MMA8652 : Transient interrupt threshold value
koichisakagami
Dear community,
I consider the Transient interrupt threshold value.
In the case of setting to register value as follows,
when does the Transient interrupt occur ?
       0x1F:TRANSIENT_THS Register THS[6:0] to 000_0000b.
       0x1D:TRANSIENT_CFG Register HPF_BYP to  1.
Which is the Transient interrupt trigger point value ,
" greater than or equal to ZERO G " or " greater than ZERO G " ?
       Koichi Sakagami
koichisakagami
Dear Tomas san,
Thank you for your reply.
> What is the use of such settings?
I would like to detect a less than 0.063g transient.
Koichi Sakagami
TomasVaverka
Dear Koichi-san,
The minimum threshold resolution is 0.063g (TRANSIENT_THS = 0x01). None of our accelerometers offer higher resolution.
Tomas
TomasVaverka
Dear Koichi-san,
What is the use of such settings? The interrupt would be generated whenever the acceleration is higher than 0g.
Tomas
%3CLINGO-SUB%20id%3D%22lingo-sub-605038%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMMA8652%20%3A%20%20Transient%20interrupt%20threshold%20value%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-605038%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDear%20community%2C%3C%2FP%3E%3CP%3EI%20consider%20the%20Transient%20interrupt%20threshold%20value.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EIn%20the%20case%20of%20setting%20to%20register%20value%20as%20follows%2C%3CBR%20%2F%3Ewhen%20does%20the%20Transient%20interrupt%20occur%20%3F%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200x1F%3ATRANSIENT_THS%20Register%20THS%5B6%3A0%5D%20to%20000_0000b.%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200x1D%3ATRANSIENT_CFG%20Register%20HPF_BYP%20to%26nbsp%3B%201.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EWhich%20is%20the%20Transient%20interrupt%20trigger%20point%20value%20%2C%3CBR%20%2F%3E%22%20greater%20than%20or%20equal%20to%20ZERO%20G%20%22%20or%20%22%20greater%20than%20ZERO%20G%20%22%20%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Best%20Regards%2C%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Koichi%20Sakagami%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-605038%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EAccelerometers%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-605041%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MMA8652%20%3A%20%20Transient%20interrupt%20threshold%20value%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-605041%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDear%20Koichi-san%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThe%20minimum%20threshold%20resolution%20is%200.063g%20(TRANSIENT_THS%20%3D%200x01).%20None%20of%20our%20accelerometers%20offer%20higher%20resolution.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBest%20regards%2C%3C%2FP%3E%3CP%3ETomas%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-605040%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MMA8652%20%3A%26nbsp%3B%20Transient%20interrupt%20threshold%20value%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-605040%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDear%20Tomas%20san%2C%3CBR%20%2F%3EThank%20you%20for%20your%20reply.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26gt%3B%20What%20is%20the%20use%20of%20such%20settings%3F%20%3CBR%20%2F%3EI%20would%20like%20to%20detect%20a%20less%20than%200.063g%20transient.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBest%20Regards%2C%3CBR%20%2F%3EKoichi%20Sakagami%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-605039%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MMA8652%20%3A%20%20Transient%20interrupt%20threshold%20value%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-605039%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDear%20Koichi-san%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EWhat%20is%20the%20use%20of%20such%20settings%3F%20The%20interrupt%20would%20be%20generated%20whenever%20the%20acceleration%20is%20higher%20than%200g.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBest%20regards%2C%3C%2FP%3E%3CP%3ETomas%3C%2FP%3E%3C%2FLINGO-BODY%3E
