Using Sensorfusion algorithm for getting exact reading from Acc+Mag+Gyro ?
4,782 次查看
Amit_Kumar1
Senior Contributor II
I am using FXOS8700CQ ACC+ mag and FXAS21002 Gyro based FRDM-AGM01 Board, Is there any appnote to interface ACC+Gyro to get exact angle, after this I would be trying to interface magnetometer with these 2 sensors for getting the roll pitch and yaw. I used the sensor fusion toolbox and its library, the data was very precised I wanted to understand and write my own code for interfacing all these 3 sensors. but the raw values had lots of offset wanted to get rid of these offset. is there any appnote for this ? Thanks in advance.
Amit
5 回复数
4,181 次查看
michaelestanley
Amit,
All documentation is included in the kit doc directory.  The kit includes several different fusion algorithms.  One of those is acc+gyro.  You can then read orientation directly from the output structures of routine and (if that is what you are trying to do) manually fuse it with the mag.  I would expect performance to be a bit better than a pure eCompass (mag+accel), but not as good as the full 9-axis fusion routine (which you also have).
Good luck,
Mike
4,180 次查看
Amit_Kumar1
Hi Michael
I tried extracting the raw values using both the (sensor fusion library + toolbox recording) and (My basic interfacing code + terminal s/w) keeping the FRDM board stable at same place at same orientation, but the values I got is different. I am sorry for troubling you my only concern is I wanted to understand how things are working. Attached is my code with the o/p files. I have changed the I2C port of AGM board using the jumper position. Please help me in resolving this issue.
Warm Regards
Amit
4,180 次查看
michaelestanley
Amit,
If I understand you, you are trying to compare raw sensor readings from our library versus those from virgin code you have written?  I can only recommend studying the drivers included in the fusion library.  They are well documented in the code, and are quite stable at this point.
Mike
4,180 次查看
Amit_Kumar1
Hi Michael
Thanks a lot for your time and patience. I went through your detailed documents. It Reflects the amount of research you would have been doing to get it work. Hats off for your wonderful work. Thanks a lot for providing such an effective library. I had few questions
1) How do I select which sensors to be used ? In My FRDM-STBC-AGM01 board I have FXOS8700CQ and FXAS21002 I don't have any other sensors and was thinking if there is an option to select only these sensors.
2) Is there any option to change the sensitivity i.e for acc 2g/4g/16g or gyro 2000dps/250 dps ?
Amit
4,180 次查看
michaelestanley
Choice of sensors usually is a mix of technical and business considerations.  The table below shows strengths and weaknesses of the various types of sensors. The board you have has accel+mag+gyro.  The choice of which accel or mag or gyro will depend on desired sampling rate, full scale range, interface type, package size, cost and so forth.
The FXOS8700CQ supports several g ranges (2/4/8).  You can change this in the drivers.c file.  The other two sensors on your board have only a single full scale range.
%3CLINGO-SUB%20id%3D%22lingo-sub-436013%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BD%BF%E7%94%A8%20Sensorfusion%20%E7%AE%97%E6%B3%95%E4%BB%8E%20Acc%2BMag%2BGyro%20%E4%B8%AD%E8%8E%B7%E5%8F%96%E7%B2%BE%E7%A1%AE%E8%AF%BB%E6%95%B0%EF%BC%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-436013%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHI%20%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E5%9F%BA%E4%BA%8E%20FXOS8700CQ%20ACC%2B%20%E5%BC%B9%E8%8D%AF%E5%92%8C%20FXAS21002%20%E9%99%80%E8%9E%BA%E4%BB%AA%E7%9A%84%20%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.freescale.com%252Fwebapp%252Fsps%252Fsite%252Fprod_summary.jsp%253Fcode%253DFRDM-STBC-AGM01%2526fsrch%253D1%2526sr%253D1%2526pageNum%253D1%22%20target%3D%22_blank%22%3EFRDM-AGM01%3C%2FA%3E%20%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%22%3E%E6%9D%BF%EF%BC%8C%E6%9C%89%E6%B2%A1%E6%9C%89%E9%A2%84%E7%BA%A6%E5%8F%AF%E4%BB%A5%E6%8E%A5%E5%8F%A3%20ACC%2BGyro%20%E4%BB%A5%E8%8E%B7%E5%BE%97%E7%B2%BE%E7%A1%AE%E7%9A%84%E8%A7%92%E5%BA%A6%EF%BC%8C%E4%B9%8B%E5%90%8E%E6%88%91%E4%BC%9A%E5%B0%9D%E8%AF%95%E5%B0%86%E7%A3%81%E5%BC%BA%E8%AE%A1%E4%B8%8E%E8%BF%99%202%20%E4%B8%AA%E4%BC%A0%E6%84%9F%E5%99%A8%E8%BF%9E%E6%8E%A5%E4%BB%A5%E8%8E%B7%E5%8F%96%E6%BB%9A%E5%8A%A8%E4%BF%AF%E4%BB%B0%E5%92%8C%E5%81%8F%E8%88%AA%E3%80%82%E6%88%91%E4%BD%BF%E7%94%A8%E4%BA%86%E4%BC%A0%E6%84%9F%E5%99%A8%E8%9E%8D%E5%90%88%E5%B7%A5%E5%85%B7%E7%AE%B1%E5%8F%8A%E5%85%B6%E5%BA%93%EF%BC%8C%E6%95%B0%E6%8D%AE%E9%9D%9E%E5%B8%B8%E7%B2%BE%E7%A1%AE%EF%BC%8C%E6%88%91%E6%83%B3%E7%90%86%E8%A7%A3%E5%92%8C%E7%BC%96%E5%86%99%E8%87%AA%E5%B7%B1%E7%9A%84%E4%BB%A3%E7%A0%81%E6%9D%A5%E8%BF%9E%E6%8E%A5%E6%89%80%E6%9C%89%E8%BF%99%E4%B8%89%E4%B8%AA%E4%BC%A0%E6%84%9F%E5%99%A8%E3%80%82%E4%BD%86%E6%98%AF%E5%8E%9F%E5%A7%8B%E5%80%BC%E6%9C%89%E5%BE%88%E5%A4%A7%E7%9A%84%E5%81%8F%E7%A7%BB%E9%87%8F%E6%83%B3%E8%A6%81%E6%B6%88%E9%99%A4%E8%BF%99%E4%BA%9B%E5%81%8F%E7%A7%BB%E9%87%8F%E3%80%82%E6%9C%89%E4%BB%BB%E4%BD%95%E6%B3%A8%E6%84%8F%E4%BA%8B%E9%A1%B9%E5%8F%AF%E4%BB%A5%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%E6%8F%90%E5%89%8D%E8%87%B4%E8%B0%A2%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%22%3E%E6%AD%A4%E8%87%B4%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%22%3E%E9%98%BF%E7%B1%B3%E7%89%B9%20%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-436013%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E4%BC%A0%E6%84%9F%E5%99%A8%E8%9E%8D%E5%90%88%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-436018%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Using%20Sensorfusion%20algorithm%20for%20getting%20exact%20reading%20from%20Acc%2BMag%2BGyro%20%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-436018%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BC%A0%E6%84%9F%E5%99%A8%E7%9A%84%E9%80%89%E6%8B%A9%E9%80%9A%E5%B8%B8%E8%A6%81%E7%BB%BC%E5%90%88%E8%80%83%E8%99%91%E6%8A%80%E6%9C%AF%E5%92%8C%E4%B8%9A%E5%8A%A1%E5%9B%A0%E7%B4%A0%E3%80%82%20%E4%B8%8B%E8%A1%A8%E6%98%BE%E7%A4%BA%E4%BA%86%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%E5%90%84%E7%B1%BB%3C%2FSPAN%3E%E4%BC%A0%E6%84%9F%E5%99%A8%E7%9A%84%E4%BC%98%E7%BC%BA%E7%82%B9%E3%80%82%E4%BD%A0%E6%9C%89%E7%9A%84%E6%9D%BF%E4%B8%8A%E6%9C%89%E5%8A%A0%E9%80%9F%E5%BA%A6%2B%E7%A3%81%2B%E9%99%80%E8%9E%BA%E4%BB%AA%E3%80%82%E9%80%89%E6%8B%A9%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%E5%93%AA%3C%2FSPAN%3E%E4%B8%AA%20accel%E3%80%81mag%20%E8%BF%98%E6%98%AF%E9%99%80%E8%9E%BA%E4%BB%AA%E5%B0%86%E5%8F%96%E5%86%B3%E4%BA%8E%E6%89%80%E9%9C%80%E7%9A%84%E9%87%87%E6%A0%B7%E7%8E%87%E3%80%81%E6%BB%A1%E9%87%8F%E7%A8%8B%E8%8C%83%E5%9B%B4%E3%80%81%E6%8E%A5%E5%8F%A3%E7%B1%BB%E5%9E%8B%E3%80%81%E5%B0%81%E8%A3%85%E5%B0%BA%E5%AF%B8%E3%80%81%E6%88%90%E6%9C%AC%E7%AD%89%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SensorStrengthsAndWeaknesses%20copy.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SensorStrengthsAndWeaknesses%20copy.png%22%20style%3D%22width%3A%20870px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F22149iF3C5594C7D8367C8%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22SensorStrengthsAndWeaknesses%20copy.png%22%20alt%3D%22SensorStrengthsAndWeaknesses%20copy.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESensorStrengthsAndWeaknesses%20copy.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3EFXOS8700CQ%20%E6%94%AF%E6%8C%81%E5%A4%9A%E4%B8%AA%20g%20%E8%8C%83%E5%9B%B4%EF%BC%882%2F4%2F8%EF%BC%89%E3%80%82%20%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%9C%A8%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F.c%E9%94%89%E5%88%80%20%E6%9D%BF%E4%B8%8A%E7%9A%84%E5%85%B6%E4%BB%96%E4%B8%A4%E4%B8%AA%E4%BC%A0%E6%84%9F%E5%99%A8%E5%8F%AA%E6%9C%89%E4%B8%80%E4%B8%AA%E6%BB%A1%E9%87%8F%E7%A8%8B%E8%8C%83%E5%9B%B4%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-436017%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Using%20Sensorfusion%20algorithm%20for%20getting%20exact%20reading%20from%20Acc%2BMag%2BGyro%20%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-436017%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%97%A8%EF%BC%8C%E8%BF%88%E5%85%8B%E5%B0%94%3C%2FP%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E4%BD%A0%E4%BB%AC%E7%9A%84%E6%97%B6%E9%97%B4%E5%92%8C%E8%80%90%E5%BF%83%E3%80%82%E6%88%91%E7%9C%8B%E4%BA%86%E4%BD%A0%E7%9A%84%E8%AF%A6%E7%BB%86%E6%96%87%E4%BB%B6%E3%80%82%E5%AE%83%E5%8F%8D%E6%98%A0%E4%BA%86%E6%82%A8%E4%B8%BA%E4%BD%BF%E5%85%B6%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E6%89%80%E5%81%9A%E7%9A%84%E5%A4%A7%E9%87%8F%E7%A0%94%E7%A9%B6%E3%80%82%E5%90%91%E4%BD%A0%E4%BB%AC%E7%9A%84%E5%87%BA%E8%89%B2%E5%B7%A5%E4%BD%9C%E8%87%B4%E6%95%AC%E3%80%82%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E4%BD%A0%E6%8F%90%E4%BE%9B%E4%BA%86%E8%BF%99%E6%A0%B7%E4%B8%80%E4%B8%AA%E6%9C%89%E6%95%88%E7%9A%84%E5%9B%BE%E4%B9%A6%E9%A6%86%E3%80%82%E6%88%91%E6%9C%89%E5%87%A0%E4%B8%AA%E9%97%AE%E9%A2%98%20%3C%2FP%3E%3CP%3E1)%20%E5%A6%82%E4%BD%95%E9%80%89%E6%8B%A9%E8%A6%81%E4%BD%BF%E7%94%A8%E7%9A%84%E4%BC%A0%E6%84%9F%E5%99%A8%EF%BC%9F%E5%9C%A8%E6%88%91%E7%9A%84%20FRDM-STBC-AGM01%20%E6%9D%BF%E4%B8%8A%E6%88%91%E6%9C%89%20FXOS8700CQ%20%E5%92%8C%20FXAS21002%20%E6%88%91%E6%B2%A1%E6%9C%89%E5%85%B6%E4%BB%96%E4%BC%A0%E6%84%9F%E5%99%A8%EF%BC%8C%E6%AD%A3%E5%9C%A8%E8%80%83%E8%99%91%E6%98%AF%E5%90%A6%E5%8F%AF%E4%BB%A5%E9%80%89%E6%8B%A9%E5%8F%AA%E9%80%89%E6%8B%A9%E8%BF%99%E4%BA%9B%E4%BC%A0%E6%84%9F%E5%99%A8%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E2)%20%E6%98%AF%E5%90%A6%E6%9C%89%E4%BB%BB%E4%BD%95%E9%80%89%E9%A1%B9%E5%8F%AF%E4%BB%A5%E6%9B%B4%E6%94%B9%E7%81%B5%E6%95%8F%E5%BA%A6%EF%BC%8C%E4%BE%8B%E5%A6%82%20acc%202g%2F4g%2F16g%20%E6%88%96%20gyro%202000dps%2F250%20dps%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3CP%3E%E9%98%BF%E7%B1%B3%E7%89%B9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-436016%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Using%20Sensorfusion%20algorithm%20for%20getting%20exact%20reading%20from%20Acc%2BMag%2BGyro%20%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-436016%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E9%98%BF%E7%B1%B3%E7%89%B9%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%88%91%E7%90%86%E8%A7%A3%E6%82%A8%E7%9A%84%E6%84%8F%E6%80%9D%EF%BC%8C%E6%82%A8%E6%98%AF%E6%83%B3%E5%B0%86%E6%88%91%E4%BB%AC%E5%BA%93%E4%B8%AD%E7%9A%84%E5%8E%9F%E5%A7%8B%E4%BC%A0%E6%84%9F%E5%99%A8%E8%AF%BB%E6%95%B0%E4%B8%8E%E6%82%A8%E7%BC%96%E5%86%99%E7%9A%84%E5%8E%9F%E5%A7%8B%E4%BB%A3%E7%A0%81%E4%B8%AD%E7%9A%84%E8%AF%BB%E6%95%B0%E8%BF%9B%E8%A1%8C%E6%AF%94%E8%BE%83%EF%BC%9F%20%E6%88%91%E5%8F%AA%E8%83%BD%E5%BB%BA%E8%AE%AE%E5%A4%A7%E5%AE%B6%E5%AD%A6%E4%B9%A0%E8%9E%8D%E5%90%88%E5%BA%93%E4%B8%AD%E7%9A%84%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E3%80%82%20%E5%AE%83%E4%BB%AC%E5%9C%A8%E4%BB%A3%E7%A0%81%E4%B8%AD%E9%83%BD%E6%9C%89%E5%BE%88%E5%A5%BD%E7%9A%84%E8%AE%B0%E5%BD%95%EF%BC%8C%E7%9B%AE%E5%89%8D%E7%9B%B8%E5%BD%93%E7%A8%B3%E5%AE%9A%E3%80%82%20%3C%2FP%3E%3CP%3EMike%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-436015%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Using%20Sensorfusion%20algorithm%20for%20getting%20exact%20reading%20from%20Acc%2BMag%2BGyro%20%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-436015%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%97%A8%EF%BC%8C%E8%BF%88%E5%85%8B%E5%B0%94%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%EF%BC%88%E4%BC%A0%E6%84%9F%E5%99%A8%E8%9E%8D%E5%90%88%E5%BA%93%20%2B%20%E5%B7%A5%E5%85%B7%E7%AE%B1%E8%AE%B0%E5%BD%95%EF%BC%89%E5%92%8C%EF%BC%88%E6%88%91%E7%9A%84%E5%9F%BA%E6%9C%AC%E6%8E%A5%E5%8F%A3%E4%BB%A3%E7%A0%81%20%2B%20%E7%BB%88%E7%AB%AF%E8%BD%AF%E4%BB%B6%EF%BC%89%E6%8F%90%E5%8F%96%E5%8E%9F%E5%A7%8B%E5%80%BC%EF%BC%8C%E4%BF%9D%E6%8C%81%20FRDM%20%E6%9D%BF%E5%9C%A8%E7%9B%B8%E5%90%8C%E6%96%B9%E5%90%91%E7%9A%84%E5%90%8C%E4%B8%80%E4%BD%8D%E7%BD%AE%E4%BF%9D%E6%8C%81%E7%A8%B3%E5%AE%9A%EF%BC%8C%E4%BD%86%E6%88%91%E5%BE%97%E5%88%B0%E7%9A%84%E5%80%BC%E4%B8%8D%E5%90%8C%E3%80%82%E5%BE%88%E6%8A%B1%E6%AD%89%E7%BB%99%E6%82%A8%E6%B7%BB%E9%BA%BB%E7%83%A6%E4%BA%86%EF%BC%8C%E6%88%91%E5%8F%AA%E6%98%AF%E6%83%B3%E4%BA%86%E8%A7%A3%E4%B8%80%E4%B8%8B%E4%BA%8B%E6%83%85%E7%9A%84%E8%BF%9B%E5%B1%95%E6%83%85%E5%86%B5%E3%80%82%E9%99%84%E4%B8%8A%E6%88%91%E7%9A%84%E4%BB%A3%E7%A0%81%E5%92%8C%20O%2FP%20%E6%96%87%E4%BB%B6%E3%80%82%E6%88%91%E5%B7%B2%E7%BB%8F%E4%BD%BF%E7%94%A8%E8%B7%B3%E7%BA%BF%E4%BD%8D%E7%BD%AE%E6%9B%B4%E6%94%B9%E4%BA%86%20AGM%20%E6%9D%BF%E7%9A%84%20I2C%20%E7%AB%AF%E5%8F%A3%E3%80%82%E8%AF%B7%E5%B8%AE%E6%88%91%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%B8%A9%E9%A6%A8%E7%9A%84%E9%97%AE%E5%80%99%3C%2FP%3E%3CP%3E%E9%98%BF%E7%B1%B3%E7%89%B9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-436014%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Using%20Sensorfusion%20algorithm%20for%20getting%20exact%20reading%20from%20Acc%2BMag%2BGyro%20%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-436014%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E9%98%BF%E7%B1%B3%E7%89%B9%3C%2FP%3E%3CP%3E%E6%89%80%E6%9C%89%E6%96%87%E6%A1%A3%E9%83%BD%E5%8C%85%E5%90%AB%E5%9C%A8%E5%B7%A5%E5%85%B7%E5%8C%85%E6%96%87%E6%A1%A3%E7%9B%AE%E5%BD%95%E4%B8%AD%E3%80%82%20%E8%AF%A5%E5%B7%A5%E5%85%B7%E5%8C%85%E5%8C%85%E6%8B%AC%E5%87%A0%E7%A7%8D%E4%B8%8D%E5%90%8C%E7%9A%84%E8%9E%8D%E5%90%88%E7%AE%97%E6%B3%95%E3%80%82%20%E5%85%B6%E4%B8%AD%E4%B9%8B%E4%B8%80%E5%B0%B1%E6%98%AF%20acc%2Bgyro%E3%80%82%20%E7%84%B6%E5%90%8E%EF%BC%8C%E4%BD%A0%E5%8F%AF%E4%BB%A5%E7%9B%B4%E6%8E%A5%E4%BB%8E%E4%BE%8B%E7%A8%8B%E7%9A%84%E8%BE%93%E5%87%BA%E7%BB%93%E6%9E%84%E4%B8%AD%E8%AF%BB%E5%8F%96%E6%96%B9%E5%90%91%EF%BC%8C%E7%84%B6%E5%90%8E%EF%BC%88%E5%A6%82%E6%9E%9C%E4%BD%A0%E6%83%B3%E8%BF%99%E6%A0%B7%E5%81%9A%EF%BC%89%E6%89%8B%E5%8A%A8%E5%B0%86%E5%85%B6%E4%B8%8E%E5%BC%B9%E5%A4%B9%E7%86%94%E4%B8%9D%E3%80%82%E6%88%91%E9%A2%84%E8%AE%A1%E6%80%A7%E8%83%BD%E4%BC%9A%E6%AF%94%E7%BA%AF%20eCompass%EF%BC%88%E7%A3%81%2B%E7%94%B5%EF%BC%89%E6%9B%B4%E5%A5%BD%E4%B8%80%E4%BA%9B%EF%BC%8C%E4%BD%86%E4%B8%8D%E5%A6%82%E5%AE%8C%E6%95%B4%E7%9A%84%209%20%E8%BD%B4%E8%9E%8D%E5%90%88%E7%A8%8B%E5%BA%8F%EF%BC%88%E4%BD%A0%E4%B9%9F%E6%9C%89%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%E7%A5%9D%E4%BD%A0%E5%A5%BD%E8%BF%90%3C%2FP%3E%3CP%3EMike%3C%2FP%3E%3C%2FLINGO-BODY%3E
