MPXV7007DP Humidity Tolerance
dengel
I am trying to find the humidity specification for the MPXV7007DP pressure sensor.  It does not appear to be included in the datasheet.
The application wants a sensor rated for operation at 0 – 95% RH, for both the pressure column and ambient environment.
Thanks.
david_diaz
Hello Daniel,
Thank you for writing.
This device was not introduced for high humidity & high temperature condition and never been qualified under long term high humidity reliability test condition such as THB.
I knew this device series have been widely used for washing machine application and I expect humidity is little higher than ambient in washing machine application.
NXP never simulated customer application, so I don’t know the humidity level of washing machine.
Anyway, I would like to recommend the application note below in order to get more detailed information.
 AN3728: Media Compatibility for IPS PRT Pressure Sensors
I hope this information helps.
David
%3CLINGO-SUB%20id%3D%22lingo-sub-611315%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMPXV7007DP%20Humidity%20Tolerance%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-611315%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20am%20trying%20to%20find%20the%20humidity%20specification%20for%20the%20MPXV7007DP%20pressure%20sensor.%26nbsp%3B%20It%20does%20not%20appear%20to%20be%20included%20in%20the%20datasheet.%26nbsp%3B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThe%20application%20wants%20a%20sensor%20rated%20for%20operation%20at%200%20%E2%80%93%2095%25%20RH%2C%20for%20both%20the%20pressure%20column%20and%20ambient%20environment.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThanks.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-611315%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EPressure%20Sensors%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-611316%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPXV7007DP%20Humidity%20Tolerance%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-611316%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20Daniel%2C%3C%2FP%3E%3CP%3EThank%20you%20for%20writing.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThis%20device%20was%20not%20introduced%20for%20high%20humidity%20%26amp%3B%20high%20temperature%20condition%20and%20never%20been%20qualified%20under%20long%20term%20high%20humidity%20reliability%20test%20condition%20such%20as%20THB.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20knew%20this%20device%20series%20have%20been%20widely%20used%20for%20washing%20machine%20application%20and%20I%20expect%20humidity%20is%20little%20higher%20than%20ambient%20in%20washing%20machine%20application.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ENXP%20never%20simulated%20customer%20application%2C%20so%20I%20don%E2%80%99t%20know%20the%20humidity%20level%20of%20washing%20machine.%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3EAnyway%2C%20I%20would%20like%20to%20recommend%20the%20application%20note%20below%20in%20order%20to%20get%20more%20detailed%20information.%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fassets%2Fdocuments%2Fdata%2Fen%2Fapplication-notes%2FAN3728.pdf%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EAN3728%3A%20Media%20Compatibility%20for%20IPS%20PRT%20Pressure%20Sensors%3C%2FA%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%20style%3D%22margin-left%3A%20.5in%3B%20text-indent%3A%20-.5in%3B%22%3EI%20hope%20this%20information%20helps.%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%20.5in%3B%20text-indent%3A%20-.5in%3B%22%3ERegards%2C%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%20.5in%3B%20text-indent%3A%20-.5in%3B%22%3EDavid%3C%2FP%3E%3C%2FLINGO-BODY%3E
