MMA8652 Sensitivity Value
4,200 次查看
tuurbo46
I am just working through the MMA8652 example code, and generating my define values.
After searching the net I cannot find an example define value for the  SENSITIVITY_2G.  So would the below be correct for the example code?
#define SENSITIVITY_2G    1024
Z_offset = (Zout_12_bit - SENSITIVITY_2G) / 2 * (-1);          // Compute Z-axis offset correction value
Rocketman46
7 回复数
3,689 次查看
TomasVaverka
Yes, it is correct:
// MMA8652FC Sensitivity
#define SENSITIVITY_4G  512
#define SENSITIVITY_8G  256
* Simple accelerometer offset calibration
void MMA8652FC_Calibration (void)
  char X_offset, Y_offset, Z_offset;
  DataReady = 0;
  while (!DataReady){} // Is a first set of data ready?
  DataReady = 0;
  I2C_WriteRegister(MMA8652FC_I2C_ADDRESS, CTRL_REG1, 0x00); // Standby mode
  I2C_ReadMultiRegisters(MMA8652FC_I2C_ADDRESS, OUT_X_MSB_REG, 6, AccelData); // Read data output registers 0x01-0x06
  Xout_12_bit = ((short) (AccelData[0]<<8 | AccelData[1])) >> 4; // Compute 12-bit X-axis acceleration output value
  Yout_12_bit = ((short) (AccelData[2]<<8 | AccelData[3])) >> 4; // Compute 12-bit Y-axis acceleration output value
  Zout_12_bit = ((short) (AccelData[4]<<8 | AccelData[5])) >> 4; // Compute 12-bit Z-axis acceleration output value
  X_offset = Xout_12_bit / 2 * (-1); // Compute X-axis offset correction value
  Y_offset = Yout_12_bit / 2 * (-1); // Compute Y-axis offset correction value
  I2C_WriteRegister(MMA8652FC_I2C_ADDRESS, OFF_X_REG, X_offset);
  I2C_WriteRegister(MMA8652FC_I2C_ADDRESS, OFF_Y_REG, Y_offset);
  I2C_WriteRegister(MMA8652FC_I2C_ADDRESS, OFF_Z_REG, Z_offset);
  I2C_WriteRegister(MMA8652FC_I2C_ADDRESS, CTRL_REG1, 0x39); // Active mode again
Take a look at my complete example code here​.
Tomas
PS: If my answer helps to solve your question, please mark it as "Correct". Thank you.
3,689 次查看
tuurbo46
OK thank you  for your fast reply.  I am converting the code for another MCU.  Can you explain the below command.  I have outlined what I think is happening, is this correct?
* MMA8652FC_I2C_ADDRESS = I2C address.
* OUT_X_MSB_REG = register.
* AccelData = int16_t AccelData[8];
* Is the 6 in the I2C_ReadMultiRegisters() just reading the low 6 bits?
* If the above is correct, therefore my command is wrong as I am reading the whole word, read_word(MMA8652FC_I2C_ADDRESS, OUT_X_MSB, AccelData);
NXP Original code Code:
Rocektman46
3,689 次查看
TomasVaverka
I do not quite understand your question.
I believe it is obvious that the burst read is performed using the I2C_ReadMultiRegisters(MMA8652FC_I2C_ADDRESS, OUT_X_MSB_REG, 6, AccelData) function, given the 7-bit slave address of the chip (0x1D), the address of the first register to read (0x01), the number of bytes to read (a value of 6 reads all six data output registers 0x01 – 0x06) and the name of an array of six bytes to store the data in. Such a burst read of 6 bytes from registers 0x01 to 0x06 looks like this:
Hope it is clearer now.
Tomas
3,689 次查看
tuurbo46
Hi Tomas,
I do not have the I2C_ReadMultiRegisters() function so I am trying to write my own.  Is my below function correct although I have commented it for 6 bytes.
//I2C_ReadMultiRegisters(MMA8652FC_I2C_ADDRESS, OUT_X_MSB, 6, AccelData);   // Read data output registers 0x01-0x06
void read_multi_registers(uint8_t MPU_Addr, uint8_t Address, uint8_t Number_Of_Bytes, uint16_t Data)
  int8_t i;
  i2c_start_wait(MPU_Addr + I2C_WRITE);
  i2c_write(Address);
  i2c_stop();
  i2c_write(Address);
  i2c_rep_start(0x3B + I2C_READ);
  // read first 5 bytes of data
  for(i = 0; i < Number_Of_Bytes-1; i++)
       AccelData[i] = i2c_readAck();
       i2c_stop();
  // read last 6th byte of data
  AccelData[i+1] = i2c_readNak();
  i2c_stop();
Thanks Rocketman46
3,689 次查看
TomasVaverka
It is usually hard to say whether the function is correct or not without seeing what is going on the bus. Do you have a logic analyzer or an oscilloscope to see the traffic on the bus?
Both the single and multiple bytes read transactions are described in the MMA8652FC data sheet (chapters 5.11.1 and 5.11.2). In my source code, you can find the I2C routines in the I2C.c file within the Sources folder.
Tomas
3,689 次查看
tuurbo46
OK thanks.
One last question, can I read the data without configuring the interrupt.  I mean just send a command and read data?
Rocketman46
3,689 次查看
TomasVaverka
Yes, there is an example illustrating it in the AN4076, chapter 9.1.
Tomas
%3CLINGO-SUB%20id%3D%22lingo-sub-486375%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMMA8652%20%E7%81%B5%E6%95%8F%E5%BA%A6%E5%80%BC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-486375%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E7%A0%94%E7%A9%B6%20MMA8652%20%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%EF%BC%8C%E5%B9%B6%E7%94%9F%E6%88%90%E6%88%91%E7%9A%84%E5%AE%9A%E4%B9%89%E5%80%BC%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%E7%BD%91%E4%B8%8A%E6%90%9C%E7%B4%A2%E5%90%8E%EF%BC%8C%E6%88%91%E6%B2%A1%E6%9C%89%E6%89%BE%E5%88%B0%20SENSITIVITY_2G%20%E7%9A%84%E5%AE%9A%E4%B9%89%E5%80%BC%E7%A4%BA%E4%BE%8B%E3%80%82%20%E9%82%A3%E4%B9%88%E4%B8%8B%E9%9D%A2%E7%9A%84%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%E6%98%AF%E5%90%A6%E6%AD%A3%E7%A1%AE%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%23define%20SENSITIVITY_2G%201024%20%20%20%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%20Z_offset%20%3D%20(Zout_12_bit%20-%20SENSITIVITY_2G)%20%2F%202%20*%20(-1)%3B%20%2F%2F%20%E8%AE%A1%E7%AE%97%20Z%20%E8%BD%B4%E5%81%8F%E7%A7%BB%E4%BF%AE%E6%AD%A3%E5%80%BC%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ERocketman46%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-486375%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E5%8A%A0%E9%80%9F%E5%BA%A6%E4%BC%A0%E6%84%9F%E5%99%A8%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-486382%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MMA8652%20Sensitivity%20Value%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-486382%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E5%9C%A8%3CA%20href%3D%22http%3A%2F%2Fcache.nxp.com%2Ffiles%2Fsensors%2Fdoc%2Fapp_note%2FAN4076.pdf%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EAN4076%3C%2FA%3E%20%E7%AC%AC%209.1%20%E7%AB%A0%E4%B8%AD%E6%9C%89%E4%B8%80%E4%B8%AA%E7%A4%BA%E4%BE%8B%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%89%98%E9%A9%AC%E6%96%AF%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-486381%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MMA8652%20Sensitivity%20Value%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-486381%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%A5%BD%E7%9A%84%EF%BC%8C%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%9C%80%E5%90%8E%E4%B8%80%E4%B8%AA%E9%97%AE%E9%A2%98%E6%98%AF%EF%BC%8C%E6%88%91%E8%83%BD%E5%90%A6%E5%9C%A8%E4%B8%8D%E9%85%8D%E7%BD%AE%E4%B8%AD%E6%96%AD%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E8%AF%BB%E5%8F%96%E6%95%B0%E6%8D%AE%E3%80%82%20%E6%88%91%E6%98%AF%E8%AF%B4%E5%8F%AA%E9%9C%80%E5%8F%91%E9%80%81%E5%91%BD%E4%BB%A4%E5%B9%B6%E8%AF%BB%E5%8F%96%E6%95%B0%E6%8D%AE%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3ERocketman46%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-486380%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MMA8652%20Sensitivity%20Value%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-486380%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E4%B8%8D%E7%9C%8B%E5%88%B0%E6%80%BB%E7%BA%BF%E4%B8%8A%E5%8F%91%E7%94%9F%E4%BA%86%E4%BB%80%E4%B9%88%EF%BC%8C%E9%80%9A%E5%B8%B8%E5%BE%88%E9%9A%BE%E8%AF%B4%E5%87%BA%E8%AF%A5%E5%8A%9F%E8%83%BD%E6%98%AF%E5%90%A6%E6%AD%A3%E7%A1%AE%E3%80%82%E4%BD%A0%E6%9C%89%E9%80%BB%E8%BE%91%E5%88%86%E6%9E%90%E5%99%A8%E6%88%96%E7%A4%BA%E6%B3%A2%E5%99%A8%E6%9D%A5%E6%9F%A5%E7%9C%8B%E6%80%BB%E7%BA%BF%E4%B8%8A%E7%9A%84%E6%B5%81%E9%87%8F%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fcache.nxp.com%2Ffiles%2Fsensors%2Fdoc%2Fdata_sheet%2FMMA8652FC.pdf%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EMMA8652FC%20%E6%95%B0%E6%8D%AE%E6%89%8B%E5%86%8C%3C%2FA%3E%EF%BC%88%E7%AC%AC%205.11.1%20%E7%AB%A0%E5%92%8C%205.11.2%20%E7%AB%A0%EF%BC%89%E4%B8%AD%E6%8F%8F%E8%BF%B0%E4%BA%86%E5%8D%95%E5%AD%97%E8%8A%82%E5%92%8C%E5%A4%9A%E5%AD%97%E8%8A%82%E8%AF%BB%E5%8F%96%E4%BA%8B%E5%8A%A1%E3%80%82%E5%9C%A8%E6%88%91%E7%9A%84%E6%BA%90%E4%BB%A3%E7%A0%81%E4%B8%AD%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%9C%A8%20Sources%20%E6%96%87%E4%BB%B6%E5%A4%B9%E4%B8%AD%E7%9A%84%3CSUP%3EI2C%3C%2FSUP%3E.c%20%E6%96%87%E4%BB%B6%E4%B8%AD%E6%89%BE%E5%88%B0%20I2C%20%E4%BE%8B%E7%A8%8B%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%89%98%E9%A9%AC%E6%96%AF%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-486379%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MMA8652%20Sensitivity%20Value%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-486379%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%97%A8%EF%BC%8C%E6%89%98%E9%A9%AC%E6%96%AF%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%B2%A1%E6%9C%89%20I2C_ReadMultiRegisters()%20%E5%87%BD%E6%95%B0%EF%BC%8C%E5%9B%A0%E6%AD%A4%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E7%BC%96%E5%86%99%E8%87%AA%E5%B7%B1%E7%9A%84%E5%87%BD%E6%95%B0%E3%80%82%20%E5%B0%BD%E7%AE%A1%E6%88%91%E5%B7%B2%E7%BB%8F%E6%B3%A8%E9%87%8A%E4%BA%866%E5%AD%97%E8%8A%82%EF%BC%8C%E4%BD%86%E6%88%91%E7%9A%84%E4%BB%A5%E4%B8%8B%E5%8A%9F%E8%83%BD%E6%98%AF%E5%90%A6%E6%AD%A3%E7%A1%AE%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2F%2FI2C_ReadMultiRegisters(MMA8652FC_I2C_ADDRESS%2C%20OUT_X_MSB%2C%206%2C%20AccelData)%3B%20%2F%2F%20%E8%AF%BB%E5%8F%96%E6%95%B0%E6%8D%AE%E8%BE%93%E5%87%BA%E5%AF%84%E5%AD%98%E5%99%A8%200x01-0x06%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Evoid%20read_multi_registers(uint8_t%20MPU_Addr%EF%BC%8Cuint8_t%20Address%EF%BC%8Cuint8_t%20Number_Of_Bytes%EF%BC%8Cuint16_t%20Data)%3C%2FP%3E%3CP%3E%7B%3C%2FP%3E%3CP%3E%20%20int8_t%20i%EF%BC%9B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%20i2c_start_wait(MPU_Addr%20%2B%20I2C_WRITE)%EF%BC%9B%20%3C%2FP%3E%3CP%3E%20%20i2c_write(Address)%EF%BC%9B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%3C%2FP%3E%3CP%3E%20%20i2c_stop()%EF%BC%9B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%20i2c_start_wait(MPU_Addr%20%2B%20I2C_WRITE)%EF%BC%9B%3C%2FP%3E%3CP%3E%20%20i2c_write(Address)%EF%BC%9B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%20i2c_rep_start(0x3B%20%2B%20I2C_READ)%EF%BC%9B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2F%2F%E8%AF%BB%E5%8F%96%E5%89%8D%205%20%E5%AD%97%E8%8A%82%E7%9A%84%E6%95%B0%E6%8D%AE%3C%2FP%3E%3CP%3E%20%20for(i%20%3D%200%3B%20i%26lt%3B%20Number_Of_Bytes-1%3B%20i%2B%2B)%3C%2FP%3E%3CP%3E%26nbsp%3B%20%7B%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%20AccelData%5Bi%5D%20%3D%20i2c_readAck()%EF%BC%9B%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%20i2c_stop()%EF%BC%9B%3C%2FP%3E%3CP%3E%26nbsp%3B%20%7D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2F%2F%E8%AF%BB%E5%8F%96%E6%9C%80%E5%90%8E%E7%AC%AC%206%20%E4%B8%AA%E5%AD%97%E8%8A%82%E7%9A%84%E6%95%B0%E6%8D%AE%3C%2FP%3E%3CP%3E%20%20AccelData%5Bi%2B1%5D%20%3D%20i2c_readNak()%EF%BC%9B%3C%2FP%3E%3CP%3E%20%20i2c_stop()%EF%BC%9B%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%20Rocketman46%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-486378%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MMA8652%20Sensitivity%20Value%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-486378%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E4%B8%8D%E5%A4%AA%E6%98%8E%E7%99%BD%E4%BD%A0%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E7%9B%B8%E4%BF%A1%E7%AA%81%E5%8F%91%E8%AF%BB%E5%8F%96%E6%98%AF%E4%BD%BF%E7%94%A8%20i2c_readMultiRegisters%EF%BC%88MMA8652FC_I2C_ADDRESS%E3%80%81OUT_X_MSB_REG%E3%80%816%E3%80%81AccelData%EF%BC%89%E5%87%BD%E6%95%B0%E6%89%A7%E8%A1%8C%E7%9A%84%EF%BC%8C%E7%BB%99%E5%AE%9A%E8%8A%AF%E7%89%87%E7%9A%84%207%20%E4%BD%8D%E4%BB%8E%E5%B1%9E%E5%9C%B0%E5%9D%80%20(0x1D)%E3%80%81%E7%AC%AC%E4%B8%80%E4%B8%AA%E8%A6%81%E8%AF%BB%E5%8F%96%E7%9A%84%E5%AF%84%E5%AD%98%E5%99%A8%E7%9A%84%E5%9C%B0%E5%9D%80%20(0x01)%E3%80%81%E8%A6%81%E8%AF%BB%E5%8F%96%E7%9A%84%E5%AD%97%E8%8A%82%E6%95%B0%EF%BC%88%E5%80%BC%E4%B8%BA%206%EF%BC%89%E3%80%81%E8%AF%BB%E5%8F%96%E7%9A%84%E5%AD%97%E8%8A%82%E6%95%B0%EF%BC%88%E5%80%BC%E4%B8%BA%206%EF%BC%89%E5%85%AD%E4%B8%AA%E6%95%B0%E6%8D%AE%E8%BE%93%E5%87%BA%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%880x01%20%E2%80%94%200x06%EF%BC%89%E5%92%8C%E7%94%A8%E4%BA%8E%E5%AD%98%E5%82%A8%E6%95%B0%E6%8D%AE%E7%9A%84%E5%85%AD%E5%AD%97%E8%8A%82%E6%95%B0%E7%BB%84%E7%9A%84%E5%90%8D%E7%A7%B0%E3%80%82%E8%BF%99%E7%A7%8D%E4%BB%8E%E5%AF%84%E5%AD%98%E5%99%A8%200x01%20%E5%88%B0%200x06%20%E7%9A%84%206%20%E5%AD%97%E8%8A%82%E7%9A%84%E7%AA%81%E5%8F%91%E8%AF%BB%E5%8F%96%E5%A6%82%E4%B8%8B%E6%89%80%E7%A4%BA%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Burst%2BRead.JPG.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Burst%2BRead.JPG.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F55078i1EB22968F0796035%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Burst%2BRead.JPG.jpg%22%20alt%3D%22Burst%2BRead.JPG.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EBurst%2BRead.JPG.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%B8%8C%E6%9C%9B%E7%8E%B0%E5%9C%A8%E6%9B%B4%E6%B8%85%E6%A5%9A%E4%BA%86%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%89%98%E9%A9%AC%E6%96%AF%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-486377%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MMA8652%20Sensitivity%20Value%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-486377%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%A5%BD%E7%9A%84%EF%BC%8C%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%BF%AB%E9%80%9F%E5%9B%9E%E5%A4%8D%E3%80%82%20%E6%88%91%E6%AD%A3%E5%9C%A8%E4%B8%BA%E5%8F%A6%E4%B8%80%E4%B8%AA%20MCU%20%E8%BD%AC%E6%8D%A2%E4%BB%A3%E7%A0%81%E3%80%82%20%E8%AF%B7%E8%A7%A3%E9%87%8A%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%E3%80%82%20%E6%88%91%E5%B7%B2%E7%BB%8F%E6%A6%82%E8%BF%B0%E4%BA%86%E6%88%91%E8%AE%A4%E4%B8%BA%E5%8F%91%E7%94%9F%E7%9A%84%E6%83%85%E5%86%B5%EF%BC%8C%E8%BF%99%E6%98%AF%E5%90%A6%E6%AD%A3%E7%A1%AE%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20Consolas%2C%20'Courier%20New'%2C%20Courier%2C%20mono%2C%20serif%3B%20font-size%3A%2012px%3B%22%3E*%20MMA8652FC_I2C_ADDRESS%20%3D%20I2C%20%E5%9C%B0%E5%9D%80%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20Consolas%2C%20'Courier%20New'%2C%20Courier%2C%20mono%2C%20serif%3B%20font-size%3A%2012px%3B%22%3E*%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20Consolas%2C%20'Courier%20New'%2C%20Courier%2C%20mono%2C%20serif%3B%20font-size%3A%2012px%3B%22%3EOUT_X_MSB_REG%20%3D%20%E5%AF%84%E5%AD%98%E5%99%A8%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E*%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20Consolas%2C%20'Courier%20New'%2C%20Courier%2C%20mono%2C%20serif%3B%20font-size%3A%2012px%3B%22%3EAccelData%20%3D%20int16_t%20AccelData%5B8%5D%EF%BC%9B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20Consolas%2C%20'Courier%20New'%2C%20Courier%2C%20mono%2C%20serif%3B%20font-size%3A%2012px%3B%22%3E*%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20Consolas%2C%20'Courier%20New'%2C%20Courier%2C%20mono%2C%20serif%3B%20font-size%3A%2012px%3B%22%3EI2C_ReadMultiRegisters()%3C%2FSPAN%3E%E4%B8%AD%E7%9A%84%206%20%E6%98%AF%E5%90%A6%E5%8F%AA%E6%98%AF%E8%AF%BB%E5%8F%96%E4%BD%8E%206%20%E4%BD%8D%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-size%3A%2012px%3B%20font-family%3A%20Consolas%2C%20'Courier%20New'%2C%20Courier%2C%20mono%2C%20serif%3B%22%3E*%20%E5%A6%82%E6%9E%9C%E4%BB%A5%E4%B8%8A%E6%98%AF%E6%AD%A3%E7%A1%AE%E7%9A%84%EF%BC%8C%E9%82%A3%E4%B9%88%E6%88%91%E7%9A%84%E5%91%BD%E4%BB%A4%E5%B0%B1%E6%98%AF%E9%94%99%E8%AF%AF%E7%9A%84%EF%BC%8C%E5%9B%A0%E4%B8%BA%E6%88%91%E8%AF%BB%E5%8F%96%E7%9A%84%E6%98%AF%E6%95%B4%E4%B8%AA%E5%AD%97%EF%BC%8Cread_word(MMA8652FC_I2C_ADDRESS%2C%20OUT_X_MSB%2C%20AccelData)%EF%BC%9B%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%20background%3A%20white%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-size%3A%2012px%3B%20font-family%3A%20Consolas%2C%20'Courier%20New'%2C%20Courier%2C%20mono%2C%20serif%3B%22%3ENXP%20Original%20Code%20Code%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20Consolas%2C%20'Courier%20New'%2C%20Courier%2C%20mono%2C%20serif%3B%20font-size%3A%2012px%3B%22%3EI2C_ReadMultiRegisters%EF%BC%88MMA8652FC_I2C_ADDRESS%EF%BC%8COUT_X_MSB_REG%E3%80%81%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%22%20style%3D%22font-size%3A%2012px%3B%20font-family%3A%20Consolas%2C%20'Courier%20New'%2C%20Courier%2C%20mono%2C%20serif%3B%20color%3A%20green%3B%22%3E6%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012px%3B%20font-family%3A%20Consolas%2C%20'Courier%20New'%2C%20Courier%2C%20mono%2C%20serif%3B%20color%3A%20%23000000%3B%22%3E%2C%20AccelData%EF%BC%89%EF%BC%9B%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22comment%22%20style%3D%22font-size%3A%2012px%3B%20font-family%3A%20Consolas%2C%20'Courier%20New'%2C%20Courier%2C%20mono%2C%20serif%3B%20color%3A%20%23008200%3B%22%3E%2F%2F%20%E8%AF%BB%E5%8F%96%E6%95%B0%E6%8D%AE%E8%BE%93%E5%87%BA%E5%AF%84%E5%AD%98%E5%99%A8%200x01-0x06%20%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012px%3B%20font-family%3A%20Consolas%2C%20'Courier%20New'%2C%20Courier%2C%20mono%2C%20serif%3B%20color%3A%20%23000000%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EXout_12_bit%20%3D%20((%3C%2FSPAN%3E%3CSTRONG%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20'inherit'%2C'serif'%3B%22%3E%E7%9F%AD%3C%2FSTRONG%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E)%20(AccelData%5B0%5D%26lt%3B%26lt%3B%208%20%7C%20AccelData%5B1%5D))%20%26gt%3B%26gt%3B%204%3B%20%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%E8%AE%A1%E7%AE%97%2012%20%E4%BD%8D%20X%20%E8%BD%B4%E5%8A%A0%E9%80%9F%E5%BA%A6%E8%BE%93%E5%87%BA%E5%80%BC%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EYout_12_bit%20%3D%20((%3C%2FSPAN%3E%3CSTRONG%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20'inherit'%2C'serif'%3B%22%3E%E7%9F%AD%3C%2FSTRONG%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E)%20(AccelData%5B2%5D%26lt%3B%26lt%3B%208%20%7C%20AccelData%5B3%5D))%20%26gt%3B%26gt%3B%204%3B%20%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%E8%AE%A1%E7%AE%97%2012%20%E4%BD%8D%20Y%20%E8%BD%B4%E5%8A%A0%E9%80%9F%E5%BA%A6%E8%BE%93%E5%87%BA%E5%80%BC%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EZout_12_bit%20%3D%20((%3C%2FSPAN%3E%3CSTRONG%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20'inherit'%2C'serif'%3B%22%3E%E7%9F%AD%3C%2FSTRONG%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E)%20(AccelData%5B4%5D%26lt%3B%26lt%3B%208%20%7C%20AccelData%5B5%5D))%20%26gt%3B%26gt%3B%204%3B%20%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%E8%AE%A1%E7%AE%97%2012%20%E4%BD%8D%20Z%20%E8%BD%B4%E5%8A%A0%E9%80%9F%E5%BA%A6%E8%BE%93%E5%87%BA%E5%80%BC%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012px%3B%20font-family%3A%20Consolas%2C%20'Courier%20New'%2C%20Courier%2C%20mono%2C%20serif%3B%20color%3A%20%23000000%3B%22%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012px%3B%20font-family%3A%20Consolas%2C%20'Courier%20New'%2C%20Courier%2C%20mono%2C%20serif%3B%20color%3A%20%23000000%3B%22%3ERocektman46%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-486376%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MMA8652%20Sensitivity%20Value%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-486376%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E6%B2%A1%E9%94%99%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MMA8652FC%20Sensitivity.JPG%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MMA8652FC%20Sensitivity.JPG%22%20style%3D%22width%3A%20678px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F55442iA019533764EBFB56%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22MMA8652FC%20Sensitivity.JPG%22%20alt%3D%22MMA8652FC%20Sensitivity.JPG%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EMMA8652FC%20Sensitivity.JPG%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22c%2B%2B%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14564791321111620%20jive_text_macro%22%20data-renderedposition%3D%22246.17897033691406_7.997159004211426_1192_77%22%20jivemacro_uid%3D%22_14564791321111620%22%20modifiedtitle%3D%22true%22%3E%3CP%3E%2F%2F%20MMA8652FC%20%E7%81%B5%E6%95%8F%E5%BA%A6%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%23define%20SENSITIVITY_2G%201024%3C%2FP%3E%3CP%3E%23define%20SENSITIVITY_4G%20512%3C%2FP%3E%3CP%3E%23define%20SENSITIVITY_8G%20256%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22c%2B%2B%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14564792264049802%20jive_text_macro%22%20data-renderedposition%3D%22348.90625_7.997159004211426_1192_464%22%20jivemacro_uid%3D%22_14564792264049802%22%3E%3CP%3E%2F******************************************************************************%3C%2FP%3E%3CP%3E*%20%E7%AE%80%E5%8D%95%E7%9A%84%E5%8A%A0%E9%80%9F%E5%BA%A6%E8%AE%A1%E5%81%8F%E7%A7%BB%E6%A0%A1%E5%87%86%3C%2FP%3E%3CP%3E******************************************************************************%2F%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Evoid%20MMA8652FC_Calibration%20(void)%3C%2FP%3E%3CP%3E%7B%3C%2FP%3E%3CP%3E%20%20char%20X_offset%E3%80%81Y_offset%E3%80%81Z_offset%EF%BC%9B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%20DataReady%20%3D%200%EF%BC%9B%3C%2FP%3E%3CP%3E%20%20while%20(!DataReady)%7B%7D%2F%2F%20%E7%AC%AC%E4%B8%80%E7%BB%84%E6%95%B0%E6%8D%AE%E5%87%86%E5%A4%87%E5%A5%BD%E4%BA%86%E5%90%97%EF%BC%9F%20%3C%2FP%3E%3CP%3E%20%20DataReady%20%3D%200%EF%BC%9B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%20I2C_WriteRegister(MMA8652FC_I2C_ADDRESS%2C%20CTRL_REG1%2C%200x00)%3B%20%2F%2F%20%E5%BE%85%E6%9C%BA%E6%A8%A1%E5%BC%8F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%20I2C_ReadMultiRegisters(MMA8652FC_I2C_ADDRESS%2C%20OUT_X_MSB_REG%2C%206%2C%20AccelData)%3B%20%2F%2F%20%E8%AF%BB%E5%8F%96%E6%95%B0%E6%8D%AE%E8%BE%93%E5%87%BA%E5%AF%84%E5%AD%98%E5%99%A8%200x01-0x06%20%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%20Xout_12_bit%20%3D%20((short)%20(AccelData%5B0%5D%26lt%3B%26lt%3B%208%20%7C%20AccelData%5B1%5D))%20%26gt%3B%26gt%3B%204%3B%20%2F%2F%20%E8%AE%A1%E7%AE%97%2012%20%E4%BD%8D%20X%20%E8%BD%B4%E5%8A%A0%E9%80%9F%E5%BA%A6%E8%BE%93%E5%87%BA%E5%80%BC%3C%2FP%3E%3CP%3E%20%20Yout_12_bit%20%3D%20((short)%20(AccelData%5B2%5D%26lt%3B%26lt%3B%208%20%7C%20AccelData%5B3%5D))%20%26gt%3B%26gt%3B%204%3B%20%2F%2F%20%E8%AE%A1%E7%AE%97%2012%20%E4%BD%8D%20Y%20%E8%BD%B4%E5%8A%A0%E9%80%9F%E5%BA%A6%E8%BE%93%E5%87%BA%E5%80%BC%3C%2FP%3E%3CP%3E%20%20Zout_12_bit%20%3D%20((short)%20(AccelData%5B4%5D%26lt%3B%26lt%3B%208%20%7C%20AccelData%5B5%5D))%20%26gt%3B%26gt%3B%204%3B%20%2F%2F%20%E8%AE%A1%E7%AE%97%2012%20%E4%BD%8D%20Z%20%E8%BD%B4%E5%8A%A0%E9%80%9F%E5%BA%A6%E8%BE%93%E5%87%BA%E5%80%BC%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%20X_offset%20%3D%20Xout_12_bit%20%2F%202%20*%20(-1)%3B%20%2F%2F%20%E8%AE%A1%E7%AE%97%20X%20%E8%BD%B4%E5%81%8F%E7%A7%BB%E4%BF%AE%E6%AD%A3%E5%80%BC%3C%2FP%3E%3CP%3E%20%20Y_offset%20%3D%20Yout_12_bit%20%2F%202%20*%20(-1)%3B%20%2F%2F%20%E8%AE%A1%E7%AE%97%20Y%20%E8%BD%B4%E5%81%8F%E7%A7%BB%E4%BF%AE%E6%AD%A3%E5%80%BC%3C%2FP%3E%3CP%3E%20%20Z_offset%20%3D%20(Zout_12_bit%20-%20SENSITIVITY_2G)%20%2F%202%20*%20(-1)%3B%20%2F%2F%20%E8%AE%A1%E7%AE%97%20Z%20%E8%BD%B4%E5%81%8F%E7%A7%BB%E4%BF%AE%E6%AD%A3%E5%80%BC%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%20I2C_WriteRegister(MMA8652FC_I2C_ADDRESS%2C%20OFF_X_REG%2C%20X_offset)%EF%BC%9B%3C%2FP%3E%3CP%3E%20%20I2C_WriteRegister(MMA8652FC_I2C_ADDRESS%2C%20OFF_Y_REG%2C%20Y_offset)%EF%BC%9B%3C%2FP%3E%3CP%3E%20%20I2C_WriteRegister(MMA8652FC_I2C_ADDRESS%2C%20OFF_Z_REG%2C%20Z_offset)%EF%BC%9B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ei2c_WriteRegister%20(MMA8652FC_I2C_ADDRESS%EF%BC%8CCTRL_REG1%EF%BC%8C0x39)%3B%2F%2F%E5%86%8D%E6%AC%A1%E5%A4%84%E4%BA%8E%E8%BF%90%E8%A1%8C%E6%A8%A1%E5%BC%8F%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-101192%22%20target%3D%22_blank%22%3E%E7%82%B9%E5%87%BB%E8%BF%99%E9%87%8C%3C%2FA%3E%E6%9F%A5%E7%9C%8B%E6%88%91%E7%9A%84%E5%AE%8C%E6%95%B4%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%89%98%E9%A9%AC%E6%96%AF%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CEM%20style%3D%22font-size%3A%2011px%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3EPS%EF%BC%9A%E5%A6%82%E6%9E%9C%E6%88%91%E7%9A%84%E5%9B%9E%E7%AD%94%E6%9C%89%E5%8A%A9%E4%BA%8E%E8%A7%A3%E5%86%B3%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E6%A0%87%E8%AE%B0%E4%B8%BA%22%E6%AD%A3%E7%A1%AE%22%20%E3%80%82%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FEM%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
