SPI pins
5,955 次查看
SandraGeorge
I need to connect pressure sensor FRDMSTBANBP8XD board to my microcontroller board. So from my understanding, I should use the below pins for SPI connection.
  1. J5.4 - SOCI
  2. J5.5 - SICO
  3. J5.6 - SCLK
  4. J5.7 - GND
  5. J6.4 - VDD
  6. J3.3 - CS/Wakeup
Is my understanding correct? Also I couldn't find the INT/RDY pin I should use. Which pin I can use for INT/RDY?
5,949 次查看
ErikaC
Thank you for contacting us.
Yes, it is correct.
For INT/RDY pin you should use J3.6 or J3.8 please refer to user manual table 1. Jumpers and NBP9 Datasheet table 3 and 4.
Updating Media
Hope this helps.
6 回复数
5,950 次查看
ErikaC
Yes, it is correct.
Updating Media
Hope this helps.
5,926 次查看
SandraGeorge
Thank you for the support.
I have one more query. From the document, I understood that the NBP8 asserts the PS ENABLE pin before generating a pulse on the INT pin if the PS_ENABLE pin is enabled.
But I wish to know what is the real benefit of using it. What is the advantage of using it if we are already watching INT pin?
5,920 次查看
ErikaC
The notification sequence depends on whether the PS ENABLE feature is enabled or not.
Please check AN13882 Host application for NBP devices Section 5.1
5,889 次查看
SandraGeorge
Hi Erika,
I understood that if we enable PS_ENABLE, then there will be an assertion on PS_ENABLE pin. But I wish to know what is the real advantage of using it. If I detect the assertion on PS_ENABLE pin, what I can do with that?
5,879 次查看
ErikaC
PS enabled pin can be used by the NBPX to turn on the external MCU power supply before triggering an interrupt in case the external MCU remains in off state most of the time.
For more details, please see BPMS Product Training slides 25 and 26.
Hope this helps.
5,852 次查看
SandraGeorge
Hello Erika,
I understood. Thank you!
%3CLINGO-SUB%20id%3D%22lingo-sub-1648692%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ESPI%20%E5%BC%95%E8%84%9A%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1648692%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CBR%20%2F%3E%E6%88%91%E9%9C%80%E8%A6%81%E5%B0%86%E5%8E%8B%E5%8A%9B%E4%BC%A0%E6%84%9F%E5%99%A8%20FRDMSTBANBP8XD%20%E6%9D%BF%E8%BF%9E%E6%8E%A5%E5%88%B0%E6%88%91%E7%9A%84%E5%BE%AE%E6%8E%A7%E5%88%B6%E5%99%A8%E6%9D%BF%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%A0%B9%E6%8D%AE%E6%88%91%E7%9A%84%E7%90%86%E8%A7%A3%EF%BC%8C%E6%88%91%E5%BA%94%E8%AF%A5%E4%BD%BF%E7%94%A8%E4%BB%A5%E4%B8%8B%E5%BC%95%E8%84%9A%E8%BF%9B%E8%A1%8C%20SPI%20%E8%BF%9E%E6%8E%A5%E3%80%82%3C%2FP%3E%3COL%3E%3CLI%3EJ5.4%20-%20%E7%A4%BE%E4%BC%9A%E7%A7%91%E5%AD%A6%E5%8F%8A%E4%BA%BA%E6%96%87%E7%A7%91%E5%AD%A6%3C%2FLI%3E%3CLI%3EJ5.5%20-%20SICO%3C%2FLI%3E%3CLI%3EJ5.6%20-%20SCLK%3C%2FLI%3E%3CLI%3EJ5.7%20-%20%E6%8E%A5%E5%9C%B0%3C%2FLI%3E%3CLI%3EJ6.4%20-%20VDD%3C%2FLI%3E%3CLI%3EJ3.3%20-%20CS%2FWakeup%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3CSPAN%3E%3CBR%20%2F%3E%E6%88%91%E7%9A%84%E7%90%86%E8%A7%A3%E6%AD%A3%E7%A1%AE%E5%90%97%EF%BC%9F%E6%AD%A4%E5%A4%96%EF%BC%8C%E6%88%91%E4%B9%9F%E6%89%BE%E4%B8%8D%E5%88%B0%E5%BA%94%E8%AF%A5%E4%BD%BF%E7%94%A8%E7%9A%84%20INT%2FRDY%20%E5%BC%95%E8%84%9A%E3%80%82INT%2FRDY%20%E5%8F%AF%E4%BB%A5%E7%94%A8%E5%93%AA%E4%B8%AA%E5%BC%95%E8%84%9A%EF%BC%9F%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1648692%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E5%8E%8B%E5%8A%9B%E4%BC%A0%E6%84%9F%E5%99%A8%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1653676%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SPI%20pins%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1653676%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E8%89%BE%E4%B8%BD%E5%8D%A1%E3%80%81%3C%2FP%3E%3CP%3E%E6%88%91%E6%98%8E%E7%99%BD%E4%BA%86%E3%80%82%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1651396%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SPI%20pins%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1651396%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A6%82%E6%9E%9C%E5%A4%96%E9%83%A8%20MCU%20%E5%A4%A7%E9%83%A8%E5%88%86%E6%97%B6%E9%97%B4%E5%A4%84%E4%BA%8E%E5%85%B3%E9%97%AD%E7%8A%B6%E6%80%81%EF%BC%8CNBPX%20%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E6%94%AF%E6%8C%81%20PS%20%E7%9A%84%E5%BC%95%E8%84%9A%E5%9C%A8%E8%A7%A6%E5%8F%91%E4%B8%AD%E6%96%AD%E4%B9%8B%E5%89%8D%E6%89%93%E5%BC%80%E5%A4%96%E9%83%A8%20MCU%20%E7%94%B5%E6%BA%90%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22ErikaC_0-1684257693495.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22ErikaC_0-1684257693495.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F223432i4705CC0E5ED75671%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22ErikaC_0-1684257693495.png%22%20alt%3D%22ErikaC_0-1684257693495.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%9B%B4%E5%A4%9A%E8%AF%A6%E6%83%85%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85%3CA%20href%3D%22https%3A%2F%2Fwww.brainshark.com%2F1%2Fplayer%2Fnxp%3Fpi%3DzI1zWf4ivzVcFXz0%26amp%3Br3f1%3D%26amp%3Bfb%3D0%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EBPMS%20%E4%BA%A7%E5%93%81%E5%9F%B9%E8%AE%AD%3C%2FA%3E%E5%B9%BB%E7%81%AF%E7%89%87%2025%20%E5%92%8C%2026%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%B8%8C%E6%9C%9B%E8%BF%99%E8%83%BD%E5%B8%AE%E5%88%B0%E6%82%A8%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1650767%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SPI%20pins%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1650767%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E8%89%BE%E4%B8%BD%E5%8D%A1%E3%80%81%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84%E7%90%86%E8%A7%A3%E6%98%AF%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%88%91%E4%BB%AC%E5%90%AF%E7%94%A8%20PS_ENABLE%EF%BC%8C%E9%82%A3%E4%B9%88%20PS_ENABLE%20%E5%BC%95%E8%84%9A%E4%B8%8A%E5%B0%B1%E4%BC%9A%E5%87%BA%E7%8E%B0%E6%96%AD%E8%A8%80%E3%80%82%E4%BD%86%E6%88%91%E6%83%B3%E7%9F%A5%E9%81%93%E4%BD%BF%E7%94%A8%E5%AE%83%E7%9A%84%E7%9C%9F%E6%AD%A3%E5%A5%BD%E5%A4%84%E6%98%AF%E4%BB%80%E4%B9%88%E3%80%82%E5%A6%82%E6%9E%9C%E6%88%91%E6%A3%80%E6%B5%8B%E5%88%B0%20PS_ENABLE%20%E5%BC%95%E8%84%9A%E4%B8%8A%E7%9A%84%E6%96%AD%E8%A8%80%EF%BC%8C%E6%88%91%E8%83%BD%E7%94%A8%E5%AE%83%E5%81%9A%E4%BB%80%E4%B9%88%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1649593%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SPI%20pins%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1649593%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CP%3E%E9%80%9A%E7%9F%A5%E9%A1%BA%E5%BA%8F%E5%8F%96%E5%86%B3%E4%BA%8E%20PS%20ENABLE%20%E5%8A%9F%E8%83%BD%E6%98%AF%E5%90%A6%E5%90%AF%E7%94%A8%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E6%9F%A5%E7%9C%8B%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN13882.pdf%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ENBP%20%E8%AE%BE%E5%A4%87%E7%9A%84%20AN13882%20%E4%B8%BB%E6%9C%BA%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E7%AC%AC%205.1%3C%2FA%3E%20%E8%8A%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1649432%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SPI%20pins%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1649432%22%20slang%3D%22en-US%22%20mode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id%3D%22lingo-sub-1648837%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SPI%20pins%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1648837%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E4%B8%8E%E6%88%91%E4%BB%AC%E8%81%94%E7%B3%BB%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E6%B2%A1%E9%94%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EINT%2FRDY%20%E5%BC%95%E8%84%9A%E5%BA%94%E4%BD%BF%E7%94%A8%20J3.6%20%E6%88%96%20J3.8%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fuser-manual%2FUM11568.pdf%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E7%94%A8%E6%88%B7%E6%89%8B%E5%86%8C%3C%2FA%3E%E8%A1%A8%201%E3%80%82%E8%B7%B3%E7%BA%BF%E5%92%8C%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fdata-sheet%2FNBP9.pdf%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ENBP9%20%E6%95%B0%E6%8D%AE%E8%A1%A8%3C%2FA%3E%E8%A1%A8%203%20%E5%92%8C%E8%A1%A8%204%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22ErikaC_0-1683817835874.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22ErikaC_0-1683817835874.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F222806i62D349FEA36EEABF%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22ErikaC_0-1683817835874.png%22%20alt%3D%22ErikaC_0-1683817835874.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CDIV%20id%3D%22tinyMceEditor_acd842accad6ErikaC_1%22%20class%3D%22mceNonEditable%20lia-copypaste-placeholder%22%3E%3CBR%20%2F%3E%0A%3CDIV%20class%3D%22lia-progress-placeholder%20mceNonEditable%22%3E%0A%3CDIV%20class%3D%22lia-media-progress%22%3E%3CI%20class%3D%22lia-fa%20lia-media-upload-progress%20lia-fa-picture-o%22%3E%3C%2FI%3E%0A%3CDIV%20class%3D%22lia-progress-bar-stripes%20lia-progress-bar-animate%20lia-media-progress-bar%22%3E%0A%3CDIV%20class%3D%22lia-progress-bar%22%20style%3D%22width%3A%20100%25%3B%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CSPAN%20class%3D%22lia-progress-value%22%3E%E6%9B%B4%E6%96%B0%E5%AA%92%E4%BD%93%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22ErikaC_2-1683818011679.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22ErikaC_2-1683818011679.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F222808i828AA7CF9BC8613E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22ErikaC_2-1683818011679.png%22%20alt%3D%22ErikaC_2-1683818011679.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%B8%8C%E6%9C%9B%E8%BF%99%E8%83%BD%E5%B8%AE%E5%88%B0%E6%82%A8%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
