mma8451 Motion Detection and RaspberryPi 2b+
luigi5hd
Goodmornig,
This is my main code:
xOffset = -0.400 # m/s^2
yOffset =  0.200 # m/s^2
zOffset =  9.400 # m/s^2
while True:
    while sensor.Motion():
        x, y, z = sensor.acceleration
        time_now = datetime.datetime.now()
        Calcx = -xOffset
        Calcy = -yOffset
        Calcz = -zOffset
        X = x + Calcx
        Y = y + Calcy
        Z = z + Calcz
        sensor.MotionRegister()
        print('Time={0}   X={1:0.3f} m/s^2  Y:{2:0.3f} m/s^2  Z:{3:0.3f} m/s^2'.format(time_now, X, Y, Z))
        time.sleep(0)
    IntSourceMFF = sensor.MotionRegister()
And I have setup my MMA8451 into a class like this:
    def Motion (self): #, IntSourceSystem,IntSourceMFF):
        reg1 = self._read_u8(_MMA8451_REG_CTRL_REG1)
        reg1 &= 0xFE #clear active bit (standby)
        self._write_u8(_MMA8451_REG_CTRL_REG1, reg1)
        self._write_u8(REG_FF_MT_CONFIG, 0x48) #Moto detection X axe after the debounce time (100)ms is reached
        self._write_u8(REG_FF_MT_THS, 0x10)    #threshold 1g: es 1g/0.063g = 16 counts = 10 (hexadecimal)
        self._write_u8(REG_FF_MT_COUNT, 0x0A) #Debounce counter, set at 12.5ms timer for 800 output data rate
        self._write_u8(_MMA8451_REG_CTRL_REG4, 0x04)
        self._write_u8(_MMA8451_REG_CTRL_REG5, 0x04)
        # self._write_u8(_MMA8451_REG_CTRL_REG3, 0x04)
        self._write_u8(_MMA8451_REG_CTRL_REG1, reg1 | 0x01) #activated
        print("It will work")
        IntSourceSystem = self._read_u8(_MMA8451_INT_SOURCE)
        if ((IntSourceSystem & 0x04) == 0x04):
            print("You are into if")
            return True
        else:
            print("You are into else")
            return False
    def MotionRegister (self):
        return self._read_u8(REG_MT_SRC)
Something strange happens, it works properly only if I print something in my setup module (in this case "It will work").
Why it does it? I don't want that print.
Maybe it is a problem with the Count register setup..I didn't well realized how to use it, I want to use a 100ms timer for 800 ODR but with 0x50 didn't works..
Can someone help me pls?
luigi5hd
Hey Tomas,
Firstly best wishes!!
I still have the same problem with the autocalibration..
But I want to change my question:
If the device is stationary on a "flat" desktop, and the measures are
X= 0.201 m/s2
Y= 0.220 m/s2
Z= 9.409 m/s2
Which is the best way to gain:
X= 0 m/s2
Y= 0 m/s2
Z= 9.81 m/s2   ?
I'm also available to use the simple method calibration, but how can I be able to delete the noise?
Am I forced to use the High pass filter or can I use the offset registers?
What do you think? And can you suggest me how to do it?
Thank you, best regards.
TomasVaverka
Hi Luigi,
First off... Happy New Year and sorry for my late response.
Everything you described in your post from Dec 21st is correct for 8g mode.
In order to reduce noise, our recommendation is using lowest possible ODR and High Resolution Mode as shown in the AN4075 (page 7).
Tomas
luigi5hd
ok I have solved the print problem; it was just a bad use of the class module; I just have the reg count problem, can someone explain it to me?
TomasVaverka
Hi Luigi,
As I do not fully understand what you are asking, I would refer to the AN4070 where you may find useful information related to the embedded motion detection function. If you need to know anything specific, please elaborate it a bit more.
Tomas
luigi5hd
Hi Tomas,
Yes I have already read the AN4070 note,
so, my problem was to how to calculate correctly the value to write into the FF_MT_THS register (0x17), and it is just "Threshold/0.063" ;
and how to calculate correctly the value to write into the FF_MT_COUNT register (0x18), and it is just  "DebounceTime/TimeStep".
Forget about them.
Now I have another problem:
I'm trying to doing the Aut-Calibration Procedure of the device.
yes, I have already read the AN4069 note :smileyhappy:
On page 6 of the note there is an example using a flow chart.
I didn't understand the 3th box:
Have I to read, (and so print?) the acceleration on X,Y, and Z using firstly the register OUT_X_MSB?
After that have I to read the acceleration on X,Y, and Z using the register OUT_X_LSB?
After that have I to read the acceleration on X,Y, and Z using the register OUT_Y_MSB? etc?
luigi5hd
I've tried to do as I mentioned and my Acceleration values are these:
first line X,Y,Z using OUT_X_MSB
second X,Y,Z using OUT_X_LSB
third X,Y,Z using OUT_Y_MSB
fourth X,Y,Z using OUT_Y_LSB
etc.
Are these the values that I need to use in the next step, for the 2's complement?
Thank you.
TomasVaverka
Hi Luigi,
Sorry for my late response. I would recommend you to take a look at my simple example code for the MMA8451Q where I illustrate offset calibration based on the AN4069.
You should use something like this:
I2C_ReadMultiRegisters(MMA845x_I2C_ADDRESS, OUT_X_MSB_REG, 6, AccData);           // Read data output registers 0x01-0x06
Xout_14_bit = ((short) (AccData[0]<<8 | AccData[1])) >> 2;           // Compute 14-bit X-axis output value
Yout_14_bit = ((short) (AccData[2]<<8 | AccData[3])) >> 2;           // Compute 14-bit Y-axis output value
Zout_14_bit = ((short) (AccData[4]<<8 | AccData[5])) >> 2;           // Compute 14-bit Z-axis output value
Xoffset = Xout_14_bit / 8 * (-1);        // Compute X-axis offset correction value
Yoffset = Yout_14_bit / 8 * (-1);        // Compute Y-axis offset correction value
Zoffset = (Zout_14_bit - SENSITIVITY_2G) / 8 * (-1);          // Compute Z-axis offset correction value
I2C_WriteRegister(MMA845x_I2C_ADDRESS, CTRL_REG1, 0x00);             // Standby mode to allow writing to the offset registers
I2C_WriteRegister(MMA845x_I2C_ADDRESS, OFF_X_REG, Xoffset);
I2C_WriteRegister(MMA845x_I2C_ADDRESS, OFF_Y_REG, Yoffset);
I2C_WriteRegister(MMA845x_I2C_ADDRESS, OFF_Z_REG, Zoffset);
Hope it helps!
Tomas
luigi5hd
Yes, I was just following your metal bare example but I still have some problem.
Firstly: I'm in 14 bit, ODR 800, 8g mode.
Here:
What are you doing with this shifting?
Is this equivalent to a 2's complement for XYZ no?
And are they approximated as integers no? ("short" operator)
Now I've calculated the  Offset like this:
Xoffset = Xout_14_bit / 2 * (-1);        // Compute X-axis offset correction value
Yoffset = Yout_14_bit / 2 * (-1);        // Compute Y-axis offset correction value
Zoffset = (Zout_14_bit - 1024) / 2 * (-1);          // Compute Z-axis offset correction value with 8g sensitivity
It looks correct to me..
After that I convert them as hexadecimal (ok?) and I put them into the Offset registers:
I2C_WriteRegister(MMA845x_I2C_ADDRESS, CTRL_REG1, 0x01);             // Active mode
And it doesn't work properly anyway :/
The y and z acceleration doesn't change enough, and  X acceleration doesn't change at all.
NB my stationary target is:
X=0g
Y=0g
Z=1g
Obvious my device is properly oriented.
I'm sorry if I'm annoying you too much, I'm a bit noob.
Thank you and merry Christmas.
%3CLINGO-SUB%20id%3D%22lingo-sub-817836%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Emma8451%20Motion%20Detection%20and%20RaspberryPi%202b%2B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-817836%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EGoodmornig%2C%3C%2FP%3E%3CP%3EThis%20is%20my%20main%20code%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%22%3C%2FP%3E%3CP%3ExOffset%20%3D%20-0.400%20%23%20m%2Fs%5E2%3CBR%20%2F%3EyOffset%20%3D%26nbsp%3B%200.200%20%23%20m%2Fs%5E2%3CBR%20%2F%3EzOffset%20%3D%26nbsp%3B%209.400%20%23%20m%2Fs%5E2%3CBR%20%2F%3Ewhile%20True%3A%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20while%20sensor.Motion()%3A%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20x%2C%20y%2C%20z%20%3D%20sensor.acceleration%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20time_now%20%3D%20datetime.datetime.now()%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Calcx%20%3D%20-xOffset%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Calcy%20%3D%20-yOffset%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Calcz%20%3D%20-zOffset%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20X%20%3D%20x%20%2B%20Calcx%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Y%20%3D%20y%20%2B%20Calcy%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Z%20%3D%20z%20%2B%20Calcz%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20sensor.MotionRegister()%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20print('Time%3D%7B0%7D%26nbsp%3B%26nbsp%3B%20X%3D%7B1%3A0.3f%7D%20m%2Fs%5E2%26nbsp%3B%20Y%3A%7B2%3A0.3f%7D%20m%2Fs%5E2%26nbsp%3B%20Z%3A%7B3%3A0.3f%7D%20m%2Fs%5E2'.format(time_now%2C%20X%2C%20Y%2C%20Z))%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20time.sleep(0)%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20IntSourceMFF%20%3D%20sensor.MotionRegister()%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%22%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EAnd%20I%20have%20setup%20my%20MMA8451%20into%20a%20class%20like%20this%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%22%22%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20def%20Motion%20(self)%3A%20%23%2C%20IntSourceSystem%2CIntSourceMFF)%3A%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20reg1%20%3D%20self._read_u8(_MMA8451_REG_CTRL_REG1)%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20reg1%20%26amp%3B%3D%200xFE%20%23clear%20active%20bit%20(standby)%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20self._write_u8(_MMA8451_REG_CTRL_REG1%2C%20reg1)%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20self._write_u8(REG_FF_MT_CONFIG%2C%200x48)%20%23Moto%20detection%20X%20axe%20after%20the%20debounce%20time%20(100)ms%20is%20reached%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20self._write_u8(REG_FF_MT_THS%2C%200x10)%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23threshold%201g%3A%20es%201g%2F0.063g%20%3D%2016%20counts%20%3D%2010%20(hexadecimal)%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20self._write_u8(REG_FF_MT_COUNT%2C%200x0A)%20%23Debounce%20counter%2C%20set%20at%2012.5ms%20timer%20for%20800%20output%20data%20rate%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20self._write_u8(_MMA8451_REG_CTRL_REG4%2C%200x04)%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20self._write_u8(_MMA8451_REG_CTRL_REG5%2C%200x04)%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23%20self._write_u8(_MMA8451_REG_CTRL_REG3%2C%200x04)%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20reg1%20%3D%20self._read_u8(_MMA8451_REG_CTRL_REG1)%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20self._write_u8(_MMA8451_REG_CTRL_REG1%2C%20reg1%20%7C%200x01)%20%23activated%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20print(%22It%20will%20work%22)%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20IntSourceSystem%20%3D%20self._read_u8(_MMA8451_INT_SOURCE)%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20if%20((IntSourceSystem%20%26amp%3B%200x04)%20%3D%3D%200x04)%3A%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20print(%22You%20are%20into%20if%22)%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20return%20True%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20else%3A%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20print(%22You%20are%20into%20else%22)%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20return%20False%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20def%20MotionRegister%20(self)%3A%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20return%20self._read_u8(REG_MT_SRC)%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%22%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ESomething%20strange%20happens%2C%20it%20works%20properly%20only%20if%20I%20print%20something%20in%20my%20setup%20module%20(in%20this%20case%20%22It%20will%20work%22).%3C%2FP%3E%3CP%3EWhy%20it%20does%20it%3F%20I%20don't%20want%20that%20print.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EMaybe%20it%20is%20a%20problem%20with%20the%20Count%20register%20setup..I%20didn't%20well%20realized%20how%20to%20use%20it%2C%20I%20want%20to%20use%20a%20100ms%20timer%20for%20800%20ODR%20but%20with%200x50%20didn't%20works..%3C%2FP%3E%3CP%3ECan%20someone%20help%20me%20pls%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-817836%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EAccelerometers%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-817844%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20mma8451%20Motion%20Detection%20and%20RaspberryPi%202b%2B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-817844%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Luigi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EFirst%20off...%20Happy%20New%20Year%20and%20sorry%20for%20my%20late%20response.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EEverything%20you%20described%20in%20your%20post%20from%20Dec%2021st%20is%20correct%20for%208g%20mode.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EIn%20order%20to%20reduce%20noise%2C%20our%20recommendation%20is%20using%20lowest%20possible%20ODR%20and%20High%20Resolution%20Mode%20as%20shown%20in%20the%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN4075.pdf%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EAN4075%3C%2FA%3E%26nbsp%3B(page%207).%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBest%20regards%2C%3C%2FP%3E%3CP%3ETomas%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-817843%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20mma8451%20Motion%20Detection%20and%20RaspberryPi%202b%2B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-817843%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHey%20Tomas%2C%3C%2FP%3E%3CP%3EFirstly%20best%20wishes!!%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20still%20have%20the%20same%20problem%20with%20the%20autocalibration..%3C%2FP%3E%3CP%3EBut%20I%20want%20to%20change%20my%20question%3A%3C%2FP%3E%3CP%3EIf%20the%20device%20is%20stationary%20on%20a%20%22flat%22%20desktop%2C%20and%20the%20measures%20are%3C%2FP%3E%3CP%3EX%3D%200.201%20m%2Fs2%3C%2FP%3E%3CP%3EY%3D%200.220%20m%2Fs2%3C%2FP%3E%3CP%3EZ%3D%209.409%20m%2Fs2%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EWhich%20is%20the%20best%20way%20to%20gain%3A%3C%2FP%3E%3CP%3EX%3D%200%20m%2Fs2%3C%2FP%3E%3CP%3EY%3D%200%20m%2Fs2%3C%2FP%3E%3CP%3EZ%3D%209.81%20m%2Fs2%26nbsp%3B%26nbsp%3B%20%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI'm%20also%20available%20to%20use%20the%20simple%20method%20calibration%2C%20but%20how%20can%20I%20be%20able%20to%20delete%20the%20noise%3F%26nbsp%3B%3C%2FP%3E%3CP%3EAm%20I%20forced%20to%20use%20the%20High%20pass%20filter%20or%20can%20I%20use%20the%20offset%20registers%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EWhat%20do%20you%20think%3F%20And%20can%20you%20suggest%20me%20how%20to%20do%20it%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThank%20you%2C%20best%20regards.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-817842%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20mma8451%20Motion%20Detection%20and%20RaspberryPi%202b%2B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-817842%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EYes%2C%20I%20was%20just%20following%20your%20metal%20bare%20example%20but%20I%20still%20have%20some%20problem.%3C%2FP%3E%3CP%3EFirstly%3A%20I'm%20in%2014%20bit%2C%20ODR%20800%2C%208g%20mode.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EHere%3A%3C%2FP%3E%3CP%20style%3D%22margin%3A%200cm%3B%20margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3EXout_14_bit%20%3D%20((%3C%2FSPAN%3E%3CSTRONG%20style%3D%22border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%20color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%22%3Eshort%3C%2FSTRONG%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E)%20(AccData%5B0%5D%26lt%3B%26lt%3B8%20%7C%20AccData%5B1%5D))%20%26gt%3B%26gt%3B%202%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%233f7f5f%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%2F%2F%20Compute%2014-bit%20X-axis%20output%20value%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200cm%3B%20margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3EYout_14_bit%20%3D%20((%3C%2FSPAN%3E%3CSTRONG%20style%3D%22border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%20color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%22%3Eshort%3C%2FSTRONG%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E)%20(AccData%5B2%5D%26lt%3B%26lt%3B8%20%7C%20AccData%5B3%5D))%20%26gt%3B%26gt%3B%202%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%233f7f5f%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%2F%2F%20Compute%2014-bit%20Y-axis%20output%20value%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200cm%3B%20margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3EZout_14_bit%20%3D%20((%3C%2FSPAN%3E%3CSTRONG%20style%3D%22border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%20color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%22%3Eshort%3C%2FSTRONG%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E)%20(AccData%5B4%5D%26lt%3B%26lt%3B8%20%7C%20AccData%5B5%5D))%20%26gt%3B%26gt%3B%202%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%233f7f5f%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%2F%2F%20Compute%2014-bit%20Z-axis%20output%20value%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EWhat%20are%20you%20doing%20with%20this%20shifting%3F%3C%2FP%3E%3CP%3EIs%20this%20equivalent%20to%20a%202's%20complement%20for%20XYZ%20no%3F%3C%2FP%3E%3CP%3EAnd%20are%20they%20approximated%20as%20integers%20no%3F%20(%22short%22%20operator)%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ENow%20I've%20calculated%20the%26nbsp%3B%20Offset%20like%20this%3A%3C%2FP%3E%3CP%20style%3D%22margin%3A%200cm%3B%20margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3EXoffset%20%3D%20Xout_14_bit%20%2F%202%20*%20(-1)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%233f7f5f%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%2F%2F%20Compute%20X-axis%20offset%20correction%20value%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200cm%3B%20margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3EYoffset%20%3D%20Yout_14_bit%20%2F%202%20*%20(-1)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%233f7f5f%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%2F%2F%20Compute%20Y-axis%20offset%20correction%20value%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200cm%3B%20margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3EZoffset%20%3D%20(Zout_14_bit%20-%201024)%20%2F%202%20*%20(-1)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%233f7f5f%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%2F%2F%20Compute%20Z-axis%20offset%20correction%20value%20with%208g%20sensitivity%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EIt%20looks%20correct%20to%20me..%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EAfter%20that%20I%20convert%20them%20as%20hexadecimal%20(ok%3F)%20and%20I%20put%20them%20into%20the%20Offset%20registers%3A%3C%2FP%3E%3CBR%20%2F%3E%3CP%20style%3D%22margin%3A%200cm%3B%20margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3EI2C_WriteRegister(MMA845x_I2C_ADDRESS%2C%20CTRL_REG1%2C%200x00)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20white%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%233f7f5f%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%2F%2F%20Standby%20mode%20to%20allow%20writing%20to%20the%20offset%20registers%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200cm%3B%20margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3EI2C_WriteRegister(MMA845x_I2C_ADDRESS%2C%20OFF_X_REG%2C%20Xoffset)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200cm%3B%20margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3EI2C_WriteRegister(MMA845x_I2C_ADDRESS%2C%20OFF_Y_REG%2C%20Yoffset)%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200cm%3B%20margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3EI2C_WriteRegister(MMA845x_I2C_ADDRESS%2C%20OFF_Z_REG%2C%20Zoffset)%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200cm%3B%20margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3EI2C_WriteRegister(MMA845x_I2C_ADDRESS%2C%20CTRL_REG1%2C%200x01)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%233f7f5f%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%2F%2F%20Active%20mode%20%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3EAnd%20it%20doesn't%20work%20properly%20anyway%20%3CLI-EMOJI%20id%3D%22lia_confused-face%22%20title%3D%22%3Aconfused_face%3A%22%3E%3C%2FLI-EMOJI%3E%3C%2FP%3E%3CP%3EThe%20y%20and%20z%20acceleration%20doesn't%20change%20enough%2C%20and%26nbsp%3B%20X%20acceleration%20doesn't%20change%20at%20all.%3C%2FP%3E%3CP%3ENB%20my%20stationary%20target%20is%3A%3C%2FP%3E%3CP%3EX%3D0g%3C%2FP%3E%3CP%3EY%3D0g%3C%2FP%3E%3CP%3EZ%3D1g%3C%2FP%3E%3CP%3EObvious%20my%20device%20is%20properly%20oriented.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI'm%20sorry%20if%20I'm%20annoying%20you%20too%20much%2C%20I'm%20a%20bit%20noob.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThank%20you%20and%20merry%20Christmas.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-817841%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20mma8451%20Motion%20Detection%20and%20RaspberryPi%202b%2B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-817841%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Luigi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ESorry%20for%20my%20late%20response.%20I%20would%20recommend%20you%20to%20take%20a%20look%20at%20my%20simple%20%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-98836%22%20target%3D%22_blank%22%3Eexample%20code%3C%2FA%3E%20for%20the%20MMA8451Q%20where%20I%20illustrate%26nbsp%3Boffset%20calibration%20based%20on%20the%20AN4069.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EYou%20should%20use%20something%20like%20this%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2010pt%3B%22%3EI2C_ReadMultiRegisters(MMA845x_I2C_ADDRESS%2C%20OUT_X_MSB_REG%2C%206%2C%20AccData)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2010pt%3B%22%3E%2F%2F%20Read%20data%20output%20registers%200x01-0x06%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2010pt%3B%22%3EXout_14_bit%20%3D%20((%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20color%3A%20%237f0055%3B%20font-weight%3A%20bold%3B%20font-size%3A%2013.3333px%3B%22%3E%3CSTRONG%3Eshort%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2010pt%3B%22%3E)%20(AccData%5B0%5D%26lt%3B%26lt%3B8%20%7C%20AccData%5B1%5D))%20%26gt%3B%26gt%3B%202%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2010pt%3B%22%3E%2F%2F%20Compute%2014-bit%20X-axis%20output%20value%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2010pt%3B%22%3EYout_14_bit%20%3D%20((%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20color%3A%20%237f0055%3B%20font-weight%3A%20bold%3B%20font-size%3A%2013.3333px%3B%22%3E%3CSTRONG%3Eshort%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2010pt%3B%22%3E)%20(AccData%5B2%5D%26lt%3B%26lt%3B8%20%7C%20AccData%5B3%5D))%20%26gt%3B%26gt%3B%202%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2010pt%3B%22%3E%2F%2F%20Compute%2014-bit%20Y-axis%20output%20value%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2010pt%3B%22%3EZout_14_bit%20%3D%20((%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20color%3A%20%237f0055%3B%20font-weight%3A%20bold%3B%20font-size%3A%2013.3333px%3B%22%3E%3CSTRONG%3Eshort%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2010pt%3B%22%3E)%20(AccData%5B4%5D%26lt%3B%26lt%3B8%20%7C%20AccData%5B5%5D))%20%26gt%3B%26gt%3B%202%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2010pt%3B%22%3E%2F%2F%20Compute%2014-bit%20Z-axis%20output%20value%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2010pt%3B%22%3EXoffset%20%3D%20Xout_14_bit%20%2F%208%20*%20(-1)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2010pt%3B%22%3E%2F%2F%20Compute%20X-axis%20offset%20correction%20value%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2010pt%3B%22%3EYoffset%20%3D%20Yout_14_bit%20%2F%208%20*%20(-1)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2010pt%3B%22%3E%2F%2F%20Compute%20Y-axis%20offset%20correction%20value%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2010pt%3B%22%3EZoffset%20%3D%20(Zout_14_bit%20-%20SENSITIVITY_2G)%20%2F%208%20*%20(-1)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2010pt%3B%22%3E%2F%2F%20Compute%20Z-axis%20offset%20correction%20value%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2010pt%3B%22%3EI2C_WriteRegister(MMA845x_I2C_ADDRESS%2C%20CTRL_REG1%2C%200x00)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2013.3333px%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2010pt%3B%22%3E%2F%2F%20Standby%20mode%20to%20allow%20writing%20to%20the%20offset%20registers%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2010pt%3B%22%3EI2C_WriteRegister(MMA845x_I2C_ADDRESS%2C%20OFF_X_REG%2C%20Xoffset)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2010pt%3B%22%3EI2C_WriteRegister(MMA845x_I2C_ADDRESS%2C%20OFF_Y_REG%2C%20Yoffset)%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2010pt%3B%22%3EI2C_WriteRegister(MMA845x_I2C_ADDRESS%2C%20OFF_Z_REG%2C%20Zoffset)%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EHope%20it%20helps!%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBest%20regards%2C%3C%2FP%3E%3CP%3ETomas%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-817840%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20mma8451%20Motion%20Detection%20and%20RaspberryPi%202b%2B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-817840%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI've%20tried%20to%20do%20as%20I%20mentioned%20and%20my%20Acceleration%20values%20are%20these%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_5.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_5.png%22%20style%3D%22width%3A%20127px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F78840i3C8EA7FFB84A1932%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_5.png%22%20alt%3D%22pastedImage_5.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Efirst%20line%20X%2CY%2CZ%20using%20OUT_X_MSB%3C%2FP%3E%3CP%3Esecond%20X%2CY%2CZ%20using%20OUT_X_LSB%3C%2FP%3E%3CP%3Ethird%20X%2CY%2CZ%20using%20OUT_Y_MSB%3C%2FP%3E%3CP%3Efourth%20X%2CY%2CZ%20using%20OUT_Y_LSB%3C%2FP%3E%3CP%3Eetc.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EAre%20these%20the%20values%20that%20I%20need%20to%20use%20in%20the%20next%20step%2C%20for%20the%202's%20complement%3F%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.png%22%20style%3D%22width%3A%20453px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F78767iE7CF48D4CB081C73%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_3.png%22%20alt%3D%22pastedImage_3.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EThank%20you.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-817839%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20mma8451%20Motion%20Detection%20and%20RaspberryPi%202b%2B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-817839%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Tomas%2C%3C%2FP%3E%3CP%3EYes%20I%20have%20already%20read%20the%20AN4070%20note%2C%3C%2FP%3E%3CP%3Eso%2C%20my%20problem%20was%20to%20how%20to%20calculate%20correctly%20the%20value%20to%20write%20into%20the%20FF_MT_THS%20register%20(0x17)%2C%20and%20it%20is%20just%20%22Threshold%2F0.063%22%20%3B%3C%2FP%3E%3CP%3Eand%20how%20to%20calculate%20correctly%20the%20value%20to%20write%20into%20the%20FF_MT_COUNT%20register%20(0x18)%2C%20and%20it%20is%20just%26nbsp%3B%20%22DebounceTime%2FTimeStep%22.%3C%2FP%3E%3CP%3EForget%20about%20them.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ENow%20I%20have%20another%20problem%3A%3C%2FP%3E%3CP%3EI'm%20trying%20to%20doing%20the%20Aut-Calibration%20Procedure%20of%20the%20device.%3C%2FP%3E%3CP%3Eyes%2C%20I%20have%20already%20read%20the%20AN4069%20note%20%3CIMG%20id%3D%22smileyhappy%22%20class%3D%22emoticon%20emoticon-smileyhappy%22%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fi%2Fsmilies%2F16x16_smiley-happy.png%22%20alt%3D%22Smiley%20Happy%22%20title%3D%22Smiley%20Happy%22%20%2F%3E%3C%2FP%3E%3CP%3EOn%20page%206%20of%20the%20note%20there%20is%20an%20example%20using%20a%20flow%20chart.%3C%2FP%3E%3CP%3EI%20didn't%20understand%20the%203th%20box%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%20style%3D%22width%3A%20560px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F78711i323A4B80F1B4213A%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_2.png%22%20alt%3D%22pastedImage_2.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EHave%20I%20to%20read%2C%20(and%20so%20print%3F)%20the%20acceleration%20on%20X%2CY%2C%20and%20Z%20using%20firstly%20the%20register%20OUT_X_MSB%3F%3C%2FP%3E%3CP%3EAfter%20that%20have%20I%20to%20read%20the%20acceleration%20on%20X%2CY%2C%20and%20Z%20using%20the%20register%20OUT_X_LSB%3F%3C%2FP%3E%3CP%3EAfter%20that%20have%20I%20to%20read%20the%20acceleration%20on%20X%2CY%2C%20and%20Z%20using%20the%20register%20OUT_Y_MSB%3F%20etc%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-817838%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20mma8451%20Motion%20Detection%20and%20RaspberryPi%202b%2B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-817838%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Luigi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EAs%20I%20do%20not%20fully%20understand%20what%20you%20are%20asking%2C%20I%20would%20refer%20to%20the%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN4070.pdf%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EAN4070%3C%2FA%3E%20where%20you%20may%20find%20useful%20information%20related%20to%20the%20embedded%20motion%20detection%20function.%20If%20you%20need%20to%20know%20anything%20specific%2C%20please%20elaborate%20it%20a%20bit%20more.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBest%20regards%2C%3C%2FP%3E%3CP%3ETomas%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-817837%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20mma8451%20Motion%20Detection%20and%20RaspberryPi%202b%2B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-817837%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Eok%20I%20have%20solved%20the%20print%20problem%3B%20it%20was%20just%20a%20bad%20use%20of%20the%20class%20module%3B%20I%20just%20have%20the%20reg%20count%20problem%2C%20can%20someone%20explain%20it%20to%20me%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E
