MPXM2053GS Pressure Sensor Footprint
heiko_dd
I can´t find the pad dimensions for the pcb layout in the datasheet. Is there any other document where I can find them or do I have to use the pin dimensions with some extra?
TomasVaverka
Hi Heiko,
Please refer to the attached files. The pad dimensions are shown in the text block below the drawing.
I hope it helps.
Tomas
PS: If my answer helps to solve your question, please mark it as "Correct". Thank you.
TomasVaverka
Hi Heiko,
I hope it helps.
Tomas
