mm9z1_638 offset step
a852013777
HI Nxp partner
We have performed mm9z1_638  calibration process , we get about 4xxx offset step for vsenor. It can’t write value to the register(comp_vo) for offset step. how we adjust the value for offset step?
guoweisun
See attached hope it can help you!
a852013777
Hi Guoweisun
We calculate the offset step by your excel, we also got 3568 which is bigger than comp_vo register size.
How to modify the valude? thanks
Br,
Mike Liang
a852013777
Hi Guoweisun
Any update? thanks
Br,
Mike Liang
