MPL3115
MPL3115
周添鹏周
对与MPL3115,想把测量精度提高到1.5Pa,怎么设置?我的配置为初始化,前面为地址,后面为数据,
  I2C_WriteReg(0x26,0x01);
  I2C_WriteReg(0x13,0x07);
  I2C_WriteReg(0x26,0x39);
然后写 I2C_WriteReg(0x26,0x3B);
等待8ms,向地址0X01,0X02,0X03读取数据,在自然状态下,20位数据,后6位会跳动,如果能精确到1.5Pa,最多后4位跳动才对啊
georgeguo
Dear Mr. Zhou,
Please note the pressure reading noise of MPL3115 is 1.5Pa when you set the OSR is 128x.
But the absolute accuracy of MPL3115 is +/-0.4kPa, and relative accuracy is up to +/-0.1kPa.
Please review the datasheet of this sensor.
George Guo
%3CLINGO-SUB%20id%3D%22lingo-sub-416524%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3EMPL3115%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-416524%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EFor%20with%20MPL3115%2C%20I%20want%20to%20increase%20the%20measurement%20accuracy%20to%201.5Pa%2C%20how%20to%20set%20it%20up%3F%20My%20configuration%20is%20initialized%20with%20address%20in%20front%20and%20data%20at%20the%20end.%3C%2FP%3E%3CP%3E%20%20I2C_WriteReg(0x26%2C0x01).%3C%2FP%3E%3CP%3E%20%20I2C_WriteReg(0x13%2C0x07).%3C%2FP%3E%3CP%3E%20%20I2C_WriteReg(0x26%2C0x39).%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThen%20write%20I2C_WriteReg(0x26%2C0x3B)%3B%3C%2FP%3E%3CP%3EWait%20for%208ms%2C%20read%20data%20to%20address%200X01%2C0X02%2C0X03%2C%20in%20the%20natural%20state%2C%2020%20bits%20of%20data%2C%20the%20last%206%20bits%20will%20jump%2C%20if%20it%20can%20be%20accurate%20to%201.5Pa%2C%20at%20most%2C%20the%20last%204%20bits%20will%20jump%20to%20the%20right%20ah!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-416524%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EPressure%20Sensors%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-416525%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL3115%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-416525%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDear%20Mr.%20Zhou%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EPlease%20note%20the%20pressure%20reading%20noise%20of%20MPL3115%20is%201.5Pa%20when%20you%20set%20the%20OSR%20is%20128x.%3C%2FP%3E%3CP%3EBut%20the%20absolute%20accuracy%20of%20MPL3115%20is%20%2B%2F-0.4kPa%2C%20and%20relative%20accuracy%20is%20up%20to%20%2B%2F-0.1kPa.%3C%2FP%3E%3CP%3EPlease%20review%20the%20datasheet%20of%20this%20sensor.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThanks%2C%3C%2FP%3E%3CP%3EGeorge%20Guo%3C%2FP%3E%3C%2FLINGO-BODY%3E
