Pressure sensor selection
jeffrickard
I'd like help selection an air pressure sensor chip for a new product. I'll give a summary of our requirements here:
- Size: Not critical, but we're looking for a PCB-mount chip to measure the air pressure at the chip.
- Pressure range: Normal ambient pressures at normal ground altitudes.
- Operating temperature range: Preferably at least 0-60 Celsius.
- Interface: For design simplicity, an I2C or SPI interface would be highly desirable.
- Sample rate: We need accurate data at about 10Hz, so allowing for noise I expect we need about 100Hz or higher.
- Voltage: Preferably 3.3V, but we can probably design around 1.8V or 5V.
- Power: Fairly important, preferably in the Milliampere range, but we can make allowances for more power if necessary.
- Cost: Around a couple of dollars per chip.
- Accuracy: This is critical. We do not need absolute accuracy or temperature stability, but we need to accurately measure pressure differences over a period of seconds with a resolution of 1Pa (0.001 kPa). We're well aware that this will be beyond the specifications of any chip we choose, but I believe that over a period of seconds with no need for temperature stability or stability over longer periods of time, and appropriately filtering the data to remove noise, we should be able to achieve a 1Pa resolution for measuring pressure difference at about a 10Hz rate.
TomasVaverka
Hello Jeff,
Thank you for your interest in NXP pressure sensors.
Based on your requirements, I would recommend considering the MPL3115A2.
- Size: 3 x 5 x 1.25mm 8-pin LGA package
- Calibrated pressure range: 50kPa to 110kPa absolute pressure
- Operating temperature range: −40°C to +85°C
- Interface: I2C only
- Sample rate: Depending on OS[2:0] bits, more in Table 46 of MPL3115 datasheet
- Voltage: 3.3V is OK (1.95V – 3.6V)
- Power: Depending on OS[2:0] bits, more in Table 6 of MPL3115 datasheet, the max current during acquisition and conversion is 2mA
- Cost: 1K @ US$1.69
- Accuracy/Resolution: Depending on OS[2:0] bits, theoretically 1.5Pa @ max OS[2:0] = 0b111, a quick test on my desk:
To evaluate the MPL3115A2, we can offer a complete demo kit, an Arduino/Freedom compatible shield board or just a breakout board - MPL3115A2 Pressure Sensor Development Boards|NXP.
If you have any further questions, please let me know.
Tomas
PS: If my answer helps to solve your question, please mark it as "Correct". Thank you.
jeffrickard
Hi Tomas,
Thanks for your help. I'll order a couple, attach it to our current
prototype, and see how it performs. Based on the datasheet it looks like
the accuracy may only just manage to fit our requirements - a bit faster
and a bit more accurate would be better - but there's a good chance that in
real-world conditions we'll have more problems with accuracy due to the
housing (porting, vibration) than due to the sensor. We'll soon find out!
Jeff
On 19 September 2016 at 12:20, TomasVaverka <[email protected]>
%3CLINGO-SUB%20id%3D%22lingo-sub-626900%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EPressure%20sensor%20selection%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-626900%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%3CP%3EI'd%20like%20help%20selection%20an%20air%20pressure%20sensor%20chip%20for%20a%20new%20product.%20I'll%20give%20a%20summary%20of%20our%20requirements%20here%3A%3C%2FP%3E%3CP%3E-%20Size%3A%20Not%20critical%2C%20but%20we're%20looking%20for%20a%20PCB-mount%20chip%20to%20measure%20the%20air%20pressure%20at%20the%20chip.%3C%2FP%3E%3CP%3E-%20Pressure%20range%3A%20Normal%20ambient%20pressures%20at%20normal%20ground%20altitudes.%3C%2FP%3E%3CP%3E-%20Operating%20temperature%20range%3A%20Preferably%20at%20least%200-60%20Celsius.%3C%2FP%3E%3CP%3E-%20Interface%3A%20For%20design%20simplicity%2C%20an%20I2C%20or%20SPI%20interface%20would%20be%20highly%20desirable.%3C%2FP%3E%3CP%3E-%20Sample%20rate%3A%20We%20need%20accurate%20data%20at%20about%2010Hz%2C%20so%20allowing%20for%20noise%20I%20expect%20we%20need%20about%20100Hz%20or%20higher.%3C%2FP%3E%3CP%3E-%20Voltage%3A%20Preferably%203.3V%2C%20but%20we%20can%20probably%20design%20around%201.8V%20or%205V.%3C%2FP%3E%3CP%3E-%20Power%3A%20Fairly%20important%2C%20preferably%20in%20the%20Milliampere%20range%2C%20but%20we%20can%20make%20allowances%20for%20more%20power%20if%20necessary.%3C%2FP%3E%3CP%3E-%20Cost%3A%20Around%20a%20couple%20of%20dollars%20per%20chip.%3C%2FP%3E%3CP%3E-%20Accuracy%3A%20This%20is%20critical.%20We%20do%20not%20need%20absolute%20accuracy%20or%20temperature%20stability%2C%20but%20we%20need%20to%20accurately%20measure%20pressure%20differences%20over%20a%20period%20of%20seconds%20with%20a%20resolution%20of%201Pa%20(0.001%20kPa).%20We're%20well%20aware%20that%20this%20will%20be%20beyond%20the%20specifications%20of%20any%20chip%20we%20choose%2C%20but%20I%20believe%20that%20over%20a%20period%20of%20seconds%20with%20no%20need%20for%20temperature%20stability%20or%20stability%20over%20longer%20periods%20of%20time%2C%20and%20appropriately%20filtering%20the%20data%20to%20remove%20noise%2C%20we%20should%20be%20able%20to%20achieve%20a%201Pa%20resolution%20for%20measuring%20pressure%20difference%20at%20about%20a%2010Hz%20rate.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-626900%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EPressure%20Sensors%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-626902%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Pressure%20sensor%20selection%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-626902%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Tomas%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThanks%20for%20your%20help.%20I'll%20order%20a%20couple%2C%20attach%20it%20to%20our%20current%3C%2FP%3E%3CP%3Eprototype%2C%20and%20see%20how%20it%20performs.%20Based%20on%20the%20datasheet%20it%20looks%20like%3C%2FP%3E%3CP%3Ethe%20accuracy%20may%20only%20just%20manage%20to%20fit%20our%20requirements%20-%20a%20bit%20faster%3C%2FP%3E%3CP%3Eand%20a%20bit%20more%20accurate%20would%20be%20better%20-%20but%20there's%20a%20good%20chance%20that%20in%3C%2FP%3E%3CP%3Ereal-world%20conditions%20we'll%20have%20more%20problems%20with%20accuracy%20due%20to%20the%3C%2FP%3E%3CP%3Ehousing%20(porting%2C%20vibration)%20than%20due%20to%20the%20sensor.%20We'll%20soon%20find%20out!%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ERegards%2C%3C%2FP%3E%3CP%3EJeff%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EOn%2019%20September%202016%20at%2012%3A20%2C%20TomasVaverka%20%3CADMIN%3E%3C%2FADMIN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-626901%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Pressure%20sensor%20selection%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-626901%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20Jeff%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThank%20you%20for%20your%20interest%20in%20NXP%20pressure%20sensors.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EBased%20on%20your%20requirements%2C%20I%20would%20recommend%20considering%20the%20%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fproducts%2Fsensors%2Fpressure-sensors%2Fbarometric-pressure-15-to-115-kpa%2F20-to-110kpa-absolute-digital-pressure-sensor%3AMPL3115A2%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EMPL3115A2%3C%2FA%3E.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E-%20Size%3A%203%20x%205%20x%201.25mm%208-pin%20LGA%20package%3C%2FP%3E%3CP%3E-%20Calibrated%20pressure%20range%3A%2050kPa%20to%20110kPa%20absolute%20pressure%3C%2FP%3E%3CP%3E-%20Operating%20temperature%20range%3A%20%E2%88%9240%C2%B0C%20to%20%2B85%C2%B0C%3C%2FP%3E%3CP%3E-%20Interface%3A%20I2C%20only%3C%2FP%3E%3CP%3E-%20Sample%20rate%3A%20Depending%20on%20OS%5B2%3A0%5D%20bits%2C%20more%20in%20Table%2046%20of%20%3CA%20href%3D%22http%3A%2F%2Fcache.nxp.com%2Ffiles%2Fsensors%2Fdoc%2Fdata_sheet%2FMPL3115A2.pdf%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EMPL3115%20datasheet%3C%2FA%3E%3C%2FP%3E%3CP%3E-%20Voltage%3A%203.3V%20is%20OK%20(1.95V%20%E2%80%93%203.6V)%3C%2FP%3E%3CP%3E-%20Power%3A%20Depending%20on%20OS%5B2%3A0%5D%20bits%2C%20more%20in%20Table%206%20of%20MPL3115%20datasheet%2C%20the%20max%20current%20during%20acquisition%20and%20conversion%20is%202mA%3C%2FP%3E%3CP%3E-%20Cost%3A%201K%20%40%20US%241.69%3C%2FP%3E%3CP%3E-%20Accuracy%2FResolution%3A%20Depending%20on%20OS%5B2%3A0%5D%20bits%2C%20theoretically%201.5Pa%20%40%20max%20OS%5B2%3A0%5D%20%3D%200b111%2C%20a%20quick%20test%20on%20my%20desk%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pressure1.JPG%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pressure1.JPG%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F6347i8E681D7551C936BB%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pressure1.JPG%22%20alt%3D%22pressure1.JPG%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Epressure1.JPG%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ETo%20evaluate%20the%20MPL3115A2%2C%20we%20can%20offer%20a%20complete%20demo%20kit%2C%20an%20Arduino%2FFreedom%20compatible%20shield%20board%20or%20just%20a%20breakout%20board%20-%20%3CA%20class%3D%22link-titled%22%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fproducts%2Fsoftware-and-tools%2Fhardware-development-tools%2Ffreedom-development-boards%2Fsensor-toolbox-development-platform-for-mpl3115a2-pressure-altimeter-sensor%3AFRDMSTBC-P3115%22%20title%3D%22http%3A%2F%2Fwww.nxp.com%2Fproducts%2Fsoftware-and-tools%2Fhardware-development-tools%2Ffreedom-development-boards%2Fsensor-toolbox-development-platform-for-mpl3115a2-pressure-altimeter-sensor%3AFRDMSTBC-P3115%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EMPL3115A2%20Pressure%20Sensor%20Development%20Boards%7CNXP.%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EIf%20you%20have%20any%20further%20questions%2C%20please%20let%20me%20know.%26nbsp%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBest%20regards%2C%3C%2FP%3E%3CP%3ETomas%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CEM%20style%3D%22margin%3A%200px%3B%20padding%3A%200px%3B%20border%3A%200px%3B%20font-weight%3A%20normal%3B%20font-style%3A%20italic%3B%20font-size%3A%2011px%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20vertical-align%3A%20baseline%3B%20color%3A%20%2351626f%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20line-height%3A%2019.03px%3B%20background-color%3A%20%23ffffff%3B%22%3EPS%3A%20If%20my%20answer%20helps%20to%20solve%20your%20question%2C%20please%20mark%20it%20as%20%22Correct%22.%20Thank%20you.%3C%2FEM%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
