MPL115A fixed point question
20,881 次查看
BillTheBiker
I am trying to make sense of the coefficients I receive from the pressure sensor MPL115A.  I can successfully access the IIC bus and get the data, but the algorithm provided in the AN3785 does not appear to work (at least for me).  Closer inspection of the comments raises some questions.  For example, the coeff C11 is described as a signed number with no int bits and 10 frac bits.  There are 11 pad zeros.  So I think the number looks like this:
S0.00000000000 F10 F9 F8 F7 F6 F5 F4 F3 F2 F1 F0
To me the representation of this number is s(0,21), but the comment says s(16,27).
When I extract the data from the sensor, C11 is given as 0x0340.  This is a 2's compliment number and only the first 11 bits are used (the 10 frac bits and the sign bit).  So if I convert this to a real number (not something I would do in the processor, but just to see if I am understanding this correctly),  I get
S0.00000000000 0000 0011 010x xxxx
this gives 2^-17+ 2^-18 + 2^-20 = 0.00001239776611328125
this is the extent of my understanding, and I wonder if someone could confirm I have done this correctly.  In addition, as the algorithm in AN3785 keeps everything in fixed point, I cannot see where lt1 (a 32-bit value) can be assigned C11 and this be correctly justified.  When I assign 0x0340 to the long I get
lt1    0x00000340
= 0000 0000 0000 0000 0000 0011 010x xxxx
so you can see I am not correctly aligned as per the bit-width specifications.  The following is the code snippet.  The comments make no sense to me, so any clarification you could prrovide would be most helpful
 //******* STEP 1 c11x1= c11 * Padc
 lt1 = (S32)sic11;                  // s(16,27)    s(N,F+zeropad) goes from s(11,10)+11ZeroPad = s(11,22) => Left Justified = s(16,27)
-Bill
35 回复数
10,168 次查看
d_
Gee, I know this thread is years old.  But I am dense.  Bill's original post was about c12 where he said the data sheet shows 11 pad zeros.  My data sheet says 9 pad zeros.
And I'm lost in that data sheet where the value of c12 is 0x33C8.  I don't see how you get from that to the value 0.000790.  If you pad F12 - F0 with 9 zeros, you get 0000000001001....  That would mean the the first 1 bit would be 2^^-10, or 0.0009xxx, which is already greater than 0.000790.
Sorry, I don't get it.  Anybody have some thoughts for me?
d.
10,168 次查看
d_
Oh, sorry.  I see that the 2 LSBs are zeros.  I still don't see how you get 0.000790 though.
d.
10,168 次查看
TomasVaverka
Hi Dave,
I have just explained it in your SR 1-1348149811.
First, you need to take into consideration that the last two bits of the c12_LSB are zero as shown on page 5 of the data sheet:
c12 MSB byte = c12[13:6] = [b13 , b12 , b11 , b10 , b9 , b8 , b7 , b6]
c12 LSB byte = c12[5:0] & “00” = [b5 , b4 , b3 , b2 , b1 , b0 , 0 , 0]
Then the c12 coefficient is formatted as follows:
c12 = b13 0 . 000 000 000 b12 b11 b10 b9 b8 b7 b6 b5 b4 b3 b2 b1 b0
So, each fractional bit has the value of 1 / 2^(9+13) and the 16-bit c12 value needs to be first right shifted by 2 (or divided by 4) to obtain 13 fractional bits.
Considering our example, the 16-bit c12 = 0x33C8.
Then c12 >> 2 = 0x33C8 >> 2 = 0xCF2 = 3314
and c12 coefficient = 3314 / 2^22 = 0.00079
I hope it helps.
Tomas
10,168 次查看
d_
Thanks Tomas,
I get it now.
Dave
10,168 次查看
Jack_at_Oxigraf
I coded this in an old assembler for the 68hc912b32
Note each coefficient is placed in a 32 bit variable.
I am sure there is room for optimizations.
   .include   "globals.s"
   .include   "hc12.s"
c12x2: .blkb 4
a1: .blkb 4
a1x1: .blkb 4
y1: .blkb 4
a2x2: .blkb 4
PComp32: .blkb 4
baro_fltr: .blkb 3
; Initialize and read coefficients
  movb #0b00000000,sp0br  ; set spi to 4 MHz clock
ibaro:  bclr portb,#0b10000000  ; Set CS low
  movb #$88,sp0dr ; read a0 msb
  brclr sp0sr,#SPIF,.  ; wait for spi
  movb #0,sp0dr ; clearing byte
ldaa sp0dr ; get a0 msb
  movb #$8A,sp0dr ; read a0 LSB
ldab sp0dr ; get a0 LSB
std BaroCoa0 ; save baro coefficient a0
movb #$8C,sp0dr ; read b1 MSB
ldaa sp0dr ; get b1 MSB
movb #$8e,sp0dr ; read b1 LSB
ldab sp0dr ; get b1 LSB
std BaroCob1 ; save baro coeffiecient b1
movb #$90,sp0dr ; read b2 msb
ldaa sp0dr ; get b2 msb
  movb #$92,sp0dr ; read b2 LSB
ldab sp0dr ; get b2 LSB
  std BaroCob2 ; save baro Coefficient b2
  movb #$94,sp0dr ; read c12 MSB
ldaa sp0dr ; get c12 MSB
  movb #$96,sp0dr ; read c12 LSB
ldab sp0dr ; get c12 LSB
  movb #0,sp0dr ; extra clearing byte
  bset portb,#0b10000000  ; Set CS hi
  std BaroCoc12 ; save baro coeffiecient c12
rts
CompBaro::
emuls ;result in Y:D needs shift 11 bits
;or divide by 2^11 which is 2048.
ldx #2048 ; **** TODO or could do 3 shifts then load from mid byte
; to acomplishs the other 8 bits.
sty c12x2+2 ; only save as 16 bit **** ;/ *
adca a1 ;preserve sign bit
ldd a1+2 ;get lower 16 bits
ror PComp32 ;Shift 1 bit
; todo check this for best resolution
ldd PComp32+1 ; Get mid bytes effectly shifts 8 bit
ldx #16394 ; 1023... times 16 for binary fraction
;use IRR filter with an index of 15 to smooth out noise
  subd AmbBaro ; subtract last filtered Baro value
  psha  ; save sign
  addd baro_fltr+1  ; add accumulator lsword
  std baro_fltr+1  ; update
  pulb  ; msbyte difference
  tfr b,d  ; extend sign to acca
  adca baro_fltr  ; add with carry to msbyte accumulator
  staa baro_fltr  ; update
  ldd baro_fltr  ; IIR filtered result in msword
  pshd  ; to temp on stack
  ldab baro_fltr+2  ; lsbyte filter for left shift
  ldaa #15 ; filter control, 0 = min fltr, 15= max fltr
  ; flip bits for decrement??
  eora #$F ; *** could use Higer if this is not enough
   ; less filtering => more shifts
bfc1:  beq bfc2  ; begin shift loop for less filtering
  lslb  ; left shift lsbyte
  rol 1,s  ; shift into filtered pressure
  rol ,s  ; msbyte
  deca ; dec shift count by subtracting bit 4
  bra bfc1  ; repeat
bfc2:  puld  ; retrieve result
std AmbBaro ;Results in kPa= mBar*10
Jack
10,168 次查看
Michael_BY
Do I convert the coefficient of c12?
MSB c12 = 00110000
LSB c12 = 101011xx
Coef c12 =S0, 000000000 00 110000101011xx = 2^-10 + 2^-11 + 2^-16 + 2^-18 + 2^-20 + 2^-21 = 0,001485
Is that right?
10,168 次查看
ey7180
I'm trying ot interface to this device and I'm havin some issues. The coefficients  and readings I get from the device are as follows:
a0:3b99 b1:ffffb8b9 b2:ffffc24d c12:3274 c11:0 c22:0 Padc:157 Tadc:1f5
Padc:343 Tadc:501
temperature: 26.536017 C
pressure: 51.450000 kPa
Compensated Pressure: 91.935486 kPA
Using the coefficient to floating point functino earlier in the forum I get these values:
a0_d:1906.250000
b1_d:-2.056824
b2_d:-0.240997
c12_d:0.000192
c11_d:0.000000
c22_d:0.000000
Pressure_d: 120.723752 kPa
I take those double values and calculate it using the:
Pcomp = a0_D + (b1_D + c11_D*Padc + c12_D*Tadc)*Padc + (b2_D + c22_D*Tadc)*Tadc
Then using the (65.0/1023.0*Pcomp + 50, I get Pressure_d. Was there something special I needed to do because neither of thsese match the 101 kPa I was expecintg and what's even more confusing is that these numbers are different. The first compensated pressure value was calculate according the application note sheet.
10,168 次查看
markleman
Bill,
Did you ever resolve this?
Regards, Mark Leman
10,168 次查看
lrf
Has anyone other then "Billthe Biker" tried to use the MPL115A eval boards. My board is an i2c version and I can talk to it but it doesn't want to read any data out. It just hangs and locks up the computer.
Anyone have any idea? I read Bill's posting about the problems with the math and I am concerned if I get thru the hardware issues then I will be faced with math issues. Did I buy a pig here?
Reading the manual shows a number of issues which one has to wonder if Freescale has made it work. Any replies would be appreciated. (I hope there are more the what Bill has received)
10,168 次查看
markleman
Yes I have the I2C version and can read the data from it using both a PIC micro and a NIOS soft CPU, what I can't do is get the coeficients to work Smiley Sad
Here is the code I use (you will need your own I2C start/stop/read/write functions)
void Measure_ambient_presure(void) { unsigned char x; unsigned char MPL115A2_data[16]; printf(";Read MPL115A2\r"); i2c_start();           // I2C Bus Start condition i2c_write(MPL115A2_I2C_address);     // I2C bus Device address i2c_write(MPL115A2_start_both_conversion_command); // Command to Convert both Pressure and Temperature i2c_write(0x01); i2c_stop();           // I2C Bus Stop condition delay_ms(5);          // wait for A-D conversion to take place i2c_start();           // I2C Bus Start condition i2c_write(MPL115A2_I2C_address);     // I2C bus Device address i2c_write(0x00);         // address in MPL115A2 i2c_start();          // I2C Bus Start condition (a restart) i2c_write(MPL115A2_I2C_address|0x01);    // address in MPL115A2 + read bit MPL115A2_data[0]  = i2c_read(1);     // read with ACK MPL115A2_data[1]  = i2c_read(1);     // read with ACK MPL115A2_data[2]  = i2c_read(1);     // read with ACK MPL115A2_data[3]  = i2c_read(1);     // read with ACK MPL115A2_data[4]  = i2c_read(1);     // read with ACK MPL115A2_data[5]  = i2c_read(1);     // read with ACK MPL115A2_data[6]  = i2c_read(1);     // read with ACK MPL115A2_data[7]  = i2c_read(1);     // read with ACK MPL115A2_data[8]  = i2c_read(1);     // read with ACK MPL115A2_data[9]  = i2c_read(1);     // read with ACK MPL115A2_data[10] = i2c_read(1);     // read with ACK MPL115A2_data[11] = i2c_read(1);     // read with ACK MPL115A2_data[12] = i2c_read(1);     // read with ACK MPL115A2_data[13] = i2c_read(1);     // read with ACK MPL115A2_data[14] = i2c_read(1);     // read with ACK MPL115A2_data[15] = i2c_read(0);     // read with noACK i2c_stop();           // I2C Bus Stop condition  printf(";MPL115A2 Data= "); for (x=0;x<16;x++)  {  printf("%02X ",MPL115A2_data[x]);  } printf("\r"); }
Here is some sample data I get from it.
 ;MPL115A2 Data= 64 C0 75 80 3D 9B B9 4A C7 46 32 BC 02 20 FD 60
;MPL115A2 Data= 65 00 76 80 3D 9B B9 4A C7 46 32 BC 02 20 FD 60
;MPL115A2 Data= 65 40 76 80 3D 9B B9 4A C7 46 32 BC 02 20 FD 60
;MPL115A2 Data= 65 00 76 C0 3D 9B B9 4A C7 46 32 BC 02 20 FD 60
;MPL115A2 Data= 65 80 75 C0 3D 9B B9 4A C7 46 32 BC 02 20 FD 60
;MPL115A2 Data= 65 00 75 40 3D 9B B9 4A C7 46 32 BC 02 20 FD 60
Regards, Mark Leman
10,168 次查看
admin
Specialist II
markleman,
I've been trying unsuccessfully for two days to start a new pressure and temp conversion with no avail.
In AN3785, under the 'Write Mode' header, it shows the commands and gives examples of how to write the 'start both conversions' byte string which shows as:
Start bit
Slave address (0x60)
Ack
Start both conversions (0x12)
Ack
Stop bit
But under the 'I2C Simplified' heading it show to write an additional byte of 0x01 after the 0x12 byte and you also have it your code. I added it and now it works, Do you know what is the 0x01 for? It's not documented anywhere in the sheet except in the 'I2C Simplified' header unless I'm not seeing it somewhere else.
Thanks!
Robert
10,168 次查看
sofie
hi,
I also use MPL115A but in SPI, I can read Temperature, pressure and coeffcicient whihout problem
but I'm not sure how to convert 10bit data receive in KPa or Celsuis degree
For example :
I get MSB pressure 0x5B
        LSB  pressure 0xC0
I do this : 0x5BC0 >>6 then  Pka = (65/1023)*Padc + 50
but I obtain 73KPa and I'm not at 2500 meters
How do you get the correct result ?
thanks
10,168 次查看
MPL115A2
I just don't know why the hell 'Freescale' made this device so confused with all the coeficients compensation calculation and not do it internally!!!
10,168 次查看
PJH
It's much cheaper and easier to do the math in another processor, rather than have the processing be built into the sensor.   I have to agree that it is awkward to figure out, but once done it is works well.  The original app note did have some errors in the description of the storage of the coefficients and the sample code is dependent on certain byte ordering of your processors.
The apps person was very helpful and I was able to get up and running within a day or so of getting the sample part.
I posted pretty much all the code I used to get this working in this forum, in the hope that others can benefit from the work I had to do.  Please look back at the other messages in this thread to see these examples.
if I had one suggestion for improvement, it would be to improve the noise on the device. The readings do bounce around quite a lot, but again a higher level processor with memory is easily able to implement a smoothing algorithm.
Good luck
10,168 次查看
MPL115A2
I'm totally agreed your points, its cheaper to have the cal' externally and thats more open to the users - once you understand the way to convert the coefficient values.
ok, I saw the programs from you and others as well, however, not everyone use C, and of cause not every one use large memory cpu/mcu as well, just think about if you have a 128bytes memory, (ram) and less than 2K code memory (flash or rom)
then your desgin may not be the same. Anyway, according to your experience, every problem solved after few days and the Freescale's support person/engineers are quite helpful, well, thats my third days, and holpfully problem can solved today, and wishing some one from Freescale can give me some helpfull hints.
Wish me luck.
cw.
10,168 次查看
PJH
Getting to the pressure is a multistep process.
First you need to read the pressureADC and the temperatureADC.  Both of these are 2 bytes.
pressureADC= (pressureMSB<<8+pressureLSB)>>6;
temperatureADC=(tempMSB<<8+tempLSB)>>6;
Next you need to use those 2 ADC values along with all the coefficients to calculate the pressure.
pressure= AO+(B1+C11*pressureADC+C12*temperatureADC)*pressureADC+(B2+C22*temperatureADC)*temperatureADC)
finally you make another correction
pressureC=(65/1023*pressure)+50;
That finally gives you a temperature compensated pressure in mBar.
The hardest thing I found was getting the coefficients to be read in correctly.
Peter
10,168 次查看
pmatil
I just managed to read something from the sensor. First of all, the coeffs C11 and C22 are all zero. Coeffs are like this (coeff1 coeff2 ... coeff12):
3E 98 B3 D2 C2 24 38 E0 00 00 00 00
And when I calculate the real pressure (pressure adc = 5C80, temp adc = 7F40) it says 918 hPa which cannot be correct since I'm at 25 m above sea level and pressure at sea level should be 1008 hPa.  It's very weird that C11 and C22 are all zero. Any ideas?
10,168 次查看
PJH
The coefficients are not all the same size,but are packed into a 12 bytes (96 bits) in registers x04 to x0F. The coeffs are really floating point numbers but the decimal point is in a different place in each number and some are negative etc.  So since I was unable to get the sample code to work due possibly to the byte endian nature of the data I wrote a function that can convert the bytes to the doubles.
First here is the code to download the coeffs.  Obviously the implementation of the I2C is left to the reader.
void CMPL115A::smileyvery-happy:ownloadCoeffs()
    int err=0;
    int resultL,resultH;
    BYTE data;
    iA0=0;
    iB1=0;
    iB2=0;
    iC11=0;
    iC12=0;
    iC22=0;
// Get A0
    err=m_I2C.ModuleReadByte(BAROMETER,0x05,&data);
    if(err==ERROR_SUCCESS) // Then we probably have a device connected. so assume rest of calls will succeed.
        resultL=INT8(data);
        m_I2C.ModuleReadByte(BAROMETER,0x04,&data);
        resultH=INT8(data);
        iA0=(resultH<<8)+(resultL&0x00FF);
        dA0=ConvertCoeffToDouble(iA0,16,12,3,0);
    // Get B1
        m_I2C.ModuleReadByte(BAROMETER,0x07,&data);
        resultL=INT8(data);
        m_I2C.ModuleReadByte(BAROMETER,0x06,&data);
        resultH=INT8(data);
        iB1=(resultH<<8)+(resultL&0x00FF);
        dB1=ConvertCoeffToDouble(iB1,16,2,13,0);
    // Get B2
        m_I2C.ModuleReadByte(BAROMETER,0x09,&data);
        resultL=INT8(data);
        m_I2C.ModuleReadByte(BAROMETER,0x08,&data);
        resultH=INT8(data);
        iB2=(resultH<<8)+(resultL&0x00FF);
        dB2=ConvertCoeffToDouble(iB2,16,1,14,0);
    // Get C12
        m_I2C.ModuleReadByte(BAROMETER,0x0B,&data);
        resultL=INT8(data);
        m_I2C.ModuleReadByte(BAROMETER,0x0A,&data);
        resultH=INT8(data);
        iC12=(resultH<<8)+(resultL&0x00FF);
        dC12=ConvertCoeffToDouble(iC12,14,0,13,9);
    // Get C11
        m_I2C.ModuleReadByte(BAROMETER,0x0D,&data);
        resultL=INT8(data);
        m_I2C.ModuleReadByte(BAROMETER,0x0C,&data);
        resultH=INT8(data);
        iC11=(resultH<<8)+(resultL&0x00FF);
        dC11=ConvertCoeffToDouble(iC11,11,0,10,11);
    // Get C22
        m_I2C.ModuleReadByte(BAROMETER,0x0F,&data);
        resultL=INT8(data);
        m_I2C.ModuleReadByte(BAROMETER,0x0E,&data);
        resultH=INT8(data);
        iC22=(resultH<<8)+(resultL&0x00FF);
        dC22=ConvertCoeffToDouble(iC22,11,0,10,15);
        m_InitSuccess=true;
    else
        m_InitSuccess=false;
and the here is the ConvertCoeffToDouble which takes the 2byte word and then parameters which describe the number of bits, integer bits, fractional bits and padbits. There may be more efficient ways to do this, but since it only has to be done once when the device is initialized it is not critical to optimize.
double ConvertCoeffToDouble(INT16 coeff,short bitCount,short iBits, short fracBits, short padBits)
// Utility function to convert the coeff's into floating point parameters.
// See Freescale App note AN3785 for details of how the parameters are stored.
    double result=0;
    bool s=false;
    bool bit;
    int fb=0;
// We start working our way through the bits from high to low.
// The incoming data is a 16bit integer which we have to shorten since the lower LSB's are empty if <16 bits. (see pg 15 of AN3785).
    if (bitCount<16)
    {// Make coeff the appropriate size
        coeff=coeff>>(16-bitCount);
// Sanity check that the parameters passed into the function make sense. We can't have more or less bits than the amount of data.
// Add 1 to account for sign bit.
    if((iBits+fracBits+1)!=bitCount)
        TRACE(_T("Error in parameters!!\n"));
        return 0;
//Sanity check that if we are padding the decimal point that we can't also have integer bits.
    if((padBits>0)&&(iBits>0))
        TRACE(_T("Error in parameters. iBits and padBits not consistent!!\n"));
        return 0;
    for(int b=bitCount;b>0;b--)
        bit=bool((int(pow(2.0,b-1))& coeff)>>(b-1)); // Get each bit in turn as a 1 or a 0.
        if (b==bitCount) // if this is the first bit (sign bit check if it is set)
            s=bit;
            if(s)
                coeff=~coeff+1; //Calculate 2's complement; //(See App note AN3785 middle of Pg15 for explanation.
        else // process the bits in turn.
            if(iBits>0)
            { // we have an integer bit;
                if(bit)
                    result+=pow(2.0,iBits-1);
                iBits--;
            else // we have a fractional bit
                fb++;
                if(bit)
                    result+= (1/pow(2.0,fb+padBits));
                fracBits--;
    if(s)
        result*=-1;
    TRACE(_T("Result=%f\n"),result);
    return result;
Only after you have converted all the coefficients to the correct  sign, significant digits etc, does the thing start to make sense and read correctly.
Peter
10,168 次查看
BapGuy
New to the game; however willing to learn. Thank you for your coding example. Do you have raw data and result so I can determine if I have converted to VB correctly? Thanks.
I used:
Padc 64 C0
Tadc 75 80
A0 - 3D 9B
B1 - B9 4A
B2 - C7 46
C12 - 32 BC
C11  - 02 20
C22 - FD 60
 my result was  105.13476438
10,168 次查看
pmatil
Thanks PJH but I believe I have converted them correctly. Or have I? At the moment the result Pcomp is 1067 which cannot be right since it should be in between 0 and 1023. Converted coeffs are:
a0 = 2003
b1 = -2.3118
b2 = -0.15836
c12 = 1.456E-10
c11 = 0
c12 = 0
Padc = 370
Tadc = 509
%3CLINGO-SUB%20id%3D%22lingo-sub-214595%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMPL115A%20%E5%AE%9A%E7%82%B9%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214595%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%E6%88%91%E6%83%B3%E5%BC%84%E6%B8%85%E6%A5%9A%E6%88%91%E4%BB%8E%E5%8E%8B%E5%8A%9B%E4%BC%A0%E6%84%9F%E5%99%A8%20MPL115A%20%E6%94%B6%E5%88%B0%E7%9A%84%E7%B3%BB%E6%95%B0%E3%80%82%E6%88%91%E5%8F%AF%E4%BB%A5%E6%88%90%E5%8A%9F%E8%AE%BF%E9%97%AE%20IIC%20%E6%80%BB%E7%BA%BF%E5%B9%B6%E8%8E%B7%E5%8F%96%E6%95%B0%E6%8D%AE%EF%BC%8C%E4%BD%86%E6%98%AF%20AN3785%20%E4%B8%AD%E6%8F%90%E4%BE%9B%E7%9A%84%E7%AE%97%E6%B3%95%E4%BC%BC%E4%B9%8E%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%EF%BC%88%E8%87%B3%E5%B0%91%E5%AF%B9%E6%88%91%E6%9D%A5%E8%AF%B4%E6%98%AF%E5%A6%82%E6%AD%A4%EF%BC%89%E3%80%82%E4%BB%94%E7%BB%86%E7%A0%94%E7%A9%B6%E8%BF%99%E4%BA%9B%E8%AF%84%E8%AE%BA%EF%BC%8C%E4%BC%9A%E5%8F%91%E7%8E%B0%E4%B8%80%E4%BA%9B%E9%97%AE%E9%A2%98%E3%80%82%20%20%E4%BE%8B%E5%A6%82%EF%BC%8C%E7%B3%BB%E6%95%B0%20C11%20%E8%A2%AB%E6%8F%8F%E8%BF%B0%E4%B8%BA%E6%97%A0%20int%20%E4%BD%8D%E5%92%8C%2010%20frac%20%E4%BD%8D%E7%9A%84%E6%9C%89%E7%AC%A6%E5%8F%B7%E6%95%B0%E3%80%82%20%20%E5%85%B1%E6%9C%89%2011%20%E4%B8%AA%E9%9B%B6%E3%80%82%20%20%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%88%91%E8%AE%A4%E4%B8%BA%E8%BF%99%E4%B8%AA%E6%95%B0%E5%AD%97%E7%9C%8B%E8%B5%B7%E6%9D%A5%E6%98%AF%E8%BF%99%E6%A0%B7%E7%9A%84%EF%BC%9A%3CBR%20%2F%3E%3CBR%20%2F%3ES0.00000000000%20F10%20F9%20F8%20F7%20F6%20F5%20F4%20F3%20F2%20F1%20F0%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%AF%B9%E6%88%91%E6%9D%A5%E8%AF%B4%EF%BC%8C%E8%BF%99%E4%B8%AA%E6%95%B0%E5%AD%97%E7%9A%84%E8%A1%A8%E7%A4%BA%E6%96%B9%E6%B3%95%E6%98%AF%20s(0%2C21)%EF%BC%8C%E4%BD%86%E6%B3%A8%E9%87%8A%E5%8D%B4%E8%AF%B4%E6%98%AF%20s(16%2C27)%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%BD%93%E6%88%91%E4%BB%8E%E4%BC%A0%E6%84%9F%E5%99%A8%E4%B8%AD%E6%8F%90%E5%8F%96%E6%95%B0%E6%8D%AE%E6%97%B6%EF%BC%8CC11%20%E6%98%BE%E7%A4%BA%E4%B8%BA%200x0340%E3%80%82%20%20%E8%BF%99%E6%98%AF%E4%B8%80%E4%B8%AA%202%20%E7%9A%84%E8%A1%A5%E7%A0%81%EF%BC%8C%E5%8F%AA%E4%BD%BF%E7%94%A8%E5%89%8D%2011%20%E4%BD%8D%EF%BC%8810%20%E4%B8%AA%E7%9F%AD%E8%AF%AD%E4%BD%8D%E5%92%8C%E7%AC%A6%E5%8F%B7%E4%BD%8D%EF%BC%89%E3%80%82%20%20%E5%9B%A0%E6%AD%A4%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%88%91%E5%B0%86%E5%85%B6%E8%BD%AC%E6%8D%A2%E4%B8%BA%E5%AE%9E%E6%95%B0%EF%BC%88%E8%BF%99%E5%B9%B6%E4%B8%8D%E6%98%AF%E6%88%91%E5%9C%A8%E5%A4%84%E7%90%86%E5%99%A8%E4%B8%AD%E4%BC%9A%E5%81%9A%E7%9A%84%E4%BA%8B%E6%83%85%EF%BC%8C%E5%8F%AA%E6%98%AF%E6%83%B3%E7%9C%8B%E7%9C%8B%E6%88%91%E7%9A%84%E7%90%86%E8%A7%A3%E6%98%AF%E5%90%A6%E6%AD%A3%E7%A1%AE%EF%BC%89%EF%BC%8C%E6%88%91%E5%B0%86%E5%BE%97%E5%88%B0%3CBR%20%2F%3E%3CBR%20%2F%3ES0.00000000000%200000%200011%20010x%20xxxx%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%BF%99%E5%B0%86%E5%BE%97%E5%88%B0%202%5E-17%2B%202%5E-18%20%2B%202%5E-20%20%3D%200.00001239776611328125%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%BF%99%E6%98%AF%E6%88%91%E7%9A%84%E7%90%86%E8%A7%A3%E8%8C%83%E5%9B%B4%EF%BC%8C%E6%88%91%E6%83%B3%E7%9F%A5%E9%81%93%E6%98%AF%E5%90%A6%E6%9C%89%E4%BA%BA%E8%83%BD%E7%A1%AE%E8%AE%A4%E6%88%91%E7%9A%84%E6%93%8D%E4%BD%9C%E6%98%AF%E5%90%A6%E6%AD%A3%E7%A1%AE%E3%80%82%20%20%E6%AD%A4%E5%A4%96%EF%BC%8C%E7%94%B1%E4%BA%8E%20AN3785%20%E4%B8%AD%E7%9A%84%E7%AE%97%E6%B3%95%E5%B0%86%E6%89%80%E6%9C%89%E5%86%85%E5%AE%B9%E9%83%BD%E4%BF%9D%E7%95%99%E5%9C%A8%E5%AE%9A%E7%82%B9%E4%B8%AD%EF%BC%8C%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%20lt1%EF%BC%88%E4%B8%80%E4%B8%AA%2032%20%E4%BD%8D%E7%9A%84%E5%80%BC%EF%BC%89%E5%A6%82%E4%BD%95%E5%88%86%E9%85%8D%E7%BB%99%20C11%20%E6%89%8D%E8%83%BD%E6%AD%A3%E7%A1%AE%E5%90%88%E7%90%86%E3%80%82%20%20%E5%BD%93%E6%88%91%E5%B0%86%200x0340%20%E8%B5%8B%E5%80%BC%E7%BB%99%20long%20%E6%97%B6%EF%BC%8C%E5%BE%97%E5%88%B0%E7%9A%84%E7%BB%93%E6%9E%9C%E6%98%AF%3CBR%20%2F%3E%3CBR%20%2F%3Elt1%200x00000340%3CBR%20%2F%3E%3D%200000%200000%200000%200000%200000%200011%20010x%20xxxx%3CBR%20%2F%3E%3CBR%20%2F%3E%EF%BC%8C%E6%89%80%E4%BB%A5%E4%BD%A0%E5%8F%AF%E4%BB%A5%E7%9C%8B%E5%88%B0%E6%88%91%E6%B2%A1%E6%9C%89%E6%8C%89%E7%85%A7%E4%BD%8D%E5%AE%BD%E8%A7%84%E8%8C%83%E6%AD%A3%E7%A1%AE%E5%AF%B9%E9%BD%90%E3%80%82%20%20%E4%BB%A5%E4%B8%8B%E6%98%AF%E4%BB%A3%E7%A0%81%E7%89%87%E6%AE%B5%E3%80%82%20%20%E8%BF%99%E4%BA%9B%E8%AF%84%E8%AE%BA%E5%AF%B9%E6%88%91%E6%9D%A5%E8%AF%B4%E6%AF%AB%E6%97%A0%E6%84%8F%E4%B9%89%EF%BC%8C%E6%89%80%E4%BB%A5%E4%BD%A0%E8%83%BD%E6%8F%90%E4%BE%9B%E7%9A%84%E4%BB%BB%E4%BD%95%E6%BE%84%E6%B8%85%E9%83%BD%E5%B0%86%E6%98%AF%E6%9C%80%E6%9C%89%E5%B8%AE%E5%8A%A9%E7%9A%84%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%2F%2F*******%20%E6%AD%A5%E9%AA%A4%201%20c11x1%3D%20c11%20*%20Padc%20%3CBR%20%2F%3E%20lt1%20%3D%20(S32)%20sic11%3B%2F%2Fs%20(16%2C27)%20s%20(N%2C%20f%2BZeroPad)%20%E6%9D%A5%E8%87%AA%20s%20(11%2C10)%20%2B11ZeroPad%20%3D%20s%20(11%2C22)%20%3D%20%26gt%3B%20Left%20Justified%20%3D%20s%20(16%2C27)-%E8%B0%A2%E8%B0%A2%E6%AF%94%E5%B0%94%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214630%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214630%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E7%94%A8%2068hc912b32%20%E7%9A%84%E6%97%A7%E6%B1%87%E7%BC%96%E5%99%A8%E7%BC%96%E5%86%99%E4%BA%86%E8%BF%99%E4%B8%AA%E4%BB%A3%E7%A0%81%3C%2FP%3E%3CP%3E%E8%AF%B7%E6%B3%A8%E6%84%8F%EF%BC%8C%E6%AF%8F%E4%B8%AA%E7%B3%BB%E6%95%B0%E9%83%BD%E6%94%BE%E5%9C%A8%E4%B8%80%E4%B8%AA%2032%20%E4%BD%8D%E5%8F%98%E9%87%8F%E4%B8%AD%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E7%9B%B8%E4%BF%A1%E8%BF%98%E6%9C%89%E4%BC%98%E5%8C%96%E7%9A%84%E4%BD%99%E5%9C%B0%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%20%20%3C%2FSPAN%3E%3CSTRONG%20style%3D%22%3A%20%3B%20color%3A%20%237f0055%3B%20font-size%3A%2010pt%3B%22%3E.include%3C%2FSTRONG%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%20%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%232a00ff%3B%20font-size%3A%2010pt%3B%22%3E%22globals.s%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232a00ff%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%20%20%3C%2FSPAN%3E%3CSTRONG%20style%3D%22%3A%20%3B%20color%3A%20%237f0055%3B%20font-size%3A%2010pt%3B%22%3E.%E5%8C%85%E6%8B%AC%3C%2FSTRONG%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%20%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%232a00ff%3B%20font-size%3A%2010pt%3B%22%3E%22hc12.s%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232a00ff%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010pt%3B%22%3E%3CSTRONG%3Ec12x2%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E.blkb%204%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010pt%3B%22%3E%3CSTRONG%3Ea1%3A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E.blkb%204%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010pt%3B%22%3E%3CSTRONG%3Ea1x1%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E.blkb%204%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010pt%3B%22%3E%3CSTRONG%3Ey1%3A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E.blkb%204%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010pt%3B%22%3E%3CSTRONG%3Ea2x2%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E.blkb%204%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010pt%3B%22%3E%3CSTRONG%3EPComp32%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E.blkb%204%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010pt%3B%22%3E%3CSTRONG%3Ebaro_fltr%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E.blkb%203%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010pt%3B%22%3E%3B***************************************************************************************************************%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E5%88%9D%E5%A7%8B%E5%8C%96%E5%B9%B6%E8%AF%BB%E5%8F%96%E7%B3%BB%E6%95%B0%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%20movb%20%230b00000000%2Csp0br%20%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E5%B0%86%20spi%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%204%20MHz%20%E6%97%B6%E9%92%9F%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010pt%3B%22%3E%3CSTRONG%3Eibaro%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%20bclr%20portb%2C%230b10000000%20%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E5%B0%86%20CS%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%E4%BD%8E%E7%94%B5%E5%B9%B3%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%20movb%20%23%2488%2Csp0dr%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E8%AF%BB%E5%8F%96%20a0%20msb%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%20brclr%20sp0sr%2C%23SPIF%2C.%20%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E7%AD%89%E5%BE%85%20spi%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Emovb%20%230%2C%20sp0dr%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20%E6%AD%A3%E5%9C%A8%E6%B8%85%E9%99%A4%E5%AD%97%E8%8A%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%20brclr%20sp0sr%2C%23SPIF%2C.%20%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E7%AD%89%E5%BE%85%20spi%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Eldaa%20sp0dr%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E8%8E%B7%E5%8F%96%20a0%20msb%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%20movb%20%23%248A%2Csp0dr%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E8%AF%BB%E5%8F%96%20a0%20LSB%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Ebrclr%20sp0sr%2C%23SPIF%2C.%20%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E7%AD%89%E5%BE%85%20spi%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Emovb%20%230%2C%20sp0dr%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20%E6%AD%A3%E5%9C%A8%E6%B8%85%E9%99%A4%E5%AD%97%E8%8A%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Ebrclr%20sp0sr%2C%23SPIF%2C.%20%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E7%AD%89%E5%BE%85%20spi%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Eldab%20sp0dr%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E8%8E%B7%E5%8F%96%20a0%20LSB%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Estd%20barocoA0%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%EF%BC%9B%E4%BF%9D%E5%AD%98%3C%2FSPAN%3E%E5%B7%B4%E7%BD%97%E7%B3%BB%E6%95%B0%20a0%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Emovb%20%23%248C%2Csp0dr%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E8%AF%BB%E5%8F%96%20b1%20%E7%9A%84%20MSB%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Ebrclr%20sp0sr%2C%23SPIF%2C.%20%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E7%AD%89%E5%BE%85%20spi%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Emovb%20%230%2C%20sp0dr%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20%E6%AD%A3%E5%9C%A8%E6%B8%85%E9%99%A4%E5%AD%97%E8%8A%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Ebrclr%20sp0sr%2C%23SPIF%2C.%20%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E7%AD%89%E5%BE%85%20spi%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Eldaa%20sp0dr%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E8%8E%B7%E5%8F%96%20b1%20MSB%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Emovb%20%23%248e%2Csp0dr%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E8%AF%BB%E5%8F%96%20b1%20LSB%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Ebrclr%20sp0sr%2C%23SPIF%2C.%20%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E7%AD%89%E5%BE%85%20spi%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Emovb%20%230%2C%20sp0dr%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20%E6%AD%A3%E5%9C%A8%E6%B8%85%E9%99%A4%E5%AD%97%E8%8A%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Ebrclr%20sp0sr%2C%23SPIF%2C.%20%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E7%AD%89%E5%BE%85%20spi%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Eldab%20sp0dr%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E8%8E%B7%E5%8F%96%20b1%20LSB%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Estd%20baroCob1%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%EF%BC%9B%E4%BF%9D%E5%AD%98%E5%B7%B4%E7%BD%97%E7%B3%BB%E6%95%B0%20b%3C%2FSPAN%3E%201%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Emovb%20%23%2490%2Csp0dr%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E8%AF%BB%E5%8F%96%20b2%20msb%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%20brclr%20sp0sr%2C%23SPIF%2C.%20%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E7%AD%89%E5%BE%85%20spi%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Emovb%20%230%2C%20sp0dr%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20%E6%AD%A3%E5%9C%A8%E6%B8%85%E9%99%A4%E5%AD%97%E8%8A%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%20brclr%20sp0sr%2C%23SPIF%2C.%20%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E7%AD%89%E5%BE%85%20spi%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Eldaa%20sp0dr%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E8%8E%B7%E5%8F%96%20b2%20msb%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%20movb%20%23%2492%2Csp0dr%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E8%AF%BB%E5%8F%96%20b2%20LSB%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%20brclr%20sp0sr%2C%23SPIF%2C.%20%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E7%AD%89%E5%BE%85%20spi%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Emovb%20%230%2C%20sp0dr%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20%E6%AD%A3%E5%9C%A8%E6%B8%85%E9%99%A4%E5%AD%97%E8%8A%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%20brclr%20sp0sr%2C%23SPIF%2C.%20%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E7%AD%89%E5%BE%85%20spi%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Eldab%20sp0dr%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E8%8E%B7%E5%8F%96%20b2%20LSB%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Estd%20baroCOB2%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%EF%BC%9B%E4%BF%9D%E5%AD%98%E5%B7%B4%E7%BD%97%E7%B3%BB%E6%95%B0%20b%3C%2FSPAN%3E%202%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%20movb%20%23%2494%2Csp0dr%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E8%AF%BB%E5%8F%96%20c12%20%E7%9A%84%20MSB%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%20brclr%20sp0sr%2C%23SPIF%2C.%20%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E7%AD%89%E5%BE%85%20spi%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Emovb%20%230%2C%20sp0dr%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20%E6%AD%A3%E5%9C%A8%E6%B8%85%E9%99%A4%E5%AD%97%E8%8A%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%20brclr%20sp0sr%2C%23SPIF%2C.%20%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E7%AD%89%E5%BE%85%20spi%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Eldaa%20sp0dr%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E8%8E%B7%E5%8F%96%20c12%20MSB%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%20movb%20%23%2496%2Csp0dr%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E8%AF%BB%E5%8F%96%20c12%20LSB%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%20brclr%20sp0sr%2C%23SPIF%2C.%20%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E7%AD%89%E5%BE%85%20spi%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Emovb%20%230%2C%20sp0dr%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20%E6%AD%A3%E5%9C%A8%E6%B8%85%E9%99%A4%E5%AD%97%E8%8A%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%20brclr%20sp0sr%2C%23SPIF%2C.%20%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E7%AD%89%E5%BE%85%20spi%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Eldab%20sp0dr%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E8%8E%B7%E5%8F%96%20c12%20LSB%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Emovb%20%230%2C%20sp0dr%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%3C%2FSPAN%3E%20%E9%A2%9D%E5%A4%96%E7%9A%84%E6%B8%85%E9%99%A4%E5%AD%97%E8%8A%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%20brclr%20sp0sr%2C%23SPIF%2C.%20%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E7%AD%89%E5%BE%85%20spi%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%20bset%20portb%2C%230b10000000%20%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E8%AE%BE%E7%BD%AE%20CS%20hi%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Estd%20barococ12%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%EF%BC%9B%E4%BF%9D%E5%AD%98%E5%B7%B4%E7%BD%97%E7%B3%BB%E6%95%B0%3C%2FSPAN%3E%20c12%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3Erts%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010pt%3B%22%3E%3CSTRONG%3ECompBaro%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3A%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%E4%B9%B3%E5%8C%96%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3BY%3AD%E4%B8%AD%E7%9A%84%E7%BB%93%E6%9E%9C%E9%9C%80%E8%A6%81%E7%A7%BB%E4%BD%8D11%E4%BD%8D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E6%88%96%E9%99%A4%E4%BB%A5%202%5E11%20%E5%8D%B3%202048%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Eldx%20%232048%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20****%3C%2FSPAN%3E%20%3CSTRONG%20style%3D%22%3A%20%3B%20color%3A%20%237f9fbf%3B%20font-size%3A%2010pt%3B%22%3E%E5%BE%85%E5%8A%9E%E4%BA%8B%E9%A1%B9%3C%2FSTRONG%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E6%88%96%E8%80%85%E5%8F%AF%E4%BB%A5%E8%BF%9B%E8%A1%8C%203%20%E6%AC%A1%E7%A7%BB%E4%BD%8D%E7%84%B6%E5%90%8E%E4%BB%8E%E4%B8%AD%E9%97%B4%E5%AD%97%E8%8A%82%E5%8A%A0%E8%BD%BD%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E6%9D%A5%E5%AE%8C%E6%88%90%E5%85%B6%E4%BB%96%208%20%E4%B8%AA%E6%AF%94%E7%89%B9%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Esty%20c12x2%2B2%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E4%BB%85%E4%BF%9D%E5%AD%98%E4%B8%BA%2016%20%E4%BD%8D%20****%20%3B%2F%20*%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3EADCA%20A1%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E4%BF%9D%E7%95%99%E7%AC%A6%E5%8F%B7%E4%BD%8D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Eldd%20a1%2B2%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E8%8E%B7%E5%8F%96%E4%BD%8E%2016%20%E4%BD%8D%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%E6%88%96%20PComp32%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E7%A7%BB%E4%BD%8D%201%20%E4%BD%8D%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20%3C%2FSPAN%3E%3CSTRONG%20style%3D%22%3A%20%3B%20color%3A%20%237f9fbf%3B%20font-size%3A%2010pt%3B%22%3E%E5%BE%85%E5%8A%9E%E4%BA%8B%E9%A1%B9%3C%2FSTRONG%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E6%9F%A5%E7%9C%8B%E6%AD%A4%E6%96%87%E4%BB%B6%E4%BB%A5%E8%8E%B7%E5%BE%97%E6%9C%80%E4%BD%B3%E5%88%86%E8%BE%A8%E7%8E%87%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Eldd%20pcomp32%2B1%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%EF%BC%9B%E8%8E%B7%E5%8F%96%E4%B8%AD%E9%97%B4%E5%AD%97%E8%8A%82%20%E6%9C%89%E6%95%88%E7%A7%BB%E5%8A%A8%208%20%E4%BD%8D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Eldx%20%2316394%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%201023...%20%E4%BA%8C%E8%BF%9B%E5%88%B6%E5%88%86%E6%95%B0%E4%B9%98%E4%BB%A5%2016%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E4%BD%BF%E7%94%A8%E6%8C%87%E6%95%B0%E4%B8%BA%2015%20%E7%9A%84%20IRR%20%E8%BF%87%E6%BB%A4%E5%99%A8%E6%9D%A5%E6%B6%88%E9%99%A4%E5%99%AA%E9%9F%B3%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%20subd%20AmbBaro%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E5%87%8F%E5%8E%BB%E6%9C%80%E5%90%8E%E4%B8%80%E4%B8%AA%E6%BB%A4%E6%B3%A2%E5%90%8E%E7%9A%84%E5%B7%B4%E7%BD%97%E5%80%BC%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%20psha%20%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E4%BF%9D%E5%AD%98%E6%A0%87%E5%BF%97%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%20addd%20baro_fltr%2B1%20%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%EF%BC%9B%E7%B4%AF%E5%8A%A0%E5%99%A8%E5%8A%A0%E6%B3%95%20lsword%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Estd%20baro_fltr%2B1%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%E6%9B%B4%E6%96%B0%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%20%E5%AD%97%E8%8A%82%20%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20msbyte%20%E5%B7%AE%E5%80%BC%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%20tfr%20b%2Cd%20%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%EF%BC%9B%E5%B0%86%E6%A0%87%E5%BF%97%E6%89%A9%E5%B1%95%E5%88%B0%20acca%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%20adca%20baro_fltr%20%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E5%B0%86%E5%B8%A6%E8%BF%9B%E4%BD%8D%E7%9A%84%E5%8A%A0%E6%B3%95%E8%BF%90%E7%AE%97%E5%8A%A0%E5%88%B0%20msbyte%20%E7%B4%AF%E5%8A%A0%E5%99%A8%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%20staa%20baro_fltr%20%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E6%9B%B4%E6%96%B0%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%20ldd%20baro_fltr%20%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E5%9C%A8%20msword%20%E4%B8%AD%E6%98%BE%E7%A4%BA%20IIR%20%E6%BB%A4%E6%B3%A2%E7%BB%93%E6%9E%9C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%20pshd%20%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E5%88%B0%E5%A0%86%E6%A0%88%E4%B8%8A%E7%9A%84%20temp%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%20ldab%20baro_fltr%2B2%20%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20%E7%94%A8%E4%BA%8E%E5%B7%A6%E7%A7%BB%E7%9A%84%20lsbyte%20%E8%BF%87%E6%BB%A4%E5%99%A8%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%20ldaa%20%2315%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E6%BB%A4%E6%B3%A2%E5%99%A8%E6%8E%A7%E5%88%B6%EF%BC%8C0%20%3D%20%E6%9C%80%E5%B0%8F%E6%BB%A4%E6%B3%A2%E9%A2%91%E7%8E%87%EF%BC%8C15%20%3D%20%E6%9C%80%E5%A4%A7%E6%BB%A4%E6%B3%A2%E9%A2%91%E7%8E%87%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E9%80%92%E5%87%8F%E6%97%B6%E7%9A%84%E7%BF%BB%E8%BD%AC%E4%BD%8D%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%20eora%20%23%24F%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E5%A6%82%E6%9E%9C%E8%BF%98%E4%B8%8D%E5%A4%9F%EF%BC%8C***%20%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20Higer%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%20%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E5%87%8F%E5%B0%91%E8%BF%87%E6%BB%A4%20%3D%26gt%3B%20%E6%9B%B4%E5%A4%9A%E7%A7%BB%E4%BD%8D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010pt%3B%22%3E%3CSTRONG%3Ebfc1%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%20beq%20bfc2%20%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E5%BC%80%E5%A7%8B%E7%A7%BB%E4%BD%8D%E5%BE%AA%E7%8E%AF%E4%BB%A5%E5%87%8F%E5%B0%91%E8%BF%87%E6%BB%A4%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%20lslb%20%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E5%B7%A6%E7%A7%BB%20lsbyte%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%201%2Cs%20%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%EF%BC%9B%E8%BD%AC%E5%8F%98%E4%B8%BA%E8%BF%87%E6%BB%A4%E5%8E%8B%E5%8A%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%20%E6%BB%BE%E5%8B%95%20%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E6%AF%AB%E5%AD%97%E8%8A%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%20%E5%8D%81%E8%BF%9B%E5%88%B6%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E5%87%8F%E5%8E%BB%E7%AC%AC%204%20%E4%BD%8D%E7%9A%84%20dec%20%E7%A7%BB%E4%BD%8D%E8%AE%A1%E6%95%B0%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%20bra%20bfc1%20%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E9%87%8D%E5%A4%8D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010pt%3B%22%3E%3CSTRONG%3Ebfc2%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%20%20puld%20%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20%E6%A3%80%E7%B4%A2%E7%BB%93%E6%9E%9C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Estd%20ambBaro%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3B%20%E7%BB%93%E6%9E%9C%E4%B8%BA%20kpa%3D%20mbar*%3C%2FSPAN%3E%2010%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-size%3A%2010pt%3B%22%3E%E6%9D%B0%E5%85%8B%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214629%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214629%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%B0%A2%E8%B0%A2%E4%BD%A0%EF%BC%8C%E6%89%98%E9%A9%AC%E6%96%AF%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E7%8E%B0%E5%9C%A8%E6%98%8E%E7%99%BD%E4%BA%86%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EDave%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214628%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Re%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214628%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%97%A8%EF%BC%8C%E6%88%B4%E5%A4%AB%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%88%9A%E6%89%8D%E5%B7%B2%E7%BB%8F%E5%9C%A8%E4%BD%A0%E7%9A%84%20SR%201-1348149811%20%E4%B8%AD%E8%A7%A3%E9%87%8A%E8%BF%87%E4%BA%86%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%A6%96%E5%85%88%EF%BC%8C%E6%82%A8%E9%9C%80%E8%A6%81%E8%80%83%E8%99%91%E5%88%B0%20c12_LSB%20%E7%9A%84%E6%9C%80%E5%90%8E%E4%B8%A4%E4%BD%8D%E4%B8%BA%E9%9B%B6%EF%BC%8C%E5%A6%82%E6%95%B0%E6%8D%AE%E8%A1%A8%E7%AC%AC%205%20%E9%A1%B5%E6%89%80%E7%A4%BA%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ec12%20MSB%20%E5%AD%97%E8%8A%82%20%3D%20c12%20%5B13%3A6%5D%20%3D%20%5Bb13%E3%80%81b12%E3%80%81b11%E3%80%81b10%E3%80%81b9%E3%80%81b8%E3%80%81b7%E3%80%81b6%5D%3C%2FP%3E%3CP%3Ec12%20LSB%20%E5%AD%97%E8%8A%82%20%3D%20c12%20%5B5%3A0%5D%20%26amp%3B%20%E2%80%9C00%E2%80%9D%20%3D%20%5Bb5%E3%80%81b4%E3%80%81b3%E3%80%81b2%E3%80%81b1%E3%80%81b0%E3%80%810%E3%80%810%E3%80%810%5D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%84%B6%E5%90%8E%EF%BC%8Cc12%20%E7%B3%BB%E6%95%B0%E7%9A%84%E6%A0%BC%E5%BC%8F%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ec12%20%3D%20b13%200%20.000%20000%20000%20B12%20B11%20B10%20B9%20B8%20B7%20B6%20B5%20B4%20B3%20B2%20B1%20B0%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%AF%8F%E4%B8%AA%E5%B0%8F%E6%95%B0%E4%BD%8D%E7%9A%84%E5%80%BC%E4%B8%BA%201%20%2F%202%5E%3CSPAN%20lang%3D%22CS%22%3E(9%2B13)%EF%BC%8C16%20%E4%BD%8D%E7%9A%84%20c12%20%E5%80%BC%E9%9C%80%E8%A6%81%E5%85%88%E5%8F%B3%E7%A7%BB%202%EF%BC%88%E6%88%96%E9%99%A4%E4%BB%A5%204%EF%BC%89%EF%BC%8C%E6%89%8D%E8%83%BD%E5%BE%97%E5%88%B0%2013%20%E4%B8%AA%E5%B0%8F%E6%95%B0%E4%BD%8D%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22CS%22%3E%E4%BB%A5%E6%88%91%E4%BB%AC%E7%9A%84%E4%BE%8B%E5%AD%90%E4%B8%BA%E4%BE%8B%EF%BC%8C16%20%E4%BD%8D%20c12%20%3D%200x33C8%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22CS%22%3E%E9%82%A3%E4%B9%88%20c12%26gt%3B%26gt%3B%202%20%3D%200x33C8%26gt%3B%26gt%3B%202%20%3D%200xCF2%20%3D%203314%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22CS%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22CS%22%3Ec12%20%E7%B3%BB%E6%95%B0%20%3D%203314%20%2F%202%5E22%20%3D%200.00079%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22CS%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22CS%22%3E%E5%B8%8C%E6%9C%9B%E5%AF%B9%E6%82%A8%E6%9C%89%E6%89%80%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22CS%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22CS%22%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22CS%22%3E%E6%89%98%E9%A9%AC%E6%96%AF%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214627%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214627%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%93%A6%EF%BC%8C%E5%AF%B9%E4%B8%8D%E8%B5%B7%E3%80%82%20%E6%88%91%E7%9C%8B%E5%88%B0%202%20%E4%B8%AA%20LSB%20%E5%9D%87%E4%B8%BA%E9%9B%B6%E3%80%82%20%E4%BD%86%E6%88%91%E8%BF%98%E6%98%AF%E4%B8%8D%E6%98%8E%E7%99%BD%E4%BD%A0%E6%98%AF%E5%A6%82%E4%BD%95%E5%BE%97%E5%88%B0%200.000790%20%E7%9A%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ed.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214626%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214626%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%93%8E%E5%91%80%EF%BC%8C%E6%88%91%E7%9F%A5%E9%81%93%E8%BF%99%E4%B8%AA%E8%AF%9D%E9%A2%98%E5%B7%B2%E7%BB%8F%E6%9C%89%E5%A5%BD%E5%87%A0%E5%B9%B4%E4%BA%86%E3%80%82%20%E4%BD%86%E6%88%91%E5%BE%88%E7%AC%A8%E3%80%82%20%E6%AF%94%E5%B0%94%E7%9A%84%E5%8E%9F%E5%B8%96%E6%98%AF%E5%85%B3%E4%BA%8E%20c12%20%E7%9A%84%EF%BC%8C%E4%BB%96%E8%AF%B4%E6%95%B0%E6%8D%AE%E8%A1%A8%E6%98%BE%E7%A4%BA%E6%9C%89%2011%20%E4%B8%AA%E7%84%8A%E7%9B%98%E9%9B%B6%E3%80%82%20%E6%88%91%E7%9A%84%E6%95%B0%E6%8D%AE%E8%A1%A8%E4%B8%8A%E5%86%99%E7%9D%80%209%20%E4%B8%AA%E5%9E%AB%E9%9B%B6%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%95%B0%E6%8D%AE%E8%A1%A8%E4%B8%AD%20c12%20%E7%9A%84%E5%80%BC%E6%98%AF%200x33C8%EF%BC%8C%E8%BF%99%E8%AE%A9%E6%88%91%E4%B8%80%E5%A4%B4%E9%9B%BE%E6%B0%B4%E3%80%82%20%E6%88%91%E4%B8%8D%E6%98%8E%E7%99%BD%E4%BD%A0%E6%98%AF%E5%A6%82%E4%BD%95%E4%BB%8E%E8%BF%99%E4%B8%AA%E6%95%B0%E5%80%BC%E5%BE%97%E5%87%BA%200.000790%20%E7%9A%84%E3%80%82%20%E5%A6%82%E6%9E%9C%E5%9C%A8%20F12%20-%20F0%20%E4%B9%8B%E9%97%B4%E5%A1%AB%E5%85%85%209%20%E4%B8%AA%200%EF%BC%8C%E5%B0%B1%E4%BC%9A%E5%BE%97%E5%88%B0%200000000001001....%20%E8%BF%99%E6%84%8F%E5%91%B3%E7%9D%80%E5%89%8D%201%20%E4%BD%8D%E5%B0%86%E6%98%AF%202%5E%5E-10%EF%BC%8C%E6%88%96%200.0009xxx%EF%BC%8C%E5%B7%B2%E7%BB%8F%E5%A4%A7%E4%BA%8E%200.000790%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%AF%B9%E4%B8%8D%E8%B5%B7%EF%BC%8C%E6%88%91%E4%B8%8D%E6%98%8E%E7%99%BD%E3%80%82%20%E6%9C%89%E4%BA%BA%E6%9C%89%E4%BB%80%E4%B9%88%E6%83%B3%E6%B3%95%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ed.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214625%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214625%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%A6%81%E8%BD%AC%E6%8D%A2%20c12%20%E7%9A%84%E7%B3%BB%E6%95%B0%E5%90%97%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EMSB%20c12%20%3D%2000110000%20%20%3C%2FP%3E%3CP%3ELSB%20c12%20%3D%20101011xx%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ECoef%20c12%20%3DS0%2C%20000000000%2000%20110000101011xx%20%3D%202%5E-10%20%2B%202%5E-11%20%2B%202%5E-16%20%2B%202%5E-18%20%2B%202%5E-20%20%2B%202%5E-21%20%3D%200%2C001485%20%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%98%AF%E8%BF%99%E6%A0%B7%E5%90%97%EF%BC%9F%20%3CBR%20%2F%3E%3CBR%20%2F%3E%20%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214624%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214624%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CBR%20%2F%3E%3CP%3E%E5%97%A8%EF%BC%8C%E5%A6%88%E5%A6%88%E3%80%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%BD%A0%E7%9A%84%E9%97%AE%E9%A2%98%E8%A7%A3%E5%86%B3%E4%BA%86%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%B4%9F%E5%8E%8B%E5%92%8C%20PADC%20%E5%80%BC%20%3D%20990%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%AD%A4%E8%87%B4%E6%95%AC%E7%A4%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214623%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214623%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%BD%BC%E5%BE%97%EF%BC%8C%E8%AF%B7%E8%A7%A3%E9%87%8A%E4%B8%80%E4%B8%8B%E4%BD%A0%E6%98%AF%E5%A6%82%E4%BD%95%E8%AE%A1%E7%AE%97%20C12%20%E7%9A%84%E3%80%82AN3785%20%E8%AF%B4%20dec%20pt%20zero%20pad%3D9%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C9%220%22%20%E5%90%8E%22%20%E3%80%82%22%20%E5%A6%82%E6%9E%9C%E6%88%91%E8%BF%99%E6%A0%B7%E5%81%9A%EF%BC%8C%E5%B0%B1%E6%97%A0%E6%B3%95%E8%8E%B7%E5%BE%97%E5%8F%AF%E6%8E%A5%E5%8F%97%E7%9A%84%E7%BB%93%E6%9E%9C%E3%80%82%E7%94%9A%E8%87%B3%E6%89%80%E6%9C%89%E5%85%B6%E4%BB%96%E5%80%BC%E9%83%BD%E4%B8%8E%E4%BD%A0%E7%9A%84%E5%87%A0%E4%B9%8E%E7%9B%B8%E5%90%8C%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EMichael%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214622%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214622%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%96%B0%E6%89%8B%EF%BC%8C%E4%BD%86%E6%84%BF%E6%84%8F%E5%AD%A6%E4%B9%A0%E3%80%82%E6%84%9F%E8%B0%A2%E6%82%A8%E6%8F%90%E4%BE%9B%E7%9A%84%E7%BC%96%E7%A0%81%E7%A4%BA%E4%BE%8B%E3%80%82%E6%82%A8%E6%98%AF%E5%90%A6%E6%9C%89%E5%8E%9F%E5%A7%8B%E6%95%B0%E6%8D%AE%E5%92%8C%E7%BB%93%E6%9E%9C%EF%BC%8C%E4%BB%A5%E4%BE%BF%E6%88%91%E7%A1%AE%E5%AE%9A%E6%98%AF%E5%90%A6%E5%B7%B2%E6%AD%A3%E7%A1%AE%E8%BD%AC%E6%8D%A2%E4%B8%BA%20VB%EF%BC%9F%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E7%94%A8%E7%9A%84%E6%98%AF%3C%2FP%3E%3CP%3EPadc%2064%20C0%20%3C%2FP%3E%3CP%3ETadc%2075%2080%20%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EA0%20-%203D%209B%20%3C%2FP%3E%3CP%3EB1%20-%20B9%204A%20%3C%2FP%3E%3CP%3EB2%20-%20C7%2046%20%3C%2FP%3E%3CP%3E%E5%85%AC%E5%85%83%E5%89%8D%2012%20-%2032%20%E5%B9%B4%20%3C%2FP%3E%3CP%3EC11%20-%2002%2020%20%3C%2FP%3E%3CP%3EC22%20-%20FD%2060%20%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E7%9A%84%E7%BB%93%E6%9E%9C%E6%98%AF%20105.13476438%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214621%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214621%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E8%BF%9E%E6%8E%A5%E8%BF%99%E4%B8%AA%E8%AE%BE%E5%A4%87%EF%BC%8C%E4%BD%86%E9%81%87%E5%88%B0%E4%BA%86%E4%B8%80%E4%BA%9B%E9%97%AE%E9%A2%98%E3%80%82%E6%88%91%E4%BB%8E%E8%AE%BE%E5%A4%87%E4%B8%8A%E5%BE%97%E5%88%B0%E7%9A%84%E7%B3%BB%E6%95%B0%E5%92%8C%E8%AF%BB%E6%95%B0%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FP%3E%3CBR%20%2F%3E%3CP%3Ea0%3A3b99%20b1%3Affffb8b9%20b2%3Affffc24d%20c12%3A3274%20c11%3A0%20c22%3A0%20Padc%3A157%20Tadc%3A1f5%3C%2FP%3E%3CP%3EPadc%3A343%20Tadc%3A501%3C%2FP%3E%3CP%3E%E6%B8%A9%E5%BA%A6%EF%BC%9A%2026.536017%20%E6%91%84%E6%B0%8F%E5%BA%A6%3C%2FP%3E%3CP%3E%E5%8E%8B%E5%8A%9B%EF%BC%9A%2051.450000%20%E5%8D%83%E5%B8%95%3C%2FP%3E%3CP%3E%E8%A1%A5%E5%81%BF%E5%8E%8B%E5%8A%9B%EF%BC%9A%2091.935486%20kPA%20%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%9C%A8%E8%AE%BA%E5%9D%9B%E5%89%8D%E9%9D%A2%E4%BD%BF%E7%94%A8%E6%B5%AE%E7%82%B9%E7%B3%BB%E6%95%B0%E5%87%BD%E6%95%B0%E6%88%91%E5%BE%97%E5%88%B0%E4%BA%86%E8%BF%99%E4%BA%9B%E5%80%BC%EF%BC%9A%3C%2FP%3E%3CP%3EA0_D%3A1906.250000%3C%2FP%3E%3CP%3Eb1_d%3A-2.056824%3C%2FP%3E%3CP%3Eb2_d%3A-0.240997%3C%2FP%3E%3CP%3Ec12_d%3A0.000192%3C%2FP%3E%3CP%3Ec11_d%3A0.000000%3C%2FP%3E%3CP%3Ec22_d%3A0.000000%20%3C%2FP%3E%3CP%3E%E5%8E%8B%E5%8A%9B_d%EF%BC%9A120.723752%20%E5%8D%83%E5%B8%95%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E5%B0%86%E8%BF%99%E4%BA%9B%E5%8F%8C%E6%95%B0%E5%80%BC%E6%8F%90%E5%8F%96%E5%87%BA%E6%9D%A5%EF%BC%8C%E7%84%B6%E5%90%8E%E4%BD%BF%E7%94%A8......%E6%9D%A5%E8%AE%A1%E7%AE%97%EF%BC%9A%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EPcomp%20%3D%20a0_D%20%2B%20(b1_D%20%2B%20c11_D*Padc%20%2B%20c12_D*Tadc)*Padc%20%2B%20(b2_D%20%2B%20c22_D*Tadc)*Tadc%3C%2FP%3E%3CP%3E%E7%84%B6%E5%90%8E%E4%BD%BF%E7%94%A8%EF%BC%8865.0%2F1023.0*Pcomp%2B%2050%EF%BC%8C%E6%88%91%E5%BE%97%E5%88%B0%E5%8E%8B%E5%8A%9B_d%E3%80%82%E6%88%91%E9%9C%80%E8%A6%81%E5%81%9A%E4%BB%80%E4%B9%88%E7%89%B9%E5%88%AB%E7%9A%84%E4%BA%8B%E6%83%85%E5%90%97%EF%BC%9F%E5%9B%A0%E4%B8%BA%E8%BF%99%E4%B8%A4%E4%B8%AA%E6%95%B0%E5%AD%97%E9%83%BD%E4%B8%8D%E7%AC%A6%E5%90%88%E6%88%91%E9%A2%84%E8%AE%A1%E7%9A%84%20101%20%E5%8D%83%E5%B8%95%EF%BC%8C%E6%9B%B4%E8%AE%A9%E4%BA%BA%E5%9B%B0%E6%83%91%E7%9A%84%E6%98%AF%E8%BF%99%E4%BA%9B%E6%95%B0%E5%AD%97%E9%83%BD%E4%B8%8D%E4%B8%80%E6%A0%B7%E3%80%82%E7%AC%AC%E4%B8%80%E4%B8%AA%E8%A1%A5%E5%81%BF%E5%8E%8B%E5%8A%9B%E5%80%BC%E6%98%AF%E6%A0%B9%E6%8D%AE%E5%BA%94%E7%94%A8%E7%AC%94%E8%AE%B0%E8%A1%A8%E8%AE%A1%E7%AE%97%E7%9A%84%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214620%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214620%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%A5%BD%E4%BA%86%EF%BC%8C%E6%88%91%E7%BB%88%E4%BA%8E%E6%89%BE%E5%88%B0%E9%97%AE%E9%A2%98%E6%89%80%E5%9C%A8%E4%BA%86%E3%80%82%E9%97%AE%E9%A2%98%E5%87%BA%E5%9C%A8%E6%95%B0%E6%8D%AE%E7%B1%BB%E5%9E%8B%20int%20%E4%B8%8A%E3%80%82%E6%88%91%E7%9A%84%E6%84%8F%E6%80%9D%E6%98%AF%E5%AE%83%E6%9C%89%2016%20%E4%BD%8D%EF%BC%88%E5%A6%82%20gcc%E3%80%81borland%20c%20%E7%AD%89%EF%BC%89%EF%BC%8C%E4%BD%86%E5%AE%9E%E9%99%85%E4%B8%8A%E5%AE%83%E6%9C%89%2032%20%E4%BD%8D%E3%80%82%E5%9B%A0%E6%AD%A4%E8%B4%9F%E6%95%B0%E4%B8%8D%E6%98%AF%E8%B4%9F%E6%95%B0...%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%A7%A3%E5%86%B3%E5%8A%9E%E6%B3%95%E6%98%AF%E5%B0%86%E6%89%80%E6%9C%89%20int%20%E6%94%B9%E4%B8%BA%20short%EF%BC%88%E8%87%B3%E5%B0%91%E5%9C%A8%20CW%206.3%20%E4%B8%AD%EF%BC%89%E3%80%82%3CIMG%20alt%3D%22%E7%AC%91%E4%B8%80%E7%AC%91%22%20class%3D%22emoticon%20emoticon-smileysad%22%20id%3D%22smileysad%22%20src%3D%22http%3A%2F%2Ffreescale.i.lithium.com%2Fi%2Fsmilies%2F16x16_smiley-sad.gif%22%20title%3D%22%E7%AC%91%E8%84%B8%E6%82%B2%E4%BC%A4%22%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214619%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214619%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHI%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%9C%89%E8%B0%81%E8%A7%A3%E5%BC%80%E4%BA%86%E8%BF%99%E4%B8%AA%E6%95%B0%E5%AD%A6%E4%B9%8B%E8%B0%9C%EF%BC%9F%E6%88%91%E7%BB%88%E4%BA%8E%E5%8F%AF%E4%BB%A5%E8%AF%BB%E5%8F%96%E4%BC%A0%E6%84%9F%E5%99%A8%E7%9A%84%E6%95%B0%E6%8D%AE%E4%BA%86%EF%BC%8C%E4%BD%86%E6%88%91%E6%97%A0%E6%B3%95%E9%80%9A%E8%BF%87%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E4%B8%AD%E6%8F%8F%E8%BF%B0%E7%9A%84%E6%95%B0%E5%AD%A6%E8%BF%90%E7%AE%97%E3%80%82%E7%AC%AC%2017-18%20%E9%A1%B5%E7%9A%84%E8%AF%B4%E6%98%8E%E3%80%82%E4%BD%9C%E4%B8%BA%20siPcomp%EF%BC%8C%E6%88%91%E5%BE%97%E5%88%B0%E4%BA%86%E5%A4%A7%E7%BA%A6%205726%EF%BC%8C%E5%A4%A7%E5%A4%A7%E8%B6%85%E8%BF%87%E4%BA%86%201023...%3C%2FP%3E%3CP%3E%E7%B3%BB%E6%95%B0%E6%B2%A1%E6%9C%89%E9%97%AE%E9%A2%98%EF%BC%88%E5%A4%84%E7%90%86%E4%B8%BA%E6%B5%AE%E5%8A%A8%EF%BC%8C%E4%BB%85%E4%BE%9B%E5%8F%82%E8%80%83%EF%BC%9A%20%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20monospace%3B%20font-size%3A%208.33333px%3B%20white-space%3A%20pre-wrap%3B%22%3EA0%20%E7%BB%93%E6%9E%9C%20%3D%202101%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20monospace%3B%20font-size%3A%208.33333px%3B%20white-space%3A%20pre-wrap%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20monospace%3B%20font-size%3A%208.33333px%3B%20white-space%3A%20pre-wrap%3B%22%3EB1%20%E7%BB%93%E6%9E%9C%20%3D%20-2.4163818359375%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20monospace%3B%20font-size%3A%208.33333px%3B%20white-space%3A%20pre-wrap%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20monospace%3B%20font-size%3A%208.33333px%3B%20white-space%3A%20pre-wrap%3B%22%3EB2%20%E7%BB%93%E6%9E%9C%20%3D%20-1.2173461914062%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20monospace%3B%20font-size%3A%208.33333px%3B%20white-space%3A%20pre-wrap%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20monospace%3B%20font-size%3A%208.33333px%3B%20white-space%3A%20pre-wrap%3B%22%3EC12%20%E7%BB%93%E6%9E%9C%20%3D%200.00083708763122559%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20monospace%3B%20font-size%3A%208.33333px%3B%20white-space%3A%20pre-wrap%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20monospace%3B%20font-size%3A%208.33333px%3B%20white-space%3A%20pre-wrap%3B%22%3EC11%20%E7%BB%93%E6%9E%9C%20%3D%200%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20monospace%3B%20font-size%3A%208.33333px%3B%20white-space%3A%20pre-wrap%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20monospace%3B%20font-size%3A%208.33333px%3B%20white-space%3A%20pre-wrap%3B%22%3EC22%20%E7%BB%93%E6%9E%9C%20%3D%200%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%BB%A3%E7%A0%81%E5%AE%8C%E5%85%A8%E6%98%AF%E4%BB%8E%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E4%B8%AD%E5%A4%8D%E5%88%B6%E7%B2%98%E8%B4%B4%E7%9A%84%E3%80%82%E6%B3%A8%E6%84%8F%EF%BC%8C%E4%BD%86%E7%BB%93%E6%9E%9C%E5%8D%B4%E5%AE%8C%E5%85%A8%E6%98%AF%E7%96%AF%E7%8B%82%E7%9A%84...%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%B0%81%E6%9C%89%E5%8F%AF%E7%94%A8%E7%9A%84%E4%BB%A3%E7%A0%81%E7%89%87%E6%AE%B5%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E7%9A%84%E6%95%B0%E6%8D%AE%E5%9C%A8%E8%BF%99%E9%87%8C%EF%BC%88%E5%8E%8B%E5%8A%9B%E3%80%81%E6%B8%A9%E5%BA%A6%E3%80%81%E7%B3%BB%E6%95%B0%EF%BC%89%EF%BC%9A%20%3CSPAN%20style%3D%22font-family%3A%20monospace%3B%20font-size%3A%208.33333px%3B%20white-space%3A%20pre-wrap%3B%22%3E5B%2040%2081%2080%2041%20A8%20B2%20AD%20B2%2017%2036%20DC%2000%2000%2000%2000%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84%E4%BB%A3%E7%A0%81%E5%9C%A8%E8%BF%99%E9%87%8C%EF%BC%9A%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CPRE%20translate%3D%22no%22%3E%3CSTRONG%3Eunsigned%20char%20mpl115a_raw_data%5B16%5D%3Bunsigned%20int%20mpl115a_p%3Bunsigned%20int%20mpl115a_t%3Bsigned%20int%20mpl115a_a0%3Bsigned%20int%20mpl115a_b1%3Bsigned%20int%20mpl115a_b2%3Bsigned%20int%20mpl115a_c12%3Bsigned%20int%20mpl115a_c11%3Bsigned%20int%20mpl115a_c22%3B%3C%2FSTRONG%3E%2F%2F%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%2F%2F%20MPL115A%20Placing%20Coefficients%20into%2016%20bit%20variables%2F%2F%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3CSTRONG%3Evoid%20mpl115a_raw_dissection(void)%7B%20mpl115a_p%20%3D%20(unsigned%20int)mpl115a_raw_data%5B0%5D%20%26lt%3B%26lt%3B8%3B%20mpl115a_p%20%2B%3D%20(unsigned%20int)mpl115a_raw_data%5B1%5D%20%26amp%3B%200x00FF%3B%20%20mpl115a_t%20%3D%20(unsigned%20int)mpl115a_raw_data%5B2%5D%20%26lt%3B%26lt%3B8%3B%20mpl115a_t%20%2B%3D%20(unsigned%20int)mpl115a_raw_data%5B3%5D%20%26amp%3B%200x00FF%3B%20%20mpl115a_a0%20%3D%20(signed%20int)mpl115a_raw_data%5B4%5D%20%26lt%3B%26lt%3B8%3B%20mpl115a_a0%20%2B%3D%20(signed%20int)mpl115a_raw_data%5B5%5D%20%26amp%3B%200x00FF%3B%20%20mpl115a_b1%20%3D%20(signed%20int)mpl115a_raw_data%5B6%5D%20%26lt%3B%26lt%3B8%3B%20mpl115a_b1%20%2B%3D%20(signed%20int)mpl115a_raw_data%5B7%5D%20%26amp%3B%200x00FF%3B%20%20mpl115a_b2%20%3D%20(signed%20int)mpl115a_raw_data%5B8%5D%20%26lt%3B%26lt%3B8%3B%20mpl115a_b2%20%2B%3D%20(signed%20int)mpl115a_raw_data%5B9%5D%20%26amp%3B%200x00FF%3B%20%20mpl115a_c12%20%3D%20(signed%20int)mpl115a_raw_data%5B10%5D%20%26lt%3B%26lt%3B8%3B%20mpl115a_c12%20%2B%3D%20(signed%20int)mpl115a_raw_data%5B11%5D%20%26amp%3B%200x00FF%3B%20%20mpl115a_c11%20%3D%20(signed%20int)mpl115a_raw_data%5B12%5D%20%26lt%3B%26lt%3B8%3B%20mpl115a_c11%20%2B%3D%20(signed%20int)mpl115a_raw_data%5B13%5D%20%26amp%3B%200x00FF%3B%20%20mpl115a_c22%20%3D%20(signed%20int)mpl115a_raw_data%5B14%5D%20%26lt%3B%26lt%3B8%3B%20mpl115a_c22%20%2B%3D%20(signed%20int)mpl115a_raw_data%5B15%5D%20%26amp%3B%200x00FF%3B%7D%3C%2FSTRONG%3E%2F%2F%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%2F%2FCoefficient%209%20equation%20compensation%2F%2F%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3CSTRONG%3Eunsigned%20long%20mpl115a_compensated_pressure(void)%7B%3C%2FSTRONG%3E%20%2F%2FVariable%20used%20to%20do%20large%20calculation%20as%203%20temp%20variables%20in%20the%20process%20below%20%3CSTRONG%3Esigned%20long%20lt1%2C%20lt2%2C%20lt3%2C%20si_c11x1%2C%20si_a11%2C%20si_c12x2%2C%20si_a1%2C%20si_c22x2%2C%20si_a2%2C%20si_a1x1%2C%20si_y1%2C%20si_a2x2%3B%3B%3C%2FSTRONG%3E%20%20%2F%2FVariables%20used%20for%20Pressure%20and%20Temperature%20Raw.%20%3CSTRONG%3Eunsigned%20int%20uiPadc%2C%20uiTadc%3B%20%20signed%20int%20siPcomp%3B%20unsigned%20long%20decPcomp%3B%20%20%20uiPadc%20%3D%20mpl115a_p%20%26gt%3B%26gt%3B%206%3B%20uiTadc%20%3D%20mpl115a_t%20%26gt%3B%26gt%3B%206%3B%3C%2FSTRONG%3E%20%2F%2F*******%20STEP%201%20c11x1%3D%20c11%20*%20Padc%20%3CSTRONG%3Elt1%20%3D%20(signed%20long)%20mpl115a_c11%3B%20lt2%20%3D%20(signed%20long)%20uiPadc%3B%20lt3%20%3D%20lt1%20*%20lt2%3B%20si_c11x1%20%3D%20(signed%20long)%20lt3%3B%3C%2FSTRONG%3E%20%20%2F%2F*******%20STEP%202%20a11%3D%20b1%20%2B%20c11x1%20%3CSTRONG%3Elt1%20%3D%20((signed%20long)%20mpl115a_b1)%20%26lt%3B%26lt%3B%2014%3B%20lt2%20%3D%20(signed%20long)%20si_c11x1%3B%20lt3%20%3D%20lt1%20%2B%20lt2%3B%20si_a11%20%3D%20(signed%20long)%20(lt3%20%26gt%3B%26gt%3B%2014)%3B%3C%2FSTRONG%3E%20%20%20%2F%2F*******%20STEP%203%20c12x2%3D%20c12%20*%20Tadc%20%3CSTRONG%3Elt1%20%3D%20(signed%20long)%20mpl115a_c12%3B%20lt2%20%3D%20(signed%20long)%20uiTadc%3B%20lt3%20%3D%20lt1%20*%20lt2%3B%20si_c12x2%20%3D%20(signed%20long)%20lt3%3B%3C%2FSTRONG%3E%20%2F%2F*******%20STEP%204%20a1%3D%20a11%20%2B%20c12x2%20%3CSTRONG%3Elt1%20%3D%20((signed%20long)%20si_a11)%20%26lt%3B%26lt%3B%2011%3B%20lt2%20%3D%20(signed%20long)%20si_c12x2%3B%20lt3%20%3D%20lt1%20%2B%20lt2%3B%20si_a1%20%3D(signed%20long)%20(lt3%20%26gt%3B%26gt%3B%2011)%3B%3C%2FSTRONG%3E%20%2F%2F*******%20STEP%205%20c22x2%3D%20c22%20*%20Tadc%20%3CSTRONG%3Elt1%20%3D%20(signed%20long)%20mpl115a_c22%3B%20lt2%20%3D%20(signed%20long)%20uiTadc%3B%20lt3%20%3D%20lt1%20*%20lt2%3B%20si_c22x2%20%3D%20(signed%20long)%20lt3%3B%3C%2FSTRONG%3E%20%2F%2F*******%20STEP%206%20a2%3D%20b2%20%2B%20c22x2%20%3CSTRONG%3Elt1%20%3D%20((signed%20long)%20mpl115a_b2)%20%26lt%3B%26lt%3B%2015%3B%20lt2%20%3D%20((signed%20long)%20si_c22x2)%20%26gt%3B%26gt%3B%201%3B%20lt3%20%3D%20lt1%20%2B%20lt2%3B%20si_a2%20%3D%20((signed%20long)lt3)%20%26gt%3B%26gt%3B%2016%3B%3C%2FSTRONG%3E%20%2F%2F*******%20STEP%207%20a1x1%3D%20a1%20*%20Padc%20%3CSTRONG%3Elt1%20%3D%20(signed%20long)%20si_a1%3B%20lt2%20%3D%20(signed%20long)%20uiPadc%3B%20lt3%20%3D%20lt1%20*%20lt2%3B%20si_a1x1%20%3D%20(signed%20long)%20lt3%3B%3C%2FSTRONG%3E%20%2F%2F*******%20STEP%208%20y1%3D%20a0%20%2B%20a1x1%20%3CSTRONG%3Elt1%20%3D%20((signed%20long)%20mpl115a_a0)%20%26lt%3B%26lt%3B%2010%3B%20lt2%20%3D%20(signed%20long)%20si_a1x1%3B%20lt3%20%3D%20lt1%20%2B%20lt2%3B%20si_y1%20%3D%20((signed%20long)lt3)%20%26gt%3B%26gt%3B%2010%3B%3C%2FSTRONG%3E%20%2F%2F*******%20STEP%209%20a2x2%3D%20a2%20*Tadc%20%3CSTRONG%3Elt1%20%3D%20(signed%20long)%20si_a2%3B%20lt2%20%3D%20(signed%20long)%20uiTadc%3B%20lt3%20%3D%20lt1%20*%20lt2%3B%20si_a2x2%20%3D%20(signed%20long)%20lt3%3B%3C%2FSTRONG%3E%20%2F%2F*******%20STEP%2010%20pComp%20%3D%20y1%20%2Ba2x2%20%3CSTRONG%3Elt1%20%3D%20((signed%20long)%20si_y1)%20%26lt%3B%26lt%3B%2010%3B%20lt2%20%3D%20(signed%20long)%20si_a2x2%3B%20lt3%20%3D%20lt1%20%2B%20lt2%3B%3C%2FSTRONG%3E%20%2F%2F%20FIXED%20POINT%20RESULT%20WITH%20ROUNDING%3A%20%3CSTRONG%3EsiPcomp%20%3D%20(signed%20int)(lt3%20%26gt%3B%26gt%3B%2013)%3B%3C%2FSTRONG%3E%20%2F%2F%20goes%20to%20no%20fractional%20parts%20since%20this%20is%20an%20ADC%20count.%20%20%2F%2FdecPcomp%20is%20defined%20as%20a%20floating%20point%20number.%20%2F%2FConversion%20to%20Decimal%20value%20from%201023%20ADC%20count%20value.%20ADC%20counts%20are%200%20to%201023.%20Pressure%20is%2050%20to%20115kPa%20correspondingly.%20%2F%2FdecPcomp%20%3D%20(((unsigned%20long)siPcomp)%20*%2065000%20%2B%2051150000)%20%2F%201023%3B%20%2F%2F%20result%20in%20Pa%2C%20not%20kPa%20%20%3CSTRONG%3EdecPcomp%20%3D%20(unsigned%20long)siPcomp%3B%3C%2FSTRONG%3E%20%2F%2F%20temporary%20%3CSTRONG%3Ereturn%20decPcomp%3B%7D%3C%2FSTRONG%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214618%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214618%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CBR%20%2F%3E%3CBLOCKQUOTE%3E%3CHR%20%2F%3Elrf%20%E5%86%99%E9%81%93%EF%BC%9A%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%E6%89%8B%E5%86%8C%E4%B8%8A%E8%AF%B4%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20face%3D%22Arial%22%3E%3CFONT%20face%3D%22Arial%22%20size%3D%222%22%3E%3C%2FFONT%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%20align%3D%22left%22%3E%3CFONT%20size%3D%222%22%3EsiPcomp%20%3D%20((S16)lt3%26gt%3B%26gt%3B%2013)%EF%BC%9B%3C%2FFONT%3E%3C%2FP%3E%3CP%20align%3D%22left%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20align%3D%22left%22%3E%3CFONT%20size%3D%222%22%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%20align%3D%22left%22%3E%3CFONT%20size%3D%222%22%3E%E6%94%B9%E6%88%90%E8%BF%99%E6%A0%B7%EF%BC%9A%3C%2FFONT%3E%3C%2FP%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3EsiPcomp%20%3D%20((S16)(lt3%26gt%3B%26gt%3B%2013))%EF%BC%9B%3C%2FFONT%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3CBR%20%2F%3E%3C%2FFONT%3E%3C%2FP%3E%3CHR%20%2F%3E%3C%2FBLOCKQUOTE%3E%3CBR%20%2F%3E%3CP%3E%E8%BF%99%E5%AF%B9%E6%88%91%E5%B8%AE%E5%8A%A9%E5%BE%88%E5%A4%A7%E3%80%82%20%20%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E(%E5%8A%A0%E4%B8%8A%E5%90%AF%E5%8A%A8%E5%8E%8B%E5%8A%9B%2F%E6%B8%A9%E5%BA%A6%E8%BD%AC%E6%8D%A2%E6%89%80%E9%9C%80%E7%9A%84%E6%9C%AA%E8%AE%B0%E5%BD%95%E7%9A%84%20ox01%20I2C%20%E5%86%99%E5%85%A5%EF%BC%89%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214617%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214617%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E5%AE%8C%E5%85%A8%E5%90%8C%E6%84%8F%E4%BD%A0%E7%9A%84%E8%A7%82%E7%82%B9%EF%BC%8C%E4%BB%8E%E5%A4%96%E9%83%A8%E8%BF%9B%E8%A1%8C%E6%A0%A1%E5%87%86%E6%88%90%E6%9C%AC%E6%9B%B4%E4%BD%8E%EF%BC%8C%E5%AF%B9%E7%94%A8%E6%88%B7%E4%B9%9F%E6%9B%B4%E5%BC%80%E6%94%BE--%E5%8F%AA%E8%A6%81%E4%BD%A0%E4%BA%86%E8%A7%A3%E8%BD%AC%E6%8D%A2%E7%B3%BB%E6%95%B0%E5%80%BC%E7%9A%84%E6%96%B9%E6%B3%95%E3%80%82%3C%2FP%3E%3CP%3E%E5%A5%BD%E5%90%A7%EF%BC%8C%E6%88%91%E4%B9%9F%E7%9C%8B%E5%88%B0%E4%BA%86%E4%BD%A0%E5%92%8C%E5%85%B6%E4%BB%96%E4%BA%BA%E7%9A%84%E7%A8%8B%E5%BA%8F%EF%BC%8C%E4%B8%8D%E8%BF%87%EF%BC%8C%E5%B9%B6%E4%B8%8D%E6%98%AF%E6%AF%8F%E4%B8%AA%E4%BA%BA%E9%83%BD%E4%BD%BF%E7%94%A8%20C%20%E8%AF%AD%E8%A8%80%EF%BC%8C%E5%BD%93%E7%84%B6%E4%B9%9F%E4%B8%8D%E6%98%AF%E6%AF%8F%E4%B8%AA%E4%BA%BA%E9%83%BD%E4%BD%BF%E7%94%A8%E5%A4%A7%E5%86%85%E5%AD%98%E7%9A%84%20CPU%2F%E5%BE%AE%E5%A4%84%E7%90%86%E5%99%A8%EF%BC%8C%E6%83%B3%E6%83%B3%E7%9C%8B%EF%BC%8C%E5%A6%82%E6%9E%9C%E4%BD%A0%E6%9C%89%20128%20%E5%AD%97%E8%8A%82%E7%9A%84%E5%86%85%E5%AD%98%EF%BC%88RAM%EF%BC%89%EF%BC%8C%E8%80%8C%E4%BB%A3%E7%A0%81%E5%86%85%E5%AD%98%EF%BC%88%E9%97%AA%E5%AD%98%E6%88%96%20ROM%EF%BC%89%E5%8D%B4%E4%B8%8D%E8%B6%B3%202K%3C%2FP%3E%3CP%3E%E9%82%A3%E4%B9%88%E4%BD%A0%E7%9A%84%E8%AE%BE%E8%AE%A1%E5%8F%AF%E8%83%BD%E5%B0%B1%E4%B8%8D%E4%B8%80%E6%A0%B7%E4%BA%86%E3%80%82%E4%B8%8D%E7%AE%A1%E6%80%8E%E4%B9%88%E8%AF%B4%EF%BC%8C%E6%A0%B9%E6%8D%AE%E4%BD%A0%E7%9A%84%E7%BB%8F%E9%AA%8C%EF%BC%8C%E6%AF%8F%E4%B8%AA%E9%97%AE%E9%A2%98%E9%83%BD%E4%BC%9A%E5%9C%A8%E5%87%A0%E5%A4%A9%E5%90%8E%E5%BE%97%E5%88%B0%E8%A7%A3%E5%86%B3%EF%BC%8C%E8%80%8C%E4%B8%94%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%E7%9A%84%E6%94%AF%E6%8C%81%E4%BA%BA%E5%91%98%2F%E5%B7%A5%E7%A8%8B%E5%B8%88%E9%83%BD%E9%9D%9E%E5%B8%B8%E4%B9%90%E4%BA%8E%E5%8A%A9%E4%BA%BA%EF%BC%8C%E8%BF%99%E5%B7%B2%E7%BB%8F%E6%98%AF%E6%88%91%E7%AC%AC%E4%B8%89%E6%AC%A1%E9%81%87%E5%88%B0%E8%BF%99%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%E4%BA%86%EF%BC%8C%E4%BD%86%E6%84%BF%E4%BB%8A%E5%A4%A9%E9%97%AE%E9%A2%98%E8%83%BD%E5%BE%97%E5%88%B0%E8%A7%A3%E5%86%B3%EF%BC%8C%E4%B9%9F%E5%B8%8C%E6%9C%9B%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%E8%83%BD%E7%BB%99%E6%88%91%E4%B8%80%E4%BA%9B%E6%9C%89%E7%94%A8%E7%9A%84%E6%8F%90%E7%A4%BA%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E7%A5%9D%E6%88%91%E5%A5%BD%E8%BF%90%E5%90%A7%3C%2FP%3E%3CP%3Ecw.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214616%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214616%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3ECW%E3%80%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%B8%BA%E4%BB%80%E4%B9%88%E9%9C%80%E8%A6%81%E4%BA%86%E8%A7%A3%E6%95%B0%E5%AD%A6%EF%BC%9F%E5%A6%82%E6%9E%9C%E6%82%A8%E6%83%B3%E8%AE%A9%E8%8A%AF%E7%89%87%E5%81%9A%E4%B8%80%E4%BA%9B%E4%BA%8B%E6%83%85%EF%BC%8C%E9%82%A3%E4%B9%88%E5%8F%AA%E9%9C%80%E4%BD%BF%E7%94%A8%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%E5%9C%A8%20AN3785%20%E4%B8%AD%E6%8F%90%E4%BE%9B%E7%9A%84%E7%BC%96%E7%A8%8B%E6%96%B9%E6%B3%95%EF%BC%8C%E5%B9%B6%E8%BF%9B%E8%A1%8C%E6%88%91%E4%B8%8A%E9%9D%A2%E6%89%80%E8%AF%B4%E7%9A%84%E5%B0%8F%E4%BF%AE%E6%94%B9%E5%8D%B3%E5%8F%AF%E3%80%82%E8%A6%81%E7%90%86%E8%A7%A3%E6%95%B0%E5%AD%A6%E5%8E%9F%E7%90%86%EF%BC%8C%E5%8F%AA%E9%9C%80%E9%80%86%E5%90%91%E6%8E%A8%E5%AF%BC%E6%96%B9%E7%A8%8B%E5%BC%8F%E5%8D%B3%E5%8F%AF%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%8A%AF%E7%89%87%E5%B0%B1%E6%98%AF%E8%8A%AF%E7%89%87%EF%BC%8C%E4%BB%96%E4%BB%AC%E9%80%89%E6%8B%A9%E7%9A%84%E8%AE%A1%E7%AE%97%E6%96%B9%E5%BC%8F%E5%B0%B1%E6%98%AF%E4%BB%96%E4%BB%AC%E9%80%89%E6%8B%A9%E7%9A%84%E6%96%B9%E5%BC%8F%E3%80%82%E5%9C%A8%20MC%20%E4%B8%8A%E8%BF%9B%E8%A1%8C%E8%BF%90%E7%AE%97%E6%AF%94%E8%AE%A9%E8%8A%AF%E7%89%87%E8%BF%9B%E8%A1%8C%E8%BF%90%E7%AE%97%E8%A6%81%E5%BF%AB%E5%BE%97%E5%A4%9A%EF%BC%8C%E4%B9%9F%E6%9B%B4%E5%AE%B9%E6%98%93%E8%AE%A9%E7%94%A8%E6%88%B7%E8%BF%9B%E8%A1%8C%E8%B0%83%E6%95%B4%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%E8%AE%A9%E4%BD%A0%E5%8F%AA%E8%83%BD%E6%8E%A5%E5%8F%97%E8%BF%90%E7%AE%97%E7%BB%93%E6%9E%9C%E3%80%82%20%20%E8%A6%81%E4%B9%88%E4%BD%BF%E7%94%A8%E5%AE%83%EF%BC%8C%E8%A6%81%E4%B9%88%E5%8F%A6%E5%AF%BB%E4%BB%96%E5%A4%84%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E7%9A%84%E6%B0%94%E8%B1%A1%E7%AB%99%E5%B7%B2%E7%BB%8F%E8%BF%90%E8%A1%8C%E4%BA%86%E5%A4%A7%E7%BA%A6%E4%B8%80%E5%B9%B4%EF%BC%8C%E6%B2%A1%E6%9C%89%E5%87%BA%E7%8E%B0%E4%BB%BB%E4%BD%95%E9%97%AE%E9%A2%98%E3%80%82%E5%AE%83%E7%9A%84%E8%AF%BB%E6%95%B0%E4%B8%8E%E5%9B%BD%E5%AE%B6%E6%B0%94%E8%B1%A1%E5%B1%80%E7%9A%84%E6%B0%94%E5%8E%8B%E8%AF%BB%E6%95%B0%E5%AE%8C%E5%85%A8%E4%B8%80%E8%87%B4%EF%BC%8C%E5%B9%B6%E6%A0%B9%E6%8D%AE%E6%B5%B7%E6%8B%94%E9%AB%98%E5%BA%A6%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%A0%A1%E6%AD%A3%EF%BC%88%E5%9B%BD%E5%AE%B6%E6%B0%94%E8%B1%A1%E5%B1%80%E7%9A%84%E6%95%B0%E5%80%BC%E6%98%AF%E6%B5%B7%E5%B9%B3%E9%9D%A2%E4%B8%8A%E7%9A%84%EF%BC%89%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214615%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214615%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%B8%8E%E5%9C%A8%E4%BC%A0%E6%84%9F%E5%99%A8%E4%B8%AD%E5%86%85%E7%BD%AE%E5%A4%84%E7%90%86%E5%99%A8%E7%9B%B8%E6%AF%94%EF%BC%8C%E5%9C%A8%E5%8F%A6%E4%B8%80%E4%B8%AA%E5%A4%84%E7%90%86%E5%99%A8%E4%B8%AD%E8%BF%9B%E8%A1%8C%E6%95%B0%E5%AD%A6%E8%BF%90%E7%AE%97%E8%A6%81%E4%BE%BF%E5%AE%9C%E5%BE%97%E5%A4%9A%EF%BC%8C%E4%B9%9F%E6%9B%B4%E5%AE%B9%E6%98%93%E3%80%82%E6%88%91%E4%B8%8D%E5%BE%97%E4%B8%8D%E5%90%8C%E6%84%8F%EF%BC%8C%E8%BF%99%E5%BE%88%E9%9A%BE%E5%BC%84%E6%87%82%EF%BC%8C%E4%BD%86%E4%B8%80%E6%97%A6%E5%BC%84%E6%87%82%E4%BA%86%E5%B0%B1%E4%BC%9A%E5%BE%88%E5%A5%BD%E7%94%A8%E3%80%82%20%E6%9C%80%E5%88%9D%E7%9A%84%E5%BA%94%E7%94%A8%E8%AF%B4%E6%98%8E%E5%9C%A8%E7%B3%BB%E6%95%B0%E5%AD%98%E5%82%A8%E7%9A%84%E6%8F%8F%E8%BF%B0%E4%B8%AD%E7%A1%AE%E5%AE%9E%E5%AD%98%E5%9C%A8%E4%B8%80%E4%BA%9B%E9%94%99%E8%AF%AF%EF%BC%8C%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%E5%8F%96%E5%86%B3%E4%BA%8E%E5%A4%84%E7%90%86%E5%99%A8%E7%9A%84%E6%9F%90%E4%BA%9B%E5%AD%97%E8%8A%82%E9%A1%BA%E5%BA%8F%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E4%BA%BA%E5%91%98%E9%9D%9E%E5%B8%B8%E4%B9%90%E4%BA%8E%E5%8A%A9%E4%BA%BA%EF%BC%8C%E5%9C%A8%E6%8B%BF%E5%88%B0%E6%A0%B7%E5%93%81%E9%83%A8%E4%BB%B6%E5%90%8E%E7%9A%84%E4%B8%80%E5%A4%A9%E5%B7%A6%E5%8F%B3%E6%97%B6%E9%97%B4%E9%87%8C%EF%BC%8C%E6%88%91%E5%B0%B1%E5%8F%AF%E4%BB%A5%E5%BC%80%E5%A7%8B%E4%BD%BF%E7%94%A8%E4%BA%86%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E5%9C%A8%E8%BF%99%E4%B8%AA%E8%AE%BA%E5%9D%9B%E4%B8%8A%E5%8F%91%E5%B8%83%E4%BA%86%E6%88%91%E7%94%A8%E6%9D%A5%E5%AE%9E%E7%8E%B0%E8%BF%99%E4%B8%AA%E5%8A%9F%E8%83%BD%E7%9A%84%E5%87%A0%E4%B9%8E%E6%89%80%E6%9C%89%E4%BB%A3%E7%A0%81%EF%BC%8C%E5%B8%8C%E6%9C%9B%E5%85%B6%E4%BB%96%E4%BA%BA%E8%83%BD%E4%BB%8E%E6%88%91%E7%9A%84%E5%B7%A5%E4%BD%9C%E4%B8%AD%E5%8F%97%E7%9B%8A%E3%80%82%20%E8%AF%B7%E5%9B%9E%E9%A1%BE%E6%9C%AC%E4%B8%BB%E9%A2%98%E4%B8%AD%E7%9A%84%E5%85%B6%E4%BB%96%E4%BF%A1%E6%81%AF%EF%BC%8C%E7%9C%8B%E7%9C%8B%E8%BF%99%E4%BA%9B%E4%BE%8B%E5%AD%90%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%88%91%E6%9C%89%E4%B8%80%E4%B8%AA%E6%94%B9%E8%BF%9B%E5%BB%BA%E8%AE%AE%EF%BC%8C%E9%82%A3%E5%B0%B1%E6%98%AF%E6%94%B9%E5%96%84%E8%AE%BE%E5%A4%87%E4%B8%8A%E7%9A%84%E5%99%AA%E9%9F%B3%E3%80%82%E8%AF%BB%E6%95%B0%E7%9A%84%E8%B7%B3%E5%8A%A8%E7%A1%AE%E5%AE%9E%E5%BE%88%E5%A4%A7%EF%BC%8C%E4%BD%86%E6%8B%A5%E6%9C%89%E5%86%85%E5%AD%98%E7%9A%84%E9%AB%98%E7%BA%A7%E5%A4%84%E7%90%86%E5%99%A8%E5%90%8C%E6%A0%B7%E5%8F%AF%E4%BB%A5%E8%BD%BB%E6%9D%BE%E5%AE%9E%E7%8E%B0%E5%B9%B3%E6%BB%91%E7%AE%97%E6%B3%95%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E7%A5%9D%E4%BD%A0%E5%A5%BD%E8%BF%90%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214614%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214614%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E5%8F%AA%E6%98%AF%E4%B8%8D%E7%9F%A5%E9%81%93%E4%B8%BA%E4%BB%80%E4%B9%88%20%E2%80%9C%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%E2%80%9D%20%E6%8A%8A%E8%BF%99%E4%B8%AA%E8%AE%BE%E5%A4%87%E4%B8%8E%E6%89%80%E6%9C%89%E7%B3%BB%E6%95%B0%E8%A1%A5%E5%81%BF%E8%AE%A1%E7%AE%97%E6%B7%B7%E6%B7%86%E8%80%8C%E4%B8%8D%E5%9C%A8%E5%86%85%E9%83%A8%E5%81%9A%EF%BC%81%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214613%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214613%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Eirf%E3%80%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E2%80%9C%E8%87%AA%E4%BB%8E%E6%88%91%E4%BD%BF%E7%94%A8%E8%BF%99%E4%B8%AA%E5%85%83%E5%99%A8%E4%BB%B6%E4%BB%A5%E6%9D%A5%E5%B7%B2%E7%BB%8F%E6%9C%89%E5%BE%88%E9%95%BF%E6%97%B6%E9%97%B4%E4%BA%86%EF%BC%8C%E4%BD%86%E6%88%91%E5%8F%AF%E4%BB%A5%E5%91%8A%E8%AF%89%E4%BD%A0%EF%BC%8C%E4%B8%80%E6%97%A6%E4%BD%A0%E5%BC%84%E5%AF%B9%E4%BA%86%E6%95%B0%E5%AD%A6%E8%BF%90%E7%AE%97%EF%BC%8C%E5%AE%83%E5%B0%B1%E5%8F%AF%E4%BB%A5%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E4%BA%86...%E2%80%9D%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E9%97%AE%E9%A2%98%E6%98%AF%E6%88%91%E6%97%A0%E6%B3%95%E6%AD%A3%E7%A1%AE%E8%AE%A1%E7%AE%97%E6%95%B0%E5%AD%A6%EF%BC%8C%E6%88%91%E9%9C%80%E8%A6%81%E4%BD%A0%E7%9A%84%E5%B8%AE%E5%8A%A9%EF%BC%8C%E4%BD%A0%E8%83%BD%E8%A7%A3%E9%87%8A%E4%B8%80%E4%B8%8B%E5%A6%82%E4%BD%95%E5%B0%86%20coef'%20%E5%80%BC%E8%BD%AC%E6%8D%A2%E4%B8%BA%E7%BA%AF%E8%8B%B1%E8%AF%AD%E7%9A%84%E6%B5%AE%E7%82%B9%E6%95%B0%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%20c%20%E7%BC%96%E7%A8%8B%E8%A1%A8%E7%A4%BA%E6%B3%95%E3%80%82%3C%2FP%3E%3CP%3E%E4%BE%8B%E5%A6%82%EF%BC%8C%E6%88%91%E4%BB%8E%E5%AF%84%E5%AD%98%E5%99%A8%20%2400%20-%20%240f%20%E4%B8%AD%E8%AF%BB%E5%8F%96%E7%9A%84%E6%95%B0%E5%AD%97%E6%98%AF%3C%2FP%3E%3CP%3E5A%20C0%2075%20C0%2039%20E3%20B9%207A%20CA%207B%2032%20CC%2000%2000%2000%2000%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E6%82%A8%E7%9A%84%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%3CP%3Ecw.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214612%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214612%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%87%AA%E4%BB%8E%E6%88%91%E4%BD%BF%E7%94%A8%E8%BF%99%E4%B8%AA%E5%85%83%E5%99%A8%E4%BB%B6%E4%BB%A5%E6%9D%A5%E5%B7%B2%E7%BB%8F%E6%9C%89%E5%BE%88%E9%95%BF%E6%97%B6%E9%97%B4%E4%BA%86%EF%BC%8C%E4%BD%86%E6%88%91%E5%8F%AF%E4%BB%A5%E5%91%8A%E8%AF%89%E4%BD%A0%EF%BC%8C%E4%B8%80%E6%97%A6%E4%BD%A0%E6%8E%8C%E6%8F%A1%E4%BA%86%E6%AD%A3%E7%A1%AE%E7%9A%84%E6%95%B0%E5%AD%A6%E8%BF%90%E7%AE%97%EF%BC%8C%E5%AE%83%E5%B0%B1%E5%8F%AF%E4%BB%A5%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E4%BA%86%E3%80%82%E6%88%91%E5%8F%91%E7%8E%B0%E6%89%8B%E5%86%8C%E4%B8%AD%E7%BB%99%E5%87%BA%E7%9A%84%E5%85%AC%E5%BC%8F%E6%98%AF%E6%AD%A3%E7%A1%AE%E7%9A%84%E3%80%82%E4%B8%8D%E5%B9%B8%E7%9A%84%E6%98%AF%EF%BC%8C%E6%88%91%E4%B8%8D%E8%AE%B0%E5%BE%97%E5%85%B7%E4%BD%93%E6%98%AF%E4%BB%80%E4%B9%88%E9%97%AE%E9%A2%98%E4%BA%86%EF%BC%8C%E6%89%80%E4%BB%A5%E6%88%91%E5%8F%88%E5%9B%9E%E5%A4%B4%E7%9C%8B%E4%BA%86%E4%B8%80%E9%81%8D%E6%88%91%E7%9A%84%E4%BB%A3%E7%A0%81%EF%BC%8C%E5%AF%BB%E6%89%BE%E4%B8%8D%E5%90%8C%E4%B9%8B%E5%A4%84%E3%80%82%E4%BB%A5%E4%B8%8B%E6%98%AF%E6%88%91%E8%83%BD%E6%89%BE%E5%88%B0%E7%9A%84%E5%94%AF%E4%B8%80%E5%8C%BA%E5%88%AB%EF%BC%9A%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%E6%89%8B%E5%86%8C%E4%B8%8A%E8%AF%B4%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20face%3D%22Arial%22%3E%3CFONT%20face%3D%22Arial%22%20size%3D%222%22%3E%3C%2FFONT%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%20align%3D%22left%22%3E%3CFONT%20size%3D%222%22%3EsiPcomp%20%3D%20((S16)lt3%26gt%3B%26gt%3B%2013)%EF%BC%9B%3C%2FFONT%3E%3C%2FP%3E%3CP%20align%3D%22left%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20align%3D%22left%22%3E%3CFONT%20size%3D%222%22%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%20align%3D%22left%22%3E%3CFONT%20size%3D%222%22%3E%E6%94%B9%E6%88%90%E8%BF%99%E6%A0%B7%EF%BC%9A%3C%2FFONT%3E%3C%2FP%3E%3CDIV%3E%3CFONT%20size%3D%222%22%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3EsiPcomp%20%3D%20((S16)(lt3%26gt%3B%26gt%3B%2013))%EF%BC%9B%3C%2FFONT%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%E5%B8%8C%E6%9C%9B%E5%AF%B9%E6%82%A8%E6%9C%89%E6%89%80%E5%B8%AE%E5%8A%A9%3C%2FFONT%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214611%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214611%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E5%92%8C%E5%85%B6%E4%BB%96%20MPL115A2%20%E7%BC%96%E7%A8%8B%E7%94%A8%E6%88%B7%E9%81%87%E5%88%B0%E4%BA%86%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98...%3C%2FP%3E%3CP%3E%E6%88%91%E5%8F%AF%E4%BB%A5%E8%AF%BB%E5%8F%96%E5%AF%84%E5%AD%98%E5%99%A8%E4%B8%AD%E7%9A%84%E6%95%B0%E6%8D%AE%EF%BC%8C%E4%BD%86%E8%A6%81%E8%8E%B7%E5%BE%97%E7%9C%9F%E5%AE%9E%E7%9A%84%E5%8E%8B%E5%8A%9B%E5%92%8C%E6%B8%A9%E5%BA%A6%EF%BC%8C%E8%BF%98%E6%9C%89%E5%BE%88%E9%95%BF%E7%9A%84%E8%B7%AF%E8%A6%81%E8%B5%B0%E3%80%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E6%98%AF%E6%88%91%E4%BB%8E%E5%AF%84%E5%AD%98%E5%99%A8%20%2400%20%E8%87%B3%20%240f%20%E4%B8%AD%E8%AF%BB%E5%8F%96%E7%9A%84%E6%95%B0%E6%8D%AE%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E5A%20C0%2075%20C0%2039%20E3%20B9%207A%20CA%207B%2032%20CC%2000%2000%2000%2000%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%8B%9C%E6%89%98%EF%BC%8C%E4%BB%BB%E4%BD%95%E4%BA%BA%E9%83%BD%E5%8F%AF%E4%BB%A5%E5%B8%AE%E6%88%91%E8%A7%A3%E5%BC%80%E4%B8%8A%E8%BF%B0%E6%95%B0%E6%8D%AE%E7%9A%84%E5%A5%A5%E7%A7%98%E2%80%94%E2%80%94%E6%88%91%E7%9F%A5%E9%81%93%E5%89%8D%E5%9B%9B%E4%B8%AA%E5%AD%97%E8%8A%82%E6%98%AF%20Padc%20%E5%92%8C%20Tadc%20%E5%80%BC%EF%BC%8C%E7%84%B6%E5%90%8E%E6%98%AF%20a0-msb%E3%80%81a0-lsb%E3%80%81b1...%20c22%20%E7%AD%89%EF%BC%8C%E4%BD%86%E6%98%AF%EF%BC%8C%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%E5%A6%82%E4%BD%95%E5%B0%86%E8%BF%99%E4%BA%9B%20No%20%E8%BD%AC%E6%8D%A2%E4%B8%BA%E6%B5%AE%E7%82%B9%E8%A1%A8%E7%A4%BA%E6%B3%95%E2%80%94%E2%80%94%E5%AE%9E%E9%99%85%E4%B8%8A%E6%88%91%E6%89%BE%E4%B8%8D%E5%88%B0%E4%BB%BB%E4%BD%95%E6%8F%90%E5%8F%8A%E5%AE%83%E7%9A%84%20%E2%80%9C%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%E2%80%9D%20%E6%96%87%E6%A1%A3%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E4%BD%A0%E4%BB%AC%E7%9A%84%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214610%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214610%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84%20MPL115A2%20%E6%9C%89%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E7%B3%BB%E6%95%B0%E6%95%B0%E6%8D%AE%E4%B8%BA%3C%2FP%3E%3CP%3E3a%204d%20ba%20cc%20bf%20a6%2031%2078%2000%2000%2000%2000%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EPadc%20%3D%20990%3C%2FP%3E%3CP%3ETadc%20%3D%20523%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E8%AE%A1%E7%AE%97%E7%9D%80%EF%BC%9A%3C%2FP%3E%3CP%3Ea0%20%3D%201865.63%3C%2FP%3E%3CP%3Eb1%20%3D%20-2.16%3C%2FP%3E%3CP%3Eb2%20%3D%20-1.01%3C%2FP%3E%3CP%3Ec12%20%3D%200.00075%3C%2FP%3E%3CP%3Ec11%20%3D%200%3C%2FP%3E%3CP%3Ec22%20%3D%200%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EPcomp%20%3D%20-411%EF%BC%88%E8%B4%9F%E5%80%BC%EF%BC%81%EF%BC%81%EF%BC%81%EF%BC%89%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%82%A8%E6%9C%89%E4%BB%80%E4%B9%88%E6%83%B3%E6%B3%95%E5%90%97%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%20%EF%BC%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%B0%BC%E5%8F%A4%E6%8B%89%EF%BC%88%E6%84%8F%E5%A4%A7%E5%88%A9%EF%BC%89%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214609%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214609%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%9E%97%E6%88%88%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%20%20%20%20%E4%BB%A5%E4%B8%8B%E6%98%AF%E6%82%A8%E4%B8%A4%E4%B8%AA%E9%97%AE%E9%A2%98%E7%9A%84%E7%AD%94%E6%A1%88%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E1.%E6%B8%A9%E5%BA%A6%20ADC%20%E6%97%A0%E6%B3%95%E7%9B%B4%E6%8E%A5%E8%BD%AC%E6%8D%A2%E4%B8%BA%E5%AE%9E%E9%99%85%E6%B8%A9%E5%BA%A6%E3%80%82%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%B0%9D%E8%AF%95%E6%94%B9%E5%8F%98%E4%BC%A0%E6%84%9F%E5%99%A8%E7%9A%84%E7%8E%AF%E5%A2%83%E6%B8%A9%E5%BA%A6%EF%BC%8C%E7%9C%8B%E7%9C%8B%20ADC%20%E5%80%BC%E5%9C%A8%E4%B8%8D%E5%90%8C%E6%B8%A9%E5%BA%A6%E4%B8%8B%E7%9A%84%E5%8F%98%E5%8C%96%E6%83%85%E5%86%B5%E3%80%82%E7%84%B6%E5%90%8E%E4%BD%A0%E4%B9%9F%E8%AE%B8%E5%B0%B1%E8%83%BD%E7%AE%97%E5%87%BA%E4%B8%80%E4%B8%AA%E6%8D%A2%E7%AE%97%E7%B3%BB%E6%95%B0%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E2.%E6%9C%80%E7%BB%88%E7%9A%84%E5%8E%8B%E5%8A%9B%E8%AF%BB%E6%95%B0%E6%98%AF%E6%9C%89%E5%99%AA%E5%A3%B0%E7%9A%84%EF%BC%8C%E5%9B%A0%E6%AD%A4%E5%B0%86%E8%AF%A5%E5%80%BC%E8%BD%AC%E6%8D%A2%E4%B8%BA%E6%B5%B7%E6%8B%94%E9%AB%98%E5%BA%A6%E6%97%B6%E4%B9%9F%E4%BC%9A%E4%BA%A7%E7%94%9F%E5%99%AA%E5%A3%B0%E3%80%82%20%E9%80%9A%E5%B8%B8%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8C%E5%8E%8B%E5%8A%9B%E7%9A%84%E5%8F%98%E5%8C%96%E7%9B%B8%E5%BD%93%E7%BC%93%E6%85%A2%EF%BC%8C%E5%9B%A0%E6%AD%A4%E6%9C%80%E5%A5%BD%E7%9A%84%E6%96%B9%E6%B3%95%E6%98%AF%E5%A4%9A%E6%AC%A1%E8%AF%BB%E5%8F%96%E6%95%B0%E6%8D%AE%EF%BC%8C%E5%B9%B6%E5%AF%B9%E6%9C%80%E5%90%8E%E4%B8%80%E6%AC%A1%E6%B5%8B%E9%87%8F%E7%BB%93%E6%9E%9C%E8%BF%9B%E8%A1%8C%E5%B9%B3%E5%9D%87%EF%BC%8C%E4%BB%A5%E6%B6%88%E9%99%A4%E5%99%AA%E9%9F%B3%E3%80%82%20%E5%AF%B9%E4%BA%8E%E6%88%91%E4%BB%AC%E7%9A%84%E5%BA%94%E7%94%A8%EF%BC%8C%E6%88%91%E4%BB%AC%E6%AF%8F%E7%A7%92%E8%BF%9B%E8%A1%8C%E4%B8%80%E6%AC%A1%E6%B5%8B%E9%87%8F%EF%BC%8C%E5%B9%B6%E5%8F%96%E8%BF%87%E5%8E%BB%20100%20%E7%A7%92%E7%9A%84%E5%B9%B3%E5%9D%87%E5%80%BC%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EPeter%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214608%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214608%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%A4%A7%E5%AE%B6%E7%9A%84%E5%87%86%E7%A1%AE%E6%80%A7%2F%E9%87%8D%E5%A4%8D%E6%80%A7%E5%A6%82%E4%BD%95%EF%BC%9F%E6%88%91%E7%9A%84%E8%BD%A6%E5%88%B0%E5%A4%84%E9%A2%A0%E7%B0%B8%E3%80%82%3C%2FP%3E%3CP%3EAlt%20feet%EF%BC%9A149%3CBR%20%2F%3EAlt%20feet%EF%BC%9A%20%2057%3CBR%20%2F%3EAlt%20feet%3A%2097%3CBR%20%2F%3EAlt%20feet%EF%BC%9A%20%2057%3CBR%20%2F%3EAlt%20feet%3A%2097%3CBR%20%2F%3EAlt%20feet%EF%BC%9A109%3CBR%20%2F%3EAlt%20feet%EF%BC%9A%20%2057%3CBR%20%2F%3EAlt%20feet%EF%BC%9A%20%2045%3CBR%20%2F%3EAlt%20feet%EF%BC%9A109%3CBR%20%2F%3EAlt%20feet%EF%BC%9A%20%2045%3CBR%20%2F%3EAlt%20feet%EF%BC%9A109%3CBR%20%2F%3EAlt%20feet%EF%BC%9A%20%2057%3CBR%20%2F%3EAlt%20feet%EF%BC%9A%20%2057%3CBR%20%2F%3EAlt%20feet%3A%2097%3CBR%20%2F%3EAlt%20feet%EF%BC%9A109%3CBR%20%2F%3EAlt%20feet%3A%2097%3CBR%20%2F%3EAlt%20feet%EF%BC%9A109%3CBR%20%2F%3EAlt%20feet%EF%BC%9A%20%2057%3CBR%20%2F%3EAlt%20feet%EF%BC%9A109%3CBR%20%2F%3EAlt%20feet%EF%BC%9A109%3CBR%20%2F%3EAlt%20feet%EF%BC%9A109%3CBR%20%2F%3EAlt%20feet%3A%2097%3CBR%20%2F%3EAlt%20feet%EF%BC%9A109%3CBR%20%2F%3EAlt%20feet%3A%2097%3CBR%20%2F%3EAlt%20feet%EF%BC%9A%20%2045%3CBR%20%2F%3EAlt%20feet%EF%BC%9A%20%2057%3CBR%20%2F%3EAlt%20feet%EF%BC%9A109%3CBR%20%2F%3EAlt%20feet%3A%2097%3CBR%20%2F%3EAlt%20feet%EF%BC%9A%20%2057%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214607%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214607%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%9C%89%E4%BA%BA%E8%83%BD%E5%91%8A%E8%AF%89%E6%88%91%E5%A6%82%E4%BD%95%E5%B0%86%20uiTADC%20%E6%95%B0%E5%AD%97%E8%BD%AC%E6%8D%A2%E4%B8%BA%20c%20%E6%88%96%20F%20%E5%90%97%EF%BC%9F%E6%88%91%E5%BE%97%E5%88%B0%E7%9A%84%E6%98%AF%20523%20%E5%B7%A6%E5%8F%B3%E3%80%82%E6%8D%A2%E7%AE%97%E7%B3%BB%E6%95%B0%E6%98%AF%E5%A4%9A%E5%B0%91%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%3C%2FP%3E%3CP%3E%E6%9E%97%E6%88%88%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214606%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214606%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E6%88%91%E6%8C%87%E7%9A%84%E6%98%AF%20C22%E3%80%82%E6%88%91%E7%94%A8%E4%BD%A0%E7%9A%84%E6%95%B0%E5%80%BC%E8%AE%A1%E7%AE%97%E4%BA%86%E5%8E%8B%E5%8A%9B%EF%BC%8C%E7%BB%93%E6%9E%9C%E5%92%8C%E4%BD%A0%E4%B8%80%E6%A0%B7%E3%80%82%E6%88%91%E6%83%B3%E6%88%91%E7%BB%88%E4%BA%8E%E6%84%8F%E8%AF%86%E5%88%B0%E8%87%AA%E5%B7%B1%E5%81%9A%E9%94%99%E4%BA%86%E4%BB%80%E4%B9%88%E3%80%82%E6%88%91%E7%9C%8B%E4%BA%86%E6%9C%AC%E4%B8%BB%E9%A2%98%E7%9A%84%E7%AC%AC%E4%B8%80%E4%B8%AA%E5%B8%96%E5%AD%90%EF%BC%8C%E5%B9%B6%E4%BB%A5%E6%AD%A4%E4%B8%BA%E4%BE%8B%E8%BD%AC%E6%8D%A2%E4%BA%86%E7%B3%BB%E6%95%B0%E3%80%82%E6%89%80%E4%BB%A5%20C12%20%E6%98%AF%20S0.0000000001110001110000%20-%26gt%3B%202%5E-10%20%2B%202%5E-11%20%2B%202%5E-12%20%2B%202%5E-16%20%2B%202%5E-17%20%2B%202%5E-18%20%3D%200.0017281%E3%80%82%E4%BD%86%E7%AC%A6%E5%8F%B7%E4%BD%8D%E4%B8%BA%201%EF%BC%880x38E0%EF%BC%89%E3%80%82%E6%88%91%E6%98%AF%E5%90%A6%E5%BA%94%E8%AF%A5%E5%8F%8D%E8%BD%AC%2013%20%E4%B8%AA%E5%B0%8F%E6%95%B0%E4%BD%8D%E5%B9%B6%E5%8A%A0%201%20%E4%BB%A5%E5%BE%97%E5%88%B0%E7%9C%9F%E5%AE%9E%E7%BB%93%E6%9E%9C%EF%BC%9F%E8%87%B3%E4%BA%8E%20B2%EF%BC%8C%E5%8F%AF%E8%83%BD%E4%B9%9F%E6%98%AF%E5%90%8C%E6%A0%B7%E7%9A%84%E9%94%99%E8%AF%AF%E3%80%82%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%B8%AE%E5%8A%A9%EF%BC%8CPJH%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214605%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214605%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E7%8C%9C%E4%BD%A0%E6%9C%80%E5%90%8E%E4%B8%80%E4%B8%AA%E7%B3%BB%E6%95%B0%E6%8C%87%E7%9A%84%E6%98%AF%20C22%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%9C%A8%E6%88%91%E7%9A%84%E4%B8%80%E4%B8%AA%E7%B3%BB%E7%BB%9F%E4%B8%AD%EF%BC%8C%E6%88%91%E5%BE%97%E5%88%B0%E4%BA%86%3C%2FP%3E%3CBR%20%2F%3E%3CP%3Ea0%3D2156.625000%3CBR%20%2F%3Eb1%3D-2.528809%3CBR%20%2F%3EB2%3D-1.034241%3CBR%20%2F%3EC12%3D0.000876%3CBR%20%2F%3EC11%3D0.000000%3CBR%20%2F%3EC22%3D0.000000%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3EpressureADC%20420%3CBR%20%2F%3EtempADC%20419%3CBR%20%2F%3E%3CBR%20%2F%3E%E7%BB%93%E6%9E%9C%20101.802%20kPa%E3%80%82%20%E5%9B%A0%E6%AD%A4%E5%BE%97%E5%87%BA%E7%9A%84%E7%BB%93%E6%9E%9C%E6%98%AF%201018.02%20%E6%AF%AB%E5%B7%B4%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%BB%8E%E6%95%B0%E5%80%BC%E4%B8%8A%E7%9C%8B%EF%BC%8C%E5%8F%AF%E8%83%BD%E5%87%BA%E9%94%99%E7%9A%84%E6%98%AF%20C12%E3%80%82%E4%BD%A0%E7%9A%84%E6%95%B0%E5%AD%97%E6%AF%94%E6%88%91%E5%BE%97%E5%88%B0%E7%9A%84%E8%A6%81%E5%B0%8F%E5%BE%97%E5%A4%9A%E3%80%82%20%E5%A6%82%E6%9E%9C%E4%BD%A0%E6%8A%8A%E6%88%91%E7%9A%84%E6%95%B0%E5%AD%97%E8%BE%93%E5%85%A5%E4%BD%A0%E7%9A%84%E8%AE%A1%E7%AE%97%E5%87%BD%E6%95%B0%EF%BC%8C%E5%BE%97%E5%88%B0%E7%9A%84%E7%BB%93%E6%9E%9C%E5%92%8C%E6%88%91%E4%B8%80%E6%A0%B7%E5%90%97%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%BF%98%E8%AF%B7%E6%A3%80%E6%9F%A5%20B2%20%E4%B8%AD%E7%9A%84%E5%B0%8F%E6%95%B0%E7%82%B9%E4%BD%8D%E7%BD%AE%EF%BC%8C%E6%82%A8%E7%9A%84%E6%95%B0%E5%AD%97%E6%AF%94%E6%88%91%E7%9A%84%E5%B0%8F%2010%20%E5%80%8D%E3%80%82%3C%2FP%3E%3CP%3E%E4%B8%8D%E8%A6%81%E5%BF%98%E4%BA%86%EF%BC%8C%E6%82%A8%E8%BF%98%E5%BF%85%E9%A1%BB%E7%BC%A9%E6%94%BE%20pComp%20%E5%80%BC%E3%80%82%20%E8%BE%93%E5%87%BA%E4%B8%BA%200-1023%EF%BC%8C%E5%88%BB%E5%BA%A6%E4%B8%BA%2050kPa%20%E8%87%B3%20115kPa%E3%80%82%E6%89%80%E4%BB%A5%E8%8C%83%E5%9B%B4%E6%98%AF%2065%20%E5%8D%83%E5%B8%95%EF%BC%8C1023%20%E6%AD%A5%E3%80%82%E6%9C%80%E7%BB%88%E5%8E%8B%E5%8A%9B%20%3D%20(65%2F1023*pComp)%2B50%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214604%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214604%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%B0%A2%E8%B0%A2%20PJH%EF%BC%8C%E4%BD%86%E6%88%91%E7%9B%B8%E4%BF%A1%E6%88%91%E7%9A%84%E8%BD%AC%E6%8D%A2%E6%98%AF%E6%AD%A3%E7%A1%AE%E7%9A%84%E3%80%82%E6%88%96%E8%80%85%E6%88%91%E6%9C%89%E5%90%97%EF%BC%9F%E7%9B%AE%E5%89%8D%EF%BC%8CPcomp%20%E7%9A%84%E7%BB%93%E6%9E%9C%E6%98%AF%201067%EF%BC%8C%E8%BF%99%E4%B8%8D%E5%8F%AF%E8%83%BD%E6%98%AF%E6%AD%A3%E7%A1%AE%E7%9A%84%EF%BC%8C%E5%9B%A0%E4%B8%BA%E5%AE%83%E5%BA%94%E8%AF%A5%E4%BB%8B%E4%BA%8E%200%20%E5%92%8C%201023%20%E4%B9%8B%E9%97%B4%E3%80%82%E8%BD%AC%E6%8D%A2%E5%90%8E%E7%9A%84%E7%B3%BB%E6%95%B0%E4%B8%BA%3C%2FP%3E%3CBR%20%2F%3E%3CP%3Ea0%20%3D%202003%3C%2FP%3E%3CP%3Eb1%20%3D%20-2.3118%3C%2FP%3E%3CP%3Eb2%20%3D%20-0.15836%3C%2FP%3E%3CP%3Ec12%20%3D%201.456E-10%3C%2FP%3E%3CP%3Ec11%20%3D%200%3C%2FP%3E%3CP%3Ec12%20%3D%200%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EPadc%20%3D%20370%3C%2FP%3E%3CP%3ETadc%20%3D%20509%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214603%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214603%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%B3%BB%E6%95%B0%E7%9A%84%E5%A4%A7%E5%B0%8F%E5%B9%B6%E4%B8%8D%E5%AE%8C%E5%85%A8%E7%9B%B8%E5%90%8C%EF%BC%8C%E4%BD%86%E5%9C%A8%20x04%20%E5%88%B0%20x0F%20%E7%9A%84%E5%AF%84%E5%AD%98%E5%99%A8%E4%B8%AD%E6%89%93%E5%8C%85%E5%88%B0%2012%20%E5%AD%97%E8%8A%82%EF%BC%8896%20%E4%BD%8D%EF%BC%89%E4%B8%AD%E3%80%82%E7%B3%BB%E6%95%B0%E5%AE%9E%E9%99%85%E4%B8%8A%E6%98%AF%E6%B5%AE%E7%82%B9%E6%95%B0%EF%BC%8C%E4%BD%86%E6%98%AF%E5%B0%8F%E6%95%B0%E7%82%B9%E5%9C%A8%E6%AF%8F%E4%B8%AA%E6%95%B0%E5%AD%97%E4%B8%AD%E4%BD%8D%E4%BA%8E%E4%B8%8D%E5%90%8C%E7%9A%84%E4%BD%8D%E7%BD%AE%EF%BC%8C%E6%9C%89%E4%BA%9B%E6%98%AF%E8%B4%9F%E6%95%B0%EF%BC%8C%E7%AD%89%E7%AD%89%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E7%94%B1%E4%BA%8E%E5%8F%AF%E8%83%BD%E7%94%B1%E4%BA%8E%E6%95%B0%E6%8D%AE%E7%9A%84%E5%AD%97%E8%8A%82%E5%BA%8F%E6%80%A7%E8%B4%A8%E8%80%8C%E6%97%A0%E6%B3%95%E4%BD%BF%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%EF%BC%8C%E5%9B%A0%E6%AD%A4%E6%88%91%E7%BC%96%E5%86%99%E4%BA%86%E4%B8%80%E4%B8%AA%E5%8F%AF%E4%BB%A5%E5%B0%86%E5%AD%97%E8%8A%82%E8%BD%AC%E6%8D%A2%E4%B8%BA%E5%8F%8C%E7%B2%BE%E5%BA%A6%E7%9A%84%E5%87%BD%E6%95%B0%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E9%A6%96%E5%85%88%EF%BC%8C%E8%BF%99%E9%87%8C%E6%98%AF%E4%B8%8B%E8%BD%BD%E7%B3%BB%E6%95%B0%E7%9A%84%E4%BB%A3%E7%A0%81%E3%80%82%20%E6%98%BE%E7%84%B6%EF%BC%8CI2C%20%E7%9A%84%E5%AE%9E%E7%8E%B0%E8%A6%81%E7%94%B1%E8%AF%BB%E8%80%85%E8%87%AA%E5%B7%B1%E6%9D%A5%E5%AE%8C%E6%88%90%E3%80%82%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3C%2FFONT%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Evoid%20CMPL115A%EF%BC%9A%3CIMG%20alt%3D%22%E7%AC%91%E5%BE%97%E5%BE%88%E5%BC%80%E5%BF%83%22%20class%3D%22emoticon%20emoticon-smileyvery-happy%22%20id%3D%22smileyvery-happy%22%20src%3D%22http%3A%2F%2Ffreescale.i.lithium.com%2Fi%2Fsmilies%2F16x16_smiley-very-happy.gif%22%20title%3D%22%E7%AC%91%E8%84%B8%20%E9%9D%9E%E5%B8%B8%E5%BF%AB%E4%B9%90%22%20%2F%3EownloadCoeffs%20()%20%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3Eint%20err%3D0%EF%BC%9Bint%20%E7%BB%93%E6%9E%9C%EF%BC%8C%E7%BB%93%E6%9E%9C%EF%BC%9B%3CBR%20%2F%3E%E5%AD%97%E8%8A%82%E6%95%B0%E6%8D%AE%EF%BC%9Bia0%3D0%EF%BC%9B%3CBR%20%2F%3E%3CBR%20%2F%3Eib1%3D0%EF%BC%9Bib2%3D0%EF%BC%9B%3CBR%20%2F%3Eic11%3D0%EF%BC%9Bic%20%3CBR%20%2F%3E%2012%3D0%EF%BC%9B%3CBR%20%2F%3Eic22%3D0%EF%BC%9B%2F%2F%E8%8E%B7%E5%8F%96%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20A0%20err%3Dm_i%20%3CBR%20%2F%3E%202c.moduleReadByte%EF%BC%88%E6%99%B4%E9%9B%A8%E8%A1%A8%EF%BC%8C0x05%EF%BC%8C%26amp%3B%20%E6%95%B0%E6%8D%AE%EF%BC%89%EF%BC%9Bif%EF%BC%88err%3Derror_Success%EF%BC%89%2F%2F%E7%84%B6%E5%90%8E%E6%88%91%E4%BB%AC%E5%8F%AF%E8%83%BD%E5%B7%B2%E7%BB%8F%E8%BF%9E%E6%8E%A5%E4%BA%86%E4%B8%80%E5%8F%B0%E8%AE%BE%E5%A4%87%E3%80%82%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%E5%9B%A0%E6%AD%A4%E5%81%87%E5%AE%9A%E5%85%B6%E4%BB%96%E5%91%BC%E5%8F%AB%E4%B9%9F%E4%BC%9A%E6%88%90%E5%8A%9F%E3%80%82%3CBR%20%2F%3E%20%20%20%7B%3CBR%20%2F%3E%20resultL%3DINT8(data)%3B%3CBR%20%2F%3E%20m_I2C.ModuleReadByte(BAROMETER%2C0x04%2C%26amp%3Bdata)%3B%3CBR%20%2F%3E%20resultH%3DINT8(data)%3B%3CBR%20%2F%3E%20iA0%3D(resultH%26lt%3B%26lt%3B%208)%2B(resultL%26amp%3B0x00FF)%3B%3CBR%20%2F%3E%20dA0%3DConvertCoeffToDouble(iA0%2C16%2C12%2C3%2C0)%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%20%2F%2F%20Get%20B1%3CBR%20%2F%3E%20m_I2C.ModuleReadByte(BAROMETER%2C0x07%2C%26amp%3Bdata)%3B%3CBR%20%2F%3E%20resultL%3DINT8(data)%3B%3CBR%20%2F%3E%20m_I2C.ModuleReadByte(BAROMETER%2C0x06%2C%26amp%3Bdata)%3B%3CBR%20%2F%3E%20resultH%3DINT8(data)%3B%3CBR%20%2F%3E%20iB1%3D(resultH%26lt%3B%26lt%3B%208)%2B(resultL%26amp%3B0x00FF)%3B%3CBR%20%2F%3E%20dB1%3DConvertCoeffToDouble(iB1%2C16%2C2%2C13%2C0)%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%20%2F%2F%20Get%20B2%3CBR%20%2F%3E%20m_I2C.ModuleReadByte(BAROMETER%2C0x09%2C%26amp%3Bdata)%3B%3CBR%20%2F%3E%20resultL%3DINT8(data)%3B%3CBR%20%2F%3E%20m_I2C.ModuleReadByte(BAROMETER%2C0x08%2C%26amp%3Bdata)%3B%3CBR%20%2F%3E%20resultH%3DINT8(data)%3B%3CBR%20%2F%3E%20iB2%3D(resultH%26lt%3B%26lt%3B%208)%2B(resultL%26amp%3B0x00FF)%3B%3CBR%20%2F%3E%20dB2%3DConvertCoeffToDouble(iB2%2C16%2C1%2C14%2C0)%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%20%2F%2F%20Get%20C12%3CBR%20%2F%3E%20m_I2C.ModuleReadByte(BAROMETER%2C0x0B%2C%26amp%3Bdata)%3B%3CBR%20%2F%3E%20resultL%3DINT8(data)%3B%3CBR%20%2F%3E%20m_I2C.ModuleReadByte(BAROMETER%2C0x0A%2C16data)%3B%3CBR%20%2F%3E%20resultH%3DINT8(data)%3B%3CBR%20%2F%3E%20iC12%3D(resultH%26lt%3B%26lt%3B%208)%2B(resultL%26amp%3B0x00FF)%3B%3CBR%20%2F%3E%20dC12%3DConvertCoeffToDouble(iC12%2C14%2C0%2C13%2C9)%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%20%2F%2F%20Get%20C11%3CBR%20%2F%3E%20m_I2C.ModuleReadByte(BAROMETER%2C0x0D%2C%26amp%3Bdata)%3B%3CBR%20%2F%3E%20resultL%3DINT8(data)%3B%3CBR%20%2F%3E%20m_I2C.ModuleReadByte(BAROMETER%2C0x0C%2C%26amp%3Bdata)%3B%3CBR%20%2F%3E%20resultH%3DINT8(data)%3B%3CBR%20%2F%3E%20iC11%3D(resultH%26lt%3B%26lt%3B%208)%2B(resultL%26amp%3B0x00FF)%3B%3CBR%20%2F%3E%20dC11%3DConvertCoeffToDouble(iC11%2C11%2C0%2C10%2C11)%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%20%2F%2F%20Get%20C22%3CBR%20%2F%3E%20m_I2C.ModuleReadByte(BAROMETER%2C0x0F%2C%26amp%3Bdata)%3B%3CBR%20%2F%3E%20resultL%3DINT8(data)%3B%3CBR%20%2F%3E%20m_I2C.ModuleReadByte(BAROMETER%2C0x0E%2C%26amp%3Bdata)%3B%3CBR%20%2F%3E%20resultH%3DINT8(data)%3B%3CBR%20%2F%3E%20iC22%3D(resultH%26lt%3B%26lt%3B%208)%2B(resultL%26amp%3B0x00FF)%EF%BC%9B%3CBR%20%2F%3E%20%20%20%20%20%20%20dC22%3DConvertCoeffToDouble(iC22%2C11%2C0%2C10%2C15)%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%20m_InitSuccess%3Dtrue%3B%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%20else%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20m_InitSuccess%3Dfalse%3B%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%7D%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CBR%20%2F%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20face%3D%22arial%2Chelvetica%2Csans-serif%22%3E%E8%BF%99%E9%87%8C%E6%98%AF%20ConvertCoeffToDouble%EF%BC%8C%E5%AE%83%E6%8E%A5%E6%94%B6%202%20%E5%AD%97%E8%8A%82%E5%AD%97%EF%BC%8C%E7%84%B6%E5%90%8E%E6%98%AF%E6%8F%8F%E8%BF%B0%E4%BD%8D%E6%95%B0%E3%80%81%E6%95%B4%E6%95%B0%E4%BD%8D%E3%80%81%E5%B0%8F%E6%95%B0%E4%BD%8D%E5%92%8C%E5%A1%AB%E5%85%85%E4%BD%8D%E7%9A%84%E5%8F%82%E6%95%B0%E3%80%82%E5%8F%AF%E8%83%BD%E6%9C%89%E6%9B%B4%E6%9C%89%E6%95%88%E7%9A%84%E6%96%B9%E6%B3%95%E5%8F%AF%E4%BB%A5%E5%81%9A%E5%88%B0%E8%BF%99%E4%B8%80%E7%82%B9%EF%BC%8C%E4%BD%86%E6%98%AF%E7%94%B1%E4%BA%8E%E5%9C%A8%E8%AE%BE%E5%A4%87%E5%88%9D%E5%A7%8B%E5%8C%96%E6%97%B6%E5%8F%AA%E9%9C%80%E8%A6%81%E5%AE%8C%E6%88%90%E4%B8%80%E6%AC%A1%EF%BC%8C%E5%9B%A0%E6%AD%A4%E4%BC%98%E5%8C%96%E5%B9%B6%E4%B8%8D%E9%87%8D%E8%A6%81%E3%80%82%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CBR%20%2F%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Edouble%20convertCoeffToDouble%EF%BC%88INT16%20coeff%E3%80%81%E7%9F%AD%20bitCount%E3%80%81%E7%9F%AD%20IBIT%E3%80%81%E7%9F%AD%20fracBits%E3%80%81%E7%9F%AD%20padBits%EF%BC%89%3CBR%20%2F%3E%7B%3CBR%20%2F%3E%2F%2F%E5%B0%86%E7%B3%BB%E6%95%B0%E8%BD%AC%E6%8D%A2%E4%B8%BA%E6%B5%AE%E7%A9%BA%E5%8F%82%E6%95%B0%E7%9A%84%E5%AE%9E%E7%94%A8%E5%87%BD%E6%95%B0%E3%80%82%3CBR%20%2F%3E%2F%2F%20%E6%9C%89%E5%85%B3%E5%A6%82%E4%BD%95%E5%AD%98%E5%82%A8%E5%8F%82%E6%95%B0%E7%9A%84%E8%AF%A6%E7%BB%86%E4%BF%A1%E6%81%AF%EF%BC%8C%E8%AF%B7%E5%8F%82%E8%A7%81%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%E5%BA%94%E7%94%A8%E8%AF%B4%E6%98%8E%20AN3785%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%20%20%20double%20result%3D0%3B%3CBR%20%2F%3E%20bool%20s%3Dfalse%3B%3CBR%20%2F%3E%20bool%20bit%3B%3CBR%20%2F%3E%20int%20fb%3D0%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%2F%2F%20%E6%88%91%E4%BB%AC%E5%BC%80%E5%A7%8B%E4%BB%8E%E9%AB%98%E4%BD%8D%E5%88%B0%E4%BD%8E%E4%BD%8D%E8%BF%9B%E8%A1%8C%E5%A4%84%E7%90%86%E3%80%82%3CBR%20%2F%3E%2F%2F%20%E4%BC%A0%E5%85%A5%E7%9A%84%E6%95%B0%E6%8D%AE%E6%98%AF%E4%B8%80%E4%B8%AA%2016%20%E4%BD%8D%E6%95%B4%E6%95%B0%EF%BC%8C%E6%88%91%E4%BB%AC%E5%BF%85%E9%A1%BB%E5%B0%86%E5%85%B6%E7%BC%A9%E7%9F%AD%EF%BC%8C%E5%9B%A0%E4%B8%BA%E5%A6%82%E6%9E%9C%26lt%3B16%20%E4%BD%8D%EF%BC%8C%E4%BD%8E%E4%BD%8D%20LSB%20%E6%98%AF%E7%A9%BA%E7%9A%84%E3%80%82%EF%BC%88%E8%A7%81%20AN3785%20%E7%AC%AC%2015%20%E9%A1%B5%EF%BC%89%E3%80%82%3CBR%20%2F%3Eif%20(bitCount%20%26lt%3B%2016)%20%3CBR%20%2F%3E%20%7B%2F%2F%E5%B0%86%20coeff%20%E8%AE%BE%E4%B8%BA%E9%80%82%E5%BD%93%E7%9A%84%E5%A4%A7%E5%B0%8F%20coeff%20%3CBR%20%2F%3E%20%3Dcoeff%20%26gt%3B%20%26gt%3B%20(16-bitCount)%3B%3CBR%20%2F%3E%7D%20%3CBR%20%2F%3E%3CBR%20%2F%3E%2F%2FSanity%20%E6%A3%80%E6%9F%A5%E4%BC%A0%E9%80%92%E7%BB%99%E5%87%BD%E6%95%B0%E7%9A%84%E5%8F%82%E6%95%B0%E6%98%AF%E5%90%A6%E6%9C%89%E6%84%8F%E4%B9%89%E3%80%82%E6%88%91%E4%BB%AC%E7%9A%84%E6%AF%94%E7%89%B9%E6%95%B0%E4%B8%8D%E8%83%BD%E5%A4%9A%E4%BA%8E%E6%88%96%E5%B0%91%E4%BA%8E%E6%95%B0%E6%8D%AE%E9%87%8F%E3%80%82%3CBR%20%2F%3E%2F%2F%3CBR%20%2F%3E%20if((iBits%2BfracBits%2B1)!%3DbitCount)%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20TRACE(_T(%22Error%20in%20parameters!!%5Cn%22))%3B%3CBR%20%2F%3E%20return%200%3B%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%2F%2FSanity%20check%20that%20if%20we%20are%20padding%20of%20decimal%20point%20that%20we%20can't%20also%20have%20integer%20bits.%3CBR%20%2F%3E%20%20%20if((padBits%26gt%3B0)%26amp%3B%26amp%3B%20(iBits%26gt%3B0))%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20TRACE(_T(%22%E5%8F%82%E6%95%B0%E9%94%99%E8%AF%AF%E3%80%82iBits%20%E5%92%8C%20padBits%20%E4%B8%8D%E4%B8%80%E8%87%B4!!%5Cn%22))%3B%3CBR%20%2F%3E%20return%200%3B%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%3CBR%20%2F%3E%20for(int%20b%3DbitCount%3Bb%26gt%3B0%3Bb--)%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20bit%3Dbool((int(pow(2.0%2Cb-1)))%26amp%3Bcoeff)%26gt%3B%26gt%3B%20(b-1))%3B%20%2F%2F%20%E4%BE%9D%E6%AC%A1%E5%B0%86%E6%AF%8F%E4%B8%AA%E4%BD%8D%E5%8F%96%E4%B8%BA%201%20%E6%88%96%200%E3%80%82%3CBR%20%2F%3E%20if%20(b%3D%3DbitCount)%20%2F%2F%20%E5%A6%82%E6%9E%9C%E8%BF%99%E6%98%AF%E7%AC%AC%E4%B8%80%E4%BD%8D%EF%BC%88%E7%AC%A6%E5%8F%B7%E4%BD%8D%E6%A3%80%E6%9F%A5%E6%98%AF%E5%90%A6%E8%A2%AB%E8%AE%BE%E7%BD%AE%EF%BC%89%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20s%3Dbit%3B%3CBR%20%2F%3E%20if(s)%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20coeff%3D~coeff%2B1%3B%20%2F%2F%E8%AE%A1%E7%AE%97%202%20%E7%9A%84%E8%A1%A5%E7%A0%81%3B%20%2F%2F(see%20App%20note%20AN3785%20middle%20of%20Pg15%20for%20explanation)%E3%80%82%3CBR%20%2F%3E%20%20%20%20%20%20%20%20%20%20%20%7D%3CBR%20%2F%3E%20%20%20%20%20%20%20%7D%3CBR%20%2F%3E%20else%20%2F%2F%20%E4%BE%9D%E6%AC%A1%E5%A4%84%E7%90%86%E6%AF%94%E7%89%B9%E3%80%82%3CBR%20%2F%3E%20%20%20%20%20%20%20%7B%3CBR%20%2F%3E%20if(iBits%26gt%3B0)%3CBR%20%2F%3E%20%7B%20%2F%2F%20%E6%88%91%E4%BB%AC%E6%9C%89%E4%B8%80%E4%B8%AA%E6%95%B4%E6%95%B0%E4%BD%8D%EF%BC%9B%3CBR%20%2F%3E%20if(bit)%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20result%2B%3Dpow(2.0%2CiBits-1)%3B%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%20iBits--%3B%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%20else%20%2F%2F%20we%20have%20a%20fractional%20bit%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20fb%2B%2B%3B%3CBR%20%2F%3E%20if(bit)%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20result%2B%3D%20(1%2Fpow(2.0%2Cfb%2BpadBits))%3B%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%20fracBits--%3B%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%20%20%20%20%20%20%20%7D%3CBR%20%2F%3E%20%20%20%7D%3CBR%20%2F%3E%20if(s)%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20result*%3D-1%3B%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%20%20%20TRACE(_T(%22Result%3D%25f%5Cn%22)%2Cresult)%3B%3CBR%20%2F%3E%20return%20result%3B%3CBR%20%2F%3E%7D%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20face%3D%22arial%2Chelvetica%2Csans-serif%22%3E%3CBR%20%2F%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CFONT%20face%3D%22arial%2Chelvetica%2Csans-serif%22%3E%E5%8F%AA%E6%9C%89%E5%9C%A8%E4%BD%A0%E5%B0%86%E6%89%80%E6%9C%89%E7%B3%BB%E6%95%B0%E8%BD%AC%E6%8D%A2%E4%B8%BA%E6%AD%A3%E7%A1%AE%E7%9A%84%E7%AC%A6%E5%8F%B7%E3%80%81%E6%9C%89%E6%95%88%E6%95%B0%E5%AD%97%E7%AD%89%E4%B9%8B%E5%90%8E%EF%BC%8C%E4%BA%8B%E6%83%85%E6%89%8D%E4%BC%9A%E5%BC%80%E5%A7%8B%E5%8F%98%E5%BE%97%E6%9C%89%E6%84%8F%E4%B9%89%E5%B9%B6%E8%83%BD%E6%AD%A3%E7%A1%AE%E8%AF%BB%E5%8F%96%E3%80%82%3C%2FFONT%3E%3C%2FFONT%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CFONT%20face%3D%22arial%2Chelvetica%2Csans-serif%22%3E%E5%BD%BC%E5%BE%97%3CBR%20%2F%3E%3C%2FFONT%3E%3C%2FFONT%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214602%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214602%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E5%88%9A%E5%88%9A%E4%BB%8E%E4%BC%A0%E6%84%9F%E5%99%A8%E4%B8%AD%E8%AF%BB%E5%8F%96%E4%BA%86%E4%B8%80%E4%BA%9B%E4%BF%A1%E6%81%AF%E3%80%82%E9%A6%96%E5%85%88%EF%BC%8C%E7%B3%BB%E6%95%B0%20C11%20%E5%92%8C%20C22%20%E5%9D%87%E4%B8%BA%E9%9B%B6%E3%80%82%E7%B3%BB%E6%95%B0%E6%98%AF%E8%BF%99%E6%A0%B7%E7%9A%84%EF%BC%88coeff1%20coeff2%20...%20coeff12%EF%BC%89%EF%BC%9A%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E3E%2098%20B3%20D2%20C2%2024%2038%20E0%2000%2000%2000%2000%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%BD%93%E6%88%91%E8%AE%A1%E7%AE%97%E5%AE%9E%E9%99%85%E5%8E%8B%E5%8A%9B%EF%BC%88%E5%8E%8B%E5%8A%9B%20adc%20%3D%205C80%EF%BC%8C%E6%B8%A9%E5%BA%A6%20adc%20%3D%207F40%EF%BC%89%E6%97%B6%EF%BC%8C%E6%98%BE%E7%A4%BA%E4%B8%BA%20918%20hPa%EF%BC%8C%E8%BF%99%E4%B8%8D%E5%8F%AF%E8%83%BD%E6%98%AF%E6%AD%A3%E7%A1%AE%E7%9A%84%EF%BC%8C%E5%9B%A0%E4%B8%BA%E6%88%91%E5%9C%A8%E6%B5%B7%E6%8B%94%2025%20%E7%B1%B3%E7%9A%84%E5%9C%B0%E6%96%B9%EF%BC%8C%E8%80%8C%E6%B5%B7%E5%B9%B3%E9%9D%A2%E7%9A%84%E5%8E%8B%E5%8A%9B%E5%BA%94%E8%AF%A5%E6%98%AF%201008%20hPa%E3%80%82%20%20%E9%9D%9E%E5%B8%B8%E5%A5%87%E6%80%AA%E7%9A%84%E6%98%AF%EF%BC%8CC11%20%E5%92%8C%20C22%20%E9%83%BD%E4%B8%BA%E9%9B%B6%E3%80%82%E6%9C%89%E4%BB%80%E4%B9%88%E6%83%B3%E6%B3%95%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214601%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214601%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%8E%B7%E5%BE%97%E5%8E%8B%E5%8A%9B%E6%98%AF%E4%B8%80%E4%B8%AA%E5%A4%9A%E6%AD%A5%E9%AA%A4%E7%9A%84%E8%BF%87%E7%A8%8B%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E9%A6%96%E5%85%88%E9%9C%80%E8%A6%81%E8%AF%BB%E5%8F%96%E5%8E%8B%E5%8A%9B%20ADC%20%E5%92%8C%E6%B8%A9%E5%BA%A6%20ADC%E3%80%82%20%E8%BF%99%E4%B8%A4%E4%B8%AA%E9%83%BD%E6%98%AF%202%20%E5%AD%97%E8%8A%82%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EpressureADC%3D%20(pressureMSB%26lt%3B%26lt%3B%208%2BpressureLSB)%26gt%3B%26gt%3B%206%EF%BC%9B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EtemperatureADC%3D(tempMSB%26lt%3B%26lt%3B%208%2BtempLSB)%26gt%3B%26gt%3B%206%EF%BC%9B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%8E%A5%E4%B8%8B%E6%9D%A5%EF%BC%8C%E6%82%A8%E9%9C%80%E8%A6%81%E4%BD%BF%E7%94%A8%E8%BF%99%E4%B8%A4%E4%B8%AA%20ADC%20%E5%80%BC%E5%92%8C%E6%89%80%E6%9C%89%E7%B3%BB%E6%95%B0%E6%9D%A5%E8%AE%A1%E7%AE%97%E5%8E%8B%E5%8A%9B%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%8E%8B%E5%8A%9B%3D%20AO%2B(B1%2BC11*%20%E5%8E%8B%E5%8A%9B%20ADC%2BC12*%20%E6%B8%A9%E5%BA%A6%20ADC)*%20%E5%8E%8B%E5%8A%9B%20ADC%2B(B2%2BC22*%20%E6%B8%A9%E5%BA%A6%20ADC)*%20%E6%B8%A9%E5%BA%A6%20ADC)%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%BD%A0%E7%BB%88%E4%BA%8E%E5%8F%88%E6%9B%B4%E6%AD%A3%E4%BA%86%3C%2FP%3E%3CP%3EpressureC%3D(65%2F1023*pressure)%2B50%3B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%9C%80%E5%90%8E%E5%BE%97%E5%87%BA%E6%B8%A9%E5%BA%A6%E8%A1%A5%E5%81%BF%E5%8E%8B%E5%8A%9B%EF%BC%88%E6%AF%AB%E5%B7%B4%EF%BC%89%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E5%8F%91%E7%8E%B0%E6%9C%80%E9%9A%BE%E7%9A%84%E6%98%AF%E6%AD%A3%E7%A1%AE%E8%AF%BB%E5%8F%96%E7%B3%BB%E6%95%B0%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EPeter%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214600%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214600%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E4%B9%9F%E4%BD%BF%E7%94%A8%20MPL115A%EF%BC%8C%E4%BD%86%E4%BD%BF%E7%94%A8%20SPI%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E6%AF%AB%E6%97%A0%E9%97%AE%E9%A2%98%E5%9C%B0%E8%AF%BB%E5%8F%96%E6%B8%A9%E5%BA%A6%E3%80%81%E5%8E%8B%E5%8A%9B%E5%92%8C%E7%B3%BB%E6%95%B0%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%86%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%E5%A6%82%E4%BD%95%E5%B0%86%2010%20%E4%BD%8D%E6%95%B0%E6%8D%AE%E8%BD%AC%E6%8D%A2%E4%B8%BA%E4%BB%A5%20KPa%20%E6%88%96%20Celsuis%20%E5%BA%A6%E6%8E%A5%E6%94%B6%E7%9A%84%E6%95%B0%E6%8D%AE%E3%80%82%3C%2FP%3E%3CP%3E%E4%BE%8B%E5%A6%82%EF%BC%9A%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E5%BE%97%E5%88%B0%20MSB%20%E5%8E%8B%E5%8A%9B%200x5B%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%20%20LSB%20%E5%8E%8B%E5%8A%9B%200xC0%3C%2FP%3E%3CP%3E%E6%88%91%E6%98%AF%E8%BF%99%E6%A0%B7%E5%81%9A%E7%9A%84%EF%BC%9A0x5BC0%26gt%3B%26gt%3B%206%20then%20Pka%20%3D%20(65%2F1023)*Padc%20%2B%2050%3C%2FP%3E%3CP%3E%E4%BD%86%E6%88%91%E8%8E%B7%E5%BE%97%E4%BA%86%2073KPa%20%E7%9A%84%E6%B0%94%E5%8E%8B%EF%BC%8C%E8%80%8C%E4%B8%94%E6%88%91%E5%B9%B6%E4%B8%8D%E5%9C%A8%202500%20%E7%B1%B3%E5%A4%84%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%A6%82%E4%BD%95%E8%8E%B7%E5%BE%97%E6%AD%A3%E7%A1%AE%E7%9A%84%E7%BB%93%E6%9E%9C%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214599%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214599%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E9%A9%AC%E5%85%8B%E8%8E%B1%E6%9B%BC%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%BF%99%E4%B8%A4%E5%A4%A9%E6%88%91%E4%B8%80%E7%9B%B4%E5%9C%A8%E5%B0%9D%E8%AF%95%E5%90%AF%E5%8A%A8%E6%96%B0%E7%9A%84%E5%8E%8B%E5%8A%9B%E5%92%8C%E6%B8%A9%E5%BA%A6%E8%BD%AC%E6%8D%A2%EF%BC%8C%E4%BD%86%E6%B2%A1%E6%9C%89%E6%88%90%E5%8A%9F%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%9C%A8%20AN3785%20%E4%B8%AD%EF%BC%8C%E5%9C%A8%20%E2%80%9C%E5%86%99%E5%85%A5%E6%A8%A1%E5%BC%8F%E2%80%9D%20%E6%A0%87%E9%A2%98%E4%B8%8B%EF%BC%8C%E5%AE%83%E6%98%BE%E7%A4%BA%E4%BA%86%E5%91%BD%E4%BB%A4%E5%B9%B6%E7%BB%99%E5%87%BA%E4%BA%86%E5%A6%82%E4%BD%95%E7%BC%96%E5%86%99%20%E2%80%9C%E5%BC%80%E5%A7%8B%E4%B8%A4%E4%B8%AA%E8%BD%AC%E6%8D%A2%E2%80%9D%20%E5%AD%97%E8%8A%82%E5%AD%97%E7%AC%A6%E4%B8%B2%E7%9A%84%E7%A4%BA%E4%BE%8B%EF%BC%8C%E8%AF%A5%E5%AD%97%E8%8A%82%E5%AD%97%E7%AC%A6%E4%B8%B2%E6%98%BE%E7%A4%BA%E4%B8%BA%EF%BC%9A%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%B5%B7%E5%A7%8B%E4%BD%8D%3C%2FP%3E%3CP%3E%E4%BB%8E%E6%9C%BA%E5%9C%B0%E5%9D%80%20(0x60)%3C%2FP%3E%3CP%3E%E5%BA%94%E7%AD%94%3C%2FP%3E%3CP%3E%E5%90%8C%E6%97%B6%E5%90%AF%E5%8A%A8%E4%B8%A4%E4%B8%AA%E8%BD%AC%E6%8D%A2%20(0x12)%3C%2FP%3E%3CP%3E%E5%BA%94%E7%AD%94%3C%2FP%3E%3CP%3E%E5%81%9C%E6%AD%A2%E4%BD%8D%20%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%BD%86%E6%98%AF%E5%9C%A8%20%E2%80%9CI2C%20Simplified%E2%80%9D%20%E6%A0%87%E9%A2%98%E4%B8%8B%EF%BC%8C%E5%AE%83%E6%98%BE%E7%A4%BA%E5%9C%A8%200x12%20%E5%AD%97%E8%8A%82%E4%B9%8B%E5%90%8E%E5%86%8D%E5%86%99%E4%B8%80%E4%B8%AA%200x01%20%E5%AD%97%E8%8A%82%EF%BC%8C%E4%BD%A0%E4%B9%9F%E5%8F%AF%E4%BB%A5%E6%8A%8A%E5%AE%83%E5%BD%93%E4%BD%9C%E8%87%AA%E5%B7%B1%E7%9A%84%E4%BB%A3%E7%A0%81%E3%80%82%E4%BD%A0%E7%9F%A5%E9%81%93%200x01%20%E4%BB%A3%E8%A1%A8%E4%BB%80%E4%B9%88%E5%90%97%EF%BC%9F%E9%99%A4%E4%BA%86%20%22I2C%20%E7%AE%80%E5%8C%96%20%22%E9%A1%B5%E7%9C%89%E5%A4%96%EF%BC%8C%E5%B7%A5%E4%BD%9C%E8%A1%A8%E4%B8%AD%E5%85%B6%E4%BB%96%E5%9C%B0%E6%96%B9%E9%83%BD%E6%B2%A1%E6%9C%89%E8%AE%B0%E5%BD%95%EF%BC%8C%E9%99%A4%E9%9D%9E%E6%88%91%E5%9C%A8%E5%85%B6%E4%BB%96%E5%9C%B0%E6%96%B9%E6%B2%A1%E7%9C%8B%E5%88%B0%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E6%82%A8%EF%BC%81%3C%2FP%3E%3CP%3E%E7%BD%97%E4%BC%AF%E7%89%B9%20%20%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214598%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214598%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%AF%94%E5%B0%94%3C%2FP%3E%3CP%3E%E4%BD%A0%E8%A7%A3%E5%86%B3%E8%BF%87%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E9%A9%AC%E5%85%8B-%E8%8E%B1%E6%9B%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214597%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214597%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E6%88%91%E6%9C%89%20I2C%20%E7%89%88%E6%9C%AC%EF%BC%8C%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20PIC%20%E5%BE%AE%E5%9E%8B%E8%8A%AF%E7%89%87%E5%92%8C%20NIOS%20%E8%BD%AF%20CPU%20%E8%AF%BB%E5%8F%96%E6%95%B0%E6%8D%AE%EF%BC%8C%E4%BD%86%E6%88%91%E5%81%9A%E4%B8%8D%E5%88%B0%E7%9A%84%E6%98%AF%E8%AE%A9%E7%B3%BB%E6%95%B0%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E3%80%82%3CIMG%20alt%3D%22%E7%AC%91%E8%84%B8%E6%82%B2%E4%BC%A4%22%20class%3D%22emoticon%20emoticon-smileysad%22%20id%3D%22smileysad%22%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fi%2Fsmilies%2F16x16_smiley-sad.png%22%20title%3D%22%E7%AC%91%E8%84%B8%E6%82%B2%E4%BC%A4%22%20%2F%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E6%98%AF%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E4%BB%A3%E7%A0%81%EF%BC%88%E6%82%A8%E9%9C%80%E8%A6%81%E8%87%AA%E5%B7%B1%E7%9A%84%20I2C%20%E5%90%AF%E5%8A%A8%2F%E5%81%9C%E6%AD%A2%2F%E8%AF%BB%E5%8F%96%2F%E5%86%99%E5%85%A5%E5%8A%9F%E8%83%BD%EF%BC%89%3C%2FP%3E%3CBR%20%2F%3E%3CPRE%20translate%3D%22no%22%3Evoid%20Measure_ambient_presure(void)%20%7B%20unsigned%20char%20x%3B%20unsigned%20char%20MPL115A2_data%5B16%5D%3B%20printf(%22%3BRead%20MPL115A2%5Cr%22)%3B%20i2c_start()%3B%20%20%20%20%20%20%20%20%20%20%20%2F%2F%20I2C%20Bus%20Start%20condition%20i2c_write(MPL115A2_I2C_address)%3B%20%20%20%20%20%2F%2F%20I2C%20bus%20Device%20address%20i2c_write(MPL115A2_start_both_conversion_command)%3B%20%2F%2F%20Command%20to%20Convert%20both%20Pressure%20and%20Temperature%20i2c_write(0x01)%3B%20i2c_stop()%3B%20%20%20%20%20%20%20%20%20%20%20%2F%2F%20I2C%20Bus%20Stop%20condition%20delay_ms(5)%3B%20%20%20%20%20%20%20%20%20%20%2F%2F%20wait%20for%20A-D%20conversion%20to%20take%20place%20i2c_start()%3B%20%20%20%20%20%20%20%20%20%20%20%2F%2F%20I2C%20Bus%20Start%20condition%20i2c_write(MPL115A2_I2C_address)%3B%20%20%20%20%20%2F%2F%20I2C%20bus%20Device%20address%20i2c_write(0x00)%3B%20%20%20%20%20%20%20%20%20%2F%2F%20address%20in%20MPL115A2%20i2c_start()%3B%20%20%20%20%20%20%20%20%20%20%2F%2F%20I2C%20Bus%20Start%20condition%20(a%20restart)%20i2c_write(MPL115A2_I2C_address%7C0x01)%3B%20%20%20%20%2F%2F%20address%20in%20MPL115A2%20%2B%20read%20bit%20MPL115A2_data%5B0%5D%20%20%3D%20i2c_read(1)%3B%20%20%20%20%20%2F%2F%20read%20with%20ACK%20MPL115A2_data%5B1%5D%20%20%3D%20i2c_read(1)%3B%20%20%20%20%20%2F%2F%20read%20with%20ACK%20MPL115A2_data%5B2%5D%20%20%3D%20i2c_read(1)%3B%20%20%20%20%20%2F%2F%20read%20with%20ACK%20MPL115A2_data%5B3%5D%20%20%3D%20i2c_read(1)%3B%20%20%20%20%20%2F%2F%20read%20with%20ACK%20MPL115A2_data%5B4%5D%20%20%3D%20i2c_read(1)%3B%20%20%20%20%20%2F%2F%20read%20with%20ACK%20MPL115A2_data%5B5%5D%20%20%3D%20i2c_read(1)%3B%20%20%20%20%20%2F%2F%20read%20with%20ACK%20MPL115A2_data%5B6%5D%20%20%3D%20i2c_read(1)%3B%20%20%20%20%20%2F%2F%20read%20with%20ACK%20MPL115A2_data%5B7%5D%20%20%3D%20i2c_read(1)%3B%20%20%20%20%20%2F%2F%20read%20with%20ACK%20MPL115A2_data%5B8%5D%20%20%3D%20i2c_read(1)%3B%20%20%20%20%20%2F%2F%20read%20with%20ACK%20MPL115A2_data%5B9%5D%20%20%3D%20i2c_read(1)%3B%20%20%20%20%20%2F%2F%20read%20with%20ACK%20MPL115A2_data%5B10%5D%20%3D%20i2c_read(1)%3B%20%20%20%20%20%2F%2F%20read%20with%20ACK%20MPL115A2_data%5B11%5D%20%3D%20i2c_read(1)%3B%20%20%20%20%20%2F%2F%20read%20with%20ACK%20MPL115A2_data%5B12%5D%20%3D%20i2c_read(1)%3B%20%20%20%20%20%2F%2F%20read%20with%20ACK%20MPL115A2_data%5B13%5D%20%3D%20i2c_read(1)%3B%20%20%20%20%20%2F%2F%20read%20with%20ACK%20MPL115A2_data%5B14%5D%20%3D%20i2c_read(1)%3B%20%20%20%20%20%2F%2F%20read%20with%20ACK%20MPL115A2_data%5B15%5D%20%3D%20i2c_read(0)%3B%20%20%20%20%20%2F%2F%20read%20with%20noACK%20i2c_stop()%3B%20%20%20%20%20%20%20%20%20%20%20%2F%2F%20I2C%20Bus%20Stop%20condition%20%20printf(%22%3BMPL115A2%20Data%3D%20%22)%3B%20for%20(x%3D0%3Bx%26lt%3B16%3Bx%2B%2B)%20%20%7B%20%20printf(%22%2502X%20%22%2CMPL115A2_data%5Bx%5D)%3B%20%20%7D%20printf(%22%5Cr%22)%3B%20%7D%3C%2FPRE%3E%3CBR%20%2F%3E%3CDIV%3E%E4%B8%8B%E9%9D%A2%E6%98%AF%E6%88%91%E4%BB%8E%E4%B8%AD%E8%8E%B7%E5%BE%97%E7%9A%84%E4%B8%80%E4%BA%9B%E6%A0%B7%E6%9C%AC%E6%95%B0%E6%8D%AE%E3%80%82%3C%2FDIV%3E%3CP%3E%3BMPL115A2%20Data%3D%2064%20C0%2075%2080%203D%209B%20B9%204A%20C7%2046%2032%20BC%2002%2020%20FD%2060%3CBR%20%2F%3E%3BMPL115A2%20Data%3D%2065%2000%2076%2080%203D%209B%20B9%204A%20C7%2046%2032%20BC%2002%2020%20FD%2060%3CBR%20%2F%3E%3BMPL115A2%20Data%3D%2065%2040%2076%2080%203D%209B%20B9%204A%20C7%2046%2032%20BC%2002%2020%20FD%2060%3CBR%20%2F%3E%20%EF%BC%9BMPL115A2%20Data%3D%2065%2000%2076%20C0%203D%209B%20B9%204A%20C7%2046%2032%20BC%2002%2020%20FD%2060%3CBR%20%2F%3E%3BMPL115A2%20Data%3D%2065%2080%2075%20C0%203D%209B%20B9%204A%20C7%2046%2032%20BC%2002%2020%20FD%2060%3CBR%20%2F%3E%3BMPL115A2%20Data%3D%2065%2000%2075%2040%203D%209B%20B9%204A%20C7%2046%2032%20BC%2002%2020%20FD%2060%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E9%A9%AC%E5%85%8B-%E8%8E%B1%E6%9B%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-214596%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A%20fixed%20point%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-214596%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E9%99%A4%E4%BA%86%20%22%20Billthe%20Biker%20%22%20%E4%B9%8B%E5%A4%96%E8%BF%98%E6%9C%89%E5%85%B6%E4%BB%96%E4%BA%BA%E5%B0%9D%E8%AF%95%E8%BF%87%E4%BD%BF%E7%94%A8%20MPL115A%20%E8%AF%84%E4%BC%B0%E6%9D%BF%E5%90%97%E3%80%82%E6%88%91%E7%9A%84%E6%9D%BF%E6%98%AF%20i2c%20%E7%89%88%E6%9C%AC%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E5%92%8C%E5%AE%83%E9%80%9A%E8%AF%9D%EF%BC%8C%E4%BD%86%E5%AE%83%E4%B8%8D%E6%83%B3%E8%AF%BB%E5%87%BA%E4%BB%BB%E4%BD%95%E6%95%B0%E6%8D%AE%E3%80%82%E5%AE%83%E5%8F%AA%E4%BC%9A%E6%8C%82%E8%B5%B7%E5%B9%B6%E9%94%81%E4%BD%8F%E7%94%B5%E8%84%91%E3%80%82%3C%2FP%3E%3CP%3E%E6%9C%89%E4%BA%BA%E7%9F%A5%E9%81%93%E5%90%97%EF%BC%9F%E6%88%91%E8%AF%BB%E4%BA%86%E6%AF%94%E5%B0%94%E5%85%B3%E4%BA%8E%E6%95%B0%E5%AD%A6%E9%97%AE%E9%A2%98%E7%9A%84%E5%B8%96%E5%AD%90%EF%BC%8C%E6%88%91%E6%8B%85%E5%BF%83%E5%A6%82%E6%9E%9C%E6%88%91%E8%A7%A3%E5%86%B3%E4%BA%86%E7%A1%AC%E4%BB%B6%E9%97%AE%E9%A2%98%EF%BC%8C%E5%B0%B1%E4%BC%9A%E9%9D%A2%E4%B8%B4%E6%95%B0%E5%AD%A6%E9%97%AE%E9%A2%98%E3%80%82%E6%88%91%E5%9C%A8%E8%BF%99%E9%87%8C%E4%B9%B0%E4%BA%86%E4%B8%80%E5%A4%B4%E7%8C%AA%E5%90%97%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%9C%A8%E9%98%85%E8%AF%BB%E6%89%8B%E5%86%8C%E6%97%B6%EF%BC%8C%E6%88%91%E4%BB%AC%E5%8F%91%E7%8E%B0%E4%BA%86%E8%AE%B8%E5%A4%9A%E9%97%AE%E9%A2%98%EF%BC%8C%E4%B8%8D%E7%A6%81%E8%AE%A9%E4%BA%BA%E6%80%80%E7%96%91%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%E6%98%AF%E5%90%A6%E8%83%BD%E5%81%9A%E5%88%B0%E8%BF%99%E4%B8%80%E7%82%B9%E3%80%82%E5%A6%82%E8%92%99%E5%9B%9E%E5%A4%8D%EF%BC%8C%E4%B8%8D%E8%83%9C%E6%84%9F%E6%BF%80%E3%80%82(%E6%88%91%E5%B8%8C%E6%9C%9B%E8%83%BD%E6%9C%89%E6%AF%94%E6%AF%94%E5%B0%94%E6%94%B6%E5%88%B0%E7%9A%84%E6%9B%B4%E5%A4%9A%E7%9A%84%EF%BC%89%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
