400 # m/s^2
yOffset =  0.200 # m/s^2
zOffset =  9.400 # m/s^2
while True:
    while sensor.Motion():
        x, y, z = sensor.acceleration
        time_now = datetime.datetime.now()
        Calcx = -xOffset
        Calcy = -yOffset
        Calcz = -zOffset
        X = x + Calcx
        Y = y + Calcy
        Z = z + Calcz
        sensor.MotionRegister()
        print('Time={0}   X={1:0.3f} m/s^2  Y:{2:0.3f} m/s^2  Z:{3:0.3f} m/s^2'.format(time_now, X, Y, Z))
        time.sleep(0)
    IntSourceMFF = sensor.MotionRegister()
And I have setup my MMA8451 into a class like this:
    def Motion (self): #, IntSourceSystem,IntSourceMFF):
        reg1 = self._read_u8(_MMA8451_REG_CTRL_REG1)
        reg1 &= 0xFE #clear active bit (standby)
        self._write_u8(_MMA8451_REG_CTRL_REG1, reg1)
        self._write_u8(REG_FF_MT_CONFIG, 0x48) #Moto detection X axe after the debounce time (100)ms is reached
        self._write_u8(REG_FF_MT_THS, 0x10)    #threshold 1g: es 1g/0.063g = 16 counts = 10 (hexadecimal)
        self._write_u8(REG_FF_MT_COUNT, 0x0A) #Debounce counter, set at 12.5ms timer for 800 output data rate
        self._write_u8(_MMA8451_REG_CTRL_REG4, 0x04)
        self._write_u8(_MMA8451_REG_CTRL_REG5, 0x04)
        # self._write_u8(_MMA8451_REG_CTRL_REG3, 0x04)
        self._write_u8(_MMA8451_REG_CTRL_REG1, reg1 | 0x01) #activated
        print("It will work")
        IntSourceSystem = self._read_u8(_MMA8451_INT_SOURCE)
        if ((IntSourceSystem & 0x04) == 0x04):
            print("You are into if")
            return True
        else:
            print("You are into else")
            return False
    def MotionRegister (self):
        return self._read_u8(REG_MT_SRC)
Something strange happens, it works properly only if I print something in my setup module (in this case "It will work").
Why it does it? I don't want that print.
Maybe it is a problem with the Count register setup..I didn't well realized how to use it, I want to use a 100ms timer for 800 ODR but with 0x50 didn't works..
Can someone help me pls?
8 回复数
4,368 次查看
luigi5hd
Hey Tomas,
Firstly best wishes!!
I still have the same problem with the autocalibration..
But I want to change my question:
If the device is stationary on a "flat" desktop, and the measures are
X= 0.201 m/s2
Y= 0.220 m/s2
Z= 9.409 m/s2
Which is the best way to gain:
X= 0 m/s2
Y= 0 m/s2
Z= 9.81 m/s2   ?
I'm also available to use the simple method calibration, but how can I be able to delete the noise?
Am I forced to use the High pass filter or can I use the offset registers?
What do you think? And can you suggest me how to do it?
Thank you, best regards.
4,368 次查看
TomasVaverka
Hi Luigi,
First off... Happy New Year and sorry for my late response.
Everything you described in your post from Dec 21st is correct for 8g mode.
In order to reduce noise, our recommendation is using lowest possible ODR and High Resolution Mode as shown in the AN4075 (page 7).
Tomas
4,367 次查看
luigi5hd
ok I have solved the print problem; it was just a bad use of the class module; I just have the reg count problem, can someone explain it to me?
4,368 次查看
TomasVaverka
Hi Luigi,
As I do not fully understand what you are asking, I would refer to the AN4070 where you may find useful information related to the embedded motion detection function. If you need to know anything specific, please elaborate it a bit more.
Tomas
4,368 次查看
luigi5hd
Hi Tomas,
Yes I have already read the AN4070 note,
so, my problem was to how to calculate correctly the value to write into the FF_MT_THS register (0x17), and it is just "Threshold/0.063" ;
and how to calculate correctly the value to write into the FF_MT_COUNT register (0x18), and it is just  "DebounceTime/TimeStep".
Forget about them.
Now I have another problem:
I'm trying to doing the Aut-Calibration Procedure of the device.
yes, I have already read the AN4069 note :smileyhappy:
On page 6 of the note there is an example using a flow chart.
I didn't understand the 3th box:
Have I to read, (and so print?) the acceleration on X,Y, and Z using firstly the register OUT_X_MSB?
After that have I to read the acceleration on X,Y, and Z using the register OUT_X_LSB?
After that have I to read the acceleration on X,Y, and Z using the register OUT_Y_MSB? etc?
4,368 次查看
luigi5hd
I've tried to do as I mentioned and my Acceleration values are these:
first line X,Y,Z using OUT_X_MSB
second X,Y,Z using OUT_X_LSB
third X,Y,Z using OUT_Y_MSB
fourth X,Y,Z using OUT_Y_LSB
etc.
Are these the values that I need to use in the next step, for the 2's complement?
Thank you.
4,368 次查看
TomasVaverka
Hi Luigi,
Sorry for my late response. I would recommend you to take a look at my simple example code for the MMA8451Q where I illustrate offset calibration based on the AN4069.
You should use something like this:
I2C_ReadMultiRegisters(MMA845x_I2C_ADDRESS, OUT_X_MSB_REG, 6, AccData);           // Read data output registers 0x01-0x06
Xout_14_bit = ((short) (AccData[0]<<8 | AccData[1])) >> 2;           // Compute 14-bit X-axis output value
Yout_14_bit = ((short) (AccData[2]<<8 | AccData[3])) >> 2;           // Compute 14-bit Y-axis output value
Zout_14_bit = ((short) (AccData[4]<<8 | AccData[5])) >> 2;           // Compute 14-bit Z-axis output value
Xoffset = Xout_14_bit / 8 * (-1);        // Compute X-axis offset correction value
Yoffset = Yout_14_bit / 8 * (-1);        // Compute Y-axis offset correction value
Zoffset = (Zout_14_bit - SENSITIVITY_2G) / 8 * (-1);          // Compute Z-axis offset correction value
I2C_WriteRegister(MMA845x_I2C_ADDRESS, CTRL_REG1, 0x00);             // Standby mode to allow writing to the offset registers
I2C_WriteRegister(MMA845x_I2C_ADDRESS, OFF_X_REG, Xoffset);
I2C_WriteRegister(MMA845x_I2C_ADDRESS, OFF_Y_REG, Yoffset);
I2C_WriteRegister(MMA845x_I2C_ADDRESS, OFF_Z_REG, Zoffset);
Hope it helps!
Tomas
4,368 次查看
luigi5hd
Yes, I was just following your metal bare example but I still have some problem.
Firstly: I'm in 14 bit, ODR 800, 8g mode.
Here:
What are you doing with this shifting?
Is this equivalent to a 2's complement for XYZ no?
And are they approximated as integers no? ("short" operator)
Now I've calculated the  Offset like this:
Xoffset = Xout_14_bit / 2 * (-1);        // Compute X-axis offset correction value
Yoffset = Yout_14_bit / 2 * (-1);        // Compute Y-axis offset correction value
Zoffset = (Zout_14_bit - 1024) / 2 * (-1);          // Compute Z-axis offset correction value with 8g sensitivity
It looks correct to me..
After that I convert them as hexadecimal (ok?) and I put them into the Offset registers:
I2C_WriteRegister(MMA845x_I2C_ADDRESS, CTRL_REG1, 0x01);             // Active mode
And it doesn't work properly anyway :/
The y and z acceleration doesn't change enough, and  X acceleration doesn't change at all.
NB my stationary target is:
X=0g
Y=0g
Z=1g
Obvious my device is properly oriented.
I'm sorry if I'm annoying you too much, I'm a bit noob.
Thank you and merry Christmas.
%3CLINGO-SUB%20id%3D%22lingo-sub-817836%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Emma8451%20%E8%BF%90%E5%8A%A8%E6%A3%80%E6%B5%8B%E5%92%8C%20RaspberryPi%202b%2B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-817836%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EGoodmornig%E3%80%81%3C%2FP%3E%3CP%3E%E8%BF%99%E6%98%AF%E6%88%91%E7%9A%84%E4%B8%BB%E4%BB%A3%E7%A0%81%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%22%3C%2FP%3E%3CP%3Ex%20%E5%81%8F%E7%A7%BB%20%3D%20-0.400%23%20m%2Fs%5E2%3CBR%20%2F%3EyOffset%20%3D%200.200%23%20m%2Fs%5E2%3CBR%20%2F%3EzOffset%20%3D%209.400%23%20m%2Fs%5E2%3CBR%20%2F%3Ewhile%20True%3A%3CBR%20%2F%3E%20while%20sensor.Motion()%EF%BC%9A%3CBR%20%2F%3E%20%20%20%20%20%20%20x%2C%20y%2C%20z%20%3D%20sensor.acceleration%3CBR%20%2F%3E%20time_now%20%3D%20datetime.datetime.now()%3CBR%20%2F%3E%20Calcx%20%3D%20-xOffset%3CBR%20%2F%3E%20Calcy%20%3D%20-yOffset%3CBR%20%2F%3E%20Calcz%20%3D%20-zOffset%3CBR%20%2F%3E%20X%20%3D%20x%20%2B%20Calcx%3CBR%20%2F%3E%20Y%20%3D%20y%20%2B%20Calcy%3CBR%20%2F%3E%20Z%20%3D%20z%20%2B%20Calcz%3CBR%20%2F%3E%20%20%20%20%3CBR%20%2F%3E%20sensor.MotionRegister()%3CBR%20%2F%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%3CBR%20%2F%3E%20print('Time%3D%7B0%7D%20X%3D%7B1%3A0.3f%7D)m%2Fs%5E2%20Y%3A%7B2%3A0.3f%7Dm%2Fs%5E2%20Z%3A%7B3%3A0.3f%7Dm%2Fs%5E2'.format(time_now%E3%80%81X%2C%20Y%2C%20Z))%3CBR%20%2F%3E%20time.sleep(0)%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%20%20IntSourceMFF%20%3D%20sensor.MotionRegister()%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%22%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%8A%8A%E6%88%91%E7%9A%84%20MMA8451%20%E8%AE%BE%E7%BD%AE%E6%88%90%E4%BA%86%E8%BF%99%E6%A0%B7%E4%B8%80%E4%B8%AA%E7%B1%BB%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%22%22%3C%2FP%3E%3CP%3E%20%20%20%20def%20Motion%20(self)%EF%BC%9A%23%2C%20IntSourceSystem%2CIntSourceMFF)%3A%3CBR%20%2F%3E%20reg1%20%3D%20self._read_u8(_MMA8451_REG_CTRL_REG1)%3CBR%20%2F%3E%20reg1%26amp%3B%3D%200xFE%20%23%E6%B8%85%E9%99%A4%E6%B4%BB%E5%8A%A8%E4%BD%8D%EF%BC%88%E5%BE%85%E6%9C%BA%EF%BC%89%3CBR%20%2F%3E%20self._write_u8(_MMA8451_REG_CTRL_REG1%E3%80%81reg1)%3CBR%20%2F%3E%20self._write_u8(REG_FF_MT_CONFIG%E3%80%810x48)%23Moto%20detection%20X%20axe%20after%20the%20debounce%20time%20(100)ms%20is%20reached%3CBR%20%2F%3E%20self._write_u8(REG_FF_MT_THS%E3%80%810x10)%20%20%20%20%23threshold%201g%3A%20es%201g%2F0.063g%3D%2016%20%E8%AE%A1%E6%95%B0%20%3D%2010%EF%BC%88%E5%8D%81%E5%85%AD%E8%BF%9B%E5%88%B6%EF%BC%89%3CBR%20%2F%3E%20self._write_u8(REG_FF_MT_COUNT%E3%80%81%3CBR%20%2F%3E%20self._write_u8(_MMA8451_REG_CTRL_REG4%E3%80%810x04)%3CBR%20%2F%3E%20self._write_u8(_MMA8451_REG_CTRL_REG5%E3%80%810x04)%3CBR%20%2F%3E%20%20%20%20%20%20%20%23%20self._write_u8(_MMA8451_REG_CTRL_REG3%2C0x04)%3CBR%20%2F%3E%20reg1%20%3D%20self._read_u8(_MMA8451_REG_CTRL_REG1)%3CBR%20%2F%3E%20self._write_u8(_MMA8451_REG_CTRL_REG1%2Creg1%20%7C%200x01)%23activated%3CBR%20%2F%3E%20print(%22It%20will%20work%22)%3CBR%20%2F%3E%20IntSourceSystem%20%3D%20self._read_u8(_MMA8451_INT_SOURCE)%3CBR%20%2F%3E%20if%20((IntSourceSystem%26amp%3B%200x04)%20%3D%3D%200x04)%3A%3CBR%20%2F%3E%20print(%22You%20are%20into%20if%22)%3CBR%20%2F%3E%20return%20True%3CBR%20%2F%3E%20else%3A%3CBR%20%2F%3E%20print(%22You%20are%20into%20else%22)%3CBR%20%2F%3E%20return%20False%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%20%20%20def%20MotionRegister%20(self)%3A%3CBR%20%2F%3E%20return%20self._read_u8(REG_MT_SRC)%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%22%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%A5%87%E6%80%AA%E7%9A%84%E4%BA%8B%E6%83%85%E5%8F%91%E7%94%9F%E4%BA%86%EF%BC%8C%E5%8F%AA%E6%9C%89%E5%9C%A8%E6%88%91%E7%9A%84%E8%AE%BE%E7%BD%AE%E6%A8%A1%E5%9D%97%E4%B8%AD%E6%89%93%E5%8D%B0%E6%9F%90%E4%BA%9B%E5%86%85%E5%AE%B9%E6%97%B6%EF%BC%8C%E5%AE%83%E6%89%8D%E8%83%BD%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%EF%BC%88%E5%9C%A8%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8C%22%E5%AE%83%E5%B0%86%E5%B7%A5%E4%BD%9C%22%20%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%E4%B8%BA%E4%BB%80%E4%B9%88%E4%BC%9A%E8%BF%99%E6%A0%B7%EF%BC%9F%E6%88%91%E4%B8%8D%E6%83%B3%E8%A6%81%E8%BF%99%E7%A7%8D%E5%8D%B0%E5%88%B7%E5%93%81%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%B9%9F%E8%AE%B8%E6%98%AF%E8%AE%A1%E6%95%B0%E5%AF%84%E5%AD%98%E5%99%A8%E7%9A%84%E8%AE%BE%E7%BD%AE%E5%87%BA%E4%BA%86%E9%97%AE%E9%A2%98......%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%E8%AF%A5%E5%A6%82%E4%BD%95%E4%BD%BF%E7%94%A8%E5%AE%83%EF%BC%8C%E6%88%91%E6%83%B3%E4%BD%BF%E7%94%A8%E4%B8%80%E4%B8%AA%20100ms%20%E7%9A%84%E5%AE%9A%E6%97%B6%E5%99%A8%E6%9D%A5%E5%A4%84%E7%90%86%20800%20ODR%EF%BC%8C%E4%BD%86%200x50%20%E5%8D%B4%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%E3%80%82%3C%2FP%3E%3CP%3E%E8%B0%81%E8%83%BD%E5%B8%AE%E5%B8%AE%E6%88%91%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-817836%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E5%8A%A0%E9%80%9F%E5%BA%A6%E4%BC%A0%E6%84%9F%E5%99%A8%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-817844%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20mma8451%20Motion%20Detection%20and%20RaspberryPi%202b%2B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-817844%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%97%A8%EF%BC%8C%E8%B7%AF%E6%98%93%E5%90%89%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%A6%96%E5%85%88...%E6%96%B0%E5%B9%B4%E5%BF%AB%E4%B9%90%EF%BC%8C%E5%AF%B9%E4%B8%8D%E8%B5%B7%EF%BC%8C%E6%88%91%E7%9A%84%E5%9B%9E%E5%A4%8D%E6%99%9A%E4%BA%86%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E5%9C%A8%2012%20%E6%9C%88%2021%20%E6%97%A5%E7%9A%84%E5%B8%96%E5%AD%90%E4%B8%AD%E6%8F%8F%E8%BF%B0%E7%9A%84%208g%20%E6%A8%A1%E5%BC%8F%E9%83%BD%E6%98%AF%E6%AD%A3%E7%A1%AE%E7%9A%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%B8%BA%E4%BA%86%E5%87%8F%E5%B0%91%E5%99%AA%E9%9F%B3%EF%BC%8C%E6%88%91%E4%BB%AC%E5%BB%BA%E8%AE%AE%E4%BD%BF%E7%94%A8%E5%B0%BD%E5%8F%AF%E8%83%BD%E4%BD%8E%E7%9A%84%20ODR%20%E5%92%8C%E9%AB%98%E5%88%86%E8%BE%A8%E7%8E%87%E6%A8%A1%E5%BC%8F%EF%BC%8C%E5%A6%82%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN4075.pdf%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EAN4075%3C%2FA%3E%EF%BC%88%E7%AC%AC%207%20%E9%A1%B5%EF%BC%89%E6%89%80%E7%A4%BA%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%3E%E6%89%98%E9%A9%AC%E6%96%AF%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-817843%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20mma8451%20Motion%20Detection%20and%20RaspberryPi%202b%2B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-817843%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%98%BF%EF%BC%8C%E6%89%98%E9%A9%AC%E6%96%AF%E3%80%81%3C%2FP%3E%3CP%3E%E9%A6%96%E5%85%88%E8%87%B4%E4%BB%A5%E6%9C%80%E7%BE%8E%E5%A5%BD%E7%9A%84%E7%A5%9D%E6%84%BF%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%9C%A8%E8%87%AA%E5%8A%A8%E6%A0%A1%E5%87%86%E6%96%B9%E9%9D%A2%E4%BB%8D%E6%9C%89%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%86%E6%88%91%E6%83%B3%E6%8D%A2%E4%B8%80%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%9A%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E8%AE%BE%E5%A4%87%E5%9C%A8%20%22%20flat%20%22%20%E6%A1%8C%E9%9D%A2%E4%B8%8A%E9%9D%99%E6%AD%A2%E4%B8%8D%E5%8A%A8%EF%BC%8C%E4%B8%94%E6%B5%8B%E9%87%8F%E5%80%BC%E4%B8%BA%3C%2FP%3E%3CP%3EX%3D%200.201%20%E7%B1%B3%2F%E7%A7%922%3C%2FP%3E%3CP%3EY%3D%200.220%20%E7%B1%B3%2F%E7%A7%922%3C%2FP%3E%3CP%3EZ%3D%209.409%20%E7%B1%B3%2F%E7%A7%922%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%BF%99%E6%98%AF%E8%8E%B7%E5%BE%97%E6%94%B6%E7%9B%8A%E7%9A%84%E6%9C%80%E4%BD%B3%E6%96%B9%E5%BC%8F%EF%BC%9A%3C%2FP%3E%3CP%3EX%3D%200%20m%2Fs2%3C%2FP%3E%3CP%3EY%3D%200%20m%2Fs2%3C%2FP%3E%3CP%3EZ%3D%209.81%20m%2Fs2%20%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E4%B9%9F%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E7%AE%80%E5%8D%95%E6%96%B9%E6%B3%95%E8%BF%9B%E8%A1%8C%E6%A0%A1%E5%87%86%EF%BC%8C%E4%BD%86%E5%A6%82%E4%BD%95%E6%89%8D%E8%83%BD%E5%88%A0%E9%99%A4%E5%99%AA%E9%9F%B3%E5%91%A2%EF%BC%9F%20%3C%2FP%3E%3CP%3E%E6%88%91%E6%98%AF%E5%BF%85%E9%A1%BB%E4%BD%BF%E7%94%A8%E9%AB%98%E9%80%9A%E6%BB%A4%E6%B3%A2%E5%99%A8%EF%BC%8C%E8%BF%98%E6%98%AF%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E5%81%8F%E7%A7%BB%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%A0%E6%80%8E%E4%B9%88%E7%9C%8B%EF%BC%9F%E6%82%A8%E8%83%BD%E5%91%8A%E8%AF%89%E6%88%91%E6%80%8E%E4%B9%88%E5%81%9A%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%8C%E8%87%B4%E4%BB%A5%E6%9C%80%E5%B4%87%E9%AB%98%E7%9A%84%E6%95%AC%E6%84%8F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-817842%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20mma8451%20Motion%20Detection%20and%20RaspberryPi%202b%2B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-817842%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E6%88%91%E5%8F%AA%E6%98%AF%E5%9C%A8%E6%95%88%E4%BB%BF%E4%BD%A0%E7%9A%84%E9%87%91%E5%B1%9E%E8%A3%B8%E4%BD%93%E7%A4%BA%E4%BE%8B%EF%BC%8C%E4%BD%86%E6%88%91%E8%BF%98%E6%98%AF%E9%81%87%E5%88%B0%E4%BA%86%E4%B8%80%E4%BA%9B%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%E9%A6%96%E5%85%88%EF%BC%9A%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%2014%20%E4%BD%8D%E3%80%81ODR%20800%E3%80%818g%20%E6%A8%A1%E5%BC%8F%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E7%BB%99%E4%BD%A0%3C%2FP%3E%3CP%20style%3D%22margin%3A%200cm%3B%20margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3EXout_14_bit%20%3D%20((%3C%2FSPAN%3E%3CSTRONG%20style%3D%22border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%20color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%22%3E%E7%9F%AD%3C%2FSTRONG%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E)%20(AccData%5B0%5D%26lt%3B%26lt%3B%208%20%7C%20AccData%5B1%5D))%26gt%3B%26gt%3B%202%EF%BC%9B%20%20%20%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%233f7f5f%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%2F%2F%20%E8%AE%A1%E7%AE%97%2014%20%E4%BD%8D%20X%20%E8%BD%B4%E8%BE%93%E5%87%BA%E5%80%BC%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200cm%3B%20margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3EYout_14_bit%20%3D%20((%3C%2FSPAN%3E%3CSTRONG%20style%3D%22border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%20color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%22%3E%E7%9F%AD%3C%2FSTRONG%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E)%20(AccData%5B2%5D%26lt%3B%26lt%3B%208%20%7C%20AccData%5B3%5D))%26gt%3B%26gt%3B%202%EF%BC%9B%20%20%20%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%233f7f5f%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%2F%2F%20%E8%AE%A1%E7%AE%97%2014%20%E4%BD%8D%20Y%20%E8%BD%B4%E8%BE%93%E5%87%BA%E5%80%BC%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200cm%3B%20margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3EZout_14_bit%20%3D%20((%3C%2FSPAN%3E%3CSTRONG%20style%3D%22border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%20color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%22%3E%E7%9F%AD%3C%2FSTRONG%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E)%20(AccData%5B4%5D%26lt%3B%26lt%3B%208%20%7C%20AccData%5B5%5D))%26gt%3B%26gt%3B%202%EF%BC%9B%20%20%20%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%233f7f5f%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%2F%2F%20%E8%AE%A1%E7%AE%97%2014%20%E4%BD%8D%20Z%20%E8%BD%B4%E8%BE%93%E5%87%BA%E5%80%BC%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%BD%A0%E5%9C%A8%E5%81%9A%E4%BB%80%E4%B9%88%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%BF%99%E6%98%AF%E5%90%A6%E7%9B%B8%E5%BD%93%E4%BA%8E%20XYZ%20%E7%9A%84%202%20%E7%9A%84%E8%A1%A5%E7%A0%81%EF%BC%9F%3C%2FP%3E%3CP%3E%E5%AE%83%E4%BB%AC%E8%A2%AB%E8%BF%91%E4%BC%BC%E4%B8%BA%E6%95%B4%E6%95%B0%E5%90%97%EF%BC%9F(%22short%22%20operator)%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E7%8E%B0%E5%9C%A8%E6%88%91%E6%98%AF%E8%BF%99%E6%A0%B7%E8%AE%A1%E7%AE%97%E5%81%8F%E7%A7%BB%E9%87%8F%E7%9A%84%EF%BC%9A%3C%2FP%3E%3CP%20style%3D%22margin%3A%200cm%3B%20margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3EXoffset%20%3D%20Xout_14_bit%20%2F%202%20*%20(-1)%EF%BC%9B%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%233f7f5f%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%2F%2F%20%E8%AE%A1%E7%AE%97%20X%20%E8%BD%B4%E5%81%8F%E7%A7%BB%E4%BF%AE%E6%AD%A3%E5%80%BC%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200cm%3B%20margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3EYoffset%20%3D%20Yout_14_bit%20%2F%202%20*%20(-1)%EF%BC%9B%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%233f7f5f%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%2F%2F%20%E8%AE%A1%E7%AE%97%20Y%20%E8%BD%B4%E5%81%8F%E7%A7%BB%E4%BF%AE%E6%AD%A3%E5%80%BC%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200cm%3B%20margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3EZoffset%20%3D%20(Zout_14_bit%20-%201024)%20%2F%202%20*%20(-1)%EF%BC%9B%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%233f7f5f%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%2F%2F%20%E4%BB%A5%208g%20%E7%81%B5%E6%95%8F%E5%BA%A6%E8%AE%A1%E7%AE%97%20Z%20%E8%BD%B4%E5%81%8F%E7%A7%BB%E4%BF%AE%E6%AD%A3%E5%80%BC%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%E6%88%91%E7%9C%8B%E6%9D%A5%E6%98%AF%E6%AD%A3%E7%A1%AE%E7%9A%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E7%84%B6%E5%90%8E%EF%BC%8C%E6%88%91%E5%B0%86%E5%AE%83%E4%BB%AC%E8%BD%AC%E6%8D%A2%E4%B8%BA%E5%8D%81%E5%85%AD%E8%BF%9B%E5%88%B6%EF%BC%88%E5%8F%AF%E4%BB%A5%E5%90%97%EF%BC%9F%EF%BC%89%EF%BC%8C%E5%B9%B6%E5%B0%86%E5%AE%83%E4%BB%AC%E6%94%BE%E5%85%A5%E5%81%8F%E7%A7%BB%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%9A%3C%2FP%3E%3CBR%20%2F%3E%3CP%20style%3D%22margin%3A%200cm%3B%20margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3EI2C_WriteRegister(MMA845x_I2C_ADDRESS%2C%20CTRL_REG1%2C%200x00)%EF%BC%9B%20%20%20%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20white%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%20%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%233f7f5f%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%2F%2F%20%E5%BE%85%E6%9C%BA%E6%A8%A1%E5%BC%8F%EF%BC%8C%E5%85%81%E8%AE%B8%E5%86%99%E5%85%A5%E5%81%8F%E7%A7%BB%E5%AF%84%E5%AD%98%E5%99%A8%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200cm%3B%20margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3EI2C_WriteRegister(MMA845x_I2C_ADDRESS%2C%20OFF_X_REG%2C%20Xoffset)%EF%BC%9B%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200cm%3B%20margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3EI2C_WriteRegister(MMA845x_I2C_ADDRESS%2C%20OFF_Y_REG%2C%20Yoffset)%EF%BC%9B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200cm%3B%20margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3EI2C_WriteRegister(MMA845x_I2C_ADDRESS%2C%20OFF_Z_REG%2C%20Zoffset)%EF%BC%9B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200cm%3B%20margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%233f7f5f%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3Ei2c_WriteRegister%20(mma845x_i2c_Address%EF%BC%8CCTRL_REG1%EF%BC%8C0x01)%3B%2F%2F%E8%BF%90%E8%A1%8C%E6%A8%A1%E5%BC%8F%20%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%E8%80%8C%E4%B8%94%E5%AE%83%E4%B9%9F%E6%97%A0%E6%B3%95%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%20%3CLI-EMOJI%20id%3D%22lia_confused-face%22%20title%3D%22%3Aconfused_face%3A%22%3E%3C%2FLI-EMOJI%3E%20%2F%E3%80%82%3C%2FP%3E%3CP%3Ey%20%E5%92%8C%20z%20%E7%9A%84%E5%8A%A0%E9%80%9F%E5%BA%A6%E5%8F%98%E5%8C%96%E4%B8%8D%E5%A4%A7%EF%BC%8C%E8%80%8C%20X%20%E7%9A%84%E5%8A%A0%E9%80%9F%E5%BA%A6%E5%88%99%E6%B2%A1%E6%9C%89%E4%BB%BB%E4%BD%95%E5%8F%98%E5%8C%96%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84%E5%9B%BA%E5%AE%9A%E7%9B%AE%E6%A0%87%E6%98%AF%EF%BC%9A%3C%2FP%3E%3CP%3EX%3D0g%3C%2FP%3E%3CP%3EY%3D0g%3C%2FP%3E%3CP%3EZ%3D1g%3C%2FP%3E%3CP%3E%E6%98%BE%E8%80%8C%E6%98%93%E8%A7%81%EF%BC%8C%E6%88%91%E7%9A%84%E8%AE%BE%E5%A4%87%E6%96%B9%E5%90%91%E6%AD%A3%E7%A1%AE%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%88%91%E8%AE%A9%E4%BD%A0%E5%A4%AA%E7%83%A6%E4%BA%86%EF%BC%8C%E6%88%91%E5%BE%88%E6%8A%B1%E6%AD%89%EF%BC%8C%E6%88%91%E6%98%AF%E4%B8%AA%E6%96%B0%E6%89%8B%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%8C%E5%9C%A3%E8%AF%9E%E5%BF%AB%E4%B9%90%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-817841%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20mma8451%20Motion%20Detection%20and%20RaspberryPi%202b%2B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-817841%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%97%A8%EF%BC%8C%E8%B7%AF%E6%98%93%E5%90%89%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%AF%B9%E4%B8%8D%E8%B5%B7%EF%BC%8C%E6%88%91%E7%9A%84%E5%9B%9E%E5%A4%8D%E6%99%9A%E4%BA%86%E3%80%82%E6%88%91%E5%BB%BA%E8%AE%AE%E6%82%A8%E7%9C%8B%E7%9C%8B%E6%88%91%E4%B8%BA%20MMA8451Q%20%E7%BC%96%E5%86%99%E7%9A%84%E7%AE%80%E5%8D%95%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-98836%22%20target%3D%22_blank%22%3E%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%3C%2FA%3E%EF%BC%8C%E6%88%91%E5%9C%A8%E5%85%B6%E4%B8%AD%E8%AF%B4%E6%98%8E%E4%BA%86%E5%9F%BA%E4%BA%8E%20AN4069%20%E7%9A%84%E5%81%8F%E7%A7%BB%E6%A0%A1%E5%87%86%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E5%BA%94%E8%AF%A5%E4%BD%BF%E7%94%A8%E7%B1%BB%E4%BC%BC%E7%9A%84%E5%8A%9F%E8%83%BD%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2010pt%3B%22%3EI2C_ReadMultiRegisters(MMA845x_I2C_ADDRESS%2C%20OUT_X_MSB_REG%2C%206%2C%20AccData)%EF%BC%9B%20%20%20%20%20%20%20%20%20%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2010pt%3B%22%3E%2F%2F%20%E8%AF%BB%E5%8F%96%E6%95%B0%E6%8D%AE%E8%BE%93%E5%87%BA%E5%AF%84%E5%AD%98%E5%99%A8%200x01-0x06%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2010pt%3B%22%3EXout_14_bit%20%3D%20((%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20color%3A%20%237f0055%3B%20font-weight%3A%20bold%3B%20font-size%3A%2013.3333px%3B%22%3E%3CSTRONG%3E%E7%9F%AD%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2010pt%3B%22%3E)%20(AccData%5B0%5D%26lt%3B%26lt%3B%208%20%7C%20AccData%5B1%5D))%26gt%3B%26gt%3B%202%EF%BC%9B%20%20%20%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2010pt%3B%22%3E%2F%2F%20%E8%AE%A1%E7%AE%97%2014%20%E4%BD%8D%20X%20%E8%BD%B4%E8%BE%93%E5%87%BA%E5%80%BC%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2010pt%3B%22%3EYout_14_bit%20%3D%20((%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20color%3A%20%237f0055%3B%20font-weight%3A%20bold%3B%20font-size%3A%2013.3333px%3B%22%3E%3CSTRONG%3E%E7%9F%AD%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2010pt%3B%22%3E)%20(AccData%5B2%5D%26lt%3B%26lt%3B%208%20%7C%20AccData%5B3%5D))%26gt%3B%26gt%3B%202%EF%BC%9B%20%20%20%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2010pt%3B%22%3E%2F%2F%20%E8%AE%A1%E7%AE%97%2014%20%E4%BD%8D%20Y%20%E8%BD%B4%E8%BE%93%E5%87%BA%E5%80%BC%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2010pt%3B%22%3EZout_14_bit%20%3D%20((%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20color%3A%20%237f0055%3B%20font-weight%3A%20bold%3B%20font-size%3A%2013.3333px%3B%22%3E%3CSTRONG%3E%E7%9F%AD%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2010pt%3B%22%3E)%20(AccData%5B4%5D%26lt%3B%26lt%3B%208%20%7C%20AccData%5B5%5D))%26gt%3B%26gt%3B%202%EF%BC%9B%20%20%20%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2010pt%3B%22%3E%2F%2F%20%E8%AE%A1%E7%AE%97%2014%20%E4%BD%8D%20Z%20%E8%BD%B4%E8%BE%93%E5%87%BA%E5%80%BC%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2010pt%3B%22%3EXoffset%20%3D%20Xout_14_bit%20%2F%208%20*%20(-1)%EF%BC%9B%20%20%20%20%20%20%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2010pt%3B%22%3E%2F%2F%20%E8%AE%A1%E7%AE%97%20X%20%E8%BD%B4%E5%81%8F%E7%A7%BB%E4%BF%AE%E6%AD%A3%E5%80%BC%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2010pt%3B%22%3EYoffset%20%3D%20Yout_14_bit%20%2F%208%20*%20(-1)%EF%BC%9B%20%20%20%20%20%20%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2010pt%3B%22%3E%2F%2F%20%E8%AE%A1%E7%AE%97%20Y%20%E8%BD%B4%E5%81%8F%E7%A7%BB%E4%BF%AE%E6%AD%A3%E5%80%BC%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2010pt%3B%22%3EZoffset%20%3D%20(Zout_14_bit%20-%20SENSITIVITY_2G)%20%2F%208%20*%20(-1)%EF%BC%9B%20%20%20%20%20%20%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2010pt%3B%22%3E%2F%2F%20%E8%AE%A1%E7%AE%97%20Z%20%E8%BD%B4%E5%81%8F%E7%A7%BB%E4%BF%AE%E6%AD%A3%E5%80%BC%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2010pt%3B%22%3EI2C_WriteRegister(MMA845x_I2C_ADDRESS%2C%20CTRL_REG1%2C%200x00)%EF%BC%9B%20%20%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2013.3333px%3B%22%3E%20%20%20%20%20%20%20%20%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2010pt%3B%22%3E%2F%2F%20%E5%BE%85%E6%9C%BA%E6%A8%A1%E5%BC%8F%EF%BC%8C%E5%85%81%E8%AE%B8%E5%86%99%E5%85%A5%E5%81%8F%E7%A7%BB%E5%AF%84%E5%AD%98%E5%99%A8%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2010pt%3B%22%3EI2C_WriteRegister(MMA845x_I2C_ADDRESS%2C%20OFF_X_REG%2C%20Xoffset)%EF%BC%9B%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2010pt%3B%22%3EI2C_WriteRegister(MMA845x_I2C_ADDRESS%2C%20OFF_Y_REG%2C%20Yoffset)%EF%BC%9B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2010pt%3B%22%3EI2C_WriteRegister(MMA845x_I2C_ADDRESS%2C%20OFF_Z_REG%2C%20Zoffset)%EF%BC%9B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%B8%8C%E6%9C%9B%E5%AF%B9%E6%82%A8%E6%9C%89%E5%B8%AE%E5%8A%A9%EF%BC%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%3E%E6%89%98%E9%A9%AC%E6%96%AF%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-817840%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20mma8451%20Motion%20Detection%20and%20RaspberryPi%202b%2B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-817840%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E8%AF%95%E7%9D%80%E6%8C%89%E6%88%91%E8%AF%B4%E7%9A%84%E5%81%9A%EF%BC%8C%E6%88%91%E7%9A%84%E5%8A%A0%E9%80%9F%E5%BA%A6%E5%80%BC%E6%98%AF%E8%BF%99%E6%A0%B7%E7%9A%84%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_5.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_5.png%22%20style%3D%22width%3A%20127px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F78840i3C8EA7FFB84A1932%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_5.png%22%20alt%3D%22pastedImage_5.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E7%AC%AC%E4%B8%80%E8%A1%8C%20X%E3%80%81Y%E3%80%81Z%20%E4%BD%BF%E7%94%A8%20OUT_X_MSB%3C%2FP%3E%3CP%3E%E4%BD%BF%E7%94%A8%20OUT_X_LSB%20%E7%A7%92%20X%E3%80%81Y%E3%80%81Z%3C%2FP%3E%3CP%3E%E4%BD%BF%E7%94%A8%20OUT_Y_MSB%20%E5%AF%B9%20X%E3%80%81Y%E3%80%81Z%20%E8%BF%9B%E8%A1%8C%E4%B8%89%E6%AC%A1%E6%B5%8B%E9%87%8F%3C%2FP%3E%3CP%3E%E4%BD%BF%E7%94%A8%20OUT_Y_LSB%20%E5%AF%B9%20X%E3%80%81Y%E3%80%81Z%20%E8%BF%9B%E8%A1%8C%E5%9B%9B%E7%AD%89%E5%88%86%3C%2FP%3E%3CP%3E%E7%AD%89%E7%AD%89%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%BF%99%E4%BA%9B%E5%80%BC%E6%98%AF%E6%88%91%E5%9C%A8%E4%B8%8B%E4%B8%80%E6%AD%A5%E8%BF%9B%E8%A1%8C%202%20%E7%9A%84%E8%A1%A5%E7%A0%81%E6%97%B6%E9%9C%80%E8%A6%81%E4%BD%BF%E7%94%A8%E7%9A%84%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.png%22%20style%3D%22width%3A%20453px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F78767iE7CF48D4CB081C73%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_3.png%22%20alt%3D%22pastedImage_3.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-817839%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20mma8451%20Motion%20Detection%20and%20RaspberryPi%202b%2B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-817839%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%97%A8%EF%BC%8C%E6%89%98%E9%A9%AC%E6%96%AF%E3%80%81%3C%2FP%3E%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E6%88%91%E5%B7%B2%E7%BB%8F%E9%98%85%E8%AF%BB%E4%BA%86%20AN4070%20%E8%AF%B4%E6%98%8E%E3%80%81%3C%2FP%3E%3CP%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%88%91%E7%9A%84%E9%97%AE%E9%A2%98%E6%98%AF%E5%A6%82%E4%BD%95%E6%AD%A3%E7%A1%AE%E8%AE%A1%E7%AE%97%E5%86%99%E5%85%A5%20FF_MT_THS%20%E5%AF%84%E5%AD%98%E5%99%A8%20(0x17)%20%E7%9A%84%E5%80%BC%EF%BC%8C%E5%AE%83%E5%B0%B1%E6%98%AF%22Threshold%2F0.063%22%20%EF%BC%9B%3C%2FP%3E%3CP%3E%E4%BB%A5%E5%8F%8A%E5%A6%82%E4%BD%95%E6%AD%A3%E7%A1%AE%E8%AE%A1%E7%AE%97%E5%86%99%E5%85%A5%20FF_MT_COUNT%20%E5%AF%84%E5%AD%98%E5%99%A8%20(0x18)%20%E7%9A%84%E5%80%BC%EF%BC%8C%E5%AE%83%E5%8F%AA%E6%98%AF%22DebounceTime%2FTimeStep%22%20%E3%80%82%3C%2FP%3E%3CP%3E%E5%BF%98%E4%BA%86%E4%BB%96%E4%BB%AC%E5%90%A7%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%8E%B0%E5%9C%A8%E6%88%91%E5%8F%88%E9%81%87%E5%88%B0%E4%BA%86%E4%B8%80%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%9A%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E5%AF%B9%E8%AE%BE%E5%A4%87%E8%BF%9B%E8%A1%8C%E8%87%AA%E5%8A%A8%E6%A0%A1%E5%87%86%E7%A8%8B%E5%BA%8F%E3%80%82%3C%2FP%3E%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E6%88%91%E5%B7%B2%E7%BB%8F%E9%98%85%E8%AF%BB%E4%BA%86%20AN4069%20%E7%9A%84%E8%AF%B4%E6%98%8E%EF%BC%9A%22%E5%BC%80%E5%BF%83%E4%B8%80%E7%AC%91%22%EF%BC%9A%3C%2FP%3E%3CP%3E%E5%9C%A8%E8%AF%B4%E6%98%8E%E7%9A%84%E7%AC%AC%206%20%E9%A1%B5%EF%BC%8C%E6%9C%89%E4%B8%80%E4%B8%AA%E4%BD%BF%E7%94%A8%E6%B5%81%E7%A8%8B%E5%9B%BE%E7%9A%84%E4%BE%8B%E5%AD%90%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%B8%8D%E6%98%8E%E7%99%BD%E7%AC%AC%203%20%E4%B8%AA%E6%96%B9%E6%A1%86%E7%9A%84%E6%84%8F%E6%80%9D%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%20style%3D%22width%3A%20560px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F78711i323A4B80F1B4213A%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_2.png%22%20alt%3D%22pastedImage_2.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%98%AF%E5%90%A6%E5%BF%85%E9%A1%BB%E9%A6%96%E5%85%88%E4%BD%BF%E7%94%A8%E5%AF%84%E5%AD%98%E5%99%A8%20OUT_X_MSB%EF%BC%8C%E8%AF%BB%E5%8F%96%EF%BC%88%E5%B9%B6%E6%89%93%E5%8D%B0%EF%BC%89X%E3%80%81Y%20%E5%92%8C%20Z%20%E7%9A%84%E5%8A%A0%E9%80%9F%E5%BA%A6%EF%BC%9F%3C%2FP%3E%3CP%3E%E4%B9%8B%E5%90%8E%EF%BC%8C%E6%88%91%E6%98%AF%E5%90%A6%E8%A6%81%E4%BD%BF%E7%94%A8%E5%AF%84%E5%AD%98%E5%99%A8%20OUT_X_LSB%20%E8%AF%BB%E5%8F%96%20X%E3%80%81Y%20%E5%92%8C%20Z%20%E7%9A%84%E5%8A%A0%E9%80%9F%E5%BA%A6%EF%BC%9F%3C%2FP%3E%3CP%3E%E4%B9%8B%E5%90%8E%EF%BC%8C%E6%88%91%E6%98%AF%E5%90%A6%E8%A6%81%E4%BD%BF%E7%94%A8%E5%AF%84%E5%AD%98%E5%99%A8%20OUT_Y_MSB%20%E8%AF%BB%E5%8F%96%20X%E3%80%81Y%20%E5%92%8C%20Z%20%E7%9A%84%E5%8A%A0%E9%80%9F%E5%BA%A6%EF%BC%9F%E7%AD%89%E7%AD%89%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-817838%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20mma8451%20Motion%20Detection%20and%20RaspberryPi%202b%2B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-817838%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%97%A8%EF%BC%8C%E8%B7%AF%E6%98%93%E5%90%89%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%94%B1%E4%BA%8E%E6%88%91%E4%B8%8D%E5%AE%8C%E5%85%A8%E7%90%86%E8%A7%A3%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E6%88%91%E6%83%B3%E8%AF%B7%E6%82%A8%E5%8F%82%E9%98%85%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN4070.pdf%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EAN4070%3C%2FA%3E%EF%BC%8C%E5%9C%A8%E9%82%A3%E9%87%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E6%89%BE%E5%88%B0%E4%B8%8E%E5%B5%8C%E5%85%A5%E5%BC%8F%E8%BF%90%E5%8A%A8%E6%A3%80%E6%B5%8B%E5%8A%9F%E8%83%BD%E7%9B%B8%E5%85%B3%E7%9A%84%E6%9C%89%E7%94%A8%E4%BF%A1%E6%81%AF%E3%80%82%E5%A6%82%E6%9E%9C%E6%82%A8%E9%9C%80%E8%A6%81%E4%BA%86%E8%A7%A3%E5%85%B7%E4%BD%93%E4%BF%A1%E6%81%AF%EF%BC%8C%E8%AF%B7%E5%86%8D%E8%AF%A6%E7%BB%86%E8%AF%B4%E6%98%8E%E4%B8%80%E4%B8%8B%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%3E%E6%89%98%E9%A9%AC%E6%96%AF%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-817837%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20mma8451%20Motion%20Detection%20and%20RaspberryPi%202b%2B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-817837%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%A5%BD%E4%BA%86%EF%BC%8C%E6%88%91%E5%B7%B2%E7%BB%8F%E8%A7%A3%E5%86%B3%E4%BA%86%E6%89%93%E5%8D%B0%E9%97%AE%E9%A2%98%EF%BC%9B%E8%BF%99%E5%8F%AA%E6%98%AF%E7%B1%BB%E6%A8%A1%E5%9D%97%E4%BD%BF%E7%94%A8%E4%B8%8D%E5%BD%93%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%9B%E6%88%91%E5%8F%AA%E6%98%AF%E9%81%87%E5%88%B0%E4%BA%86%E6%B3%A8%E5%86%8C%E8%AE%A1%E6%95%B0%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E6%9C%89%E4%BA%BA%E8%83%BD%E8%A7%A3%E9%87%8A%E4%B8%80%E4%B8%8B%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E
