access to storage data
2,099 次查看
Nadmi-Am
hello. I am trying to write a main program in goal to send An IMU value using BLE
i have two questions :
1) how to access and print a stored  data ?
2) how to send stored data using BLE ?
3 回复数
2,086 次查看
EduardoZamora
Could you please help us with more details about which device are you using?
Eduardo.
2,079 次查看
Nadmi-Am
Hi @EduardoZamora
i am using nanosense with kw38 . My project is to access stored data witch is an accelerometer data and send it with BLE
thank you
2,072 次查看
EduardoZamora
Could you please take a look at the Heart Rate Sensor (hrs) and Temperature Sensor (temp_sens) example projects? Inside the KW38 SDK (wireless_examples > bluetooth). These examples could be used as a base to develop your application, they are highly configurable, allowing the user to set some relevant parameters and change the information being transmitted.
Eduardo.
