MP3V5010DP with P1 < P2
torkomairware
Would I damage the MP3V5010DP if I run it over a range of 50 kPa to 106 kPa at sea level?  In the range from 101 kPa to 106 kPa, P1 < P2. I am not tying to make measurements from 101 to 106 kPa, I just want to avoid damaging the sensor.
miguelsalhuana
I would like to know some more details of your particular use case. Are you using this sensor as a gauged device (one port vented to atmospheric pressure)? When you say that you will be taking measurements at 101 to 106kPa is this atmospheric pressure or line pressure?
Miguel
%3CLINGO-SUB%20id%3D%22lingo-sub-399411%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMP3V5010DP%20with%20P1%20%26lt%3B%20P2%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-399411%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EWould%20I%20damage%20the%20MP3V5010DP%20if%20I%20run%20it%20over%20a%20range%20of%2050%20kPa%20to%20106%20kPa%20at%20sea%20level%3F%26nbsp%3B%20In%20the%20range%20from%20101%20kPa%20to%20106%20kPa%2C%20P1%20%26lt%3B%20P2.%20I%20am%20not%20tying%20to%20make%20measurements%20from%20101%20to%20106%20kPa%2C%20I%20just%20want%20to%20avoid%20damaging%20the%20sensor.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-399411%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EPressure%20Sensors%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-399412%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MP3V5010DP%20with%20P1%20%26lt%3B%20P2%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-399412%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20would%20like%20to%20know%20some%20more%20details%20of%20your%20particular%20use%20case.%20Are%20you%20using%20this%20sensor%20as%20a%20gauged%20device%20(one%20port%20vented%20to%20atmospheric%20pressure)%3F%20When%20you%20say%20that%20you%20will%20be%20taking%20measurements%20at%20101%20to%20106kPa%20is%20this%20atmospheric%20pressure%20or%20line%20pressure%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ERegards%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EMiguel%3C%2FP%3E%3C%2FLINGO-BODY%3E
