MPX5999D processing issue
sunny_gao
Hello NXP engineers,
This is Sunny from Plexus China, need your help to check below issue, please kindly give feedback asap, thanks first.
Your part MPX5999D is used for our customer new product, and customer told us that the part need to be processed by selective soldering machine. The trouble is, our plant have no this kind of machine for now. So we want to know, except for the machine can process the part, are there alternative methods we can use? for example, hand solder the part on the product?
It will be best if you can supply the processing instruction document.
Look forward to hearing from you soon.
Regards, Sunny
TomasVaverka
Hello Sunny,
There is no specific document for the MPX5999D, but I would recommend taking a closer look at our AN3150 - Soldering Recommendations for Pressure Sensor Devices.
The maximum peak temperature during the soldering process should not exceed 220°C for 30 seconds maximum duration as shown on this website.
Tomas
%3CLINGO-SUB%20id%3D%22lingo-sub-1027344%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMPX5999D%20processing%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1027344%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20NXP%20engineers%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThis%20is%20Sunny%20from%20Plexus%20China%2C%20need%20your%20help%20to%20check%20below%20issue%2C%20please%20kindly%20give%20feedback%20asap%2C%20thanks%20first.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EYour%20part%20MPX5999D%20is%20used%20for%20our%20customer%20new%20product%2C%20and%20customer%26nbsp%3Btold%26nbsp%3Bus%20that%20the%20part%20need%20to%20be%26nbsp%3Bprocessed%20by%20selective%20soldering%20machine.%20The%26nbsp%3Btrouble%20is%2C%20our%20plant%20have%20no%20this%20kind%20of%20machine%20for%20now.%20So%20we%20want%20to%20know%2C%20except%20for%20the%20machine%20can%20process%20the%20part%2C%20are%20there%20alternative%20methods%20we%20can%20use%3F%20for%20example%2C%20hand%20solder%20the%20part%26nbsp%3Bon%20the%20product%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EIt%26nbsp%3Bwill%20be%20best%20if%20you%20can%20supply%20the%20processing%20instruction%20document.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ELook%20forward%20to%20hearing%20from%20you%20soon.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ERegards%2C%20Sunny%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1027344%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EPressure%20Sensors%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1027345%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPX5999D%20processing%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1027345%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20Sunny%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThere%20is%20no%20specific%20document%20for%20the%20MPX5999D%2C%20but%20I%20would%20recommend%20taking%20a%20closer%20look%20at%20our%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN3150.pdf%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EAN3150%3C%2FA%3E%20-%20Soldering%20Recommendations%20for%20Pressure%20Sensor%20Devices.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThe%20maximum%20peak%20temperature%20during%20the%20soldering%20process%20should%20not%20exceed%20220%C2%B0C%20for%2030%20seconds%20maximum%20duration%20as%20shown%20on%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fsensors%2Fpressure-sensors%2Fdifferential-gauge-up-to-1000-kpa%2F0-to-1000kpa-differential-integrated-pressure-sensor%3AMPX5999%3Ftab%3DPackage_Quality_Tab%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ethis%3C%2FA%3E%20website.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBest%20regards%2C%3C%2FP%3E%3CP%3ETomas%3C%2FP%3E%3C%2FLINGO-BODY%3E
