Problems using two MMA8452Q simultaneously
clovismarcondes
I´m trying to use two MMA8452Q simultaneously to check differents accelerations over the same body, and detect deformations while on movement. For this project I´m using an ARDUINO board for prototipation and after some succesful preliminary tests, after preparing a kit for a second phase tests the systems stop working. I already checked all the connections between and tested both accelerometers and everything is ok, but when I try to init the second accelerometer, no matter which one was the first, I got an error. The WHO_AM_I command for the second accelerometer is returning 0x01.
Thanks in advance, and sorry for english mistakes on the text above,
Clóvis
reyes
Hi Clóvis,
According to our last communication, the problem seems to be corrected by adding a call delay (100), correct?
Can you please confirm is this solved the problem?
Jose Reyes
clovismarcondes
Hi Reyes,
You are right. I´ve tried to put the delay as a workaround for the problem and it has worked. I´m not sure about the cause but I tried this to avoid possible data overrun. I have to put a minimum delay (10ms) between consecutive reads to avoid similar problems.
Thanks a lot!
%3CLINGO-SUB%20id%3D%22lingo-sub-456910%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EProblems%20using%20two%20MMA8452Q%20simultaneously%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-456910%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%C2%B4m%20trying%20to%20use%20two%20MMA8452Q%20simultaneously%20to%20check%20differents%20accelerations%20over%20the%20same%20body%2C%20and%20detect%20deformations%20while%20on%20movement.%20For%20this%20project%20I%C2%B4m%20using%20an%20ARDUINO%20board%20for%20prototipation%20and%20after%20some%20succesful%20preliminary%20tests%2C%20after%20preparing%20a%20kit%20for%20a%20second%20phase%20tests%20the%20systems%20stop%20working.%20I%20already%20checked%20all%20the%20connections%20between%20and%20tested%20both%20accelerometers%20and%20everything%20is%20ok%2C%20but%20when%20I%20try%20to%20init%20the%20second%20accelerometer%2C%20no%20matter%20which%20one%20was%20the%20first%2C%20I%20got%20an%20error.%20The%20WHO_AM_I%20command%20for%20the%20second%20accelerometer%20is%20returning%200x01.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThanks%20in%20advance%2C%20and%20sorry%20for%20english%20mistakes%20on%20the%20text%20above%2C%3C%2FP%3E%3CP%3ECl%C3%B3vis%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-456910%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EAccelerometers%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-456912%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Problems%20using%20two%20MMA8452Q%20simultaneously%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-456912%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Reyes%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EYou%20are%20right.%20I%C2%B4ve%20tried%20to%20put%20the%20delay%20as%20a%20workaround%20for%20the%20problem%20and%20it%20has%20worked.%20I%C2%B4m%20not%20sure%20about%20the%20cause%20but%20I%20tried%20this%20to%20avoid%20possible%20data%20overrun.%20I%20have%20to%20put%20a%20minimum%20delay%20(10ms)%20between%20consecutive%20reads%20to%20avoid%20similar%20problems.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThanks%20a%20lot!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-456911%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Problems%20using%20two%20MMA8452Q%20simultaneously%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-456911%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Cl%C3%B3vis%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EAccording%20to%20our%20last%20communication%2C%20the%20problem%20seems%20to%20be%20corrected%20by%20adding%20a%20call%20delay%20(100)%2C%20correct%3F%3C%2FP%3E%3CP%3ECan%20you%20please%20confirm%20is%20this%20solved%20the%20problem%3F%3C%2FP%3E%3CP%3E%3CBR%20%2F%3EHave%20a%20great%20day%2C%3CBR%20%2F%3EJose%20Reyes%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E-----------------------------------------------------------------------------------------------------------------------%3CBR%20%2F%3ENote%3A%20If%20this%20post%20answers%20your%20question%2C%20please%20click%20the%20Correct%20Answer%20button.%20Thank%20you!%3CBR%20%2F%3E-----------------------------------------------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E
