MPL115A fixed point question
21,205件の閲覧回数
BillTheBiker
I am trying to make sense of the coefficients I receive from the pressure sensor MPL115A.  I can successfully access the IIC bus and get the data, but the algorithm provided in the AN3785 does not appear to work (at least for me).  Closer inspection of the comments raises some questions.  For example, the coeff C11 is described as a signed number with no int bits and 10 frac bits.  There are 11 pad zeros.  So I think the number looks like this:
S0.00000000000 F10 F9 F8 F7 F6 F5 F4 F3 F2 F1 F0
To me the representation of this number is s(0,21), but the comment says s(16,27).
When I extract the data from the sensor, C11 is given as 0x0340.  This is a 2's compliment number and only the first 11 bits are used (the 10 frac bits and the sign bit).  So if I convert this to a real number (not something I would do in the processor, but just to see if I am understanding this correctly),  I get
S0.00000000000 0000 0011 010x xxxx
this gives 2^-17+ 2^-18 + 2^-20 = 0.00001239776611328125
this is the extent of my understanding, and I wonder if someone could confirm I have done this correctly.  In addition, as the algorithm in AN3785 keeps everything in fixed point, I cannot see where lt1 (a 32-bit value) can be assigned C11 and this be correctly justified.  When I assign 0x0340 to the long I get
lt1    0x00000340
= 0000 0000 0000 0000 0000 0011 010x xxxx
so you can see I am not correctly aligned as per the bit-width specifications.  The following is the code snippet.  The comments make no sense to me, so any clarification you could prrovide would be most helpful
 //******* STEP 1 c11x1= c11 * Padc
 lt1 = (S32)sic11;                  // s(16,27)    s(N,F+zeropad) goes from s(11,10)+11ZeroPad = s(11,22) => Left Justified = s(16,27)
-Bill
35 返答(返信)
6,118件の閲覧回数
PJH
I assume you mean C22 for your last coefficient.
On one of my systems I got
A0=2156.625000
B1=-2.528809
B2=-1.034241
C12=0.000876
C11=0.000000
C22=0.000000
pressureADC 420
tempADC 419
result 101.802 kPa.  So that comes out at 1018.02 mBar.
Looking at the  values it seems that the one which is likely to be wrong is C12. Your number is much smaller than what I get.  If you put my numbers into your calculation function do you get the same result as I did?
Also check the decimial point position in B2 your number is a factor of 10 smaller than mine.
Don't forget too that you have to scale the pComp value.  The output is 0-1023 which is for a scale of 50kPa to 115kPa. So range is 65kPa in 1023 steps. Final pressure = (65/1023*pComp)+50
6,118件の閲覧回数
tremichl
Peter, please could you explane how you have calculated C12. The AN3785 says dec pt zero pad=9. So 9 "0" after "."  If I do so I can't get an acceptable result. Even all other values are almost the same as yours.
Thank you!
Michael
6,118件の閲覧回数
Mommmo
I have a problem with the MPL115A2.
The coef data are:
3a 4d ba cc bf a6 31 78 00 00 00 00
Padc = 990
Tadc = 523
I calculate:
a0 = 1865.63
b1 = -2.16
b2 = -1.01
c12 = 0.00075
c11 = 0
c22 = 0
Pcomp = -411 (negative!!!)
Any idea?
Many thank !
Nicola (Italy)
6,118件の閲覧回数
ZenerX
Hi Mommmo,
Did you solve your problem?, As they give me similar results.
Negative pressure and a value of PADC = 990
regards
6,118件の閲覧回数
MPL115A2
I've the same problem as other users of the MPL115A2 programming...
I can read the data from the registers, however, to get the real pressure and temperature is a long way to go from there,
ok, here's my problems and wishing someone can help me, the following are the data I read from the registers $00 to $0f
5a c0 75 c0 39 e3 b9 7a ca 7b 32 cc 00 00 00 00
Please, anyone can help me to decipher the mystery of the above data - I know the first four bytes are the Padc and Tadc value, then the a0-msb, a0-lsb, b1.....c22 etc, however, I don't know how to convert these No. into floating point notation - actually I can't find any 'Freescale' document mention about it.
Many thanks for your help.
6,118件の閲覧回数
lrf
It has been a long time since I worked with this component but I can tell you it works fine once you get the math correct. I found that the equations given in the manual are in correct. Unfortunately I don't remember exactly what the issue was so I went back thru my code looking for differences. The following is the only difference I can find:
The manual says:
siPcomp = ((S16)lt3>>13);
Change this to this:
siPcomp = ((S16)(lt3>>13));
Hope this helps
6,118件の閲覧回数
PWC
lrf wrote:
The manual says:
That was a HUGE help to me.  Thank you very much!
(This, plus the undocumented ox01 I2C   write that is necessary to initiate the pressure/Temp conversion)
6,118件の閲覧回数
risototh
has anyone solved this math mystery? I can finaly read the data from the sensor, but i can't pass thru the math described in the app. note on pages 17-18. As siPcomp i get about 5726, which is significantly more than 1023...
The coefs are fine (proccessed to float just for info:
A0 Result = 2101
 B1 Result = -2.4163818359375
 B2 Result = -1.2173461914062
 C12 Result = 0.00083708763122559
 C11 Result = 0
 C22 Result = 0
The code is exactly copy-pasted from the app. note, but the result is completly insane...
Has anyone a working code snippet?
My data are here (pressure, temperature, coeffs):  5B 40 81 80 41 A8 B2 AD B2 17 36 DC 00 00 00 00
My code is here:
unsigned char mpl115a_raw_data[16];unsigned int mpl115a_p;unsigned int mpl115a_t;signed int mpl115a_a0;signed int mpl115a_b1;signed int mpl115a_b2;signed int mpl115a_c12;signed int mpl115a_c11;signed int mpl115a_c22;//====================================================// MPL115A Placing Coefficients into 16 bit variables//====================================================void mpl115a_raw_dissection(void){ mpl115a_p = (unsigned int)mpl115a_raw_data[0] <<8; mpl115a_p += (unsigned int)mpl115a_raw_data[1] & 0x00FF;  mpl115a_t = (unsigned int)mpl115a_raw_data[2] <<8; mpl115a_t += (unsigned int)mpl115a_raw_data[3] & 0x00FF;  mpl115a_a0 = (signed int)mpl115a_raw_data[4] <<8; mpl115a_a0 += (signed int)mpl115a_raw_data[5] & 0x00FF;  mpl115a_b1 = (signed int)mpl115a_raw_data[6] <<8; mpl115a_b1 += (signed int)mpl115a_raw_data[7] & 0x00FF;  mpl115a_b2 = (signed int)mpl115a_raw_data[8] <<8; mpl115a_b2 += (signed int)mpl115a_raw_data[9] & 0x00FF;  mpl115a_c12 = (signed int)mpl115a_raw_data[10] <<8; mpl115a_c12 += (signed int)mpl115a_raw_data[11] & 0x00FF;  mpl115a_c11 = (signed int)mpl115a_raw_data[12] <<8; mpl115a_c11 += (signed int)mpl115a_raw_data[13] & 0x00FF;  mpl115a_c22 = (signed int)mpl115a_raw_data[14] <<8; mpl115a_c22 += (signed int)mpl115a_raw_data[15] & 0x00FF;}//===================================================//Coefficient 9 equation compensation//===================================================unsigned long mpl115a_compensated_pressure(void){ //Variable used to do large calculation as 3 temp variables in the process below signed long lt1, lt2, lt3, si_c11x1, si_a11, si_c12x2, si_a1, si_c22x2, si_a2, si_a1x1, si_y1, si_a2x2;;  //Variables used for Pressure and Temperature Raw. unsigned int uiPadc, uiTadc;  signed int siPcomp; unsigned long decPcomp;   uiPadc = mpl115a_p >> 6; uiTadc = mpl115a_t >> 6; //******* STEP 1 c11x1= c11 * Padc lt1 = (signed long) mpl115a_c11; lt2 = (signed long) uiPadc; lt3 = lt1 * lt2; si_c11x1 = (signed long) lt3;  //******* STEP 2 a11= b1 + c11x1 lt1 = ((signed long) mpl115a_b1) << 14; lt2 = (signed long) si_c11x1; lt3 = lt1 + lt2; si_a11 = (signed long) (lt3 >> 14);   //******* STEP 3 c12x2= c12 * Tadc lt1 = (signed long) mpl115a_c12; lt2 = (signed long) uiTadc; lt3 = lt1 * lt2; si_c12x2 = (signed long) lt3; //******* STEP 4 a1= a11 + c12x2 lt1 = ((signed long) si_a11) << 11; lt2 = (signed long) si_c12x2; lt3 = lt1 + lt2; si_a1 =(signed long) (lt3 >> 11); //******* STEP 5 c22x2= c22 * Tadc lt1 = (signed long) mpl115a_c22; lt2 = (signed long) uiTadc; lt3 = lt1 * lt2; si_c22x2 = (signed long) lt3; //******* STEP 6 a2= b2 + c22x2 lt1 = ((signed long) mpl115a_b2) << 15; lt2 = ((signed long) si_c22x2) >> 1; lt3 = lt1 + lt2; si_a2 = ((signed long)lt3) >> 16; //******* STEP 7 a1x1= a1 * Padc lt1 = (signed long) si_a1; lt2 = (signed long) uiPadc; lt3 = lt1 * lt2; si_a1x1 = (signed long) lt3; //******* STEP 8 y1= a0 + a1x1 lt1 = ((signed long) mpl115a_a0) << 10; lt2 = (signed long) si_a1x1; lt3 = lt1 + lt2; si_y1 = ((signed long)lt3) >> 10; //******* STEP 9 a2x2= a2 *Tadc lt1 = (signed long) si_a2; lt2 = (signed long) uiTadc; lt3 = lt1 * lt2; si_a2x2 = (signed long) lt3; //******* STEP 10 pComp = y1 +a2x2 lt1 = ((signed long) si_y1) << 10; lt2 = (signed long) si_a2x2; lt3 = lt1 + lt2; // FIXED POINT RESULT WITH ROUNDING: siPcomp = (signed int)(lt3 >> 13); // goes to no fractional parts since this is an ADC count.  //decPcomp is defined as a floating point number. //Conversion to Decimal value from 1023 ADC count value. ADC counts are 0 to 1023. Pressure is 50 to 115kPa correspondingly. //decPcomp = (((unsigned long)siPcomp) * 65000 + 51150000) / 1023; // result in Pa, not kPa  decPcomp = (unsigned long)siPcomp; // temporary return decPcomp;}
6,118件の閲覧回数
risototh
Ok, finally i found the problem. The problem is in data type int. I meant that it has 16 bits (as in gcc, borland c, ...) but in fact it has 32. And therefore the negative numbers aren't negative...
The solution is to change all int to short (at least in CW 6.3). :smileysad:
6,118件の閲覧回数
MPL115A2
irf,
'It has been a long time since I worked with this component but I can tell you it works fine once you get the math correct...'
The problem is I can't get the math correct, I need your help, would you please explain how to convert the coef' value into floating point number in plain english, not c programming notation.
eg, the numbers I read from the registers of $00 - $0f are:
Thanks your help.
cw.
6,118件の閲覧回数
lrf
CW,
Why do you need to understand the math? If you are trying to get the chip to do something then just use the programming that Freescale provided in AN3785, with the small mod I stated above. To understand the math simply reverse engineer the equations.
The chip is what it is and the way they chose to do the calculations is what they chose. Doing the equations at the MC is much faster and open to user tweaking better then having the chip do the math and you are stuck with the results.  Either use it or find another.
My weather station has been running for about a year and without any issues. Its readings track with the national weather service spot on for barometric pressure, given a correction for altitutde (NWS values are at sea level).
6,118件の閲覧回数
pmatil
Yes I meant C22. I calculated the pressure using your values and got the same result as you. And I think I finally realized what I did wrong. I looked at the first post of this thread and converted the coeffs following that as an example. So C12 is S0.0000000001110001110000 -> 2^-10 + 2^-11 + 2^-12 + 2^-16 + 2^-17 + 2^-18 = 0.0017281. But the sign bit is 1 (0x38E0). Should I invert the 13 fractional bits and add 1 to get the real result? And for the B2 it's probably the same error. Thanks for your help PJH!
6,118件の閲覧回数
ringo42
Can anyone tell me how to convert the uiTADC number to c or F? I'm getting around a 523. What is the conversion factor?
Thansk
Ringo
6,118件の閲覧回数
ringo42
What kind of accuracy/repeatability is anyone getting? Mine is bouncing all over the place.
Alt feet: 149
Alt feet:  57
Alt feet:  97
Alt feet:  57
Alt feet:  97
Alt feet: 109
Alt feet:  57
Alt feet:  45
Alt feet: 109
Alt feet:  45
Alt feet: 109
Alt feet:  57
Alt feet:  57
Alt feet:  97
Alt feet: 109
Alt feet:  97
Alt feet: 109
Alt feet:  57
Alt feet: 109
Alt feet: 109
Alt feet: 109
Alt feet:  97
Alt feet: 109
Alt feet:  97
Alt feet:  45
Alt feet:  57
Alt feet: 109
Alt feet:  97
Alt feet:  57
6,118件の閲覧回数
PJH
Ringo,
          Here are answers to your 2 questions.
1. The temperature ADC does not have a direct conversion to an actual temperature. You could always try and vary the ambient temperature of the sensor and see what the ADC value is over a range of temperatures. Then you might be able to figure out a conversion factor.
2. The final pressure reading is noisy and thus any conversion of that value to an altitude will also be noisy.  Typically the pressure varies quite slowly so the best approach is to take multiple readings and have a running average of the last measurements so that noise is averaged out.  For our application we take measurements every second and average over the last 100 seconds.
Peter
%3CLINGO-SUB%20id%3D%22lingo-sub-214595%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMPL115A%20%E5%9B%BA%E5%AE%9A%E5%B0%8F%E6%95%B0%E7%82%B9%E5%95%8F%E9%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214595%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%E5%9C%A7%E5%8A%9B%E3%82%BB%E3%83%B3%E3%82%B5%20MPL115A%20%E3%81%8B%E3%82%89%E5%8F%97%E4%BF%A1%E3%81%97%E3%81%9F%E4%BF%82%E6%95%B0%E3%81%AE%E6%84%8F%E5%91%B3%E3%82%92%E7%90%86%E8%A7%A3%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82IIC%20%E3%83%90%E3%82%B9%E3%81%AB%E6%AD%A3%E5%B8%B8%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%97%E3%81%A6%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E5%8F%96%E5%BE%97%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81AN3785%20%E3%81%A7%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%E3%81%AF%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%20(%E5%B0%91%E3%81%AA%E3%81%8F%E3%81%A8%E3%82%82%E7%A7%81%E3%81%AB%E3%81%A8%E3%81%A3%E3%81%A6%E3%81%AF)%E3%80%82%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E8%A9%B3%E3%81%97%E3%81%8F%E8%AA%BF%E3%81%B9%E3%81%A6%E3%81%BF%E3%82%8B%E3%81%A8%E3%80%81%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E7%96%91%E5%95%8F%E3%81%8C%E6%B5%AE%E3%81%8B%E3%81%B3%E4%B8%8A%E3%81%8C%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%9F%E3%81%A8%E3%81%88%E3%81%B0%E3%80%81coeff%20C11%20%E3%81%AF%E3%80%81int%20%E3%83%93%E3%83%83%E3%83%88%E3%81%8C%E3%81%AA%E3%81%8F%2010%20%E5%80%8B%E3%81%AE%20frac%20%E3%83%93%E3%83%83%E3%83%88%E3%82%92%E6%8C%81%E3%81%A4%E7%AC%A6%E5%8F%B7%E4%BB%98%E3%81%8D%E6%95%B0%E5%80%A4%E3%81%A8%E3%81%97%E3%81%A6%E8%A8%98%E8%BF%B0%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%83%91%E3%83%83%E3%83%89%E3%82%BC%E3%83%AD%E3%81%AF%2011%20%E5%80%8B%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81%E6%95%B0%E5%AD%97%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%20S0.00000000000%20F10%20F9%20F8%20F7%20F6%20F5%20F4%20F3%20F2%20F1%20F0%3CBR%20%2F%3E%3CBR%20%2F%3E%E7%A7%81%E3%81%AB%E3%81%A8%E3%81%A3%E3%81%A6%E3%81%93%E3%81%AE%E6%95%B0%E5%80%A4%E3%81%AE%E8%A1%A8%E7%8F%BE%E3%81%AF%20s(0%2C21)%20%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E3%81%AF%20s(16%2C27)%20%E3%81%A8%E6%9B%B8%E3%81%8B%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%BB%E3%83%B3%E3%82%B5%E3%81%8B%E3%82%89%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E6%8A%BD%E5%87%BA%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81C11%20%E3%81%AF%200x0340%20%E3%81%A8%E3%81%97%E3%81%A6%E8%BF%94%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%202%20%E3%81%AE%E8%A3%9C%E6%95%B0%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E6%9C%80%E5%88%9D%E3%81%AE%2011%20%E3%83%93%E3%83%83%E3%83%88%20(10%20%E5%80%8B%E3%81%AE%20frac%20%E3%83%93%E3%83%83%E3%83%88%E3%81%A8%E7%AC%A6%E5%8F%B7%E3%83%93%E3%83%83%E3%83%88)%20%E3%81%AE%E3%81%BF%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82SO%E3%80%81%E3%81%93%E3%82%8C%E3%82%92%E5%AE%9F%E6%95%B0%E3%81%AB%E5%A4%89%E6%8F%9B%E3%81%99%E3%82%8B%E3%81%A8%EF%BC%88%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E5%86%85%E3%81%A7%E8%A1%8C%E3%81%86%E3%82%82%E3%81%AE%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%8C%E3%80%81%E6%AD%A3%E3%81%97%E3%81%8F%E7%90%86%E8%A7%A3%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%EF%BC%89%E3%80%81%3CBR%20%2F%3E%3CBR%20%2F%3E%20S0.00000000000%200000%200011%20010x%20xxxx%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%93%E3%82%8C%E3%81%AF2%5E-17%2B%202%5E-18%20%2B%202%5E-20%20%3D%200.00001239776611328125%E3%81%A8%E3%81%AA%E3%82%8B%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%93%E3%82%8C%E3%81%8C%E7%A7%81%E3%81%AE%E7%90%86%E8%A7%A3%E3%81%AE%E7%AF%84%E5%9B%B2%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E8%AA%B0%E3%81%8B%E3%81%8C%E7%A7%81%E3%81%8C%E3%81%93%E3%82%8C%E3%82%92%E6%AD%A3%E3%81%97%E3%81%8F%E8%A1%8C%E3%81%A3%E3%81%9F%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%82%8C%E3%82%8B%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%E3%80%82%E3%81%95%E3%82%89%E3%81%AB%E3%80%81AN3785%20%E3%81%AE%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%E3%81%A7%E3%81%AF%E3%81%99%E3%81%B9%E3%81%A6%E3%81%8C%E5%9B%BA%E5%AE%9A%E5%B0%8F%E6%95%B0%E7%82%B9%E3%81%AB%E4%BF%9D%E6%8C%81%E3%81%95%E3%82%8C%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81lt1%20(32%20%E3%83%93%E3%83%83%E3%83%88%E5%80%A4)%20%E3%82%92%20CAN%20C11%20%E3%81%AB%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%80%81%E3%81%93%E3%82%8C%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E6%AD%A3%E5%BD%93%E5%8C%96%E3%81%95%E3%82%8C%E3%82%8B%E5%A0%B4%E6%89%80%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%820x0340%E3%82%92long%E3%81%AB%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%8B%E3%81%A8%E3%80%81%3CBR%20%2F%3E%3CBR%20%2F%3E%20lt1%200x00000340%3CBR%20%2F%3E%20%3D%200000%200000%200000%200000%200000%200011%20010x%20xxxx%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%83%93%E3%83%83%E3%83%88%E5%B9%85%E3%81%AE%E4%BB%95%E6%A7%98%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E6%AD%A3%E3%81%97%E3%81%8F%E6%95%B4%E5%88%97%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E4%BB%A5%E4%B8%8B%E3%81%AF%E3%82%B3%E3%83%BC%E3%83%89%20%E3%82%B9%E3%83%8B%E3%83%9A%E3%83%83%E3%83%88%E3%81%A7%E3%81%99%E3%80%82%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AF%E7%A7%81%E3%81%AB%E3%81%AF%E6%84%8F%E5%91%B3%E3%81%8C%E5%88%86%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8B%E3%81%A8%E5%8A%A9%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%20%2F%2F*******%20%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%201%20c11x1%3D%20c11%20*%20Padc%3CBR%20%2F%3E%20lt1%20%3D%20(S32)sic11%3B%20%2F%2F%20s(16%2C27)%20s(N%2CF%2Bzeropad)%20%E3%81%AF%20s(11%2C10)%2B11ZeroPad%20%3D%20s(11%2C22)%20%3D%26gt%3B%20%E5%B7%A6%E6%8F%83%E3%81%88%20%3D%20s(16%2C27)%20%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%3CBR%20%2F%3E%3CBR%20%2F%3E-%E8%AB%8B%E6%B1%82%E6%9B%B8%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214630%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214630%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A7%81%E3%81%AF%E3%81%93%E3%82%8C%E3%82%9268hc912b32%E7%94%A8%E3%81%AE%E5%8F%A4%E3%81%84%E3%82%A2%E3%82%BB%E3%83%B3%E3%83%96%E3%83%A9%E3%81%A7%E3%82%B3%E3%83%BC%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%E5%90%84%E4%BF%82%E6%95%B0%E3%81%AF%2032%20%E3%83%93%E3%83%83%E3%83%88%E5%A4%89%E6%95%B0%E3%81%AB%E9%85%8D%E7%BD%AE%E3%81%95%E3%82%8C%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%B3%A8%E6%84%8F%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E6%9C%80%E9%81%A9%E5%8C%96%E3%81%AE%E4%BD%99%E5%9C%B0%E3%81%AF%E7%A2%BA%E3%81%8B%E3%81%AB%E3%81%82%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSTRONG%20style%3D%22%3A%20%3B%20color%3A%20%237f0055%3B%20font-size%3A%2010pt%3B%22%3E%E3%80%82%E5%90%AB%E3%82%80%3C%2FSTRONG%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%232a00ff%3B%20font-size%3A%2010pt%3B%22%3E%E3%80%8C%E3%82%B0%E3%83%AD%E3%83%BC%E3%83%90%E3%83%AB.s%E3%80%8D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232a00ff%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSTRONG%20style%3D%22%3A%20%3B%20color%3A%20%237f0055%3B%20font-size%3A%2010pt%3B%22%3E%E3%80%82%E5%90%AB%E3%82%80%3C%2FSTRONG%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%232a00ff%3B%20font-size%3A%2010pt%3B%22%3E%E3%80%8Chc12.s%E3%80%8D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232a00ff%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010pt%3B%22%3E%3CSTRONG%3Ec12x2%3A%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E.blkb%204%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010pt%3B%22%3E%3CSTRONG%3Ea1%3A%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E.blkb%204%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010pt%3B%22%3E%3CSTRONG%3Ea1x1%3A%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E.blkb%204%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010pt%3B%22%3E%3CSTRONG%3Ey1%3A%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E.blkb%204%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010pt%3B%22%3E%3CSTRONG%3Ea2x2%3A%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E.blkb%204%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010pt%3B%22%3E%3CSTRONG%3EPComp32%3A%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E.blkb%204%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010pt%3B%22%3E%3CSTRONG%3Ebaro_fltr%3A%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E.blkb%203%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010pt%3B%22%3E%3B****************************************************************************************************************************%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20%E4%BF%82%E6%95%B0%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%A6%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%80%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Emovb%20%230b00000000%2Csp0br%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20SPI%E3%82%924MHz%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AB%E8%A8%AD%E5%AE%9A%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010pt%3B%22%3E%3CSTRONG%3Eibaro%3A%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Ebclr%20portb%2C%230b10000000%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20CS%E3%82%92%E4%BD%8E%E3%81%8F%E8%A8%AD%E5%AE%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Emovb%20%23%2488%2Csp0dr%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20a0%20msb%20%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Ebrclr%20sp0sr%2C%23SPIF%2C.%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20SPI%E3%82%92%E5%BE%85%E3%81%A4%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Emovb%20%230%2Csp0dr%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20%E3%83%90%E3%82%A4%E3%83%88%E3%82%92%E3%82%AF%E3%83%AA%E3%82%A2%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Ebrclr%20sp0sr%2C%23SPIF%2C.%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20SPI%E3%82%92%E5%BE%85%E3%81%A4%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Eldaa%20sp0dr%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20a0%20msb%20%E3%82%92%E5%8F%96%E5%BE%97%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Emovb%20%23%248A%2Csp0dr%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20a0%20LSB%20%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Ebrclr%20sp0sr%2C%23SPIF%2C.%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20SPI%E3%82%92%E5%BE%85%E3%81%A4%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Emovb%20%230%2Csp0dr%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20%E3%83%90%E3%82%A4%E3%83%88%E3%82%92%E3%82%AF%E3%83%AA%E3%82%A2%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Ebrclr%20sp0sr%2C%23SPIF%2C.%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20SPI%E3%82%92%E5%BE%85%E3%81%A4%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Eldab%20sp0dr%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20a0%20LSB%20%E3%82%92%E5%8F%96%E5%BE%97%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Estd%20BaroCoa0%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20%E6%B0%97%E5%9C%A7%E4%BF%82%E6%95%B0a0%E3%82%92%E4%BF%9D%E5%AD%98%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Emovb%20%23%248C%2Csp0dr%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20b1%20MSB%20%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Ebrclr%20sp0sr%2C%23SPIF%2C.%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20SPI%E3%82%92%E5%BE%85%E3%81%A4%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Emovb%20%230%2Csp0dr%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20%E3%83%90%E3%82%A4%E3%83%88%E3%82%92%E3%82%AF%E3%83%AA%E3%82%A2%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Ebrclr%20sp0sr%2C%23SPIF%2C.%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20SPI%E3%82%92%E5%BE%85%E3%81%A4%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Eldaa%20sp0dr%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20b1%20MSB%20%E3%82%92%E5%8F%96%E5%BE%97%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Emovb%20%23%248e%2Csp0dr%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20b1%20LSB%20%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Ebrclr%20sp0sr%2C%23SPIF%2C.%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20SPI%E3%82%92%E5%BE%85%E3%81%A4%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Emovb%20%230%2Csp0dr%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20%E3%83%90%E3%82%A4%E3%83%88%E3%82%92%E3%82%AF%E3%83%AA%E3%82%A2%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Ebrclr%20sp0sr%2C%23SPIF%2C.%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20SPI%E3%82%92%E5%BE%85%E3%81%A4%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Eldab%20sp0dr%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20b1%20LSB%20%E3%82%92%E5%8F%96%E5%BE%97%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Estd%20BaroCob1%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20%E5%9C%A7%E5%8A%9B%E4%BF%82%E6%95%B0%20b1%20%E3%82%92%E4%BF%9D%E5%AD%98%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Emovb%20%23%2490%2Csp0dr%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20b2%20msb%20%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Ebrclr%20sp0sr%2C%23SPIF%2C.%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20SPI%E3%82%92%E5%BE%85%E3%81%A4%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Emovb%20%230%2Csp0dr%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20%E3%83%90%E3%82%A4%E3%83%88%E3%82%92%E3%82%AF%E3%83%AA%E3%82%A2%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Ebrclr%20sp0sr%2C%23SPIF%2C.%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20SPI%E3%82%92%E5%BE%85%E3%81%A4%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Eldaa%20sp0dr%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20b2%20msb%20%E3%82%92%E5%8F%96%E5%BE%97%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Emovb%20%23%2492%2Csp0dr%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20b2%20LSB%20%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Ebrclr%20sp0sr%2C%23SPIF%2C.%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20SPI%E3%82%92%E5%BE%85%E3%81%A4%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Emovb%20%230%2Csp0dr%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20%E3%83%90%E3%82%A4%E3%83%88%E3%82%92%E3%82%AF%E3%83%AA%E3%82%A2%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Ebrclr%20sp0sr%2C%23SPIF%2C.%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20SPI%E3%82%92%E5%BE%85%E3%81%A4%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Eldab%20sp0dr%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20b2%20LSB%20%E3%82%92%E5%8F%96%E5%BE%97%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Estd%20BaroCob2%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20%E6%B0%97%E5%9C%A7%E4%BF%82%E6%95%B0%20b2%20%E3%82%92%E4%BF%9D%E5%AD%98%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Emovb%20%23%2494%2Csp0dr%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20c12%20MSB%20%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Ebrclr%20sp0sr%2C%23SPIF%2C.%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20SPI%E3%82%92%E5%BE%85%E3%81%A4%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Emovb%20%230%2Csp0dr%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20%E3%83%90%E3%82%A4%E3%83%88%E3%82%92%E3%82%AF%E3%83%AA%E3%82%A2%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Ebrclr%20sp0sr%2C%23SPIF%2C.%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20SPI%E3%82%92%E5%BE%85%E3%81%A4%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Eldaa%20sp0dr%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20c12%20MSB%20%E3%82%92%E5%8F%96%E5%BE%97%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Emovb%20%23%2496%2Csp0dr%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20c12%20LSB%20%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Ebrclr%20sp0sr%2C%23SPIF%2C.%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20SPI%E3%82%92%E5%BE%85%E3%81%A4%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Emovb%20%230%2Csp0dr%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20%E3%83%90%E3%82%A4%E3%83%88%E3%82%92%E3%82%AF%E3%83%AA%E3%82%A2%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Ebrclr%20sp0sr%2C%23SPIF%2C.%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20SPI%E3%82%92%E5%BE%85%E3%81%A4%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Eldab%20sp0dr%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20c12%20LSB%20%E3%82%92%E5%8F%96%E5%BE%97%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Emovb%20%230%2Csp0dr%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20%E8%BF%BD%E5%8A%A0%E3%81%AE%E3%82%AF%E3%83%AA%E3%82%A2%E3%83%90%E3%82%A4%E3%83%88%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Ebrclr%20sp0sr%2C%23SPIF%2C.%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20SPI%E3%82%92%E5%BE%85%E3%81%A4%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Ebset%20portb%2C%230b10000000%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20CS%E3%82%92hi%E3%81%AB%E8%A8%AD%E5%AE%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Estd%20BaroCoc12%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20%E5%9C%A7%E5%8A%9B%E4%BF%82%E6%95%B0%20c12%20%E3%82%92%E4%BF%9D%E5%AD%98%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3Erts%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010pt%3B%22%3E%3CSTRONG%3E%E3%82%B3%E3%83%B3%E3%83%97%E3%83%90%E3%83%AD%3A%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3A%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Eemuls%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3BY%3AD%E3%81%AE%E7%B5%90%E6%9E%9C%E3%81%AF11%E3%83%93%E3%83%83%E3%83%88%E3%82%B7%E3%83%95%E3%83%88%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%E3%81%BE%E3%81%9F%E3%81%AF%202%5E11%20%E3%81%A7%E5%89%B2%E3%82%8B%E3%81%A8%202048%20%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Eldx%20%232048%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20****%3C%2FSPAN%3E%20%3CSTRONG%20style%3D%22%3A%20%3B%20color%3A%20%237f9fbf%3B%20font-size%3A%2010pt%3B%22%3ETODO%3C%2FSTRONG%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E3%81%BE%E3%81%9F%E3%81%AF%203%20%E3%82%B7%E3%83%95%E3%83%88%E3%81%97%E3%81%A6%E3%81%8B%E3%82%89%E4%B8%AD%E9%96%93%E3%83%90%E3%82%A4%E3%83%88%E3%81%8B%E3%82%89%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20%E6%AE%8B%E3%82%8A%E3%81%AE%208%20%E3%83%93%E3%83%83%E3%83%88%E3%82%92%E5%AE%9F%E7%8F%BE%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Esty%20c12x2%2B2%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%2016%E3%83%93%E3%83%83%E3%83%88%E3%81%A8%E3%81%97%E3%81%A6%E3%81%AE%E3%81%BF%E4%BF%9D%E5%AD%98%20****%20%3B%2F%20*%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Eadca%20a1%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%E7%AC%A6%E5%8F%B7%E3%83%93%E3%83%83%E3%83%88%E3%82%92%E4%BF%9D%E6%8C%81%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Eldd%20a1%2B2%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%E4%B8%8B%E4%BD%8D16%E3%83%93%E3%83%83%E3%83%88%E3%82%92%E5%8F%96%E5%BE%97%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Eror%20PComp32%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B1%E3%83%93%E3%83%83%E3%83%88%E3%82%B7%E3%83%95%E3%83%88%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%E6%9C%80%E9%AB%98%E3%81%AE%E8%A7%A3%E5%83%8F%E5%BA%A6%E3%82%92%E5%BE%97%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%93%E3%82%8C%E3%82%92%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%3C%2FSPAN%3E%3CSTRONG%20style%3D%22%3A%20%3B%20color%3A%20%237f9fbf%3B%20font-size%3A%2010pt%3B%22%3E%20%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Eldd%20PComp32%2B1%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20%E4%B8%AD%E9%96%93%E3%83%90%E3%82%A4%E3%83%88%E3%82%928%E3%83%93%E3%83%83%E3%83%88%E3%82%B7%E3%83%95%E3%83%88%E3%81%97%E3%81%A6%E5%8F%96%E5%BE%97%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Eldx%20%2316394%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%201023...%20%E3%82%92%2016%20%E5%80%8D%E3%81%97%E3%81%A6%E4%BA%8C%E9%80%B2%E5%B0%8F%E6%95%B0%E3%81%AB%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%E3%83%8E%E3%82%A4%E3%82%BA%E3%82%92%E6%BB%91%E3%82%89%E3%81%8B%E3%81%AB%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B915%E3%81%AEIRR%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Esubd%20AmbBaro%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20%E6%9C%80%E5%BE%8C%E3%81%AB%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%95%E3%82%8C%E3%81%9FBaro%E5%80%A4%E3%82%92%E6%B8%9B%E7%AE%97%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Epsha%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20%E3%82%B5%E3%82%A4%E3%83%B3%E3%82%92%E4%BF%9D%E5%AD%98%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Eaddd%20baro_fltr%2B1%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20%E3%82%A2%E3%82%AD%E3%83%A5%E3%83%A0%E3%83%AC%E3%83%BC%E3%82%BF%20lsword%20%E3%82%92%E8%BF%BD%E5%8A%A0%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Estd%20baro_fltr%2B1%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20%E6%9B%B4%E6%96%B0%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Epubb%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20msbyte%20%E5%B7%AE%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Etfr%20b%2Cd%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20%E7%AC%A6%E5%8F%B7%E3%82%92acca%E3%81%AB%E6%8B%A1%E5%BC%B5%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Eadca%20baro_fltr%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20msbyte%20%E3%82%A2%E3%82%AD%E3%83%A5%E3%83%A0%E3%83%AC%E3%83%BC%E3%82%BF%E3%81%AB%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%BC%E4%BB%98%E3%81%8D%E3%81%A7%E5%8A%A0%E7%AE%97%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Estaa%20baro_fltr%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20%E6%9B%B4%E6%96%B0%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Eldd%20baro_fltr%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20IIR%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%95%E3%82%8C%E3%81%9F%E7%B5%90%E6%9E%9C%E3%82%92msword%E3%81%A7%E8%BF%94%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Epshd%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E4%B8%8A%E3%81%AE%E4%B8%80%E6%99%82%E9%A0%98%E5%9F%9F%E3%81%B8%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Eldab%20baro_fltr%2B2%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20%E5%B7%A6%E3%82%B7%E3%83%95%E3%83%88%E7%94%A8%E3%81%AElsbyte%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Eldaa%20%2315%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%83%BC%E5%88%B6%E5%BE%A1%E3%80%810%20%3D%20%E6%9C%80%E5%B0%8F%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%83%BC%E3%80%8115%20%3D%20%E6%9C%80%E5%A4%A7%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%83%BC%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20%E6%B8%9B%E5%88%86%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E3%83%93%E3%83%83%E3%83%88%E3%82%92%E5%8F%8D%E8%BB%A2%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Eeora%20%23%24F%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20***%20%E3%81%93%E3%82%8C%E3%81%A7%E5%8D%81%E5%88%86%E3%81%A7%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AFHiger%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%8C%E5%B0%91%E3%81%AA%E3%81%84%20%3D%26gt%3B%20%E3%82%B7%E3%83%95%E3%83%88%E3%81%8C%E5%A4%9A%E3%81%84%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010pt%3B%22%3E%3CSTRONG%3Ebfc1%3A%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Ebeq%20bfc2%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%83%AA%E3%83%B3%E3%82%B0%E3%82%92%E6%B8%9B%E3%82%89%E3%81%99%E3%81%9F%E3%82%81%E3%81%AE%E3%82%B7%E3%83%95%E3%83%88%E3%83%AB%E3%83%BC%E3%83%97%E3%82%92%E9%96%8B%E5%A7%8B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Elslb%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20lsbyte%20%E3%82%92%E5%B7%A6%E3%82%B7%E3%83%95%E3%83%88%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%E3%83%AD%E3%83%BC%E3%83%AB1%2Cs%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20%E6%BF%BE%E9%81%8E%E5%9C%A7%E5%8A%9B%E3%81%B8%E3%81%AE%E7%A7%BB%E8%A1%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%E3%83%AD%E3%83%BC%E3%83%AB%E3%80%81s%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20%E3%83%9F%E3%83%AA%E7%A7%92%E3%83%90%E3%82%A4%E3%83%88%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Edeca%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20%E3%83%93%E3%83%83%E3%83%884%E3%82%92%E6%B8%9B%E7%AE%97%E3%81%97%E3%81%A6%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%82%92%E3%82%B7%E3%83%95%E3%83%88%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%E3%83%96%E3%83%A9%E3%82%B8%E3%83%A3%E3%83%BC%20bfc1%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20%E7%B9%B0%E3%82%8A%E8%BF%94%E3%81%97%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010pt%3B%22%3E%3CSTRONG%3Ebfc2%3A%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Epuld%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20%E7%B5%90%E6%9E%9C%E3%82%92%E5%8F%96%E5%BE%97%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Estd%20AmbBaro%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%E7%B5%90%E6%9E%9C%EF%BC%88kPa%EF%BC%89%3D%20mBar*10%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E3%82%B8%E3%83%A3%E3%83%83%E3%82%AF%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214629%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214629%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%81%E3%83%88%E3%83%BC%E3%83%9E%E3%82%B9%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%88%86%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EDave%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214628%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Re%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214628%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%87%E3%82%A4%E3%83%96%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ESR%201-1348149811%20%E3%81%A7%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9A%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%81%AE%205%20%E3%83%9A%E3%83%BC%E3%82%B8%E3%81%AB%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%81c12_LSB%20%E3%81%AE%E6%9C%80%E5%BE%8C%E3%81%AE%202%20%E3%83%93%E3%83%83%E3%83%88%E3%81%8C%E3%82%BC%E3%83%AD%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E8%80%83%E6%85%AE%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ec12%20MSB%E3%83%90%E3%82%A4%E3%83%88%20%3D%20c12%5B13%3A6%5D%20%3D%20%5Bb13%E3%80%81b12%E3%80%81b11%E3%80%81b10%E3%80%81b9%E3%80%81b8%E3%80%81b7%E3%80%81b6%5D%3C%2FP%3E%3CP%3Ec12%20LSB%E3%83%90%E3%82%A4%E3%83%88%20%3D%20c12%5B5%3A0%5D%20%26amp%3B%20%E2%80%9C00%E2%80%9D%20%3D%20%5Bb5%E3%80%81b4%E3%80%81b3%E3%80%81b2%E3%80%81b1%E3%80%81b0%E3%80%810%E3%80%810%5D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81c12%20%E4%BF%82%E6%95%B0%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ec12%20%3D%20b13%200%20.000%20000%20000%20b12%20b11%20b10%20b9%20b8%20b7%20b6%20b5%20b4%20b3%20b2%20b1%20b0%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81%E5%90%84%E5%B0%8F%E6%95%B0%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E5%80%A4%E3%81%AF%201%20%2F%202%20%3CSPAN%20lang%3D%22CS%22%3E%5E(9%2B13)%20%E3%81%A8%E3%81%AA%E3%82%8A%E3%80%8116%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%20c12%20%E5%80%A4%E3%82%92%E6%9C%80%E5%88%9D%E3%81%AB%202%20%E5%8F%B3%E3%82%B7%E3%83%95%E3%83%88%20(%E3%81%BE%E3%81%9F%E3%81%AF%204%20%E3%81%A7%E5%89%B2%E3%82%8B)%20%E3%81%97%E3%81%A6%2013%20%E5%80%8B%E3%81%AE%E5%B0%8F%E6%95%B0%E3%83%93%E3%83%83%E3%83%88%E3%82%92%E5%8F%96%E5%BE%97%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22CS%22%3E%E3%81%93%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%AF%E3%80%8116%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%20c12%20%3D%200x33C8%20%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22CS%22%3E%E3%81%9D%E3%81%97%E3%81%A6%20c12%20%26gt%3B%26gt%3B%202%20%3D%200x33C8%20%26gt%3B%26gt%3B%202%20%3D%200xCF2%20%3D%203314%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22CS%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22CS%22%3E%E3%81%9D%E3%81%97%E3%81%A6c12%E4%BF%82%E6%95%B0%20%3D%203314%20%2F%202%5E22%20%3D%200.00079%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22CS%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22CS%22%3E%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22CS%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22CS%22%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22CS%22%3E%E3%83%88%E3%83%BC%E3%83%9E%E3%82%B9%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214627%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214627%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%82%E3%81%82%E3%80%81%E3%81%94%E3%82%81%E3%82%93%E3%81%AA%E3%81%95%E3%81%84%E3%80%822%20%E3%81%A4%E3%81%AE%20LSB%20%E3%81%8C%E3%82%BC%E3%83%AD%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%81%A6%200.000790%20%E3%81%8C%E5%BE%97%E3%82%89%E3%82%8C%E3%82%8B%E3%81%AE%E3%81%8B%E3%81%AF%E3%81%BE%E3%81%A0%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ed.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214626%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214626%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%82%E3%81%82%E3%80%81%E3%81%93%E3%81%AEThread%E3%81%8C%E4%BD%95%E5%B9%B4%E3%82%82%E5%89%8D%E3%81%AE%E3%82%82%E3%81%AE%E3%81%A0%E3%81%A8%E3%81%84%E3%81%86%E3%81%93%E3%81%A8%E3%81%AF%E3%82%8F%E3%81%8B%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E7%A7%81%E3%81%AF%E9%88%8D%E6%84%9F%E3%81%AA%E3%82%93%E3%81%A7%E3%81%99%E3%80%82Bill%20%E3%81%AE%E5%85%83%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%AF%20c12%20%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A7%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%81%AB%E3%81%AF%2011%20%E5%80%8B%E3%81%AE%E3%83%91%E3%83%83%E3%83%89%E3%81%AE%E3%82%BC%E3%83%AD%E3%81%8C%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E8%BF%B0%E3%81%B9%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%81%AB%E3%81%AF%209%20%E5%80%8B%E3%81%AE%E3%82%BC%E3%83%AD%E3%83%91%E3%83%83%E3%83%89%E3%81%A8%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81c12%20%E3%81%AE%E5%80%A4%E3%81%8C%200x33C8%20%E3%81%A7%E3%81%82%E3%82%8B%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%81%A7%E8%BF%B7%E3%81%A3%E3%81%A6%E3%81%97%E3%81%BE%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%9D%E3%81%93%E3%81%8B%E3%82%89%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%81%A6%200.000790%20%E3%81%A8%E3%81%84%E3%81%86%E5%80%A4%E3%81%8C%E5%BE%97%E3%82%89%E3%82%8C%E3%82%8B%E3%81%AE%E3%81%8B%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82F12%20-%20F0%20%E3%81%AB%209%20%E5%80%8B%E3%81%AE%E3%82%BC%E3%83%AD%E3%82%92%E5%9F%8B%E3%82%81%E8%BE%BC%E3%82%80%E3%81%A8%E3%80%810000000001001%20%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81%E6%9C%80%E5%88%9D%E3%81%AE%201%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AF%202%5E%5E-10%E3%80%81%E3%81%A4%E3%81%BE%E3%82%8A%200.0009xxx%20%E3%81%A8%E3%81%AA%E3%82%8A%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E3%81%99%E3%81%A7%E3%81%AB%200.000790%20%E3%82%88%E3%82%8A%E3%82%82%E5%A4%A7%E3%81%8D%E3%81%84%E3%81%93%E3%81%A8%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E8%AA%B0%E3%81%8B%E7%A7%81%E3%81%AB%E4%BD%95%E3%81%8B%E6%84%8F%E8%A6%8B%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ed.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214625%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214625%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Ec12%E3%81%AE%E4%BF%82%E6%95%B0%E3%82%92%E5%A4%89%E6%8F%9B%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EMSB%20c12%20%3D%2000110000%3C%2FP%3E%3CP%3ELSB%20c12%20%3D%20101011xx%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%BF%82%E6%95%B0%20c12%20%3DS0%2C%20000000000%2000%20110000101011xx%20%3D%202%5E-10%20%2B%202%5E-11%20%2B%202%5E-16%20%2B%202%5E-18%20%2B%202%5E-20%20%2B%202%5E-21%20%3D%200%2C001485%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%9D%E3%81%86%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%26nbsp%3B%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214624%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214624%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CBR%20%2F%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%9E%E3%83%9E%E3%81%95%E3%82%93%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%95%8F%E9%A1%8C%E3%81%AF%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%EF%BC%9F%E7%A7%81%E3%82%82%E5%90%8C%E6%A7%98%E3%81%AE%E7%B5%90%E6%9E%9C%E3%81%8C%E5%BE%97%E3%82%89%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E8%B2%A0%E5%9C%A7%E3%81%8A%E3%82%88%E3%81%B3PADC%E3%81%AE%E5%80%A4%20%3D%20990%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%95%AC%E5%85%B7%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214623%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214623%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%94%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%95%E3%82%93%E3%80%81C12%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%A8%88%E7%AE%97%E3%81%97%E3%81%9F%E3%81%8B%E3%82%92%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82AN3785%20%E3%81%A7%E3%81%AF%E3%80%81dec%20pt%20zero%20pad%3D9%20%E3%81%A8%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82SO%E3%80%81%E3%80%8C.%E3%80%8D%E3%81%AE%E5%BE%8C%E3%81%AB%E3%80%8C0%E3%80%8D%E3%81%8C9%E3%81%A4%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%86%E3%81%99%E3%82%8B%E3%81%A8%E6%BA%80%E8%B6%B3%E3%81%A7%E3%81%8D%E3%82%8B%E7%B5%90%E6%9E%9C%E3%81%8C%E5%BE%97%E3%82%89%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E4%BB%96%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E5%80%A4%E3%82%82%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%82%82%E3%81%AE%E3%81%A8%E3%81%BB%E3%81%BC%E5%90%8C%E3%81%98%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%94%E5%9B%9E%E7%AD%94%E3%82%92%E3%81%8A%E5%BE%85%E3%81%A1%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EMichael%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214622%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214622%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%82%B2%E3%83%BC%E3%83%A0%E3%81%AF%E5%88%9D%E5%BF%83%E8%80%85%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E5%AD%A6%E3%81%B6%E6%84%8F%E6%AC%B2%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%82%B3%E3%83%BC%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E4%BE%8B%E3%82%92%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82VB%20%E3%81%AB%E6%AD%A3%E3%81%97%E3%81%8F%E5%A4%89%E6%8F%9B%E3%81%A7%E3%81%8D%E3%81%9F%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%82%8B%E7%94%9F%E3%83%87%E3%83%BC%E3%82%BF%E3%81%A8%E7%B5%90%E6%9E%9C%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%81%AE%E3%81%AF%3A%3C%2FP%3E%3CP%3E%E3%83%91%E3%83%89%E3%83%83%E3%82%AF%2064%20C0%3C%2FP%3E%3CP%3E%E3%82%BF%E3%83%89%E3%83%83%E3%82%AF%2075%2080%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EA0%20-%203D%209B%3C%2FP%3E%3CP%3EB1%20-%20B9%204A%3C%2FP%3E%3CP%3EB2%20-%20C7%2046%3C%2FP%3E%3CP%3E%E7%B4%80%E5%85%83%E5%89%8D12%EF%BD%9E32%E5%B9%B4%3C%2FP%3E%3CP%3EC11%20-%2002%2020%3C%2FP%3E%3CP%3EC22%20-%20FD60%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E7%A7%81%E3%81%AE%E7%B5%90%E6%9E%9C%E3%81%AF105.13476438%E3%81%A7%E3%81%97%E3%81%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214621%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214621%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A8%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%92%E8%A9%A6%E3%81%BF%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8B%E3%82%89%E5%8F%96%E5%BE%97%E3%81%97%E3%81%9F%E4%BF%82%E6%95%B0%E3%81%A8%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E5%80%A4%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3Ea0%3A3b99%20b1%3Affffb8b9%20b2%3Affffc24d%20c12%3A3274%20c11%3A0%20c22%3A0%20Padc%3A157%20Tadc%3A1f5%3C%2FP%3E%3CP%3EPadc%3A343%20Tadc%3A501%3C%2FP%3E%3CP%3E%E6%B8%A9%E5%BA%A6%3A%2026.536017%E2%84%83%3C%2FP%3E%3CP%3E%E5%9C%A7%E5%8A%9B%3A%2051.450000%20kPa%3C%2FP%3E%3CP%3E%E8%A3%9C%E6%AD%A3%E5%9C%A7%E5%8A%9B%3A%2091.935486%20kPA%20%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A9%E3%83%A0%E3%81%AE%E5%89%8D%E5%8D%8A%E3%81%A7%E4%BF%82%E6%95%B0%E3%81%8B%E3%82%89%E6%B5%AE%E5%8B%95%E5%B0%8F%E6%95%B0%E7%82%B9%E9%96%A2%E6%95%B0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E6%AC%A1%E3%81%AE%E5%80%A4%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3Ea0_d%3A1906.250000%3C%2FP%3E%3CP%3Eb1_d%3A-2.056824%3C%2FP%3E%3CP%3Eb2_d%3A-0.240997%3C%2FP%3E%3CP%3Ec12_d%3A0.000192%3C%2FP%3E%3CP%3Ec11_d%3A0.000000%3C%2FP%3E%3CP%3Ec22_d%3A0.000000%3C%2FP%3E%3CP%3E%E5%9C%A7%E5%8A%9B_d%3A%20120.723752%20kPa%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%20double%20%E5%80%A4%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%80%81%E6%AC%A1%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E8%A8%88%E7%AE%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EPcomp%20%3D%20a0_D%20%2B%20(b1_D%20%2B%20c11_D*Padc%20%2B%20c12_D*Tadc)*Padc%20%2B%20(b2_D%20%2B%20c22_D*Tadc)*Tadc%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81(65.0%2F1023.0*Pcomp%2B%2050%E3%80%81Pressure_d%20%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%A9%E3%81%A1%E3%82%89%E3%82%82%E7%A7%81%E3%81%8C%E4%BA%88%E6%83%B3%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%20101%20kPa%20%E3%81%A8%E4%B8%80%E8%87%B4%E3%81%97%E3%81%AA%E3%81%84%E3%81%AE%E3%81%A7%E3%80%81%E4%BD%95%E3%81%8B%E7%89%B9%E5%88%A5%E3%81%AA%E3%81%93%E3%81%A8%E3%82%92%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%81%A3%E3%81%9F%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%E3%80%82%E3%81%95%E3%82%89%E3%81%AB%E6%B7%B7%E4%B9%B1%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%AF%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E6%95%B0%E5%80%A4%E3%81%8C%E7%95%B0%E3%81%AA%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%E6%9C%80%E5%88%9D%E3%81%AE%E8%A3%9C%E6%AD%A3%E5%9C%A7%E5%8A%9B%E5%80%A4%E3%81%AF%E3%80%81%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20%E3%83%8E%E3%83%BC%E3%83%88%20%E3%82%B7%E3%83%BC%E3%83%88%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E8%A8%88%E7%AE%97%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214620%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214620%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%AF%E3%81%84%E3%80%81%E3%82%88%E3%81%86%E3%82%84%E3%81%8F%E5%95%8F%E9%A1%8C%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%95%8F%E9%A1%8C%E3%81%AF%E3%83%87%E3%83%BC%E3%82%BF%E5%9E%8B%20int%20%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%8C%E8%A8%80%E3%81%84%E3%81%9F%E3%81%84%E3%81%AE%E3%81%AF%E3%80%81(gcc%E3%80%81borland%20c%20%E3%81%AA%E3%81%A9%E3%81%A8%E5%90%8C%E6%A7%98%E3%81%AB)%2016%20%E3%83%93%E3%83%83%E3%83%88%E3%81%82%E3%82%8B%E3%81%A8%E3%81%84%E3%81%86%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E5%AE%9F%E9%9A%9B%E3%81%AF%2032%20%E3%83%93%E3%83%83%E3%83%88%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81%E8%B2%A0%E3%81%AE%E6%95%B0%E3%81%AF%E8%B2%A0%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93...%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%81%AF%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%20int%20%E3%82%92%20short%20%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%20(%E5%B0%91%E3%81%AA%E3%81%8F%E3%81%A8%E3%82%82%20CW%206.3%20%E3%81%A7%E3%81%AF)%E3%80%82%3CIMG%20alt%3D%22%3Asmileysad%3A%22%20class%3D%22emoticon%20emoticon-smileysad%22%20id%3D%22smileysad%22%20src%3D%22http%3A%2F%2Ffreescale.i.lithium.com%2Fi%2Fsmilies%2F16x16_smiley-sad.gif%22%20title%3D%22%E3%82%B9%E3%83%9E%E3%82%A4%E3%83%AA%E3%83%BC%E3%82%B5%E3%83%83%E3%83%89%22%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214619%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214619%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%8F%E3%82%A4%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%93%E3%81%AE%E6%95%B0%E5%AD%A6%E3%81%AE%E8%AC%8E%E3%82%92%E8%A7%A3%E3%81%84%E3%81%9F%E4%BA%BA%E3%81%AF%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E6%9C%80%E7%B5%82%E7%9A%84%E3%81%AB%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%81%8B%E3%82%89%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%82%A2%E3%83%97%E3%83%AA%E3%81%AB%E8%A8%98%E8%BF%B0%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E8%A8%88%E7%AE%97%E3%82%92%E9%80%9A%E9%81%8E%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%8217%EF%BD%9E18%E3%83%9A%E3%83%BC%E3%82%B8%E3%81%AE%E6%B3%A8%E8%A8%98%E3%80%82siPcomp%20%E3%81%A7%E3%81%AF%E7%B4%84%205726%20%E3%81%8C%E5%BE%97%E3%82%89%E3%82%8C%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%201023%20%E3%82%88%E3%82%8A%E3%82%82%E5%A4%A7%E5%B9%85%E3%81%AB%E5%A4%A7%E3%81%8D%E3%81%84%E3%81%A7%E3%81%99...%3C%2FP%3E%3CP%3E%E4%BF%82%E6%95%B0%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%A7%E3%81%99%EF%BC%88%E6%83%85%E5%A0%B1%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E3%83%95%E3%83%AD%E3%83%BC%E3%83%88%E5%87%A6%E7%90%86%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%EF%BC%9A%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20monospace%3B%20font-size%3A%208.33333px%3B%20white-space%3A%20pre-wrap%3B%22%3EA0%20%E7%B5%90%E6%9E%9C%20%3D%202101%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20monospace%3B%20font-size%3A%208.33333px%3B%20white-space%3A%20pre-wrap%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20monospace%3B%20font-size%3A%208.33333px%3B%20white-space%3A%20pre-wrap%3B%22%3EB1%20%E7%B5%90%E6%9E%9C%20%3D%20-2.4163818359375%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20monospace%3B%20font-size%3A%208.33333px%3B%20white-space%3A%20pre-wrap%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20monospace%3B%20font-size%3A%208.33333px%3B%20white-space%3A%20pre-wrap%3B%22%3EB2%20%E7%B5%90%E6%9E%9C%20%3D%20-1.2173461914062%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20monospace%3B%20font-size%3A%208.33333px%3B%20white-space%3A%20pre-wrap%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20monospace%3B%20font-size%3A%208.33333px%3B%20white-space%3A%20pre-wrap%3B%22%3EC12%20%E7%B5%90%E6%9E%9C%20%3D%200.00083708763122559%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20monospace%3B%20font-size%3A%208.33333px%3B%20white-space%3A%20pre-wrap%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20monospace%3B%20font-size%3A%208.33333px%3B%20white-space%3A%20pre-wrap%3B%22%3EC11%20%E7%B5%90%E6%9E%9C%20%3D%200%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20monospace%3B%20font-size%3A%208.33333px%3B%20white-space%3A%20pre-wrap%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20monospace%3B%20font-size%3A%208.33333px%3B%20white-space%3A%20pre-wrap%3B%22%3EC22%20%E7%B5%90%E6%9E%9C%20%3D%200%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E3%82%A2%E3%83%97%E3%83%AA%E3%81%8B%E3%82%89%E3%81%9D%E3%81%AE%E3%81%BE%E3%81%BE%E3%82%B3%E3%83%94%E3%83%BC%EF%BC%86%E3%83%9A%E3%83%BC%E3%82%B9%E3%83%88%E3%81%97%E3%81%9F%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99%E3%80%82%E6%B3%A8%E6%84%8F%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%81%E3%81%97%E3%81%8B%E3%81%97%E7%B5%90%E6%9E%9C%E3%81%AF%E5%AE%8C%E5%85%A8%E3%81%AB%E7%8B%82%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%82%B3%E3%83%BC%E3%83%89%E3%82%B9%E3%83%8B%E3%83%9A%E3%83%83%E3%83%88%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E4%BA%BA%E3%81%AF%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E7%A7%81%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AF%E3%81%93%E3%81%93%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%EF%BC%88%E5%9C%A7%E5%8A%9B%E3%80%81%E6%B8%A9%E5%BA%A6%E3%80%81%E4%BF%82%E6%95%B0%EF%BC%89%EF%BC%9A%20%3CSPAN%20style%3D%22font-family%3A%20monospace%3B%20font-size%3A%208.33333px%3B%20white-space%3A%20pre-wrap%3B%22%3E5B%2040%2081%2080%2041%20A8%20B2%20AD%20B2%2017%2036%20DC%2000%2000%2000%2000%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%3A%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CPRE%20translate%3D%22no%22%3E%3CSTRONG%3Eunsigned%20char%20mpl115a_raw_data%5B16%5D%3Bunsigned%20int%20mpl115a_p%3Bunsigned%20int%20mpl115a_t%3Bsigned%20int%20mpl115a_a0%3Bsigned%20int%20mpl115a_b1%3Bsigned%20int%20mpl115a_b2%3Bsigned%20int%20mpl115a_c12%3Bsigned%20int%20mpl115a_c11%3Bsigned%20int%20mpl115a_c22%3B%3C%2FSTRONG%3E%2F%2F%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%2F%2F%20MPL115A%20Placing%20Coefficients%20into%2016%20bit%20variables%2F%2F%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3CSTRONG%3Evoid%20mpl115a_raw_dissection(void)%7B%20mpl115a_p%20%3D%20(unsigned%20int)mpl115a_raw_data%5B0%5D%20%26lt%3B%26lt%3B8%3B%20mpl115a_p%20%2B%3D%20(unsigned%20int)mpl115a_raw_data%5B1%5D%20%26amp%3B%200x00FF%3B%20%20mpl115a_t%20%3D%20(unsigned%20int)mpl115a_raw_data%5B2%5D%20%26lt%3B%26lt%3B8%3B%20mpl115a_t%20%2B%3D%20(unsigned%20int)mpl115a_raw_data%5B3%5D%20%26amp%3B%200x00FF%3B%20%20mpl115a_a0%20%3D%20(signed%20int)mpl115a_raw_data%5B4%5D%20%26lt%3B%26lt%3B8%3B%20mpl115a_a0%20%2B%3D%20(signed%20int)mpl115a_raw_data%5B5%5D%20%26amp%3B%200x00FF%3B%20%20mpl115a_b1%20%3D%20(signed%20int)mpl115a_raw_data%5B6%5D%20%26lt%3B%26lt%3B8%3B%20mpl115a_b1%20%2B%3D%20(signed%20int)mpl115a_raw_data%5B7%5D%20%26amp%3B%200x00FF%3B%20%20mpl115a_b2%20%3D%20(signed%20int)mpl115a_raw_data%5B8%5D%20%26lt%3B%26lt%3B8%3B%20mpl115a_b2%20%2B%3D%20(signed%20int)mpl115a_raw_data%5B9%5D%20%26amp%3B%200x00FF%3B%20%20mpl115a_c12%20%3D%20(signed%20int)mpl115a_raw_data%5B10%5D%20%26lt%3B%26lt%3B8%3B%20mpl115a_c12%20%2B%3D%20(signed%20int)mpl115a_raw_data%5B11%5D%20%26amp%3B%200x00FF%3B%20%20mpl115a_c11%20%3D%20(signed%20int)mpl115a_raw_data%5B12%5D%20%26lt%3B%26lt%3B8%3B%20mpl115a_c11%20%2B%3D%20(signed%20int)mpl115a_raw_data%5B13%5D%20%26amp%3B%200x00FF%3B%20%20mpl115a_c22%20%3D%20(signed%20int)mpl115a_raw_data%5B14%5D%20%26lt%3B%26lt%3B8%3B%20mpl115a_c22%20%2B%3D%20(signed%20int)mpl115a_raw_data%5B15%5D%20%26amp%3B%200x00FF%3B%7D%3C%2FSTRONG%3E%2F%2F%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%2F%2FCoefficient%209%20equation%20compensation%2F%2F%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3CSTRONG%3Eunsigned%20long%20mpl115a_compensated_pressure(void)%7B%3C%2FSTRONG%3E%20%2F%2FVariable%20used%20to%20do%20large%20calculation%20as%203%20temp%20variables%20in%20the%20process%20below%20%3CSTRONG%3Esigned%20long%20lt1%2C%20lt2%2C%20lt3%2C%20si_c11x1%2C%20si_a11%2C%20si_c12x2%2C%20si_a1%2C%20si_c22x2%2C%20si_a2%2C%20si_a1x1%2C%20si_y1%2C%20si_a2x2%3B%3B%3C%2FSTRONG%3E%20%20%2F%2FVariables%20used%20for%20Pressure%20and%20Temperature%20Raw.%20%3CSTRONG%3Eunsigned%20int%20uiPadc%2C%20uiTadc%3B%20%20signed%20int%20siPcomp%3B%20unsigned%20long%20decPcomp%3B%20%20%20uiPadc%20%3D%20mpl115a_p%20%26gt%3B%26gt%3B%206%3B%20uiTadc%20%3D%20mpl115a_t%20%26gt%3B%26gt%3B%206%3B%3C%2FSTRONG%3E%20%2F%2F*******%20STEP%201%20c11x1%3D%20c11%20*%20Padc%20%3CSTRONG%3Elt1%20%3D%20(signed%20long)%20mpl115a_c11%3B%20lt2%20%3D%20(signed%20long)%20uiPadc%3B%20lt3%20%3D%20lt1%20*%20lt2%3B%20si_c11x1%20%3D%20(signed%20long)%20lt3%3B%3C%2FSTRONG%3E%20%20%2F%2F*******%20STEP%202%20a11%3D%20b1%20%2B%20c11x1%20%3CSTRONG%3Elt1%20%3D%20((signed%20long)%20mpl115a_b1)%20%26lt%3B%26lt%3B%2014%3B%20lt2%20%3D%20(signed%20long)%20si_c11x1%3B%20lt3%20%3D%20lt1%20%2B%20lt2%3B%20si_a11%20%3D%20(signed%20long)%20(lt3%20%26gt%3B%26gt%3B%2014)%3B%3C%2FSTRONG%3E%20%20%20%2F%2F*******%20STEP%203%20c12x2%3D%20c12%20*%20Tadc%20%3CSTRONG%3Elt1%20%3D%20(signed%20long)%20mpl115a_c12%3B%20lt2%20%3D%20(signed%20long)%20uiTadc%3B%20lt3%20%3D%20lt1%20*%20lt2%3B%20si_c12x2%20%3D%20(signed%20long)%20lt3%3B%3C%2FSTRONG%3E%20%2F%2F*******%20STEP%204%20a1%3D%20a11%20%2B%20c12x2%20%3CSTRONG%3Elt1%20%3D%20((signed%20long)%20si_a11)%20%26lt%3B%26lt%3B%2011%3B%20lt2%20%3D%20(signed%20long)%20si_c12x2%3B%20lt3%20%3D%20lt1%20%2B%20lt2%3B%20si_a1%20%3D(signed%20long)%20(lt3%20%26gt%3B%26gt%3B%2011)%3B%3C%2FSTRONG%3E%20%2F%2F*******%20STEP%205%20c22x2%3D%20c22%20*%20Tadc%20%3CSTRONG%3Elt1%20%3D%20(signed%20long)%20mpl115a_c22%3B%20lt2%20%3D%20(signed%20long)%20uiTadc%3B%20lt3%20%3D%20lt1%20*%20lt2%3B%20si_c22x2%20%3D%20(signed%20long)%20lt3%3B%3C%2FSTRONG%3E%20%2F%2F*******%20STEP%206%20a2%3D%20b2%20%2B%20c22x2%20%3CSTRONG%3Elt1%20%3D%20((signed%20long)%20mpl115a_b2)%20%26lt%3B%26lt%3B%2015%3B%20lt2%20%3D%20((signed%20long)%20si_c22x2)%20%26gt%3B%26gt%3B%201%3B%20lt3%20%3D%20lt1%20%2B%20lt2%3B%20si_a2%20%3D%20((signed%20long)lt3)%20%26gt%3B%26gt%3B%2016%3B%3C%2FSTRONG%3E%20%2F%2F*******%20STEP%207%20a1x1%3D%20a1%20*%20Padc%20%3CSTRONG%3Elt1%20%3D%20(signed%20long)%20si_a1%3B%20lt2%20%3D%20(signed%20long)%20uiPadc%3B%20lt3%20%3D%20lt1%20*%20lt2%3B%20si_a1x1%20%3D%20(signed%20long)%20lt3%3B%3C%2FSTRONG%3E%20%2F%2F*******%20STEP%208%20y1%3D%20a0%20%2B%20a1x1%20%3CSTRONG%3Elt1%20%3D%20((signed%20long)%20mpl115a_a0)%20%26lt%3B%26lt%3B%2010%3B%20lt2%20%3D%20(signed%20long)%20si_a1x1%3B%20lt3%20%3D%20lt1%20%2B%20lt2%3B%20si_y1%20%3D%20((signed%20long)lt3)%20%26gt%3B%26gt%3B%2010%3B%3C%2FSTRONG%3E%20%2F%2F*******%20STEP%209%20a2x2%3D%20a2%20*Tadc%20%3CSTRONG%3Elt1%20%3D%20(signed%20long)%20si_a2%3B%20lt2%20%3D%20(signed%20long)%20uiTadc%3B%20lt3%20%3D%20lt1%20*%20lt2%3B%20si_a2x2%20%3D%20(signed%20long)%20lt3%3B%3C%2FSTRONG%3E%20%2F%2F*******%20STEP%2010%20pComp%20%3D%20y1%20%2Ba2x2%20%3CSTRONG%3Elt1%20%3D%20((signed%20long)%20si_y1)%20%26lt%3B%26lt%3B%2010%3B%20lt2%20%3D%20(signed%20long)%20si_a2x2%3B%20lt3%20%3D%20lt1%20%2B%20lt2%3B%3C%2FSTRONG%3E%20%2F%2F%20FIXED%20POINT%20RESULT%20WITH%20ROUNDING%3A%20%3CSTRONG%3EsiPcomp%20%3D%20(signed%20int)(lt3%20%26gt%3B%26gt%3B%2013)%3B%3C%2FSTRONG%3E%20%2F%2F%20goes%20to%20no%20fractional%20parts%20since%20this%20is%20an%20ADC%20count.%20%20%2F%2FdecPcomp%20is%20defined%20as%20a%20floating%20point%20number.%20%2F%2FConversion%20to%20Decimal%20value%20from%201023%20ADC%20count%20value.%20ADC%20counts%20are%200%20to%201023.%20Pressure%20is%2050%20to%20115kPa%20correspondingly.%20%2F%2FdecPcomp%20%3D%20(((unsigned%20long)siPcomp)%20*%2065000%20%2B%2051150000)%20%2F%201023%3B%20%2F%2F%20result%20in%20Pa%2C%20not%20kPa%20%20%3CSTRONG%3EdecPcomp%20%3D%20(unsigned%20long)siPcomp%3B%3C%2FSTRONG%3E%20%2F%2F%20temporary%20%3CSTRONG%3Ereturn%20decPcomp%3B%7D%3C%2FSTRONG%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214618%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214618%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CBR%20%2F%3E%3CBLOCKQUOTE%3E%3CHR%20%2F%3Elrf%20%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E6%9B%B8%E3%81%84%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3A%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%81%AB%E3%81%AF%E3%81%93%E3%81%86%E6%9B%B8%E3%81%8B%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3A%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20face%3D%22Arial%22%3E%3CFONT%20face%3D%22Arial%22%20size%3D%222%22%3E%3C%2FFONT%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%20align%3D%22left%22%3E%3CFONT%20size%3D%222%22%3EsiPcomp%20%3D%20((S16)lt3%26gt%3B%26gt%3B13)%3B%3C%2FFONT%3E%3C%2FP%3E%3CP%20align%3D%22left%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20align%3D%22left%22%3E%3CFONT%20size%3D%222%22%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%20align%3D%22left%22%3E%3CFONT%20size%3D%222%22%3E%E3%81%93%E3%82%8C%E3%82%92%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FFONT%3E%3C%2FP%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3EsiPcomp%20%3D%20((S16)(lt3%26gt%3B%26gt%3B13))%3B%3C%2FFONT%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3CBR%20%2F%3E%3C%2FFONT%3E%3C%2FP%3E%3CHR%20%2F%3E%3C%2FBLOCKQUOTE%3E%3CBR%20%2F%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%81%AF%E7%A7%81%E3%81%AB%E3%81%A8%E3%81%A3%E3%81%A6%E5%A4%A7%E3%81%8D%E3%81%AA%E5%8A%A9%E3%81%91%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%A9%E3%81%86%E3%82%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E(%E3%81%93%E3%82%8C%E3%81%AB%E5%8A%A0%E3%81%88%E3%81%A6%E3%80%81%E5%9C%A7%E5%8A%9B%2F%E6%B8%A9%E5%BA%A6%E5%A4%89%E6%8F%9B%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E3%80%81%E6%96%87%E6%9B%B8%E5%8C%96%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%20ox01%20I2C%20%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF)%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214617%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214617%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E6%8C%87%E6%91%98%E3%81%AB%E5%AE%8C%E5%85%A8%E3%81%AB%E5%90%8C%E6%84%8F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E4%BF%82%E6%95%B0%E5%80%A4%E3%82%92%E5%A4%89%E6%8F%9B%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%8C%E5%88%86%E3%81%8B%E3%82%8C%E3%81%B0%E3%80%81%E5%A4%96%E9%83%A8%E3%81%A7%E8%A8%88%E7%AE%97%E3%81%99%E3%82%8B%E6%96%B9%E3%81%8C%E5%AE%89%E3%81%8F%E3%80%81%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%AB%E3%81%A8%E3%81%A3%E3%81%A6%E3%82%82%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%82%E3%81%AA%E3%81%9F%E3%82%84%E4%BB%96%E3%81%AE%E4%BA%BA%E3%81%9F%E3%81%A1%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%82%82%E8%A6%8B%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E8%AA%B0%E3%82%82%E3%81%8C%20C%20%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%82%8F%E3%81%91%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%97%E3%80%81%E3%82%82%E3%81%A1%E3%82%8D%E3%82%93%E8%AA%B0%E3%82%82%E3%81%8C%E5%A4%A7%E5%AE%B9%E9%87%8F%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AE%20CPU%2FMCU%20%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%82%8F%E3%81%91%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82128%20%E3%83%90%E3%82%A4%E3%83%88%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%20(RAM)%20%E3%81%A8%202K%20%E6%9C%AA%E6%BA%80%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%20%E3%83%A1%E3%83%A2%E3%83%AA%20(%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%BE%E3%81%9F%E3%81%AF%20ROM)%20%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%82%92%E8%80%83%E3%81%88%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%81%AF%E5%90%8C%E3%81%98%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%84%E3%81%9A%E3%82%8C%E3%81%AB%E3%81%9B%E3%82%88%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E7%B5%8C%E9%A8%93%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E6%95%B0%E6%97%A5%E5%BE%8C%E3%81%AB%E3%81%AF%E8%A7%A3%E6%B1%BA%E3%81%97%E3%80%81Freescale%20%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E6%8B%85%E5%BD%93%E8%80%85%2F%E3%82%A8%E3%83%B3%E3%82%B8%E3%83%8B%E3%82%A2%E3%81%AF%E9%9D%9E%E5%B8%B8%E3%81%AB%E5%BD%B9%E7%AB%8B%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%203%20%E6%97%A5%E7%9B%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E4%BB%8A%E6%97%A5%E3%81%AF%E5%95%8F%E9%A1%8C%E3%81%8C%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E9%A1%98%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82Freescale%20%E3%81%AE%E8%AA%B0%E3%81%8B%E3%81%8C%E5%BD%B9%E7%AB%8B%E3%81%A4%E3%83%92%E3%83%B3%E3%83%88%E3%82%92%E3%81%8F%E3%82%8C%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E9%A1%98%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%B9%B8%E9%81%8B%E3%82%92%E7%A5%88%E3%81%A3%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3Ecw%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214616%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214616%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3ECW%E3%80%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%AA%E3%81%9C%E6%95%B0%E5%AD%A6%E3%82%92%E7%90%86%E8%A7%A3%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%E3%83%81%E3%83%83%E3%83%97%E3%81%AB%E4%BD%95%E3%81%8B%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%95%E3%81%9B%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81Freescale%20%E3%81%8C%20AN3785%20%E3%81%A7%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%A8%E3%80%81%E4%B8%8A%E3%81%A7%E8%BF%B0%E3%81%B9%E3%81%9F%E5%B0%8F%E3%81%95%E3%81%AA%E5%A4%89%E6%9B%B4%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%E3%80%82%E6%95%B0%E5%AD%A6%E3%82%92%E7%90%86%E8%A7%A3%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E6%96%B9%E7%A8%8B%E5%BC%8F%E3%82%92%E9%80%86%E3%81%AB%E8%A7%A3%E6%9E%90%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%83%81%E3%83%83%E3%83%97%E3%81%AF%E3%83%81%E3%83%83%E3%83%97%E3%81%9D%E3%81%AE%E3%82%82%E3%81%AE%E3%81%A7%E3%80%81%E8%A8%88%E7%AE%97%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%9F%E6%96%B9%E6%B3%95%E3%82%82%E3%83%81%E3%83%83%E3%83%97%E3%81%9D%E3%81%AE%E3%82%82%E3%81%AE%E3%81%AA%E3%81%AE%E3%81%A7%E3%81%99%E3%80%82MC%20%E3%81%A7%E6%96%B9%E7%A8%8B%E5%BC%8F%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%83%81%E3%83%83%E3%83%97%E3%81%AB%E8%A8%88%E7%AE%97%E3%81%95%E3%81%9B%E3%81%A6%E7%B5%90%E6%9E%9C%E3%81%AB%E5%9B%BA%E5%9F%B7%E3%81%99%E3%82%8B%E3%82%88%E3%82%8A%E3%82%82%E3%80%81%E3%81%AF%E3%82%8B%E3%81%8B%E3%81%AB%E9%AB%98%E9%80%9F%E3%81%A7%E3%80%81%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%AB%E3%82%88%E3%82%8B%E8%AA%BF%E6%95%B4%E3%82%82%E5%AE%B9%E6%98%93%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%82%8C%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%8B%E3%80%81%E5%88%A5%E3%81%AE%E3%82%82%E3%81%AE%E3%82%92%E6%8E%A2%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E7%A7%81%E3%81%AE%E6%B0%97%E8%B1%A1%E8%A6%B3%E6%B8%AC%E6%89%80%E3%81%AF%E7%B4%84%201%20%E5%B9%B4%E9%96%93%E7%A8%BC%E5%83%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E4%BD%95%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%82%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%9D%E3%81%AE%E6%B8%AC%E5%AE%9A%E5%80%A4%E3%81%AF%E3%80%81%E9%AB%98%E5%BA%A6%E8%A3%9C%E6%AD%A3%E3%82%92%E8%80%83%E6%85%AE%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E5%9B%BD%E7%AB%8B%E6%B0%97%E8%B1%A1%E5%B1%80%E3%81%AE%E6%B0%97%E5%9C%A7%E3%81%A8%E6%AD%A3%E7%A2%BA%E3%81%AB%E4%B8%80%E8%87%B4%E3%81%97%E3%81%BE%E3%81%99%20(NWS%20%E3%81%AE%E5%80%A4%E3%81%AF%E6%B5%B7%E9%9D%A2%E3%81%A7%E3%81%AE%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99)%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214615%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214615%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B7%E3%83%B3%E3%82%B0%E3%82%92%E3%82%BB%E3%83%B3%E3%82%B5%E3%81%AB%E7%B5%84%E3%81%BF%E8%BE%BC%E3%82%80%E3%82%88%E3%82%8A%E3%82%82%E3%80%81%E5%88%A5%E3%81%AE%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%A7%E8%A8%88%E7%AE%97%E3%82%92%E8%A1%8C%E3%81%86%E6%96%B9%E3%81%8C%E3%81%AF%E3%82%8B%E3%81%8B%E3%81%AB%E5%AE%89%E4%BE%A1%E3%81%A7%E7%B0%A1%E5%8D%98%E3%81%A7%E3%81%99%E3%80%82%E7%A2%BA%E3%81%8B%E3%81%AB%E3%80%81%E7%90%86%E8%A7%A3%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AF%E9%9D%A2%E5%80%92%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E4%B8%80%E5%BA%A6%E7%90%86%E8%A7%A3%E3%81%97%E3%81%A6%E3%81%97%E3%81%BE%E3%81%88%E3%81%B0%E3%81%86%E3%81%BE%E3%81%8F%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E5%85%83%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20%E3%83%8E%E3%83%BC%E3%83%88%E3%81%AB%E3%81%AF%E3%80%81%E4%BF%82%E6%95%B0%E3%81%AE%E4%BF%9D%E5%AD%98%E3%81%AE%E8%AA%AC%E6%98%8E%E3%81%AB%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%20%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%AE%E7%89%B9%E5%AE%9A%E3%81%AE%E3%83%90%E3%82%A4%E3%83%88%E9%A0%86%E5%BA%8F%E3%81%AB%E4%BE%9D%E5%AD%98%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%A2%E3%83%97%E3%83%AA%E6%8B%85%E5%BD%93%E8%80%85%E3%81%AF%E9%9D%9E%E5%B8%B8%E3%81%AB%E8%A6%AA%E5%88%87%E3%81%A7%E3%80%81%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%92%E5%85%A5%E6%89%8B%E3%81%97%E3%81%A6%E3%81%8B%E3%82%89%201%20%E6%97%A5%E3%81%BB%E3%81%A9%E3%81%A7%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E7%A7%81%E3%81%8C%E8%A1%8C%E3%81%A3%E3%81%9F%E4%BD%9C%E6%A5%AD%E3%81%8B%E3%82%89%E4%BB%96%E3%81%AE%E4%BA%BA%E3%82%82%E6%81%A9%E6%81%B5%E3%82%92%E5%8F%97%E3%81%91%E3%82%89%E3%82%8C%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%9C%9F%E5%BE%85%E3%81%97%E3%81%A6%E3%80%81%E3%81%93%E3%82%8C%E3%82%92%E6%A9%9F%E8%83%BD%E3%81%95%E3%81%9B%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%81%BB%E3%81%BC%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E3%81%93%E3%81%AE%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A9%E3%83%A0%E3%81%AB%E6%8A%95%E7%A8%BF%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E4%BE%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E5%86%85%E3%81%AE%E4%BB%96%E3%81%AE%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E3%82%82%E3%81%86%E4%B8%80%E5%BA%A6%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%94%B9%E5%96%84%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AE%E6%8F%90%E6%A1%88%E3%81%8C%201%20%E3%81%A4%E3%81%82%E3%82%8B%E3%81%A8%E3%81%99%E3%82%8C%E3%81%B0%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E3%83%8E%E3%82%A4%E3%82%BA%E3%82%92%E6%94%B9%E5%96%84%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E5%80%A4%E3%81%AF%E3%81%8B%E3%81%AA%E3%82%8A%E5%A4%89%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%81%AE%E5%A0%B4%E5%90%88%E3%82%82%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E5%82%99%E3%81%88%E3%81%9F%E9%AB%98%E3%83%AC%E3%83%99%E3%83%AB%E3%81%AE%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E5%B9%B3%E6%BB%91%E5%8C%96%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%E3%82%92%E7%B0%A1%E5%8D%98%E3%81%AB%E5%AE%9F%E8%A3%85%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%B9%B8%E9%81%8B%E3%82%92%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214614%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214614%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%B8%80%E4%BD%93%E3%81%AA%E3%81%9C%E3%80%8C%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%80%8D%E3%81%8C%E3%81%93%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E4%BF%82%E6%95%B0%E8%A3%9C%E6%AD%A3%E8%A8%88%E7%AE%97%E3%81%A7%E6%B7%B7%E4%B9%B1%E3%81%95%E3%81%9B%E3%80%81%E3%81%9D%E3%82%8C%E3%82%92%E5%86%85%E9%83%A8%E3%81%A7%E8%A1%8C%E3%82%8F%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%AE%E3%81%8B%E3%80%81%E7%A7%81%E3%81%AB%E3%81%AF%E5%85%A8%E3%81%8F%E5%88%86%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214613%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214613%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Eirf%E3%80%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%80%8C%E3%81%93%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%8D%E3%83%B3%E3%83%88%E3%82%92%E6%89%B1%E3%81%A3%E3%81%9F%E3%81%AE%E3%81%AF%E4%B9%85%E3%81%97%E3%81%B6%E3%82%8A%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E8%A8%88%E7%AE%97%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%91%E3%82%8C%E3%81%B0%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%8F%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%81%A8%E6%96%AD%E8%A8%80%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99...%E3%80%8D%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%95%8F%E9%A1%8C%E3%81%AF%E3%80%81%E7%A7%81%E3%81%8C%E6%95%B0%E5%AD%A6%E3%82%92%E6%AD%A3%E3%81%97%E3%81%8F%E7%90%86%E8%A7%A3%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%E7%9A%86%E3%81%95%E3%82%93%E3%81%AE%E5%8A%A9%E3%81%91%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82C%20%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%E8%A1%A8%E8%A8%98%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81%E5%B9%B3%E6%98%93%E3%81%AA%E8%8B%B1%E8%AA%9E%E3%81%A7%E3%80%81%E4%BF%82%E6%95%B0%E3%81%AE%E5%80%A4%E3%82%92%E6%B5%AE%E5%8B%95%E5%B0%8F%E6%95%B0%E7%82%B9%E6%95%B0%E3%81%AB%E5%A4%89%E6%8F%9B%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9F%E3%81%A8%E3%81%88%E3%81%B0%E3%80%81%2400%20-%20%240f%20%E3%81%AE%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%8B%E3%82%89%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E6%95%B0%E5%80%A4%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E5a%20c0%2075%20c0%2039%20e3%20b9%207a%20ca%207b%2032%20cc%2000%2000%2000%2000%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%94%E5%8D%94%E5%8A%9B%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Ecw%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214612%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214612%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%8D%E3%83%B3%E3%83%88%E3%82%92%E6%89%B1%E3%81%A3%E3%81%9F%E3%81%AE%E3%81%AF%E4%B9%85%E3%81%97%E3%81%B6%E3%82%8A%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E8%A8%88%E7%AE%97%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%91%E3%82%8C%E3%81%B0%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%8F%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%81%A8%E8%A8%80%E3%81%88%E3%81%BE%E3%81%99%E3%80%82%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%BC%8F%E3%81%8C%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%AE%8B%E5%BF%B5%E3%81%AA%E3%81%8C%E3%82%89%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%8C%E4%BD%95%E3%81%A7%E3%81%82%E3%81%A3%E3%81%9F%E3%81%8B%E6%AD%A3%E7%A2%BA%E3%81%AB%E3%81%AF%E6%80%9D%E3%81%84%E5%87%BA%E3%81%9B%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%AE%E3%81%A7%E3%80%81%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AB%E6%88%BB%E3%81%A3%E3%81%A6%E9%81%95%E3%81%84%E3%82%92%E6%8E%A2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E7%A7%81%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%9F%E5%94%AF%E4%B8%80%E3%81%AE%E9%81%95%E3%81%84%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%81%AB%E3%81%AF%E3%81%93%E3%81%86%E6%9B%B8%E3%81%8B%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3A%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20face%3D%22Arial%22%3E%3CFONT%20face%3D%22Arial%22%20size%3D%222%22%3E%3C%2FFONT%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%20align%3D%22left%22%3E%3CFONT%20size%3D%222%22%3EsiPcomp%20%3D%20((S16)lt3%26gt%3B%26gt%3B13)%3B%3C%2FFONT%3E%3C%2FP%3E%3CP%20align%3D%22left%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20align%3D%22left%22%3E%3CFONT%20size%3D%222%22%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%20align%3D%22left%22%3E%3CFONT%20size%3D%222%22%3E%E3%81%93%E3%82%8C%E3%82%92%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FFONT%3E%3C%2FP%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3EsiPcomp%20%3D%20((S16)(lt3%26gt%3B%26gt%3B13))%3B%3C%2FFONT%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%E3%81%93%E3%82%8C%E3%81%8C%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A4%E3%81%93%E3%81%A8%E3%82%92%E9%A1%98%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FFONT%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214611%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214611%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EMPL115A2%20%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%AE%E4%BB%96%E3%81%AE%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%A8%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%82%92%E6%8A%B1%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3C%2FP%3E%3CP%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%8B%E3%82%89%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E5%AE%9F%E9%9A%9B%E3%81%AE%E5%9C%A7%E5%8A%9B%E3%81%A8%E6%B8%A9%E5%BA%A6%E3%82%92%E5%8F%96%E5%BE%97%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%9D%E3%81%93%E3%81%8B%E3%82%89%E9%95%B7%E3%81%84%E9%81%93%E3%81%AE%E3%82%8A%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%95%E3%81%A6%E3%80%81%E3%81%93%E3%82%8C%E3%81%8C%E7%A7%81%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%A7%E3%81%99%E3%80%82%E8%AA%B0%E3%81%8B%E3%81%8C%E7%A7%81%E3%82%92%E5%8A%A9%E3%81%91%E3%81%A6%E3%81%8F%E3%82%8C%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E9%A1%98%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E4%BB%A5%E4%B8%8B%E3%81%AF%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%2400%E3%81%8B%E3%82%89%240f%E3%81%8B%E3%82%89%E8%AA%AD%E3%81%BF%E5%8F%96%E3%81%A3%E3%81%9F%E3%83%87%E3%83%BC%E3%82%BF%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E5a%20c0%2075%20c0%2039%20e3%20b9%207a%20ca%207b%2032%20cc%2000%2000%2000%2000%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%A9%E3%81%AA%E3%81%9F%E3%81%8B%E3%80%81%E4%B8%8A%E8%A8%98%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AE%E8%AC%8E%E3%82%92%E8%A7%A3%E8%AA%AD%E3%81%99%E3%82%8B%E3%81%AE%E3%82%92%E6%89%8B%E4%BC%9D%E3%81%A3%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%E3%80%82%E6%9C%80%E5%88%9D%E3%81%AE%204%20%E3%83%90%E3%82%A4%E3%83%88%E3%81%8C%20Padc%20%E5%80%A4%E3%81%A8%20Tadc%20%E5%80%A4%E3%81%A7%E3%80%81%E3%81%9D%E3%81%AE%E5%BE%8C%E3%81%8C%20a0-msb%E3%80%81a0-lsb%E3%80%81b1.....c22%20%E3%81%AA%E3%81%A9%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%82%8F%E3%81%8B%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E6%95%B0%E5%80%A4%E3%82%92%E6%B5%AE%E5%8B%95%E5%B0%8F%E6%95%B0%E7%82%B9%E8%A1%A8%E8%A8%98%E3%81%AB%E5%A4%89%E6%8F%9B%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E5%AE%9F%E9%9A%9B%E3%80%81%E3%81%93%E3%82%8C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%A8%80%E5%8F%8A%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%80%8CFreescale%E3%80%8D%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%94%E5%8D%94%E5%8A%9B%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214610%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214610%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3EMPL115A2%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%BF%82%E6%95%B0%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E3a%204d%20ba%20cc%20bf%20a6%2031%2078%2000%2000%2000%2000%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%83%91%E3%83%83%E3%83%89%20%3D%20990%3C%2FP%3E%3CP%3E%E3%82%BF%E3%83%83%E3%83%89c%20%3D%20523%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%A8%88%E7%AE%97%E3%81%99%E3%82%8B%E3%81%A8%EF%BC%9A%3C%2FP%3E%3CP%3Ea0%20%3D%201865.63%3C%2FP%3E%3CP%3Eb1%20%3D%20-2.16%3C%2FP%3E%3CP%3Eb2%20%3D%20-1.01%3C%2FP%3E%3CP%3Ec12%20%3D%200.00075%3C%2FP%3E%3CP%3Ec11%20%3D%200%3C%2FP%3E%3CP%3Ec22%20%3D%200%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EPcomp%20%3D%20-411%20(%E8%B2%A0!!!)%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%BD%95%E3%81%8B%E3%82%A2%E3%82%A4%E3%83%87%E3%82%A2%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%9C%AC%E5%BD%93%E3%81%AB%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%83%8B%E3%82%B3%E3%83%A9%EF%BC%88%E3%82%A4%E3%82%BF%E3%83%AA%E3%82%A2%EF%BC%89%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214609%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214609%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%AA%E3%83%B3%E3%82%B4%E3%80%81%3C%2FP%3E%3CP%3E2%E3%81%A4%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AB%E5%AF%BE%E3%81%99%E3%82%8B%E5%9B%9E%E7%AD%94%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E1.%E6%B8%A9%E5%BA%A6%20ADC%20%E3%81%AF%E5%AE%9F%E9%9A%9B%E3%81%AE%E6%B8%A9%E5%BA%A6%E3%81%AB%E7%9B%B4%E6%8E%A5%E5%A4%89%E6%8F%9B%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%84%E3%81%A4%E3%81%A7%E3%82%82%E3%82%BB%E3%83%B3%E3%82%B5%E3%81%AE%E5%91%A8%E5%9B%B2%E6%B8%A9%E5%BA%A6%E3%82%92%E5%A4%89%E3%81%88%E3%81%A6%E3%81%BF%E3%81%A6%E3%80%81%E3%81%95%E3%81%BE%E3%81%96%E3%81%BE%E3%81%AA%E6%B8%A9%E5%BA%A6%E7%AF%84%E5%9B%B2%E3%81%A7%E3%81%AE%20ADC%20%E5%80%A4%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%80%81%E5%A4%89%E6%8F%9B%E4%BF%82%E6%95%B0%E3%82%92%E8%A8%88%E7%AE%97%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E2.%20%E6%9C%80%E7%B5%82%E7%9A%84%E3%81%AA%E5%9C%A7%E5%8A%9B%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E5%80%A4%E3%81%AB%E3%81%AF%E3%83%8E%E3%82%A4%E3%82%BA%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%81%9D%E3%81%AE%E5%80%A4%E3%82%92%E9%AB%98%E5%BA%A6%E3%81%AB%E5%A4%89%E6%8F%9B%E3%81%99%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AB%E3%82%82%E3%83%8E%E3%82%A4%E3%82%BA%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E9%80%9A%E5%B8%B8%E3%80%81%E5%9C%A7%E5%8A%9B%E3%81%AF%E9%9D%9E%E5%B8%B8%E3%81%AB%E3%82%86%E3%81%A3%E3%81%8F%E3%82%8A%E3%81%A8%E5%A4%89%E5%8C%96%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E6%9C%80%E5%96%84%E3%81%AE%E6%96%B9%E6%B3%95%E3%81%AF%E3%80%81%E8%A4%87%E6%95%B0%E5%9B%9E%E3%81%AE%E6%B8%AC%E5%AE%9A%E3%82%92%E8%A1%8C%E3%81%84%E3%80%81%E6%9C%80%E5%BE%8C%E3%81%AE%E6%B8%AC%E5%AE%9A%E3%81%AE%E5%AE%9F%E8%A1%8C%E5%B9%B3%E5%9D%87%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%A6%E3%83%8E%E3%82%A4%E3%82%BA%E3%82%92%E5%B9%B3%E5%9D%87%E5%8C%96%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%AF%E3%80%811%20%E7%A7%92%E3%81%94%E3%81%A8%E3%81%AB%E6%B8%AC%E5%AE%9A%E3%82%92%E8%A1%8C%E3%81%84%E3%80%81%E9%81%8E%E5%8E%BB%20100%20%E7%A7%92%E9%96%93%E3%81%AE%E5%B9%B3%E5%9D%87%E3%82%92%E7%AE%97%E5%87%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%83%94%E3%83%BC%E3%82%BF%E3%83%BC%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214608%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214608%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E7%B2%BE%E5%BA%A6%2F%E5%86%8D%E7%8F%BE%E6%80%A7%E3%81%8C%E5%BE%97%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%E7%A7%81%E3%81%AE%E3%81%AF%E3%81%82%E3%81%A1%E3%81%93%E3%81%A1%E9%A3%9B%E3%81%B3%E5%9B%9E%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E9%AB%98%E5%BA%A6%3A%20149%3CBR%20%2F%3E%E9%AB%98%E5%BA%A6%3A%2057%3CBR%20%2F%3E%E9%AB%98%E5%BA%A6%3A%2097%3CBR%20%2F%3E%E9%AB%98%E5%BA%A6%3A%2057%3CBR%20%2F%3E%E9%AB%98%E5%BA%A6%3A%2097%3CBR%20%2F%3E%E9%AB%98%E5%BA%A6%3A%20109%3CBR%20%2F%3E%E9%AB%98%E5%BA%A6%3A%2057%3CBR%20%2F%3E%E9%AB%98%E5%BA%A6%3A%2045%3CBR%20%2F%3E%E9%AB%98%E5%BA%A6%3A%20109%3CBR%20%2F%3E%E9%AB%98%E5%BA%A6%3A%2045%3CBR%20%2F%3E%E9%AB%98%E5%BA%A6%3A%20109%3CBR%20%2F%3E%E9%AB%98%E5%BA%A6%3A%2057%3CBR%20%2F%3E%E9%AB%98%E5%BA%A6%3A%2057%3CBR%20%2F%3E%E9%AB%98%E5%BA%A6%3A%2097%3CBR%20%2F%3E%E9%AB%98%E5%BA%A6%3A%20109%3CBR%20%2F%3E%E9%AB%98%E5%BA%A6%3A%2097%3CBR%20%2F%3E%E9%AB%98%E5%BA%A6%3A%20109%3CBR%20%2F%3E%E9%AB%98%E5%BA%A6%3A%2057%3CBR%20%2F%3E%E9%AB%98%E5%BA%A6%3A%20109%3CBR%20%2F%3E%E9%AB%98%E5%BA%A6%3A%20109%3CBR%20%2F%3E%E9%AB%98%E5%BA%A6%3A%20109%3CBR%20%2F%3E%E9%AB%98%E5%BA%A6%3A%2097%3CBR%20%2F%3E%E9%AB%98%E5%BA%A6%3A%20109%3CBR%20%2F%3E%E9%AB%98%E5%BA%A6%3A%2097%3CBR%20%2F%3E%E9%AB%98%E5%BA%A6%3A%2045%3CBR%20%2F%3E%E9%AB%98%E5%BA%A6%3A%2057%3CBR%20%2F%3E%E9%AB%98%E5%BA%A6%3A%20109%3CBR%20%2F%3E%E9%AB%98%E5%BA%A6%3A%2097%3CBR%20%2F%3E%E9%AB%98%E5%BA%A6%3A%2057%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214607%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214607%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EuiTADC%20%E3%81%AE%E6%95%B0%E5%80%A4%E3%82%92%20c%20%E3%81%BE%E3%81%9F%E3%81%AF%20F%20%E3%81%AB%E5%A4%89%E6%8F%9B%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E7%B4%84%20523%20%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E5%A4%89%E6%8F%9B%E4%BF%82%E6%95%B0%E3%81%A8%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%3C%2FP%3E%3CP%3E%E3%83%AA%E3%83%B3%E3%82%B4%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214606%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214606%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%AF%E3%81%84%E3%80%81C22%E3%81%AE%E3%81%93%E3%81%A8%E3%82%92%E8%A8%80%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E5%80%A4%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E5%9C%A7%E5%8A%9B%E3%82%92%E8%A8%88%E7%AE%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%A8%E5%90%8C%E3%81%98%E7%B5%90%E6%9E%9C%E3%81%8C%E5%BE%97%E3%82%89%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E3%82%88%E3%81%86%E3%82%84%E3%81%8F%E8%87%AA%E5%88%86%E3%81%8C%E4%BD%95%E3%82%92%E9%96%93%E9%81%95%E3%81%88%E3%81%9F%E3%81%AE%E3%81%8B%E3%81%AB%E6%B0%97%E3%81%A5%E3%81%84%E3%81%9F%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AF%E3%81%93%E3%81%AE%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%81%AE%E6%9C%80%E5%88%9D%E3%81%AE%E6%8A%95%E7%A8%BF%E3%82%92%E8%A6%8B%E3%81%A6%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E4%BE%8B%E3%81%A8%E3%81%97%E3%81%A6%E4%BF%82%E6%95%B0%E3%82%92%E5%A4%89%E6%8F%9B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82SO%20C12%E3%81%AFS0.0000000001110001110000%20-%26gt%3B%202%5E-10%20%2B%202%5E-11%20%2B%202%5E-12%20%2B%202%5E-16%20%2B%202%5E-17%20%2B%202%5E-18%20%3D%200.0017281%E3%81%A7%E3%81%99%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E7%AC%A6%E5%8F%B7%E3%83%93%E3%83%83%E3%83%88%E3%81%AF%201%20(0x38E0)%20%E3%81%A7%E3%81%99%E3%80%82%E5%AE%9F%E9%9A%9B%E3%81%AE%E7%B5%90%E6%9E%9C%E3%82%92%E5%BE%97%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%8113%20%E5%80%8B%E3%81%AE%E5%B0%8F%E6%95%B0%E3%83%93%E3%83%83%E3%83%88%E3%82%92%E5%8F%8D%E8%BB%A2%E3%81%97%E3%81%A6%201%20%E3%82%92%E5%8A%A0%E7%AE%97%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3FB2%20%E3%81%A7%E3%82%82%E3%81%8A%E3%81%9D%E3%82%89%E3%81%8F%E5%90%8C%E3%81%98%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%94%E5%8D%94%E5%8A%9B%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%81PJH!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214605%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214605%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%9C%80%E5%BE%8C%E3%81%AE%E4%BF%82%E6%95%B0%E3%81%AF%20C22%20%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E7%A7%81%E3%81%AE%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E4%B8%80%E3%81%A4%E3%81%A7%E3%81%AF%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EA0%3D2156.625000%3CBR%20%2F%3E%20B1%3D-2.528809%3CBR%20%2F%3EB2%3D-1.034241%3CBR%20%2F%3EC12%3D0.000876%3CBR%20%2F%3EC11%3D0.000000%3CBR%20%2F%3EC22%3D0.000000%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%9C%A7%E5%8A%9BADC%20420%3CBR%20%2F%3E%E3%83%86%E3%83%B3%E3%83%97ADC%20419%3CBR%20%2F%3E%3CBR%20%2F%3E%E7%B5%90%E6%9E%9C101.802%20kPa%E3%80%82%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%811018.02%20mBar%20%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%80%A4%E3%82%92%E8%A6%8B%E3%82%8B%E3%81%A8%E3%80%81%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E9%AB%98%E3%81%84%E3%81%AE%E3%81%AF%20C12%20%E3%81%AE%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E6%95%B0%E5%AD%97%E3%81%AF%E7%A7%81%E3%81%8C%E5%BE%97%E3%81%9F%E6%95%B0%E5%AD%97%E3%82%88%E3%82%8A%E3%81%9A%E3%81%A3%E3%81%A8%E5%B0%8F%E3%81%95%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%E7%A7%81%E3%81%AE%E6%95%B0%E5%80%A4%E3%82%92%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E8%A8%88%E7%AE%97%E9%96%A2%E6%95%B0%E3%81%AB%E5%85%A5%E5%8A%9B%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E7%A7%81%E3%81%A8%E5%90%8C%E3%81%98%E7%B5%90%E6%9E%9C%E3%81%8C%E5%BE%97%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81B2%20%E3%81%AE%E5%B0%8F%E6%95%B0%E7%82%B9%E3%81%AE%E4%BD%8D%E7%BD%AE%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E6%95%B0%E5%AD%97%E3%81%AF%E7%A7%81%E3%81%AE%E6%95%B0%E5%AD%97%E3%82%88%E3%82%8A%2010%20%E5%80%8D%E5%B0%8F%E3%81%95%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EpComp%20%E5%80%A4%E3%82%92%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82%E5%BF%98%E3%82%8C%E3%81%AA%E3%81%84%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E5%87%BA%E5%8A%9B%E3%81%AF%200%20%EF%BD%9E%201023%20%E3%81%A7%E3%80%8150kPa%20%EF%BD%9E%20115kPa%20%E3%81%AE%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82SO%20%E7%AF%84%E5%9B%B2%E3%81%AF%201023%20%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%A7%2065kPa%20%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E6%9C%80%E7%B5%82%E5%9C%A7%E5%8A%9B%20%3D%20(65%2F1023*pComp)%2B50%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214604%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214604%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EPJH%E3%81%95%E3%82%93%E3%80%81%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E6%AD%A3%E3%81%97%E3%81%8F%E5%A4%89%E6%8F%9B%E3%81%A7%E3%81%8D%E3%81%9F%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E3%81%9D%E3%81%86%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%E7%8F%BE%E6%99%82%E7%82%B9%E3%81%A7%E3%81%AF%E3%80%81%E7%B5%90%E6%9E%9C%20Pcomp%20%E3%81%AF%201067%20%E3%81%A7%E3%81%99%E3%81%8C%E3%80%810%20%E3%81%8B%E3%82%89%201023%20%E3%81%AE%E9%96%93%E3%81%A7%E3%81%82%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%AA%E3%81%AE%E3%81%A7%E3%80%81%E6%AD%A3%E3%81%97%E3%81%8F%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E5%A4%89%E6%8F%9B%E3%81%95%E3%82%8C%E3%81%9F%E4%BF%82%E6%95%B0%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3Ea0%20%3D%202003%3C%2FP%3E%3CP%3Eb1%20%3D%20-2.3118%3C%2FP%3E%3CP%3Eb2%20%3D%20-0.15836%3C%2FP%3E%3CP%3Ec12%20%3D%201.456E-10%3C%2FP%3E%3CP%3Ec11%20%3D%200%3C%2FP%3E%3CP%3Ec12%20%3D%200%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%83%91%E3%83%83%E3%83%89%20%3D%20370%3C%2FP%3E%3CP%3E%E3%82%BF%E3%83%83%E3%83%89c%20%3D%20509%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214603%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214603%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BF%82%E6%95%B0%E3%81%AF%E3%81%99%E3%81%B9%E3%81%A6%E5%90%8C%E3%81%98%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%20x04%20%EF%BD%9E%20x0F%20%E3%81%AE%2012%20%E3%83%90%E3%82%A4%E3%83%88%20(96%20%E3%83%93%E3%83%83%E3%83%88)%20%E3%81%AB%E3%83%91%E3%83%83%E3%82%AF%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E4%BF%82%E6%95%B0%E3%81%AF%E5%AE%9F%E9%9A%9B%E3%81%AB%E3%81%AF%E6%B5%AE%E5%8B%95%E5%B0%8F%E6%95%B0%E7%82%B9%E6%95%B0%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E5%B0%8F%E6%95%B0%E7%82%B9%E3%81%AF%E5%90%84%E6%95%B0%E5%80%A4%E3%81%94%E3%81%A8%E3%81%AB%E7%95%B0%E3%81%AA%E3%82%8B%E5%A0%B4%E6%89%80%E3%81%AB%E3%81%82%E3%82%8A%E3%80%81%E4%B8%80%E9%83%A8%E3%81%AF%E8%B2%A0%E3%81%AE%E5%80%A4%E3%81%AA%E3%81%A9%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81%E3%81%8A%E3%81%9D%E3%82%89%E3%81%8F%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AE%E3%83%90%E3%82%A4%E3%83%88%20%E3%82%A8%E3%83%B3%E3%83%87%E3%82%A3%E3%82%A2%E3%83%B3%E3%81%AE%E6%80%A7%E8%B3%AA%E3%81%AB%E3%82%88%E3%82%8A%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%20%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E5%8B%95%E4%BD%9C%E3%81%95%E3%81%9B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%9F%E3%82%81%E3%80%81%E3%83%90%E3%82%A4%E3%83%88%E3%82%92%20double%20%E3%81%AB%E5%A4%89%E6%8F%9B%E3%81%A7%E3%81%8D%E3%82%8B%E9%96%A2%E6%95%B0%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%BE%E3%81%9A%E3%80%81%E4%BF%82%E6%95%B0%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E5%BD%93%E7%84%B6%E3%81%AA%E3%81%8C%E3%82%89%E3%80%81I2C%20%E3%81%AE%E5%AE%9F%E8%A3%85%E3%81%AF%E8%AA%AD%E8%80%85%E3%81%AB%E5%A7%94%E3%81%AD%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3C%2FFONT%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3ECMPL115A%E3%82%92%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%3A%3CIMG%20alt%3D%22%3Asmileyvery-happy%3A%22%20class%3D%22emoticon%20emoticon-smileyvery-happy%22%20id%3D%22smileyvery-happy%22%20src%3D%22http%3A%2F%2Ffreescale.i.lithium.com%2Fi%2Fsmilies%2F16x16_smiley-very-happy.gif%22%20title%3D%22%E3%82%B9%E3%83%9E%E3%82%A4%E3%83%AA%E3%83%BC%E3%81%A8%E3%81%A6%E3%82%82%E5%B9%B8%E3%81%9B%22%20%2F%3E%E7%8B%AC%E8%87%AA%E3%81%AE%E3%83%AD%E3%83%BC%E3%83%89%E3%82%B3%E3%82%A8%E3%83%95()%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%E6%95%B4%E6%95%B0%E3%82%A8%E3%83%A9%E3%83%BC%3D0%3B%3CBR%20%2F%3E%20int%20%E7%B5%90%E6%9E%9CL%E3%80%81%E7%B5%90%E6%9E%9CH%3B%3CBR%20%2F%3E%20BYTE%20%E3%83%87%E3%83%BC%E3%82%BF%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%20iA0%3D0%3B%3CBR%20%2F%3E%20iB1%3D0%3B%3CBR%20%2F%3E%20iB2%3D0%3B%3CBR%20%2F%3E%20iC11%3D0%3B%3CBR%20%2F%3E%20iC12%3D0%3B%3CBR%20%2F%3E%20iC22%3D0%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%20%2F%2F%20A0%20%E3%82%92%E5%8F%96%E5%BE%97%3CBR%20%2F%3Eerr%3Dm_I2C.ModuleReadByte(BAROMETER%2C0x05%2C%26amp%3Bdata)%3B%3CBR%20%2F%3E%20if(err%3D%3DERROR_SUCCESS)%20%2F%2F%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%83%83%E3%83%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81%E6%AE%8B%E3%82%8A%E3%81%AE%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%AF%E6%88%90%E5%8A%9F%E3%81%99%E3%82%8B%E3%81%A8%E6%83%B3%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%7B%3CBR%20%2F%3E%20resultL%3DINT8(%E3%83%87%E3%83%BC%E3%82%BF)%3B%3CBR%20%2F%3E%20m_I2C.ModuleReadByte(%E6%B0%97%E5%9C%A7%E8%A8%88%E3%80%810x04%E3%80%81%26amp%3B%E3%83%87%E3%83%BC%E3%82%BF)%3B%3CBR%20%2F%3E%20resultH%3DINT8(%E3%83%87%E3%83%BC%E3%82%BF)%3B%3CBR%20%2F%3E%20iA0%3D(%E7%B5%90%E6%9E%9CH%26lt%3B%26lt%3B8)%2B(%E7%B5%90%E6%9E%9CL%26amp%3B0x00FF)%3B%3CBR%20%2F%3E%20dA0%3DConvertCoeffToDouble(iA0%2C16%2C12%2C3%2C0)%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%20%2F%2F%20B1%20%E3%82%92%E5%8F%96%E5%BE%97%3CBR%20%2F%3Em_I2C.ModuleReadByte(%E6%B0%97%E5%9C%A7%E8%A8%88%E3%80%810x07%E3%80%81%26amp%3B%E3%83%87%E3%83%BC%E3%82%BF)%3B%3CBR%20%2F%3E%20resultL%3DINT8(%E3%83%87%E3%83%BC%E3%82%BF)%3B%3CBR%20%2F%3E%20m_I2C.ModuleReadByte(%E6%B0%97%E5%9C%A7%E8%A8%88%E3%80%810x06%E3%80%81%26amp%3B%E3%83%87%E3%83%BC%E3%82%BF)%3B%3CBR%20%2F%3E%20resultH%3DINT8(%E3%83%87%E3%83%BC%E3%82%BF)%3B%3CBR%20%2F%3E%20iB1%3D(%E7%B5%90%E6%9E%9CH%26lt%3B%26lt%3B8)%2B(%E7%B5%90%E6%9E%9CL%26amp%3B0x00FF)%3B%3CBR%20%2F%3E%20dB1%3DConvertCoeffToDouble(iB1%2C16%2C2%2C13%2C0)%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%20%2F%2F%20B2%20%E3%82%92%E5%8F%96%E5%BE%97%3CBR%20%2F%3Em_I2C.ModuleReadByte(%E6%B0%97%E5%9C%A7%E8%A8%88%E3%80%810x09%E3%80%81%26amp%3B%E3%83%87%E3%83%BC%E3%82%BF)%3B%3CBR%20%2F%3E%20resultL%3DINT8(%E3%83%87%E3%83%BC%E3%82%BF)%3B%3CBR%20%2F%3E%20m_I2C.ModuleReadByte(%E6%B0%97%E5%9C%A7%E8%A8%88%E3%80%810x08%E3%80%81%26amp%3B%E3%83%87%E3%83%BC%E3%82%BF)%3B%3CBR%20%2F%3E%20resultH%3DINT8(%E3%83%87%E3%83%BC%E3%82%BF)%3B%3CBR%20%2F%3E%20iB2%3D(%E7%B5%90%E6%9E%9CH%26lt%3B%26lt%3B8)%2B(%E7%B5%90%E6%9E%9CL%26amp%3B0x00FF)%3B%3CBR%20%2F%3E%20dB2%3DConvertCoeffToDouble(iB2%2C16%2C1%2C14%2C0)%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%20%2F%2F%20C12%20%E3%82%92%E5%8F%96%E5%BE%97%3CBR%20%2F%3Em_I2C.ModuleReadByte(%E6%B0%97%E5%9C%A7%E8%A8%88%E3%80%810x0B%E3%80%81%26amp%3B%E3%83%87%E3%83%BC%E3%82%BF)%3B%3CBR%20%2F%3E%20resultL%3DINT8(%E3%83%87%E3%83%BC%E3%82%BF)%3B%3CBR%20%2F%3E%20m_I2C.ModuleReadByte(%E6%B0%97%E5%9C%A7%E8%A8%88%E3%80%810x0A%E3%80%81%26amp%3B%E3%83%87%E3%83%BC%E3%82%BF)%3B%3CBR%20%2F%3E%20resultH%3DINT8(%E3%83%87%E3%83%BC%E3%82%BF)%3B%3CBR%20%2F%3E%20iC12%3D(%E7%B5%90%E6%9E%9CH%26lt%3B%26lt%3B8)%2B(%E7%B5%90%E6%9E%9CL%26amp%3B0x00FF)%3B%3CBR%20%2F%3E%20dC12%3D%E4%BF%82%E6%95%B0%E3%82%92%E5%80%8D%E7%B2%BE%E5%BA%A6%E3%81%AB%E5%A4%89%E6%8F%9B(iC12%2C14%2C0%2C13%2C9)%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%20%2F%2F%20C11%20%E3%82%92%E5%8F%96%E5%BE%97%3CBR%20%2F%3Em_I2C.ModuleReadByte(%E6%B0%97%E5%9C%A7%E8%A8%88%E3%80%810x0D%E3%80%81%26amp%3B%E3%83%87%E3%83%BC%E3%82%BF)%3B%3CBR%20%2F%3E%20resultL%3DINT8(%E3%83%87%E3%83%BC%E3%82%BF)%3B%3CBR%20%2F%3E%20m_I2C.ModuleReadByte(%E6%B0%97%E5%9C%A7%E8%A8%88%E3%80%810x0C%E3%80%81%26amp%3B%E3%83%87%E3%83%BC%E3%82%BF)%3B%3CBR%20%2F%3E%20resultH%3DINT8(%E3%83%87%E3%83%BC%E3%82%BF)%3B%3CBR%20%2F%3E%20iC11%3D(%E7%B5%90%E6%9E%9CH%26lt%3B%26lt%3B8)%2B(%E7%B5%90%E6%9E%9CL%26amp%3B0x00FF)%3B%3CBR%20%2F%3E%20dC11%3D%E4%BF%82%E6%95%B0%E3%82%92%E5%80%8D%E7%B2%BE%E5%BA%A6%E3%81%AB%E5%A4%89%E6%8F%9B(iC11%2C11%2C0%2C10%2C11)%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%20%2F%2F%20C22%20%E3%82%92%E5%8F%96%E5%BE%97%3CBR%20%2F%3Em_I2C.ModuleReadByte(%E6%B0%97%E5%9C%A7%E8%A8%88%E3%80%810x0F%E3%80%81%26amp%3B%E3%83%87%E3%83%BC%E3%82%BF)%3B%3CBR%20%2F%3E%20resultL%3DINT8(%E3%83%87%E3%83%BC%E3%82%BF)%3B%3CBR%20%2F%3E%20m_I2C.ModuleReadByte(%E6%B0%97%E5%9C%A7%E8%A8%88%E3%80%810x0E%E3%80%81%26amp%3B%E3%83%87%E3%83%BC%E3%82%BF)%3B%3CBR%20%2F%3E%20resultH%3DINT8(%E3%83%87%E3%83%BC%E3%82%BF)%3B%3CBR%20%2F%3E%20iC22%3D(%E7%B5%90%E6%9E%9CH%26lt%3B%26lt%3B8)%2B(%E7%B5%90%E6%9E%9CL%26amp%3B0x00FF)%3B%3CBR%20%2F%3E%20dC22%3D%E4%BF%82%E6%95%B0%E3%82%92%E5%80%8D%E7%B2%BE%E5%BA%A6%E3%81%AB%E5%A4%89%E6%8F%9B(iC22%2C11%2C0%2C10%2C15)%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%20m_InitSuccess%3Dtrue%3B%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%E3%81%9D%E3%82%8C%E4%BB%A5%E5%A4%96%3CBR%20%2F%3E%7B%3CBR%20%2F%3E%20m_InitSuccess%3Dfalse%3B%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%20%7D%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CBR%20%2F%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20face%3D%22arial%2Chelvetica%2Csans-serif%22%3E%E3%81%93%E3%81%93%E3%81%A7%E3%81%AF%E3%80%812%20%E3%83%90%E3%82%A4%E3%83%88%E3%81%AE%E3%83%AF%E3%83%BC%E3%83%89%E3%81%A8%E3%80%81%E3%83%93%E3%83%83%E3%83%88%E6%95%B0%E3%80%81%E6%95%B4%E6%95%B0%E3%83%93%E3%83%83%E3%83%88%E3%80%81%E5%B0%8F%E6%95%B0%E3%83%93%E3%83%83%E3%83%88%E3%80%81%E3%83%91%E3%83%83%E3%83%89%E3%83%93%E3%83%83%E3%83%88%E3%82%92%E8%A8%98%E8%BF%B0%E3%81%99%E3%82%8B%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%82%92%E5%8F%97%E3%81%91%E5%8F%96%E3%82%8B%20ConvertCoeffToDouble%20%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%82%92%E8%A1%8C%E3%81%86%E3%81%AB%E3%81%AF%E3%82%88%E3%82%8A%E5%8A%B9%E7%8E%87%E7%9A%84%E3%81%AA%E6%96%B9%E6%B3%95%E3%81%8C%E3%81%82%E3%82%8B%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E6%99%82%E3%81%AB%201%20%E5%9B%9E%E3%81%A0%E3%81%91%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E6%9C%80%E9%81%A9%E5%8C%96%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CBR%20%2F%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Edouble%20ConvertCoeffToDouble(INT16%20coeff%2Cshort%20bitCount%2Cshort%20iBits%2C%20short%20fracBits%2C%20short%20padBits)%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20%2F%2F%20%E4%BF%82%E6%95%B0%E3%82%92%E6%B5%AE%E5%8B%95%E5%B0%8F%E6%95%B0%E7%82%B9%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%AB%E5%A4%89%E6%8F%9B%E3%81%99%E3%82%8B%E3%83%A6%E3%83%BC%E3%83%86%E3%82%A3%E3%83%AA%E3%83%86%E3%82%A3%E9%96%A2%E6%95%B0%E3%80%82%3CBR%20%2F%3E%2F%2F%20%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%AE%E4%BF%9D%E5%AD%98%E6%96%B9%E6%B3%95%E3%81%AE%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81Freescale%20%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20%E3%83%8E%E3%83%BC%E3%83%88%20AN3785%20%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%83%80%E3%83%96%E3%83%AB%E7%B5%90%E6%9E%9C%3D0%3B%3CBR%20%2F%3E%E3%83%96%E3%83%BC%E3%83%AB%20s%3Dfalse%3B%3CBR%20%2F%3E%20bool%20%E3%83%93%E3%83%83%E3%83%88%3B%3CBR%20%2F%3E%E6%95%B4%E6%95%B0%20fb%3D0%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%20%2F%2F%20%E4%B8%8A%E4%BD%8D%E3%81%8B%E3%82%89%E4%B8%8B%E4%BD%8D%E3%81%AE%E3%83%93%E3%83%83%E3%83%88%E3%81%AB%E5%90%91%E3%81%8B%E3%81%A3%E3%81%A6%E4%BD%9C%E6%A5%AD%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%2F%2F%20%E5%8F%97%E4%BF%A1%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AF%2016%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E6%95%B4%E6%95%B0%E3%81%A7%E3%81%99%E3%81%8C%E3%80%8116%20%E3%83%93%E3%83%83%E3%83%88%E6%9C%AA%E6%BA%80%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E4%B8%8B%E4%BD%8D%20LSB%20%E3%81%8C%E7%A9%BA%E3%81%AB%E3%81%AA%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E7%9F%AD%E7%B8%AE%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%EF%BC%88AN3785%20%E3%81%AE%2015%20%E3%83%9A%E3%83%BC%E3%82%B8%E3%82%92%E5%8F%82%E7%85%A7%EF%BC%89%E3%80%82%3CBR%20%2F%3E%20%EF%BC%88%E3%83%93%E3%83%83%E3%83%88%E6%95%B0%26lt%3B16%EF%BC%89%E3%81%AE%E5%A0%B4%E5%90%88%3CBR%20%2F%3E%7B%2F%2F%20%E4%BF%82%E6%95%B0%E3%82%92%E9%81%A9%E5%88%87%E3%81%AA%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AB%E3%81%99%E3%82%8B%3CBR%20%2F%3E%E4%BF%82%E6%95%B0%3D%E4%BF%82%E6%95%B0%26gt%3B%26gt%3B(16%E3%83%93%E3%83%83%E3%83%88%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88)%3B%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%3CBR%20%2F%3E%20%2F%2F%20%E9%96%A2%E6%95%B0%E3%81%AB%E6%B8%A1%E3%81%95%E3%82%8C%E3%81%9F%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%8C%E6%84%8F%E5%91%B3%E3%82%92%E6%88%90%E3%81%99%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%81%AE%E5%81%A5%E5%85%A8%E6%80%A7%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%80%82%E3%83%87%E3%83%BC%E3%82%BF%E9%87%8F%E3%82%88%E3%82%8A%E3%82%82%E5%A4%9A%E3%81%8F%E3%81%AE%E3%83%93%E3%83%83%E3%83%88%E3%82%84%E5%B0%91%E3%81%AA%E3%81%84%E3%83%93%E3%83%83%E3%83%88%E3%82%92%E6%8C%81%E3%81%A4%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%2F%2F%20%E7%AC%A6%E5%8F%B7%E3%83%93%E3%83%83%E3%83%88%E3%82%92%E8%80%83%E6%85%AE%E3%81%97%E3%81%A6%201%20%E3%82%92%E5%8A%A0%E7%AE%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20if((iBits%2BfracBits%2B1)!%3D%E3%83%93%E3%83%83%E3%83%88%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88)%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20TRACE(_T(%22%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%AB%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99!!%5Cn%22))%3B%3CBR%20%2F%3E%200%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%20%2F%2F%20%E5%B0%8F%E6%95%B0%E7%82%B9%E3%82%92%E5%9F%8B%E3%82%81%E8%BE%BC%E3%82%80%E5%A0%B4%E5%90%88%E3%81%AF%E6%95%B4%E6%95%B0%E3%83%93%E3%83%83%E3%83%88%E3%82%82%E5%90%AB%E3%82%81%E3%82%89%E3%82%8C%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E5%81%A5%E5%85%A8%E6%80%A7%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3Eif((padBits%26gt%3B0)%26amp%3B%26amp%3B(iBits%26gt%3B0))%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20TRACE(_T(%22%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%AB%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82iBits%20%E3%81%A8%20padBits%20%E3%81%8C%E4%B8%80%E8%87%B4%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93!!%5Cn%22))%3B%3CBR%20%2F%3E%200%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%3CBR%20%2F%3E%20for(int%20b%3D%E3%83%93%E3%83%83%E3%83%88%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%3Bb%26gt%3B0%3Bb--)%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%E3%83%93%E3%83%83%E3%83%88%3D%E3%83%96%E3%83%BC%E3%83%AB((int(pow(2.0%2Cb-1))%26amp%3Bcoeff)%26gt%3B%26gt%3B(b-1))%3B%20%2F%2F%20%E5%90%84%E3%83%93%E3%83%83%E3%83%88%E3%82%92%E9%A0%86%E7%95%AA%E3%81%AB%201%20%E3%81%BE%E3%81%9F%E3%81%AF%200%20%E3%81%A8%E3%81%97%E3%81%A6%E5%8F%96%E5%BE%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20if%20(b%3D%3DbitCount)%20%2F%2F%20%E3%81%93%E3%82%8C%E3%81%8C%E6%9C%80%E5%88%9D%E3%81%AE%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E5%A0%B4%E5%90%88%EF%BC%88%E7%AC%A6%E5%8F%B7%E3%83%93%E3%83%83%E3%83%88%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%EF%BC%89%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20s%3D%E3%83%93%E3%83%83%E3%83%88%3B%3CBR%20%2F%3E%E3%82%82%E3%81%97%3CBR%20%2F%3E%7B%3CBR%20%2F%3E%20coeff%3D~coeff%2B1%3B%20%2F%2F2%E3%81%AE%E8%A3%9C%E6%95%B0%E3%82%92%E8%A8%88%E7%AE%97%3B%20%2F%2F(%E8%AA%AC%E6%98%8E%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%8E%E3%83%BC%E3%83%88AN3785%E3%81%AE15%E3%83%9A%E3%83%BC%E3%82%B8%E3%81%AE%E4%B8%AD%E5%A4%AE%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%20else%20%2F%2F%20%E3%83%93%E3%83%83%E3%83%88%E3%82%92%E9%A0%86%E7%95%AA%E3%81%AB%E5%87%A6%E7%90%86%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%7B%3CBR%20%2F%3E%20iBits%26gt%3B0%E3%81%AE%E5%A0%B4%E5%90%88%3CBR%20%2F%3E%7B%20%2F%2F%20%E6%95%B4%E6%95%B0%E3%83%93%E3%83%83%E3%83%88%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20if(%E3%83%93%E3%83%83%E3%83%88)%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%E7%B5%90%E6%9E%9C%2B%3Dpow(2.0%2CiBits-1)%3B%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%20iBits--%3B%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%20else%20%2F%2F%20%E5%B0%8F%E6%95%B0%E3%83%93%E3%83%83%E3%83%88%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3CBR%20%2F%3E%7B%3CBR%20%2F%3E%20fb%2B%2B%3B%3CBR%20%2F%3E%20if(%E3%83%93%E3%83%83%E3%83%88)%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%E7%B5%90%E6%9E%9C%2B%3D%20(1%2Fpow(2.0%2Cfb%2BpadBits))%3B%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%20fracBits--%3B%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%E3%82%82%E3%81%97%3CBR%20%2F%3E%7B%3CBR%20%2F%3E%E7%B5%90%E6%9E%9C*%3D-1%3B%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%20TRACE(_T(%22%E7%B5%90%E6%9E%9C%3D%25f%5Cn%22)%2C%E7%B5%90%E6%9E%9C)%3B%3CBR%20%2F%3E%E7%B5%90%E6%9E%9C%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%7D%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20face%3D%22arial%2Chelvetica%2Csans-serif%22%3E%3CBR%20%2F%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CFONT%20face%3D%22arial%2Chelvetica%2Csans-serif%22%3E%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E4%BF%82%E6%95%B0%E3%82%92%E6%AD%A3%E3%81%97%E3%81%84%E7%AC%A6%E5%8F%B7%E3%80%81%E6%9C%89%E5%8A%B9%E6%95%B0%E5%AD%97%E3%81%AA%E3%81%A9%E3%81%AB%E5%A4%89%E6%8F%9B%E3%81%97%E3%81%A6%E5%88%9D%E3%82%81%E3%81%A6%E3%80%81%E6%84%8F%E5%91%B3%E3%81%8C%E9%80%9A%E3%81%98%E3%80%81%E6%AD%A3%E3%81%97%E3%81%8F%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8C%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FFONT%3E%3C%2FFONT%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CFONT%20face%3D%22arial%2Chelvetica%2Csans-serif%22%3E%E3%83%94%E3%83%BC%E3%82%BF%E3%83%BC%3CBR%20%2F%3E%3C%2FFONT%3E%3C%2FFONT%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214602%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214602%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%82%BB%E3%83%B3%E3%82%B5%E3%81%8B%E3%82%89%E4%BD%95%E3%81%8B%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%BE%E3%81%9A%E3%80%81%E4%BF%82%E6%95%B0%20C11%20%E3%81%A8%20C22%20%E3%81%AF%E3%81%99%E3%81%B9%E3%81%A6%E3%82%BC%E3%83%AD%E3%81%A7%E3%81%99%E3%80%82%E4%BF%82%E6%95%B0%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%20(coeff1%20coeff2%20...%20coeff12)%3A%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E3E%2098%20B3%20D2%20C2%2024%2038%20E0%2000%2000%2000%2000%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E5%AE%9F%E9%9A%9B%E3%81%AE%E5%9C%A7%E5%8A%9B%E3%82%92%E8%A8%88%E7%AE%97%E3%81%99%E3%82%8B%E3%81%A8%EF%BC%88%E5%9C%A7%E5%8A%9B%20adc%20%3D%205C80%E3%80%81%E6%B8%A9%E5%BA%A6%20adc%20%3D%207F40%EF%BC%89%E3%80%81918%20hPa%20%E3%81%A8%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%8F%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%AA%E3%81%9C%E3%81%AA%E3%82%89%E3%80%81%E7%A7%81%E3%81%AF%E6%B5%B7%E6%8A%9C%2025%20%E3%83%A1%E3%83%BC%E3%83%88%E3%83%AB%E3%81%AB%E3%81%84%E3%81%A6%E3%80%81%E6%B5%B7%E9%9D%A2%E3%81%A7%E3%81%AE%E5%9C%A7%E5%8A%9B%E3%81%AF%201008%20hPa%20%E3%81%A7%E3%81%82%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A0%E3%81%8B%E3%82%89%E3%81%A7%E3%81%99%E3%80%82C11%20%E3%81%A8%20C22%20%E3%81%8C%E3%81%99%E3%81%B9%E3%81%A6%E3%82%BC%E3%83%AD%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E9%9D%9E%E5%B8%B8%E3%81%AB%E5%A5%87%E5%A6%99%E3%81%A7%E3%81%99%E3%80%82%E4%BD%95%E3%81%8B%E3%82%A2%E3%82%A4%E3%83%87%E3%82%A2%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214601%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214601%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%9C%A7%E5%8A%9B%E3%82%92%E3%81%8B%E3%81%91%E3%82%8B%E3%81%AB%E3%81%AF%E8%A4%87%E6%95%B0%E3%81%AE%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%82%92%E8%B8%8F%E3%82%80%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%BE%E3%81%9A%E3%80%81%E5%9C%A7%E5%8A%9B%20ADC%20%E3%81%A8%E6%B8%A9%E5%BA%A6%20ADC%20%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%82%89%E3%81%AF%E4%B8%A1%E6%96%B9%E3%81%A8%E3%82%82%202%20%E3%83%90%E3%82%A4%E3%83%88%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%9C%A7%E5%8A%9BADC%3D%20(%E5%9C%A7%E5%8A%9BMSB%26lt%3B%26lt%3B8%2B%E5%9C%A7%E5%8A%9BLSB)%26gt%3B%26gt%3B6%3B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%B8%A9%E5%BA%A6ADC%3D(%E6%B8%A9%E5%BA%A6MSB%26lt%3B%26lt%3B8%2B%E6%B8%A9%E5%BA%A6LSB)%26gt%3B%26gt%3B6%3B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%202%20%E3%81%A4%E3%81%AE%20ADC%20%E5%80%A4%E3%81%A8%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E4%BF%82%E6%95%B0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E5%9C%A7%E5%8A%9B%E3%82%92%E8%A8%88%E7%AE%97%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%9C%A7%E5%8A%9B%3D%20AO%2B(B1%2BC11*%E5%9C%A7%E5%8A%9BADC%2BC12*%E6%B8%A9%E5%BA%A6ADC)*%E5%9C%A7%E5%8A%9BADC%2B(B2%2BC22*%E6%B8%A9%E5%BA%A6ADC)*%E6%B8%A9%E5%BA%A6ADC)%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%9C%80%E5%BE%8C%E3%81%AB%E3%82%82%E3%81%86%E4%B8%80%E5%BA%A6%E8%A8%82%E6%AD%A3%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E5%9C%A7%E5%8A%9BC%3D(65%2F1023*%E5%9C%A7%E5%8A%9B)%2B50%3B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%9C%80%E7%B5%82%E7%9A%84%E3%81%AB%E3%80%81%E6%B8%A9%E5%BA%A6%E8%A3%9C%E6%AD%A3%E3%81%95%E3%82%8C%E3%81%9F%E5%9C%A7%E5%8A%9B%E3%81%8C%20mBar%20%E5%8D%98%E4%BD%8D%E3%81%A7%E5%BE%97%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%B8%80%E7%95%AA%E9%9B%A3%E3%81%97%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%AE%E3%81%AF%E3%80%81%E4%BF%82%E6%95%B0%E3%82%92%E6%AD%A3%E3%81%97%E3%81%8F%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%83%94%E3%83%BC%E3%82%BF%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214600%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214600%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E7%A7%81%E3%82%82MPL115A%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81SPI%E3%81%A7%E3%81%AF%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%8F%E6%B8%A9%E5%BA%A6%E3%80%81%E5%9C%A7%E5%8A%9B%E3%80%81%E4%BF%82%E6%95%B0%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%8110%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92KPa%E3%81%BE%E3%81%9F%E3%81%AF%E6%91%82%E6%B0%8F%E5%BA%A6%E3%81%AB%E5%A4%89%E6%8F%9B%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3E%E4%BE%8B%EF%BC%9A%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EMSB%E5%9C%A7%E5%8A%9B0x5B%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3ELSB%E5%9C%A7%E5%8A%9B%200xC0%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%81%93%E3%81%86%E3%81%97%E3%81%BE%E3%81%99%3A%200x5BC0%20%26gt%3B%26gt%3B6%20%E3%81%99%E3%82%8B%E3%81%A8%20Pka%20%3D%20(65%2F1023)*Padc%20%2B%2050%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E7%A7%81%E3%81%AF73KPa%E3%82%92%E5%BE%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E9%AB%98%E5%BA%A6%E3%81%AF2500%E3%83%A1%E3%83%BC%E3%83%88%E3%83%AB%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%A9%E3%81%86%E3%81%97%E3%81%9F%E3%82%89%E6%AD%A3%E3%81%97%E3%81%84%E7%B5%90%E6%9E%9C%E3%82%92%E5%BE%97%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214599%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214599%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%9E%E3%83%BC%E3%82%AF%E3%83%AB%E3%83%9E%E3%83%B3%E3%80%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E2%E6%97%A5%E9%96%93%E3%80%81%E5%9C%A7%E5%8A%9B%E3%81%A8%E6%B8%A9%E5%BA%A6%E3%81%AE%E6%96%B0%E3%81%9F%E3%81%AA%E5%A4%89%E6%8F%9B%E3%82%92%E8%A9%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EAN3785%20%E3%81%AE%E3%80%8C%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%83%A2%E3%83%BC%E3%83%89%E3%80%8D%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%E3%81%AE%E4%B8%8B%E3%81%AB%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%82%8B%E3%80%8C%E4%B8%A1%E6%96%B9%E3%81%AE%E5%A4%89%E6%8F%9B%E3%82%92%E9%96%8B%E5%A7%8B%E3%80%8D%E3%83%90%E3%82%A4%E3%83%88%E6%96%87%E5%AD%97%E5%88%97%E3%81%AE%E6%9B%B8%E3%81%8D%E6%96%B9%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%A8%E4%BE%8B%E3%81%8C%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88%E3%83%BB%E3%83%93%E3%83%83%E3%83%88%3C%2FP%3E%3CP%3E%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%EF%BC%880x60%EF%BC%89%3C%2FP%3E%3CP%3E%E3%82%A2%E3%82%AF%E3%83%8E%E3%83%AA%E3%83%83%E3%82%B8%3C%2FP%3E%3CP%3E%E4%B8%A1%E6%96%B9%E3%81%AE%E5%A4%89%E6%8F%9B%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%99%E3%82%8B%20(0x12)%3C%2FP%3E%3CP%3E%E3%82%A2%E3%82%AF%E3%83%8E%E3%83%AA%E3%83%83%E3%82%B8%3C%2FP%3E%3CP%3E%E3%82%B9%E3%83%88%E3%83%83%E3%83%97%E3%83%93%E3%83%83%E3%83%88%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%80%8CI2C%20%E7%B0%A1%E7%95%A5%E5%8C%96%E3%80%8D%E3%81%AE%E8%A6%8B%E5%87%BA%E3%81%97%E3%81%AE%E4%B8%8B%E3%81%AB%E3%81%AF%E3%80%810x12%20%E3%83%90%E3%82%A4%E3%83%88%E3%81%AE%E5%BE%8C%E3%81%AB%200x01%20%E3%81%AE%E8%BF%BD%E5%8A%A0%E3%83%90%E3%82%A4%E3%83%88%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%80%E3%82%88%E3%81%86%E3%81%AB%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AB%E3%82%82%E3%81%9D%E3%82%8C%E3%81%8C%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%9F%E3%82%89%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%820x01%20%E3%81%AF%E4%BD%95%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%E3%81%8B%E3%81%94%E5%AD%98%E7%9F%A5%E3%81%A7%E3%81%99%E3%81%8B%3F%E4%BB%96%E3%81%AE%E5%A0%B4%E6%89%80%E3%81%A7%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%AA%E3%81%84%E9%99%90%E3%82%8A%E3%80%81%E3%82%B7%E3%83%BC%E3%83%88%E3%81%AE%E3%80%8CI2C%20Simplified%E3%80%8D%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%E4%BB%A5%E5%A4%96%E3%81%AE%E3%81%A9%E3%81%93%E3%81%AB%E3%82%82%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%3CP%3E%E3%83%AD%E3%83%90%E3%83%BC%E3%83%88%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214598%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214598%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%AB%8B%E6%B1%82%E6%9B%B8%E3%80%81%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E6%95%AC%E5%85%B7%E3%80%81%E3%83%9E%E3%83%BC%E3%82%AF%E3%83%BB%E3%83%AA%E3%83%BC%E3%83%9E%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214597%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214597%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%AF%E3%81%84%E3%80%81I2C%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81PIC%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%81%A8NIOS%E3%82%BD%E3%83%95%E3%83%88CPU%E3%81%AE%E4%B8%A1%E6%96%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%9D%E3%81%93%E3%81%8B%E3%82%89%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E4%BF%82%E6%95%B0%E3%82%92%E6%A9%9F%E8%83%BD%E3%81%95%E3%81%9B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CIMG%20alt%3D%22%E3%82%B9%E3%83%9E%E3%82%A4%E3%83%AA%E3%83%BC%E3%82%B5%E3%83%83%E3%83%89%22%20class%3D%22emoticon%20emoticon-smileysad%22%20id%3D%22smileysad%22%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fi%2Fsmilies%2F16x16_smiley-sad.png%22%20title%3D%22%E3%82%B9%E3%83%9E%E3%82%A4%E3%83%AA%E3%83%BC%E3%82%B5%E3%83%83%E3%83%89%22%20%2F%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E7%A7%81%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%EF%BC%88%E7%8B%AC%E8%87%AA%E3%81%AE%20I2C%20%E9%96%8B%E5%A7%8B%2F%E5%81%9C%E6%AD%A2%2F%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%2F%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E9%96%A2%E6%95%B0%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%EF%BC%89%3C%2FP%3E%3CBR%20%2F%3E%3CPRE%20translate%3D%22no%22%3Evoid%20Measure_ambient_presure(void)%20%7B%20unsigned%20char%20x%3B%20unsigned%20char%20MPL115A2_data%5B16%5D%3B%20printf(%22%3BRead%20MPL115A2%5Cr%22)%3B%20i2c_start()%3B%20%20%20%20%20%20%20%20%20%20%20%2F%2F%20I2C%20Bus%20Start%20condition%20i2c_write(MPL115A2_I2C_address)%3B%20%20%20%20%20%2F%2F%20I2C%20bus%20Device%20address%20i2c_write(MPL115A2_start_both_conversion_command)%3B%20%2F%2F%20Command%20to%20Convert%20both%20Pressure%20and%20Temperature%20i2c_write(0x01)%3B%20i2c_stop()%3B%20%20%20%20%20%20%20%20%20%20%20%2F%2F%20I2C%20Bus%20Stop%20condition%20delay_ms(5)%3B%20%20%20%20%20%20%20%20%20%20%2F%2F%20wait%20for%20A-D%20conversion%20to%20take%20place%20i2c_start()%3B%20%20%20%20%20%20%20%20%20%20%20%2F%2F%20I2C%20Bus%20Start%20condition%20i2c_write(MPL115A2_I2C_address)%3B%20%20%20%20%20%2F%2F%20I2C%20bus%20Device%20address%20i2c_write(0x00)%3B%20%20%20%20%20%20%20%20%20%2F%2F%20address%20in%20MPL115A2%20i2c_start()%3B%20%20%20%20%20%20%20%20%20%20%2F%2F%20I2C%20Bus%20Start%20condition%20(a%20restart)%20i2c_write(MPL115A2_I2C_address%7C0x01)%3B%20%20%20%20%2F%2F%20address%20in%20MPL115A2%20%2B%20read%20bit%20MPL115A2_data%5B0%5D%20%20%3D%20i2c_read(1)%3B%20%20%20%20%20%2F%2F%20read%20with%20ACK%20MPL115A2_data%5B1%5D%20%20%3D%20i2c_read(1)%3B%20%20%20%20%20%2F%2F%20read%20with%20ACK%20MPL115A2_data%5B2%5D%20%20%3D%20i2c_read(1)%3B%20%20%20%20%20%2F%2F%20read%20with%20ACK%20MPL115A2_data%5B3%5D%20%20%3D%20i2c_read(1)%3B%20%20%20%20%20%2F%2F%20read%20with%20ACK%20MPL115A2_data%5B4%5D%20%20%3D%20i2c_read(1)%3B%20%20%20%20%20%2F%2F%20read%20with%20ACK%20MPL115A2_data%5B5%5D%20%20%3D%20i2c_read(1)%3B%20%20%20%20%20%2F%2F%20read%20with%20ACK%20MPL115A2_data%5B6%5D%20%20%3D%20i2c_read(1)%3B%20%20%20%20%20%2F%2F%20read%20with%20ACK%20MPL115A2_data%5B7%5D%20%20%3D%20i2c_read(1)%3B%20%20%20%20%20%2F%2F%20read%20with%20ACK%20MPL115A2_data%5B8%5D%20%20%3D%20i2c_read(1)%3B%20%20%20%20%20%2F%2F%20read%20with%20ACK%20MPL115A2_data%5B9%5D%20%20%3D%20i2c_read(1)%3B%20%20%20%20%20%2F%2F%20read%20with%20ACK%20MPL115A2_data%5B10%5D%20%3D%20i2c_read(1)%3B%20%20%20%20%20%2F%2F%20read%20with%20ACK%20MPL115A2_data%5B11%5D%20%3D%20i2c_read(1)%3B%20%20%20%20%20%2F%2F%20read%20with%20ACK%20MPL115A2_data%5B12%5D%20%3D%20i2c_read(1)%3B%20%20%20%20%20%2F%2F%20read%20with%20ACK%20MPL115A2_data%5B13%5D%20%3D%20i2c_read(1)%3B%20%20%20%20%20%2F%2F%20read%20with%20ACK%20MPL115A2_data%5B14%5D%20%3D%20i2c_read(1)%3B%20%20%20%20%20%2F%2F%20read%20with%20ACK%20MPL115A2_data%5B15%5D%20%3D%20i2c_read(0)%3B%20%20%20%20%20%2F%2F%20read%20with%20noACK%20i2c_stop()%3B%20%20%20%20%20%20%20%20%20%20%20%2F%2F%20I2C%20Bus%20Stop%20condition%20%20printf(%22%3BMPL115A2%20Data%3D%20%22)%3B%20for%20(x%3D0%3Bx%26lt%3B16%3Bx%2B%2B)%20%20%7B%20%20printf(%22%2502X%20%22%2CMPL115A2_data%5Bx%5D)%3B%20%20%7D%20printf(%22%5Cr%22)%3B%20%7D%3C%2FPRE%3E%3CBR%20%2F%3E%3CDIV%3E%E4%BB%A5%E4%B8%8B%E3%81%AB%E3%80%81%E3%81%9D%E3%81%93%E3%81%8B%E3%82%89%E5%8F%96%E5%BE%97%E3%81%97%E3%81%9F%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CP%3E%3BMPL115A2%20%E3%83%87%E3%83%BC%E3%82%BF%20%3D%2064%20C0%2075%2080%203D%209B%20B9%204A%20C7%2046%2032%20BC%2002%2020%20FD%2060%3CBR%20%2F%3E%20%3BMPL115A2%20%E3%83%87%E3%83%BC%E3%82%BF%20%3D%2065%2000%2076%2080%203D%209B%20B9%204A%20C7%2046%2032%20BC%2002%2020%20FD%2060%3CBR%20%2F%3E%20%3BMPL115A2%20%E3%83%87%E3%83%BC%E3%82%BF%20%3D%2065%2040%2076%2080%203D%209B%20B9%204A%20C7%2046%2032%20BC%2002%2020%20FD%2060%3CBR%20%2F%3E%20%3BMPL115A2%20%E3%83%87%E3%83%BC%E3%82%BF%20%3D%2065%2000%2076%20C0%203D%209B%20B9%204A%20C7%2046%2032%20BC%2002%2020%20FD%2060%3CBR%20%2F%3E%20%3BMPL115A2%20%E3%83%87%E3%83%BC%E3%82%BF%20%3D%2065%2080%2075%20C0%203D%209B%20B9%204A%20C7%2046%2032%20BC%2002%2020%20FD%2060%3CBR%20%2F%3E%20%3BMPL115A2%20%E3%83%87%E3%83%BC%E3%82%BF%20%3D%2065%2000%2075%2040%203D%209B%20B9%204A%20C7%2046%2032%20BC%2002%2020%20FD%2060%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%95%AC%E5%85%B7%E3%80%81%E3%83%9E%E3%83%BC%E3%82%AF%E3%83%BB%E3%83%AA%E3%83%BC%E3%83%9E%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214596%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214596%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%80%8CBillthe%20Biker%E3%80%8D%E4%BB%A5%E5%A4%96%E3%81%AB%E3%80%81MPL115A%20%E8%A9%95%E4%BE%A1%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E4%BD%BF%E7%94%A8%E3%82%92%E8%A9%A6%E3%81%BF%E3%81%9F%E4%BA%BA%E3%81%AF%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%E7%A7%81%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AF%20i2c%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E9%80%9A%E4%BF%A1%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E8%AA%AD%E3%81%BF%E5%87%BA%E3%81%9D%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%82%B3%E3%83%B3%E3%83%94%E3%83%A5%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%8C%E3%83%8F%E3%83%B3%E3%82%B0%E3%81%97%E3%81%A6%E3%83%AD%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%81%97%E3%81%BE%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E8%AA%B0%E3%81%8B%E4%BD%95%E3%81%8B%E3%82%A2%E3%82%A4%E3%83%87%E3%82%A2%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%E7%A7%81%E3%81%AF%E6%95%B0%E5%AD%A6%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%83%93%E3%83%AB%E3%81%AE%E6%8A%95%E7%A8%BF%E3%82%92%E8%AA%AD%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%A6%E3%82%82%E6%95%B0%E5%AD%A6%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E7%9B%B4%E9%9D%A2%E3%81%99%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%8B%E3%81%A8%E5%BF%83%E9%85%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%93%E3%81%A7%E8%B1%9A%E3%82%92%E8%B2%B7%E3%81%A3%E3%81%9F%E3%82%93%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%82%92%E8%AA%AD%E3%82%80%E3%81%A8%E3%80%81Freescale%20%E3%81%8C%E3%81%9D%E3%82%8C%E3%82%92%E3%81%86%E3%81%BE%E3%81%8F%E6%A9%9F%E8%83%BD%E3%81%95%E3%81%9B%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E7%96%91%E5%95%8F%E3%81%AB%E6%80%9D%E3%81%86%E3%82%88%E3%81%86%E3%81%AA%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%EF%BC%88%E3%83%93%E3%83%AB%E3%81%8C%E5%8F%97%E3%81%91%E5%8F%96%E3%81%A3%E3%81%9F%E3%82%82%E3%81%AE%E4%BB%A5%E4%B8%8A%E3%81%AE%E3%82%82%E3%81%AE%E3%81%8C%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E9%A1%98%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%EF%BC%89%3C%2FP%3E%3C%2FLINGO-BODY%3E
