MPX53DP voltage output
3,256 次查看
jordan123
According to the datasheet for the MPX53DP differential pressure sensor, the output voltage should be in the range of 20-80mV, proportional to the differential pressure.
I have set it up with a 3.3v power supply and was expecting to need an amplifying circuit but at a differential pressure of 0 (both nozzles are open), the output voltage is 1.75V. However, when I apply pressure, the voltage rises as expected in the datasheet.
So my question is this: How do I have an offset of 1.75V when it should be 0.02V?
Thank you in advance for your help
Jordan
3,163 次查看
TomasVaverka
Hi Jordan,
I believe you are measuring the voltage on either +Vout or -Vout output with respect to GND. However, you should measure the differential voltage between +Vout or -Vout. At the maximum differential pressure of 50kPa, the differential output voltage between +Vout or -Vout should be around 60mV.
I hope it helps. If I misunderstood your question or if you have further questions, please let me know.
Tomas
3,164 次查看
TomasVaverka
Hi Jordan,
Tomas
3,037 次查看
naitali
. I am working on a project to detect change in breathing patterns and I am using an MPX53D pressure sensor.
Using a cool hair dryer to reproduce the breathing exercise, I apply different pressures on the MPX53D and when I measure the difference output voltage using Fluke 115 Multimeter between (Vout +) and (Vout -).
The voltage difference does not exceed 25 mV and the MPX53D data sheet indicates Full scale span  is  45mV <Vfss< 90 mV.
Please, any help would be appreciated.
3,163 次查看
jordan123
Thank you so much Tomas - It seems so simple once you put it like that.
I will have to use a differential op-amp then :smileyhappy:
%3CLINGO-SUB%20id%3D%22lingo-sub-875619%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMPX53DP%20%E7%94%B5%E5%8E%8B%E8%BE%93%E5%87%BA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-875619%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%A0%B9%E6%8D%AE%20MPX53DP%20%E5%8E%8B%E5%B7%AE%E4%BC%A0%E6%84%9F%E5%99%A8%E7%9A%84%E6%95%B0%E6%8D%AE%E8%A1%A8%EF%BC%8C%E8%BE%93%E5%87%BA%E7%94%B5%E5%8E%8B%E5%BA%94%E5%9C%A8%2020-80mV%20%E8%8C%83%E5%9B%B4%E5%86%85%EF%BC%8C%E4%B8%8E%E5%8E%8B%E5%B7%AE%E6%88%90%E6%AD%A3%E6%AF%94%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E7%94%A8%203.3%20%E4%BC%8F%E7%94%B5%E6%BA%90%E5%AF%B9%E5%85%B6%E8%BF%9B%E8%A1%8C%E4%BA%86%E8%AE%BE%E7%BD%AE%EF%BC%8C%E6%9C%AC%E4%BB%A5%E4%B8%BA%E9%9C%80%E8%A6%81%E4%B8%80%E4%B8%AA%E6%94%BE%E5%A4%A7%E7%94%B5%E8%B7%AF%EF%BC%8C%E4%BD%86%E5%9C%A8%E5%8E%8B%E5%B7%AE%E4%B8%BA%200%20%E6%97%B6%EF%BC%88%E4%B8%A4%E4%B8%AA%E5%96%B7%E5%98%B4%E9%83%BD%E6%89%93%E5%BC%80%EF%BC%89%EF%BC%8C%E8%BE%93%E5%87%BA%E7%94%B5%E5%8E%8B%E4%B8%BA%201.75%20%E4%BC%8F%E3%80%82%E4%BD%86%E6%98%AF%EF%BC%8C%E5%BD%93%E6%88%91%E6%96%BD%E5%8A%A0%E5%8E%8B%E5%8A%9B%E6%97%B6%EF%BC%8C%E7%94%B5%E5%8E%8B%E4%BC%9A%E6%8C%89%E7%85%A7%E6%95%B0%E6%8D%AE%E8%A1%A8%E4%B8%AD%E7%9A%84%E9%A2%84%E6%9C%9F%E4%B8%8A%E5%8D%87%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84%E9%97%AE%E9%A2%98%E6%98%AF%E5%81%8F%E7%A7%BB%E5%BA%94%E8%AF%A5%E6%98%AF%200.02V%EF%BC%8C%E6%80%8E%E4%B9%88%E4%BC%9A%E5%81%8F%E7%A7%BB%E5%88%B0%201.75V%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%B8%AE%E5%8A%A9%3C%2FP%3E%3CP%3E%E7%BA%A6%E6%97%A6%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-875619%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E5%8E%8B%E5%8A%9B%E4%BC%A0%E6%84%9F%E5%99%A8%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1249110%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPX53DP%20voltage%20output%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1249110%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3E.%E6%88%91%E6%AD%A3%E5%9C%A8%E5%81%9A%E4%B8%80%E4%B8%AA%E6%A3%80%E6%B5%8B%E5%91%BC%E5%90%B8%E6%A8%A1%E5%BC%8F%E5%8F%98%E5%8C%96%E7%9A%84%E9%A1%B9%E7%9B%AE%EF%BC%8C%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20MPX53D%20%E5%8E%8B%E5%8A%9B%E4%BC%A0%E6%84%9F%E5%99%A8%E3%80%82%3C%2FDIV%3E%3CDIV%3E%E4%BD%BF%E7%94%A8%E5%86%B7%E5%90%B9%E9%A3%8E%E6%9C%BA%E9%87%8D%E7%8E%B0%E5%91%BC%E5%90%B8%E7%BB%83%E4%B9%A0%EF%BC%8C%E6%88%91%E5%AF%B9%20MPX53D%20%E6%96%BD%E5%8A%A0%E4%B8%8D%E5%90%8C%E7%9A%84%E5%8E%8B%E5%8A%9B%EF%BC%8C%E7%84%B6%E5%90%8E%E4%BD%BF%E7%94%A8%20Fluke%20115%20%E4%B8%87%E7%94%A8%E8%A1%A8%E6%B5%8B%E9%87%8F%E8%BE%93%E5%87%BA%E7%94%B5%E5%8E%8B%EF%BC%88Vout%20%2B%EF%BC%89%E5%92%8C%EF%BC%88Vout%20-%EF%BC%89%E4%B9%8B%E9%97%B4%E7%9A%84%E5%B7%AE%E5%BC%82%E3%80%82%20%3C%2FDIV%3E%3CDIV%3E%E7%94%B5%E5%8E%8B%E5%B7%AE%E4%B8%8D%E8%B6%85%E8%BF%87%2025%20mV%EF%BC%8CMPX53D%20%E6%95%B0%E6%8D%AE%E8%A1%A8%E6%98%BE%E7%A4%BA%E6%BB%A1%E5%88%BB%E5%BA%A6%E8%B7%A8%E5%BA%A6%E4%B8%BA%2045mV%3CVFSS%3E%26lt%3B%2090%20mV%E3%80%82%3C%2FVFSS%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E8%AF%B7%E6%8F%90%E4%BE%9B%E4%BB%BB%E4%BD%95%E5%B8%AE%E5%8A%A9%EF%BC%8C%E4%B8%8D%E8%83%9C%E6%84%9F%E6%BF%80%E3%80%82%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-875621%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPX53DP%20voltage%20output%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-875621%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E4%BD%A0%EF%BC%8C%E6%89%98%E9%A9%AC%E6%96%AF%20-%20%E4%BD%A0%E8%BF%99%E4%B9%88%E4%B8%80%E8%AF%B4%EF%BC%8C%E6%88%91%E5%B0%B1%E6%98%8E%E7%99%BD%E4%BA%86%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%82%A3%E6%88%91%E5%B0%B1%E5%BE%97%E4%BD%BF%E7%94%A8%E5%B7%AE%E5%88%86%E8%BF%90%E7%AE%97%E6%94%BE%E5%A4%A7%E5%99%A8%E4%BA%86%EF%BC%9A%E7%AC%91%E4%B8%80%E7%AC%91%EF%BC%9A%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-875620%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPX53DP%20voltage%20output%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-875620%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%97%A8%EF%BC%8C%E4%B9%94%E4%B8%B9%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E7%9B%B8%E4%BF%A1%E6%82%A8%E6%B5%8B%E9%87%8F%E7%9A%84%E6%98%AF%20%2BVout%20%E6%88%96%20-Vout%20%E8%BE%93%E5%87%BA%E7%AB%AF%E7%9B%B8%E5%AF%B9%E4%BA%8E%E6%8E%A5%E5%9C%B0%E7%AB%AF%E7%9A%84%E7%94%B5%E5%8E%8B%E3%80%82%E4%B8%8D%E8%BF%87%EF%BC%8C%E6%82%A8%E5%BA%94%E8%AF%A5%E6%B5%8B%E9%87%8F%3CSPAN%3E%2BVout%20%E6%88%96%20-Vout%20%3C%2FSPAN%3E%E4%B9%8B%E9%97%B4%E7%9A%84%E5%B7%AE%E5%88%86%E7%94%B5%E5%8E%8B%E3%80%82%20%E5%9C%A8%E6%9C%80%E5%A4%A7%E5%8E%8B%E5%B7%AE%E4%B8%BA%2050kPa%20%E6%97%B6%EF%BC%8C%3CSPAN%3E%2BVout%20%E6%88%96%20-Vout%3C%2FSPAN%3E%20%3CSPAN%3E%E4%B9%8B%E9%97%B4%E7%9A%84%20%3C%2FSPAN%3E%E5%B7%AE%E5%88%86%E8%BE%93%E5%87%BA%E7%94%B5%E5%8E%8B%E5%BA%94%E5%9C%A8%2060mV%20%E5%B7%A6%E5%8F%B3%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%B8%8C%E6%9C%9B%E5%AF%B9%E4%BD%A0%E6%9C%89%E6%89%80%E5%B8%AE%E5%8A%A9%E3%80%82%E5%A6%82%E6%9E%9C%E6%88%91%E8%AF%AF%E8%A7%A3%E4%BA%86%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E6%88%96%E8%80%85%E6%82%A8%E8%BF%98%E6%9C%89%E5%85%B6%E4%BB%96%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%3E%E6%89%98%E9%A9%AC%E6%96%AF%20%3C%2FP%3E%3C%2FLINGO-BODY%3E
