Using Sensorfusion algorithm for getting exact reading from Acc+Mag+Gyro ?
Amit_Kumar1
Senior Contributor II
I am using FXOS8700CQ ACC+ mag and FXAS21002 Gyro based FRDM-AGM01 Board, Is there any appnote to interface ACC+Gyro to get exact angle, after this I would be trying to interface magnetometer with these 2 sensors for getting the roll pitch and yaw. I used the sensor fusion toolbox and its library, the data was very precised I wanted to understand and write my own code for interfacing all these 3 sensors. but the raw values had lots of offset wanted to get rid of these offset. is there any appnote for this ? Thanks in advance.
Amit
michaelestanley
Amit,
All documentation is included in the kit doc directory.  The kit includes several different fusion algorithms.  One of those is acc+gyro.  You can then read orientation directly from the output structures of routine and (if that is what you are trying to do) manually fuse it with the mag.  I would expect performance to be a bit better than a pure eCompass (mag+accel), but not as good as the full 9-axis fusion routine (which you also have).
Good luck,
Mike
Amit_Kumar1
Hi Michael
I tried extracting the raw values using both the (sensor fusion library + toolbox recording) and (My basic interfacing code + terminal s/w) keeping the FRDM board stable at same place at same orientation, but the values I got is different. I am sorry for troubling you my only concern is I wanted to understand how things are working. Attached is my code with the o/p files. I have changed the I2C port of AGM board using the jumper position. Please help me in resolving this issue.
Warm Regards
Amit
michaelestanley
Amit,
If I understand you, you are trying to compare raw sensor readings from our library versus those from virgin code you have written?  I can only recommend studying the drivers included in the fusion library.  They are well documented in the code, and are quite stable at this point.
Mike
Amit_Kumar1
Hi Michael
Thanks a lot for your time and patience. I went through your detailed documents. It Reflects the amount of research you would have been doing to get it work. Hats off for your wonderful work. Thanks a lot for providing such an effective library. I had few questions
1) How do I select which sensors to be used ? In My FRDM-STBC-AGM01 board I have FXOS8700CQ and FXAS21002 I don't have any other sensors and was thinking if there is an option to select only these sensors.
2) Is there any option to change the sensitivity i.e for acc 2g/4g/16g or gyro 2000dps/250 dps ?
Amit
michaelestanley
Choice of sensors usually is a mix of technical and business considerations.  The table below shows strengths and weaknesses of the various types of sensors. The board you have has accel+mag+gyro.  The choice of which accel or mag or gyro will depend on desired sampling rate, full scale range, interface type, package size, cost and so forth.
The FXOS8700CQ supports several g ranges (2/4/8).  You can change this in the drivers.c file.  The other two sensors on your board have only a single full scale range.
%3CLINGO-SUB%20id%3D%22lingo-sub-436013%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EUsing%20Sensorfusion%20algorithm%20for%20getting%20exact%20reading%20from%20Acc%2BMag%2BGyro%20%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-436013%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3C%2FP%3E%3CP%3EI%20am%20using%20FXOS8700CQ%20ACC%2B%20mag%20and%20FXAS21002%20Gyro%20based%20%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.freescale.com%252Fwebapp%252Fsps%252Fsite%252Fprod_summary.jsp%253Fcode%253DFRDM-STBC-AGM01%2526fsrch%253D1%2526sr%253D1%2526pageNum%253D1%22%20target%3D%22_blank%22%3EFRDM-AGM01%20%3C%2FA%3E%20%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%22%3EBoard%2C%20Is%20there%20any%20appnote%20to%20interface%20ACC%2BGyro%20to%20get%20exact%20angle%2C%20after%20this%20I%20would%20be%20trying%20to%20interface%20magnetometer%20with%20these%202%20sensors%20for%20getting%20the%20roll%20pitch%20and%20yaw.%20I%20used%20the%20sensor%20fusion%20toolbox%20and%20its%20library%2C%20the%20data%20was%20very%20precised%20I%20wanted%20to%20understand%20and%20write%20my%20own%20code%20for%20interfacing%20all%20these%203%20sensors.%20but%20the%20raw%20values%20had%20lots%20of%20offset%20wanted%20to%20get%20rid%20of%20these%20offset.%20is%20there%20any%20appnote%20for%20this%20%3F%20Thanks%20in%20advance.%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%22%3ERegards%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%22%3EAmit%20%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-436013%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ESensorFusion%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-436018%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Using%20Sensorfusion%20algorithm%20for%20getting%20exact%20reading%20from%20Acc%2BMag%2BGyro%20%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-436018%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EChoice%20of%20sensors%20usually%20is%20a%20mix%20of%20technical%20and%20business%20considerations.%26nbsp%3B%20The%20table%20below%20shows%20strengths%20and%20weaknesses%20of%20the%20various%20%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3Etypes%3C%2FSPAN%3E%20of%20sensors.%20The%20board%20you%20have%20has%20accel%2Bmag%2Bgyro.%26nbsp%3B%20The%20choice%20of%20%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3Ewhich%3C%2FSPAN%3E%20accel%20or%20mag%20or%20gyro%20will%20depend%20on%20desired%20sampling%20rate%2C%20full%20scale%20range%2C%20interface%20type%2C%20package%20size%2C%20cost%20and%20so%20forth.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SensorStrengthsAndWeaknesses%20copy.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SensorStrengthsAndWeaknesses%20copy.png%22%20style%3D%22width%3A%20870px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F22149iF3C5594C7D8367C8%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22SensorStrengthsAndWeaknesses%20copy.png%22%20alt%3D%22SensorStrengthsAndWeaknesses%20copy.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESensorStrengthsAndWeaknesses%20copy.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3EThe%20FXOS8700CQ%20supports%20several%20g%20ranges%20(2%2F4%2F8).%26nbsp%3B%20You%20can%20change%20this%20in%20the%20drivers.c%20file.%26nbsp%3B%20The%20other%20two%20sensors%20on%20your%20board%20have%20only%20a%20single%20full%20scale%20range.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-436017%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Using%20Sensorfusion%20algorithm%20for%20getting%20exact%20reading%20from%20Acc%2BMag%2BGyro%20%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-436017%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Michael%3C%2FP%3E%3CP%3EThanks%20a%20lot%20for%20your%20time%20and%20patience.%20I%20went%20through%20your%20detailed%20documents.%20It%20Reflects%20the%20amount%20of%20research%20you%20would%20have%20been%20doing%20to%20get%20it%20work.%20Hats%20off%20for%20your%20wonderful%20work.%20Thanks%20a%20lot%20for%20providing%20such%20an%20effective%20library.%20I%20had%20few%20questions%20%3C%2FP%3E%3CP%3E1)%20How%20do%20I%20select%20which%20sensors%20to%20be%20used%20%3F%20In%20My%20FRDM-STBC-AGM01%20board%20I%20have%20FXOS8700CQ%20and%20FXAS21002%20I%20don't%20have%20any%20other%20sensors%20and%20was%20thinking%20if%20there%20is%20an%20option%20to%20select%20only%20these%20sensors.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E2)%20Is%20there%20any%20option%20to%20change%20the%20sensitivity%20i.e%20for%20acc%202g%2F4g%2F16g%20or%20gyro%202000dps%2F250%20dps%20%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ERegards%3C%2FP%3E%3CP%3EAmit%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-436016%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Using%20Sensorfusion%20algorithm%20for%20getting%20exact%20reading%20from%20Acc%2BMag%2BGyro%20%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-436016%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EAmit%2C%3C%2FP%3E%3CP%3EIf%20I%20understand%20you%2C%20you%20are%20trying%20to%20compare%20raw%20sensor%20readings%20from%20our%20library%20versus%20those%20from%20virgin%20code%20you%20have%20written%3F%26nbsp%3B%20I%20can%20only%20recommend%20studying%20the%20drivers%20included%20in%20the%20fusion%20library.%26nbsp%3B%20They%20are%20well%20documented%20in%20the%20code%2C%20and%20are%20quite%20stable%20at%20this%20point.%20%3C%2FP%3E%3CP%3EMike%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-436015%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Using%20Sensorfusion%20algorithm%20for%20getting%20exact%20reading%20from%20Acc%2BMag%2BGyro%20%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-436015%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Michael%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20tried%20extracting%20the%20raw%20values%20using%20both%20the%20(sensor%20fusion%20library%20%2B%20toolbox%20recording)%20and%20(My%20basic%20interfacing%20code%20%2B%20terminal%20s%2Fw)%20keeping%20the%20FRDM%20board%20stable%20at%20same%20place%20at%20same%20orientation%2C%20but%20the%20values%20I%20got%20is%20different.%20I%20am%20sorry%20for%20troubling%20you%20my%20only%20concern%20is%20I%20wanted%20to%20understand%20how%20things%20are%20working.%20Attached%20is%20my%20code%20with%20the%20o%2Fp%20files.%20I%20have%20changed%20the%20I2C%20port%20of%20AGM%20board%20using%20the%20jumper%20position.%20Please%20help%20me%20in%20resolving%20this%20issue.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EWarm%20Regards%3C%2FP%3E%3CP%3EAmit%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-436014%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Using%20Sensorfusion%20algorithm%20for%20getting%20exact%20reading%20from%20Acc%2BMag%2BGyro%20%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-436014%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EAmit%2C%3C%2FP%3E%3CP%3EAll%20documentation%20is%20included%20in%20the%20kit%20doc%20directory.%26nbsp%3B%20The%20kit%20includes%20several%20different%20fusion%20algorithms.%26nbsp%3B%20One%20of%20those%20is%20acc%2Bgyro.%26nbsp%3B%20You%20can%20then%20read%20orientation%20directly%20from%20the%20output%20structures%20of%20routine%20and%20(if%20that%20is%20what%20you%20are%20trying%20to%20do)%20manually%20fuse%20it%20with%20the%20mag.%26nbsp%3B%20I%20would%20expect%20performance%20to%20be%20a%20bit%20better%20than%20a%20pure%20eCompass%20(mag%2Baccel)%2C%20but%20not%20as%20good%20as%20the%20full%209-axis%20fusion%20routine%20(which%20you%20also%20have).%3C%2FP%3E%3CP%3EGood%20luck%2C%3C%2FP%3E%3CP%3EMike%3C%2FP%3E%3C%2FLINGO-BODY%3E
