Spikes on Accelerometer Data
3,005件の閲覧回数
moisesferber
Hello! I 'm developing a motion detection application using MMA8453Q and I2C for communication between the microcontroller and the accelerometer. Occasionally, like once every five or ten seconds, there 's a spike in the data. For example, the z-axis acceleration is at around 1.0g and suddenly it drops to almost 0.0g and goes back to 1.0g. All of that happens in 3 samples, at 800Hz.
Is this a "normal" situation or there's something I'm missing? One of my colleagues thinks it's a problem with the I2C, but I doubt it.
2 返答(返信)
2,564件の閲覧回数
TomasVaverka
Hello Moises,
It sounds like a timing issue, the first thing I would recommend to try is using a lower ODR and/or a higher I2C clock speed.
Do you have a logic analyzer or an oscilloscope to know what is going on on the I2C bus and interrupt pins (if used)?
It might also be helpful to see your source code (at least the initialization and data processing routines).
Tomas
PS: If my answer helps to solve your question, please mark it as "Correct" or “Helpful”. Thank you.
2,564件の閲覧回数
moisesferber
Dear Tomas Vaverka,
thank you for your reply. I reduced the ODR to 100Hz and set the High Resolution mode. The number of spikes reduced significantly. However, there are still about 2 spikes every 5 minutes. Do you think I should reduce even more the ODR or this time increase the I2C clock, so that this problem will disappear definitely?
Some parts of the source code:
// ---------- I2C INIT ---------- //
void I2C0Init( void )
  LPC_SC->PCONP |= (1 << 7);
  /* set PIO0.27 and PIO0.28 to I2C0 SDA and SCL */
  /* function to 01 on both SDA and SCL. */
  LPC_PINCON->PINSEL1 &= ~((0x03<<22)|(0x03<<24));
  LPC_PINCON->PINSEL1 |= ((0x01<<22)|(0x01<<24));
  /*--- Clear flags ---*/
  LPC_I2C0->I2CONCLR = I2CONCLR_AAC | I2CONCLR_SIC | I2CONCLR_STAC | I2CONCLR_I2ENC;
  /*--- Reset registers ---*/
#if FAST_MODE_PLUS
  LPC_PINCON->I2CPADCFG |= ((0x1<<0)|(0x1<<2));
  LPC_I2C0->I2SCLL   = I2SCLL_HS_SCLL;
  LPC_I2C0->I2SCLH   = I2SCLH_HS_SCLH;
#else
  LPC_PINCON->I2CPADCFG &= ~((0x1<<0)|(0x1<<2));
  LPC_I2C0->I2SCLL   = I2SCLL_SCLL;
  LPC_I2C0->I2SCLH   = I2SCLH_SCLH;
#endif
  /* Install interrupt handler */
  NVIC_EnableIRQ(I2C0_IRQn);
  LPC_I2C0->I2CONSET = I2CONSET_I2EN;
  return;
// ---------- WRITE IN REGISTER ---------- //
void ACEL_EscreveRegistrador(uint8_t registrador, uint8_t dado)
  //uint32_t PORT_USED = 0;
  I2CMasterBuffer[0][0] = 0x3A; //write
  I2CMasterBuffer[0][1] = registrador;
  I2CMasterBuffer[0][2] = dado; //dado a ser escrito no registrador
  I2CWriteLength[0] = 3;
  I2CReadLength[0] = 0;
  I2CEngine(0);
// ---------- ACCELEROMETER INIT ---------- //
  // High Resolution
  ACEL_EscreveRegistrador(ACEL_REG_CTRL_REG2, 0b00010010); //0x2B: CTRL_REG2
  // ODR = 100 Hz, page 35 do datasheet
  ACEL_EscreveRegistrador(ACEL_REG_CTRL_REG1, 0b00011000); //0x2A: CTRL_REG1
// ---------- READING FUNCTION OF THE ACCELEROMETER ---------- //
void ACEL_LeDadosFormatoG(uint16_t *dados)
  uint16_t counts[6];
  uint16_t temp;
  // uint8_t i;
  uint8_t divisor = 0;
  uint8_t range = 0;
  //verifica qual o range (2g, 4g ou 8g) para selecionar o divisor
  range = ACEL_LeRegistrador(ACEL_REG_XYZ_DATA_CFG);
  switch (range & 0b11)
    case 0b00: //2g
      divisor = 8;
      break;
    case 0b01: //4g
      divisor = 7;
      break;
    case 0b10: //8g
      divisor = 6;
      break;
  ACEL_LeDadosFormatoCounts(counts);
  //copia os sinais
  dados[0] = counts[0];
  dados[2] = counts[2];
  dados[4] = counts[4];
  temp = ((counts[1] & 0x1FF) * 1000 + 512) >> divisor;
  dados[1] = temp;
  temp = ((counts[3] & 0x1FF) * 1000 + 512) >> divisor;
  dados[3] = temp;
  temp = ((counts[5] & 0x1FF) * 1000 + 512) >> divisor;
  dados[5] = temp;
%3CLINGO-SUB%20id%3D%22lingo-sub-385738%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%8A%A0%E9%80%9F%E5%BA%A6%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AE%E6%80%A5%E4%B8%8A%E6%98%87%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-385738%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20tahoma%2C%20arial%2C%20verdana%2C%20sans-serif%3B%20font-size%3A%2014.3999996185303px%3B%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%EF%BC%81%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%81%A8%E5%8A%A0%E9%80%9F%E5%BA%A6%E8%A8%88%E9%96%93%E3%81%AE%E9%80%9A%E4%BF%A1%E3%81%AB%20MMA8453Q%20%E3%81%A8%20I2C%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%A2%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E6%A4%9C%E5%87%BA%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E9%96%8B%E7%99%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E6%99%82%E3%80%85%E3%80%815%20%E7%A7%92%E3%81%BE%E3%81%9F%E3%81%AF%2010%20%E7%A7%92%E3%81%AB%201%20%E5%9B%9E%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AB%E6%80%A5%E4%B8%8A%E6%98%87%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%9F%E3%81%A8%E3%81%88%E3%81%B0%E3%80%81Z%20%E8%BB%B8%E3%81%AE%E5%8A%A0%E9%80%9F%E5%BA%A6%E3%81%AF%E7%B4%84%201.0g%20%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E7%AA%81%E7%84%B6%200.0g%20%E8%BF%91%E3%81%8F%E3%81%BE%E3%81%A7%E4%BD%8E%E4%B8%8B%E3%81%97%E3%80%81%E3%81%9D%E3%81%AE%E5%BE%8C%201.0g%20%E3%81%AB%E6%88%BB%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%82%89%E3%81%AF%E3%81%99%E3%81%B9%E3%81%A6%203%20%E3%81%A4%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%81%A7%20800%20Hz%20%E3%81%A7%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20tahoma%2C%20arial%2C%20verdana%2C%20sans-serif%3B%20font-size%3A%2014.3999996185303px%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20tahoma%2C%20arial%2C%20verdana%2C%20sans-serif%3B%20font-size%3A%2014.3999996185303px%3B%22%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%80%8C%E9%80%9A%E5%B8%B8%E3%81%AE%E3%80%8D%E7%8A%B6%E6%B3%81%E3%81%A7%E3%81%99%E3%81%8B%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E7%A7%81%E3%81%8C%E8%A6%8B%E8%90%BD%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E4%BD%95%E3%81%8B%E3%81%8C%E3%81%82%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%E5%90%8C%E5%83%9A%E3%81%AE%E4%B8%80%E4%BA%BA%E3%81%AF%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%20I2C%20%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%A0%E3%81%A8%E8%80%83%E3%81%88%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E7%A7%81%E3%81%AF%E3%81%9D%E3%81%86%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-385738%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E5%8A%A0%E9%80%9F%E5%BA%A6%E3%82%BB%E3%83%B3%E3%82%B5%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-385740%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Spikes%20on%20Accelerometer%20Data%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-385740%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%88%E3%83%9E%E3%82%B9%E3%83%BB%E3%83%B4%E3%82%A1%E3%83%B4%E3%82%A7%E3%83%AB%E3%82%AB%E6%A7%98%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%8A%E8%BF%94%E4%BA%8B%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82ODR%E3%82%92100Hz%E3%81%AB%E4%B8%8B%E3%81%92%E3%81%A6%E9%AB%98%E8%A7%A3%E5%83%8F%E5%BA%A6%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%B9%E3%83%91%E3%82%A4%E3%82%AF%E3%81%AE%E6%95%B0%E3%81%8C%E5%A4%A7%E5%B9%85%E3%81%AB%E6%B8%9B%E5%B0%91%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%815%20%E5%88%86%E3%81%94%E3%81%A8%E3%81%AB%E7%B4%84%202%20%E5%9B%9E%E3%81%AE%E3%82%B9%E3%83%91%E3%82%A4%E3%82%AF%E3%81%8C%E3%81%BE%E3%81%A0%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E7%A2%BA%E5%AE%9F%E3%81%AB%E8%A7%A3%E6%B6%88%E3%81%95%E3%82%8C%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81ODR%20%E3%82%92%E3%81%95%E3%82%89%E3%81%AB%E6%B8%9B%E3%82%89%E3%81%99%E3%81%8B%E3%80%81%E4%BB%8A%E5%BA%A6%E3%81%AF%20I2C%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E5%A2%97%E3%82%84%E3%81%99%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E4%B8%80%E9%83%A8%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2F%2F%20----------%20I2C%20%E5%88%9D%E6%9C%9F%E5%8C%96%20----------%20%2F%2F%3C%2FP%3E%3CP%3Evoid%20I2C0Init(void)%20%3C%2FP%3E%3CP%3E%7B%3C%2FP%3E%3CP%3ELPC_SC-%26gt%3BPCONP%20%7C%3D%20(1%20%26lt%3B%26lt%3B%207)%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2F*%20PIO0.27%E3%81%A8PIO0.28%E3%82%92I2C0%E3%81%AESDA%E3%81%A8SCL%E3%81%AB%E8%A8%AD%E5%AE%9A%20*%2F%3C%2FP%3E%3CP%3E%2F*%20SDA%20%E3%81%A8%20SCL%20%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%A7%2001%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82*%2F%3C%2FP%3E%3CP%3ELPC_PINCON-%26gt%3BPINSEL1%20%26amp%3B%3D%20~((0x03%26lt%3B%26lt%3B22)%7C(0x03%26lt%3B%26lt%3B24))%3B%3C%2FP%3E%3CP%3ELPC_PINCON-%26gt%3BPINSEL1%20%7C%3D%20((0x01%26lt%3B%26lt%3B22)%7C(0x01%26lt%3B%26lt%3B24))%3B%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2F*---%20%E3%83%95%E3%83%A9%E3%82%B0%E3%82%92%E3%82%AF%E3%83%AA%E3%82%A2%E3%81%99%E3%82%8B%20---*%2F%3C%2FP%3E%3CP%3ELPC_I2C0-%26gt%3BI2CONCLR%20%3D%20I2CONCLR_AAC%20%7C%20I2CONCLR_SIC%20%7C%20I2CONCLR_STAC%20%7C%20I2CONCLR_I2ENC%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2F*---%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%20---*%2F%3C%2FP%3E%3CP%3E%23FAST_MODE_PLUS%E3%81%AE%E5%A0%B4%E5%90%88%3C%2FP%3E%3CP%3ELPC_PINCON-%26gt%3BI2CPADCFG%20%7C%3D%20((0x1%26lt%3B%26lt%3B0)%7C(0x1%26lt%3B%26lt%3B2))%3B%3C%2FP%3E%3CP%3ELPC_I2C0-%26gt%3BI2SCLL%20%3D%20I2SCLL_HS_SCLL%3B%3C%2FP%3E%3CP%3ELPC_I2C0-%26gt%3BI2SCLH%20%3D%20I2SCLH_HS_SCLH%3B%3C%2FP%3E%3CP%3E%EF%BC%83%E3%81%9D%E3%82%8C%E4%BB%A5%E5%A4%96%3C%2FP%3E%3CP%3ELPC_PINCON-%26gt%3BI2CPADCFG%20%26amp%3B%3D%20~((0x1%26lt%3B%26lt%3B0)%7C(0x1%26lt%3B%26lt%3B2))%3B%3C%2FP%3E%3CP%3ELPC_I2C0-%26gt%3BI2SCLL%20%3D%20I2SCLL_SCLL%3B%3C%2FP%3E%3CP%3ELPC_I2C0-%26gt%3BI2SCLH%20%3D%20I2SCLH_SCLH%3B%3C%2FP%3E%3CP%3E%23endif%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2F*%20%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%20*%2F%3C%2FP%3E%3CP%3ENVIC_EnableIRQ(I2C0_IRQn)%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ELPC_I2C0-%26gt%3BI2CONSET%20%3D%20I2CONSET_I2EN%3B%3C%2FP%3E%3CP%3E%E6%88%BB%E3%82%8B%3B%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3CP%3E%2F%2F%20----------%20I2C%20%E5%88%9D%E6%9C%9F%E5%8C%96%20----------%20%2F%2F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2F%2F%20----------%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%20----------%20%2F%2F%3C%2FP%3E%3CP%3Evoid%20ACEL_EscreveRegistrador(uint8_t%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%83%88%E3%83%A9%E3%83%89%E3%83%BC%E3%83%AB%E3%80%81uint8_t%20%E3%83%80%E3%83%89)%3C%2FP%3E%3CP%3E%7B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2F%2Fuint32_t%20PORT_USED%20%3D%200%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI2CMasterBuffer%5B0%5D%5B0%5D%20%3D%200x3A%3B%20%2F%2F%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%3C%2FP%3E%3CP%3EI2CMasterBuffer%5B0%5D%5B1%5D%20%3D%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%83%88%E3%83%A9%3B%3C%2FP%3E%3CP%3EI2CMasterBuffer%5B0%5D%5B2%5D%20%3D%20%E3%83%80%E3%83%89%3B%20%2F%2F%20%E7%99%BB%E9%8C%B2%E8%80%85%E3%82%92%E7%99%BB%E9%8C%B2%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3EI2C%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E9%95%B7%E3%81%95%5B0%5D%20%3D%203%3B%3C%2FP%3E%3CP%3EI2CReadLength%5B0%5D%20%3D%200%3B%3C%2FP%3E%3CP%3EI2C%E3%82%A8%E3%83%B3%E3%82%B8%E3%83%B3(0)%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3CP%3E%2F%2F%20----------%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%20----------%20%2F%2F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2F%2F%20----------%20%E5%8A%A0%E9%80%9F%E5%BA%A6%E3%82%BB%E3%83%B3%E3%82%B5%E5%88%9D%E6%9C%9F%E5%8C%96%20----------%20%2F%2F%3C%2FP%3E%3CP%3E%2F%2F%20%E9%AB%98%E8%A7%A3%E5%83%8F%E5%BA%A6%3C%2FP%3E%3CP%3EACEL_EscreveRegistrador(ACEL_REG_CTRL_REG2%2C%200b00010010)%3B%20%2F%2F0x2B%3A%20CTRL_REG2%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2F%2F%20ODR%20%3D%20100%20Hz%E3%80%8135%E3%83%9A%E3%83%BC%E3%82%B8%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%3C%2FP%3E%3CP%3EACEL_EscreveRegistrador(ACEL_REG_CTRL_REG1%2C%200b00011000)%3B%20%2F%2F0x2A%3A%20CTRL_REG1%3C%2FP%3E%3CP%3E%2F%2F%20----------%20%E5%8A%A0%E9%80%9F%E5%BA%A6%E3%82%BB%E3%83%B3%E3%82%B5%E5%88%9D%E6%9C%9F%E5%8C%96%20----------%20%2F%2F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2F%2F%20----------%20%E5%8A%A0%E9%80%9F%E5%BA%A6%E3%82%BB%E3%83%B3%E3%82%B5%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E6%A9%9F%E8%83%BD%20----------%20%2F%2F%3C%2FP%3E%3CP%3Evoid%20ACEL_LeDadosFormatoG(uint16_t%20*dados)%3C%2FP%3E%3CP%3E%7B%3C%2FP%3E%3CP%3Euint16_t%20%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%5B6%5D%3B%3C%2FP%3E%3CP%3Euint16_t%20%E6%B8%A9%E5%BA%A6%3B%3C%2FP%3E%3CP%3E%2F%2F%20uint8_t%20i%3B%3C%2FP%3E%3CP%3Euint8_t%20%E9%99%A4%E6%95%B0%20%3D%200%3B%3C%2FP%3E%3CP%3Euint8_t%20%E7%AF%84%E5%9B%B2%20%3D%200%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2F%2Fverifica%20qual%20o%20range%20(2g%2C%204g%20ou%208g)%20%E3%81%AE%E9%99%A4%E6%95%B0%E3%81%AE%E9%81%B8%E6%8A%9E%3C%2FP%3E%3CP%3E%E7%AF%84%E5%9B%B2%20%3D%20ACEL_LeRegistrador(ACEL_REG_XYZ_DATA_CFG)%3B%3C%2FP%3E%3CP%3E%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%EF%BC%88%E7%AF%84%E5%9B%B2%E3%81%A80b11%EF%BC%89%3C%2FP%3E%3CP%3E%26nbsp%3B%20%7B%3C%2FP%3E%3CP%3ECASE%200b00%3A%20%2F%2F2g%3C%2FP%3E%3CP%3E%E9%99%A4%E6%95%B0%20%3D%208%3B%3C%2FP%3E%3CP%3E%E5%A3%8A%E3%81%99%3B%3C%2FP%3E%3CP%3ECASE%200b01%3A%20%2F%2F4g%3C%2FP%3E%3CP%3E%E9%99%A4%E6%95%B0%20%3D%207%3B%3C%2FP%3E%3CP%3E%E5%A3%8A%E3%81%99%3B%3C%2FP%3E%3CP%3ECASE%200b10%3A%20%2F%2F8g%3C%2FP%3E%3CP%3E%E9%99%A4%E6%95%B0%20%3D%206%3B%3C%2FP%3E%3CP%3E%E5%A3%8A%E3%81%99%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%20%7D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EACEL_LeDadosFormatoCounts(%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88)%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2F%2F%E3%82%B3%E3%83%94%E3%83%BC%20os%20sinais%3C%2FP%3E%3CP%3Edados%5B0%5D%20%3D%20counts%5B0%5D%3B%3C%2FP%3E%3CP%3Edados%5B2%5D%20%3D%20%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%5B2%5D%3B%3C%2FP%3E%3CP%3Edados%5B4%5D%20%3D%20%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%5B4%5D%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Etemp%20%3D%20((counts%5B1%5D%20%26amp%3B%200x1FF)%20*%201000%20%2B%20512)%20%26gt%3B%26gt%3B%20%E9%99%A4%E6%95%B0%3B%3C%2FP%3E%3CP%3Edados%5B1%5D%20%3D%20%E4%B8%80%E6%99%82%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Etemp%20%3D%20((counts%5B3%5D%20%26amp%3B%200x1FF)%20*%201000%20%2B%20512)%20%26gt%3B%26gt%3B%20%E9%99%A4%E6%95%B0%3B%3C%2FP%3E%3CP%3Edados%5B3%5D%20%3D%20%E4%B8%80%E6%99%82%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Etemp%20%3D%20((counts%5B5%5D%20%26amp%3B%200x1FF)%20*%201000%20%2B%20512)%20%26gt%3B%26gt%3B%20%E9%99%A4%E6%95%B0%3B%3C%2FP%3E%3CP%3Edados%5B5%5D%20%3D%20%E4%B8%80%E6%99%82%3B%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3CP%3E%2F%2F%20----------%20%E5%8A%A0%E9%80%9F%E5%BA%A6%E3%82%BB%E3%83%B3%E3%82%B5%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E6%A9%9F%E8%83%BD%20----------%20%2F%2F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-385739%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Spikes%20on%20Accelerometer%20Data%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-385739%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%A2%E3%82%A4%E3%82%BB%E3%82%B9%E3%81%95%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20class%3D%22Default%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AE%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E3%81%BE%E3%81%9A%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82ODR%20%E3%82%92%E4%BD%8E%E3%81%8F%E3%81%99%E3%82%8B%E3%81%8B%E3%80%81I2C%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E9%80%9F%E5%BA%A6%E3%82%92%E9%AB%98%E3%81%8F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Default%22%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3EI2C%20%E3%83%90%E3%82%B9%E3%81%A8%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%83%94%E3%83%B3%20(%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88)%20%E3%81%A7%E4%BD%95%E3%81%8C%E8%B5%B7%E3%81%93%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%83%AD%E3%82%B8%E3%83%83%E3%82%AF%20%E3%82%A2%E3%83%8A%E3%83%A9%E3%82%A4%E3%82%B6%E3%83%BC%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%AA%E3%82%B7%E3%83%AD%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%97%E3%82%92%E3%81%8A%E6%8C%81%E3%81%A1%E3%81%A7%E3%81%99%E3%81%8B%3F%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%E3%82%BD%E3%83%BC%E3%82%B9%20%E3%82%B3%E3%83%BC%E3%83%89%20(%E5%B0%91%E3%81%AA%E3%81%8F%E3%81%A8%E3%82%82%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%A8%E3%83%87%E3%83%BC%E3%82%BF%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%81%E3%83%B3)%20%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82%E5%BD%B9%E7%AB%8B%E3%81%A4%E5%A0%B4%E5%90%88%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%E3%83%88%E3%83%BC%E3%83%9E%E3%82%B9%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%3CEM%20style%3D%22font-family%3A%20Arial%2C%20sans-serif%3B%20color%3A%20%23333333%3B%22%3E%3CSPAN%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-size%3A%2011px%3B%20font-family%3A%20inherit%3B%20color%3A%20%233d3d3d%3B%22%3E%3CEM%20style%3D%22font-weight%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%E8%BF%BD%E4%BC%B8%3A%3CSPAN%20class%3D%22Apple-converted-space%22%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CSPAN%20class%3D%22Apple-converted-space%22%3E%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-size%3A%2011px%3B%20font-family%3A%20inherit%3B%20color%3A%20%233d3d3d%3B%22%3E%E7%A7%81%E3%81%AE%E5%9B%9E%E7%AD%94%E3%81%8C%E3%81%94%E8%B3%AA%E5%95%8F%E3%81%AE%E8%A7%A3%E6%B1%BA%E3%81%AB%E5%BD%B9%E7%AB%8B%E3%81%A3%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%80%8C%E6%AD%A3%E8%A7%A3%E3%80%8D%E3%81%BE%E3%81%9F%E3%81%AF%E3%80%8C%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A3%E3%81%9F%E3%80%8D%E3%81%A8%E8%A9%95%E4%BE%A1%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
