MPL3115A2 fail
MPL3115A2 fail
4,314件の閲覧回数
alexanderkobzev
I use MPL3115A2 (M3PR YI0C) to measure temperature, pressure and elevation. Periodically change the mode of the altimeter to barometer mode and Vice versa. I ran into the following problem: After some time of operation, the STATUS register (0x00) stops updating and becomes always equal to 0x00. Registers the altitude/pressure and temperature (0x01 - 0x05) are set to zero. While reading the configuration registers shows that MPL3115A2 configured true.
Here is an example of registers in a single measurement prior to the crash:
STATUS:    0x0e
OUT P_MSB: 0x61
OUT_P_CSB: 0xa0
OUT_P_LSB: 0xd0
OUT_T_MSB: 0x1a
OUT_T_LSB: 0x50
SYSMOD:      0x01
INT_SOURCE:  0x00
PT_DATA_CFG: 0x07
CTRL_REG1: 0x39
CTRL_REG2: 0x00
CTRL_REG3: 0x00
CTRL_REG4: 0x00
CTRL_REG5: 0x00
Here is the first failed measurement:
STATUS:    0x00
OUT P_MSB: 0x61
OUT_P_CSB: 0xa0
OUT_P_LSB: 0xd0
OUT_T_MSB: 0x1a
OUT_T_LSB: 0x50
SYSMOD:      0x01
INT_SOURCE:  0x00
PT_DATA_CFG: 0x07
CTRL_REG1: 0x39
CTRL_REG2: 0x00
CTRL_REG3: 0x00
CTRL_REG4: 0x00
CTRL_REG5: 0x00
Here are 10 unsuccessful measurement (with attempt to switch mode):
STATUS:    0x00
OUT P_MSB: 0x00
OUT_P_CSB: 0x00
OUT_P_LSB: 0x00
OUT_T_MSB: 0x00
OUT_T_LSB: 0x00
SYSMOD:      0x01
INT_SOURCE:  0x00
PT_DATA_CFG: 0x07
CTRL_REG1: 0xb9
CTRL_REG2: 0x00
CTRL_REG3: 0x00
CTRL_REG4: 0x00
CTRL_REG5: 0x00
The problem appears both when using the interrupt, and when using polling. The only way to MPL3115A2 return to normal operation is a software reboot. What could be the problem?
(Sorry for translate)
5 返答(返信)
3,812件の閲覧回数
waynesoutter
We also encountered this issue.  After extensive testing, we didn't manage to resolve it, but we found a work around.  It was to "software reset" (Search for RST in datasheet) the device in the initialise routine.
    mpl3115a2_write(MPL3115A2_CTRL_REG1,0b00000100);
Hope this helps.
TrackerSense Support
3,811件の閲覧回数
reyes
Hi Alexander,
I checked your source code and I didn't see anything that could cause the problem you are mentioning.
Can I asked if you found the source of your problem? If you did, can you share it, please?
If not, please let me know if there are further details from the mentioned in the community.
Jose
3,811件の閲覧回数
anthonyduhamel
Thanks Alexander for sharing,
I have taken a quick look on your source code. I did not spot any specific problem. If I have time, I'll check that in detail. If anybody has the answer, do not hesitate to reply.
Anthony
3,811件の閲覧回数
anthonyduhamel
Hi Alexander,
I'm not sure to answer the question but did you  put the MPL3115A2 to Standby mode before switching the mode?  It could be a problem.
Can you share with us your code? I'd like to check your configuration.
Anthony
3,806件の閲覧回数
alexanderkobzev
Hi Anthony!
Thanks for answer!
I use my own driver for MPL3115A2. The driver source code in attachment.
And so I use it:
mpl3115a2_init( &mpl3115a2 );
mpl3115a2_set_pwrmode( &mpl3115a2, MPL3115A2_PWRMODE_STANDBY );
mpl3115a2_set_ready_mode(
    &mpl3115a2,
    MPL3115A2_READY_MODE_POLLING );
mpl3115a2_set_mode(
    &mpl3115a2,
    MPL3115A2_MODE_ALTIMETER,
    MPL3115A2_OSR_128 );
mpl3115a2_set_pt(
    &mpl3115a2,
    MPL3115A2_PT_DREM  |
    MPL3115A2_PT_PDEFE |
    MPL3115A2_PT_TDEFE );
mpl3115a2_set_pwrmode( &mpl3115a2, MPL3115A2_PWRMODE_ACTIVE );
while ( 1 ) {
    dev_res = mpl3115a2_update( &mpl3115a2 );
    dev_res = mpl3115a2_get_h( &mpl3115a2, &data->alt, NULL );
    dev_res = mpl3115a2_get_t( &mpl3115a2, &data->temp, &data->temp_l );
    dev_res = mpl3115a2_get_p( &mpl3115a2, &data->ph, &data->pl );
    // (In timer-counter value of 'mode_change' increment)
    if ( mode_change >= 50 ) {
        if ( mpl3115a2.mode == MPL3115A2_MODE_ALTIMETER ) {
            mpl3115a2_set_mode( &mpl3115a2, MPL3115A2_MODE_BAROMETER, MPL3115A2_OSR_128 );
        else {
            mpl3115a2_set_mode( &mpl3115a2, MPL3115A2_MODE_ALTIMETER, MPL3115A2_OSR_128 );
        mode_change = 0;
    // And sleep at 1 - 2 sec...
    //Restore after fail
#if MPL3115A2_DEBUG
    if ( mpl3115a2_get_fail_count( &mpl3115a2 ) > 11 ) {
        mpl3115a2_reset( &mpl3115a2 );
        mpl3115a2_set_pt(
            &mpl3115a2,
            MPL3115A2_PT_DREM  |
        mpl3115a2_fail_count_clear( &mpl3115a2 );
#endif
%3CLINGO-SUB%20id%3D%22lingo-sub-458633%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMPL3115A2%E3%81%AE%E6%95%85%E9%9A%9C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-458633%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%B8%A9%E5%BA%A6%E3%80%81%E5%9C%A7%E5%8A%9B%E3%80%81%E9%AB%98%E5%BA%A6%E3%82%92%E6%B8%AC%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%20MPL3115A2%20(M3PR%20YI0C)%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E5%AE%9A%E6%9C%9F%E7%9A%84%E3%81%AB%E9%AB%98%E5%BA%A6%E8%A8%88%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E6%B0%97%E5%9C%A7%E8%A8%88%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E3%80%81%E3%81%BE%E3%81%9F%E3%81%9D%E3%81%AE%E9%80%86%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%20%E3%81%97%E3%81%B0%E3%82%89%E3%81%8F%E6%93%8D%E4%BD%9C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81STATUS%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%20(0x00)%20%E3%81%AE%E6%9B%B4%E6%96%B0%E3%81%8C%E5%81%9C%E6%AD%A2%E3%81%97%E3%80%81%E5%B8%B8%E3%81%AB%200x00%20%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E9%AB%98%E5%BA%A6%2F%E6%B0%97%E5%9C%A7%E3%81%A8%E6%B8%A9%E5%BA%A6%E3%81%AE%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%20(0x01%20-%200x05)%20%E3%81%AF%E3%82%BC%E3%83%AD%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E6%A7%8B%E6%88%90%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E3%81%A8%E3%80%81MPL3115A2%20%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AF%E3%82%AF%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E5%89%8D%E3%81%AE%E5%8D%98%E4%B8%80%E6%B8%AC%E5%AE%9A%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8B%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%200x0e%3C%2FP%3E%3CP%3E%E5%87%BA%E5%8A%9BP_MSB%3A%200x61%3C%2FP%3E%3CP%3EOUT_P_CSB%3A%200xa0%3C%2FP%3E%3CP%3EOUT_P_LSB%3A%200xd0%3C%2FP%3E%3CP%3EOUT_T_MSB%3A%200x1a%3C%2FP%3E%3CP%3EOUT_T_LSB%3A%200x50%3C%2FP%3E%3CP%3ESYSMOD%3A%200x01%3C%2FP%3E%3CP%3EINT_SOURCE%3A%200x00%3C%2FP%3E%3CP%3EPT_DATA_CFG%3A%200x07%3C%2FP%3E%3CP%3ECTRL_REG1%3A%200x39%3C%2FP%3E%3CP%3ECTRL_REG2%3A%200x00%3C%2FP%3E%3CP%3ECTRL_REG3%3A%200x00%3C%2FP%3E%3CP%3ECTRL_REG4%3A%200x00%3C%2FP%3E%3CP%3ECTRL_REG5%3A%200x00%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%9C%80%E5%88%9D%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%9F%E6%B8%AC%E5%AE%9A%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%200x00%3C%2FP%3E%3CP%3E%E5%87%BA%E5%8A%9BP_MSB%3A%200x61%3C%2FP%3E%3CP%3EOUT_P_CSB%3A%200xa0%3C%2FP%3E%3CP%3EOUT_P_LSB%3A%200xd0%3C%2FP%3E%3CP%3EOUT_T_MSB%3A%200x1a%3C%2FP%3E%3CP%3EOUT_T_LSB%3A%200x50%3C%2FP%3E%3CP%3ESYSMOD%3A%200x01%3C%2FP%3E%3CP%3EINT_SOURCE%3A%200x00%3C%2FP%3E%3CP%3EPT_DATA_CFG%3A%200x07%3C%2FP%3E%3CP%3ECTRL_REG1%3A%200x39%3C%2FP%3E%3CP%3ECTRL_REG2%3A%200x00%3C%2FP%3E%3CP%3ECTRL_REG3%3A%200x00%3C%2FP%3E%3CP%3ECTRL_REG4%3A%200x00%3C%2FP%3E%3CP%3ECTRL_REG5%3A%200x00%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AF%E3%80%81%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%82%92%E8%A9%A6%E3%81%BF%E3%81%9F%E3%82%82%E3%81%AE%E3%81%AE%E5%A4%B1%E6%95%97%E3%81%97%E3%81%9F%E6%B8%AC%E5%AE%9A%2010%20%E4%BB%B6%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%200x00%3C%2FP%3E%3CP%3E%E5%87%BA%E5%8A%9BP_MSB%3A%200x00%3C%2FP%3E%3CP%3EOUT_P_CSB%3A%200x00%3C%2FP%3E%3CP%3EOUT_P_LSB%3A%200x00%3C%2FP%3E%3CP%3EOUT_T_MSB%3A%200x00%3C%2FP%3E%3CP%3EOUT_T_LSB%3A%200x00%3C%2FP%3E%3CP%3ESYSMOD%3A%200x01%3C%2FP%3E%3CP%3EINT_SOURCE%3A%200x00%3C%2FP%3E%3CP%3EPT_DATA_CFG%3A%200x07%3C%2FP%3E%3CP%3ECTRL_REG1%3A%200xb9%3C%2FP%3E%3CP%3ECTRL_REG2%3A%200x00%3C%2FP%3E%3CP%3ECTRL_REG3%3A%200x00%3C%2FP%3E%3CP%3ECTRL_REG4%3A%200x00%3C%2FP%3E%3CP%3ECTRL_REG5%3A%200x00%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E3%80%81%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%A8%E3%83%9D%E3%83%BC%E3%83%AA%E3%83%B3%E3%82%B0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%A7%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82MPL3115A2%20%E3%82%92%E9%80%9A%E5%B8%B8%E3%81%AE%E5%8B%95%E4%BD%9C%E3%81%AB%E6%88%BB%E3%81%99%E5%94%AF%E4%B8%80%E3%81%AE%E6%96%B9%E6%B3%95%E3%81%AF%E3%80%81%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E5%86%8D%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%E4%BD%95%E3%81%8C%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FP%3E%3CP%3E%EF%BC%88%E7%BF%BB%E8%A8%B3%E3%81%97%E3%81%A6%E3%81%99%E3%81%BF%E3%81%BE%E3%81%9B%E3%82%93%EF%BC%89%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-458638%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL3115A2%20fail%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-458638%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A7%81%E3%81%9F%E3%81%A1%E3%82%82%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E9%81%AD%E9%81%87%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%BE%B9%E5%BA%95%E7%9A%84%E3%81%AA%E3%83%86%E3%82%B9%E3%83%88%E3%82%92%E8%A1%8C%E3%81%A3%E3%81%9F%E7%B5%90%E6%9E%9C%E3%80%81%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E5%9B%9E%E9%81%BF%E7%AD%96%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%9D%E3%82%8C%E3%81%AF%E3%80%81%E5%88%9D%E6%9C%9F%E5%8C%96%E3%83%AB%E3%83%BC%E3%83%81%E3%83%B3%E3%81%A7%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%80%8C%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%20%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%80%8D%EF%BC%88%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%81%A7%20RST%20%E3%82%92%E6%A4%9C%E7%B4%A2%EF%BC%89%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Empl3115a2_write(MPL3115A2_CTRL_REG1%2C0b00000100)%3B%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%8C%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ETrackerSense%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-458637%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL3115A2%20fail%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-458637%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%82%A2%E3%83%AC%E3%82%AF%E3%82%B5%E3%83%B3%E3%83%80%E3%83%BC%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E8%A8%80%E5%8F%8A%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%95%8F%E9%A1%8C%E3%82%92%E5%BC%95%E3%81%8D%E8%B5%B7%E3%81%93%E3%81%99%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%AE%E3%81%82%E3%82%8B%E3%82%82%E3%81%AE%E3%81%AF%E4%BD%95%E3%82%82%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%95%8F%E9%A1%8C%E3%81%AE%E5%8E%9F%E5%9B%A0%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%82%82%E3%81%97%E3%81%9D%E3%81%86%E3%81%AA%E3%82%89%E3%80%81%E3%82%B7%E3%82%A7%E3%82%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%86%E3%81%A7%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E3%81%A7%E8%A8%80%E5%8F%8A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E8%A9%B3%E7%B4%B0%E6%83%85%E5%A0%B1%E3%81%8C%E3%81%82%E3%82%8C%E3%81%B0%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%9B%E3%82%BB%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-458636%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL3115A2%20fail%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-458636%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%82%B7%E3%82%A7%E3%82%A2%E3%81%97%E3%81%A6%E3%81%8F%E3%82%8C%E3%81%A6%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%81%E3%82%A2%E3%83%AC%E3%82%AF%E3%82%B5%E3%83%B3%E3%83%80%E3%83%BC%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E3%81%96%E3%81%A3%E3%81%A8%E8%A6%8B%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E7%89%B9%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%AF%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E6%99%82%E9%96%93%E3%81%8C%E3%81%82%E3%82%8C%E3%81%B0%E8%A9%B3%E3%81%97%E3%81%8F%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%E8%AA%B0%E3%81%8B%E3%81%8C%E7%AD%94%E3%81%88%E3%82%92%E7%9F%A5%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AA%E3%82%89%E3%80%81%E9%81%A0%E6%85%AE%E3%81%AA%E3%81%8F%E8%BF%94%E4%BF%A1%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%A2%E3%83%B3%E3%82%BD%E3%83%8B%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-458635%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL3115A2%20fail%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-458635%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%82%A2%E3%83%B3%E3%82%BD%E3%83%8B%E3%83%BC%EF%BC%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9B%9E%E7%AD%94%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EMPL3115A2%20%E3%81%AB%E3%81%AF%E7%8B%AC%E8%87%AA%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E6%B7%BB%E4%BB%98%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%81%A7%E7%A7%81%E3%81%AF%E3%81%9D%E3%82%8C%E3%82%92%E4%BD%BF%E3%81%84%E3%81%BE%E3%81%99%3A%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%2F%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%2F%2F%20...%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%2F%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Empl3115a2_init(%20%26amp%3Bmpl3115a2%20)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Empl3115a2_set_pwrmode(%20%26amp%3Bmpl3115a2%2C%20MPL3115A2_PWRMODE_STANDBY%20)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Empl3115a2_set_ready_mode(%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%26amp%3Bmpl3115a2%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3EMPL3115A2_READY_MODE_POLLING%20)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Empl3115a2_set_mode(%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%26amp%3Bmpl3115a2%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3EMPL3115A2_MODE_ALTIMETER%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3EMPL3115A2_OSR_128%20)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Empl3115a2_set_pt(%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%26amp%3Bmpl3115a2%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3EMPL3115A2_PT_DREM%20%7C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3EMPL3115A2_PT_PDEFE%20%7C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3EMPL3115A2_PT_TDEFE%20)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Empl3115a2_set_pwrmode(%20%26amp%3Bmpl3115a2%2C%20MPL3115A2_PWRMODE_ACTIVE%20)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%2F%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%2F%2F%20...%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%2F%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%EF%BC%881%EF%BC%89%E3%81%AE%E9%96%93%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%2F%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%2F%2F%20...%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%2F%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Edev_res%20%3D%20mpl3115a2_update(%20%26amp%3Bmpl3115a2%20)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Edev_res%20%3D%20mpl3115a2_get_h(%20%26amp%3Bmpl3115a2%2C%20%26amp%3Bdata-%26gt%3Balt%2C%20NULL%20)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Edev_res%20%3D%20mpl3115a2_get_t(%20%26amp%3Bmpl3115a2%2C%20%26amp%3Bdata-%26gt%3Btemp%2C%20%26amp%3Bdata-%26gt%3Btemp_l%20)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Edev_res%20%3D%20mpl3115a2_get_p(%20%26amp%3Bmpl3115a2%2C%20%26amp%3Bdata-%26gt%3Bph%2C%20%26amp%3Bdata-%26gt%3Bpl%20)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%2F%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%2F%2F%20...%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%2F%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%2F%2F%20('mode_change'%20%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E5%80%A4%E3%81%AE%E5%A2%97%E5%88%86)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Eif%20(%20mode_change%20%26gt%3B%3D%2050%20)%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Eif%20(%20mpl3115a2.mode%20%3D%3D%20MPL3115A2_MODE_ALTIMETER%20)%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Empl3115a2_set_pwrmode(%20%26amp%3Bmpl3115a2%2C%20MPL3115A2_PWRMODE_STANDBY%20)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Empl3115a2_set_mode(%20%26amp%3Bmpl3115a2%2C%20MPL3115A2_MODE_BAROMETER%2C%20MPL3115A2_OSR_128%20)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Empl3115a2_set_pwrmode(%20%26amp%3Bmpl3115a2%2C%20MPL3115A2_PWRMODE_ACTIVE%20)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%E3%81%9D%E3%82%8C%E4%BB%A5%E5%A4%96%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Empl3115a2_set_pwrmode(%20%26amp%3Bmpl3115a2%2C%20MPL3115A2_PWRMODE_STANDBY%20)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Empl3115a2_set_mode(%20%26amp%3Bmpl3115a2%2C%20MPL3115A2_MODE_ALTIMETER%2C%20MPL3115A2_OSR_128%20)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Empl3115a2_set_pwrmode(%20%26amp%3Bmpl3115a2%2C%20MPL3115A2_PWRMODE_ACTIVE%20)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%E3%83%A2%E3%83%BC%E3%83%89%E5%A4%89%E6%9B%B4%20%3D%200%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%2F%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%2F%2F%20...%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%2F%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%2F%2F%20%E3%81%9D%E3%81%97%E3%81%A6%201%20-%202%20%E7%A7%92%E3%81%A7%E3%82%B9%E3%83%AA%E3%83%BC%E3%83%97%E3%81%97%E3%81%BE%E3%81%99...%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%2F%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%2F%2F...%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%2F%2F%E5%A4%B1%E6%95%97%E5%BE%8C%E3%81%AB%E5%BE%A9%E5%85%83%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%23MPL3115A2_DEBUG%E3%81%AE%E5%A0%B4%E5%90%88%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Eif%20(%20mpl3115a2_get_fail_count(%20%26amp%3Bmpl3115a2%20)%20%26gt%3B%2011%20)%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Empl3115a2_reset(%26amp%3Bmpl3115a2)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Empl3115a2_set_pt(%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%26amp%3Bmpl3115a2%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3EMPL3115A2_PT_DREM%20%7C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3EMPL3115A2_PT_PDEFE%20%7C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3EMPL3115A2_PT_TDEFE%20)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Empl3115a2_set_pwrmode(%20%26amp%3Bmpl3115a2%2C%20MPL3115A2_PWRMODE_ACTIVE%20)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Empl3115a2_fail_count_clear(%26amp%3Bmpl3115a2)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%23endif%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-458634%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL3115A2%20fail%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-458634%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%82%A2%E3%83%AC%E3%82%AF%E3%82%B5%E3%83%B3%E3%83%80%E3%83%BC%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B3%AA%E5%95%8F%E3%81%AB%E7%AD%94%E3%81%88%E3%82%89%E3%82%8C%E3%82%8B%E3%81%8B%E5%88%86%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%82%8B%E5%89%8D%E3%81%AB%20MPL3115A2%20%E3%82%92%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%90%E3%82%A4%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%E3%81%9D%E3%82%8C%E3%81%AF%E5%95%8F%E9%A1%8C%E3%81%AB%E3%81%AA%E3%82%8B%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Capture.PNG%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Capture.PNG%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F3012i718CFE384620DE21%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Capture.PNG%22%20alt%3D%22Capture.PNG%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ECapture.PNG%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%E8%A8%AD%E5%AE%9A%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%A2%E3%83%B3%E3%82%BD%E3%83%8B%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E
