MP3V5004G output impedance?
921 次查看
abbian
Does anyone know the output impedance of the MP3V5004G?  Wondering if I need to buffer the output prior to interfacing to a Kinetis K51 ADC.  The datasheet does not give any output impedance information.
835 次查看
TomasVaverka
Hi Dan,
The output impedance of typical amplified pressure sensors (MPX4000/5000/6000/7000 series) is about 1..10 ohms for sampling frequencies from 1 Hz to 100 Hz. So the output of the MP3V5004G can be connected directly to a Kinetis K51 ADC.
Tomas
PS: If my answer helps to solve your question, please mark it as "Correct". Thank you.
