MP3V5004DP Performance Issues
jiajian_huang
1.The pressure measurement range is 0-3.92 kpa. Whether the negative pressure can be tested is equivalent to the pressure measurement range of 0-3.92 kpa
2.Temperature compensation range is 10 to 60°C, so if it is 0°C or -10°C, what is the error range?
3.Operating temperature is 0 to 85°C. Can it work at -10°C? If it works properly, what is the error range? Thanks。
TomasVaverka
The MP3V5004DP is a differential pressure sensor measuring a pressure difference between its two ports. This device is designed to operate with positive pressure only (P1 > P2). It cannot measure a negative pressure difference (output would be at ~0V).
We cannot recommend operating the MP3V5004DP below 0°C as it may cause a degradation of the functionality or even a permanent damage.
We can guarantee the MP3V5004DP specification and its parameters at the limited temperature range of +10°C to +60°C only. From 0°C to 85°C is the operating temperature range, any normal application is allowed, but when the temperature is below +10°C or above +60°C, the accuracy cannot be guaranteed. We do not provide any official error report for temperatures below +10°C.
Tomas
jiajian_huang
Hi Tomas,
If P1 is connected to atmosphere, P2 is connected to negative pressure, such as -2kpa, P1 is still larger than P2, the output is positive voltage, so is it available? Thanks.
%3CLINGO-SUB%20id%3D%22lingo-sub-858052%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMP3V5004DP%20Performance%20Issues%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-858052%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%23252526%3B%20font-size%3A%2018px%3B%20%22%3E%3CSTRONG%3E1.The%20pressure%20measurement%20range%20is%200-3.92%20kpa.%20Whether%20the%20negative%20pressure%20can%20be%20tested%20is%20equivalent%20to%20the%20pressure%20measurement%20range%20of%200-3.92%20kpa%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%23252526%3B%20font-size%3A%2018px%3B%20%22%3E%3CSTRONG%3E2.Temperature%20compensation%20range%20is%2010%20to%2060%C2%B0C%2C%20so%20if%20it%20is%200%C2%B0C%20or%20-10%C2%B0C%2C%20what%20is%20the%20error%20range%3F%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%23252526%3B%20font-size%3A%2018px%3B%20%22%3E%3CSTRONG%3E3.Operating%20temperature%20is%200%20to%2085%C2%B0C.%20Can%20it%20work%20at%20-10%C2%B0C%3F%20If%20it%20works%20properly%2C%20what%20is%20the%20error%20range%3F%20Thanks%E3%80%82%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-858054%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%26nbsp%3B%20MP3V5004DP%20Performance%20Issues%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-858054%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Tomas%EF%BC%8C%3C%2FP%3E%3CP%3EIf%20P1%20is%20connected%20to%20atmosphere%2C%20P2%20is%20connected%20to%20negative%20pressure%2C%20such%20as%20-2kpa%2C%20P1%20is%20still%20larger%20than%20P2%2C%20the%20output%20is%20positive%20voltage%2C%20so%20is%20it%20available%3F%20Thanks.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-858053%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%20MP3V5004DP%20Performance%20Issues%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-858053%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThe%20MP3V5004DP%20is%20a%20differential%20pressure%20sensor%20measuring%20a%20pressure%20difference%20between%20its%20two%20ports.%20This%20device%20is%20designed%20to%20operate%20with%20positive%20pressure%20only%20(P1%20%26gt%3B%20P2).%20It%20cannot%20measure%20a%20negative%20pressure%20difference%20(output%20would%20be%20at%20~0V).%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EWe%20cannot%20recommend%20operating%20the%20MP3V5004DP%20below%200%C2%B0C%20as%20it%20may%20cause%20a%20degradation%20of%20the%20functionality%20or%20even%20a%20permanent%20damage.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EWe%20can%20guarantee%20the%20MP3V5004DP%20specification%20and%20its%20parameters%20at%20the%20limited%20temperature%20range%20of%20%2B10%C2%B0C%20to%20%2B60%C2%B0C%20only.%20From%200%C2%B0C%20to%2085%C2%B0C%20is%20the%20operating%20temperature%20range%2C%20any%20normal%20application%20is%20allowed%2C%20but%20when%20the%20temperature%20is%20below%20%2B10%C2%B0C%20or%20above%20%2B60%C2%B0C%2C%20the%20accuracy%20cannot%20be%20guaranteed.%20We%20do%20not%20provide%20any%20official%20error%20report%20for%20temperatures%20below%20%2B10%C2%B0C.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EBest%20regards%2C%3C%2FP%3E%3CP%3ETomas%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E
