MPXV5050GP - Pin functions and package
prathameshdhanp
I am thinking of using MPXV5050GP and the datasheet says that it is of SOP-8 package. But the dimensions are quite different than the usual SOP-8 package. Also, the pin functions are based on style 1 and style 2, but the datasheet doesn't say which one applies to MPXV5050GP. Can anyone throw light on this please?
Thank you.Sensors​
reyes
Hi Prathamesh Dhanpalwar,
Package used in the MPXV5050GP is a SOP-8 with a case no. 1369-01, package dimensions of this device can be found here.
As stated in Document DOC-97353, the difference between style 1 and style 2 in the package dimensions is due to the two main families of pressure sensors Freescale offers.
Style 1 is usually applicable for all MPXx10, MPXx53 and MPXx2000-series SOP Type package pressure sensors featuring differential outputs.
Style 2 is applicable for all MPXx4000-series, MPXx5000-series, MPXx6000-series, MPXx7000-series integrated devices in surface mount packages featuring single ended outputs.
So for the case of the MPXV5050GP, case no. 1369-01, you should use Style 2:
Pin 1: N/C
Pin 2: Vs
Pin3: GND
Pin 4: Vout
Pin 5: N/C
Pin 6: N/C
Pin 7: N/C
Pin 8: N/C
Additionally, you can find a 3D Step design for this package here.
Jose Reyes
%3CLINGO-SUB%20id%3D%22lingo-sub-418463%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMPXV5050GP%20-%20Pin%20functions%20and%20package%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-418463%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%20%3C%2FP%3E%3CP%3EI%20am%20thinking%20of%20using%20MPXV5050GP%20and%20the%20datasheet%20says%20that%20it%20is%20of%20SOP-8%20package.%20But%20the%20dimensions%20are%20quite%20different%20than%20the%20usual%20SOP-8%20package.%20Also%2C%20the%20pin%20functions%20are%20based%20on%20style%201%20and%20style%202%2C%20but%20the%20datasheet%20doesn't%20say%20which%20one%20applies%20to%20MPXV5050GP.%20Can%20anyone%20throw%20light%20on%20this%20please%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThank%20you.%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fspace%2F11146%22%20target%3D%22_blank%22%3ESensors%3C%2FA%3E%E2%80%8B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-418463%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EPressure%20Sensors%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-418464%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPXV5050GP%20-%20Pin%20functions%20and%20package%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-418464%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Prathamesh%20Dhanpalwar%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EPackage%20used%20in%20the%20MPXV5050GP%20is%20a%20SOP-8%20with%20a%20case%20no.%201369-01%2C%20package%20dimensions%20of%20this%20device%20can%20be%20found%20%3CA%20href%3D%22http%3A%2F%2Fcache.freescale.com%2Ffiles%2Fshared%2Fdoc%2Fpackage_info%2F98ASA99303D.pdf%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehere%3C%2FA%3E.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EAs%20stated%20in%20Document%20%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-97353%22%20target%3D%22_blank%22%3EDOC-97353%3C%2FA%3E%2C%20the%20difference%20between%20style%201%20and%20style%202%20in%20the%20package%20dimensions%20is%20due%20to%20the%20two%20main%20families%20of%20pressure%20sensors%20Freescale%20offers.%3CBR%20%2F%3E%20%3C%2FP%3E%3CP%3EStyle%201%20is%20usually%20applicable%20for%20all%20MPXx10%2C%20MPXx53%20and%20MPXx2000-series%20SOP%20Type%20package%20pressure%20sensors%20featuring%20differential%20outputs.%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20Style%202%20is%20applicable%20for%20all%20MPXx4000-series%2C%20MPXx5000-series%2C%20MPXx6000-series%2C%20MPXx7000-series%20integrated%20devices%20in%20surface%20mount%20packages%20featuring%20single%20ended%20outputs.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ESo%20for%20the%20case%20of%20the%20MPXV5050GP%2C%20case%20no.%201369-01%2C%20you%20should%20use%20Style%202%3A%3C%2FP%3E%3CP%3EPin%201%3A%20N%2FC%3C%2FP%3E%3CP%3EPin%202%3A%20Vs%3C%2FP%3E%3CP%3EPin3%3A%20GND%3C%2FP%3E%3CP%3EPin%204%3A%20Vout%3C%2FP%3E%3CP%3EPin%205%3A%20N%2FC%3C%2FP%3E%3CP%3EPin%206%3A%20N%2FC%3C%2FP%3E%3CP%3EPin%207%3A%20N%2FC%3C%2FP%3E%3CP%3EPin%208%3A%20N%2FC%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EAdditionally%2C%20you%20can%20find%20a%203D%20Step%20design%20for%20this%20package%20%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-95443%22%20target%3D%22_blank%22%3Ehere%3C%2FA%3E.%3C%2FP%3E%3CP%3E%3CBR%20%2F%3EHave%20a%20great%20day%2C%3CBR%20%2F%3EJose%20Reyes%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E-----------------------------------------------------------------------------------------------------------------------%3CBR%20%2F%3ENote%3A%20If%20this%20post%20answers%20your%20question%2C%20please%20click%20the%20Correct%20Answer%20button.%20Thank%20you!%3CBR%20%2F%3E-----------------------------------------------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E
